Bon, on reprend
Fichier interfaces
[quote]SCSERVER:~# cat /etc/network/interfaces
This file describes the network interfaces available on your system
auto lo
iface lo inet loopback
The primary network interface
auto eth0
iface eth0 inet dhcp
auto eth1
iface eth1 inet dhcp
auto eth2
iface eth2 inet dhcp
auto bond0
iface bond0 inet static
address 192.168.1.253
netmask 255.255.255.0
network 192.168.1.0
broadcast 192.168.1.255
up /sbin/ifenslave bond0 eth1 eth2
down /sbin/ifenslave -d bond0 eth1 eth2[/quote]
networking restart
[quote]
SCSERVER:~# /etc/init.d/networking restart
Reconfiguring network interfaces…There is already a pid file /var/run/dhclient.eth1.pid with pid 1340
killed old client process, removed PID file
Internet Systems Consortium DHCP Client V3.1.3
Copyright 2004-2009 Internet Systems Consortium.
All rights reserved.
For info, please visit isc.org/software/dhcp/
Listening on LPF/eth1/00:1d:1a:05:28:96
Sending on LPF/eth1/00:1d:1a:05:28:96
Sending on Socket/fallback
DHCPRELEASE on eth1 to 192.168.1.252 port 67
Reloading /etc/samba/smb.conf: smbd only.
There is already a pid file /var/run/dhclient.eth2.pid with pid 1392
Listening on LPF/eth2/00:1d:1a:05:28:96
Sending on LPF/eth2/00:1d:1a:05:28:96
DHCPRELEASE on eth2 to 192.168.1.252 port 67
Illegal operation: The specified slave interface ‘eth1’ is not a slave
Master ‘bond0’, Slave ‘eth1’: Error: Release failed
Illegal operation: The specified slave interface ‘eth2’ is not a slave
Master ‘bond0’, Slave ‘eth2’: Error: Release failed
SIOCSIFADDR: No such device
eth0: ERROR while getting interface flags: No such device
Bind socket to interface: No such device
Failed to bring up eth0.
DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 7
DHCPOFFER from 192.168.1.252
DHCPREQUEST on eth1 to 255.255.255.255 port 67
DHCPACK from 192.168.1.252
bound to 192.168.1.39 – renewal in 16583 seconds.
Listening on LPF/eth2/00:1d:1a:05:24:e4
Sending on LPF/eth2/00:1d:1a:05:24:e4
DHCPDISCOVER on eth2 to 255.255.255.255 port 67 interval 8
DHCPREQUEST on eth2 to 255.255.255.255 port 67
bound to 192.168.1.35 – renewal in 17866 seconds.
done.[/quote]
bound to 192.168.1.35 – renewal in 17866 seconds. --> C’est quoi ça ??
[quote]SCSERVER:~# ifconfig
bond0 Link encap:Ethernet HWaddr 00:1d:1a:05:28:96
inet adr:192.168.1.253 Bcast:192.168.1.255 Masque:255.255.255.0
adr inet6: fe80::21d:1aff:fe05:2896/64 Scope:Lien
UP BROADCAST RUNNING MASTER MULTICAST MTU:1500 Metric:1
RX packets:697 errors:0 dropped:0 overruns:0 frame:0
TX packets:523 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:64946 (63.4 KiB) TX bytes:80184 (78.3 KiB)
eth1 Link encap:Ethernet HWaddr 00:1d:1a:05:28:96
UP BROADCAST RUNNING SLAVE MULTICAST MTU:1500 Metric:1
RX packets:348 errors:0 dropped:0 overruns:0 frame:0
TX packets:251 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:32797 (32.0 KiB) TX bytes:39810 (38.8 KiB)
Interruption:18 Adresse de base:0xe000
eth2 Link encap:Ethernet HWaddr 00:1d:1a:05:28:96
RX packets:349 errors:0 dropped:0 overruns:0 frame:0
TX packets:272 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:32149 (31.3 KiB) TX bytes:40374 (39.4 KiB)
Interruption:16 Adresse de base:0x6000
lo Link encap:Boucle locale
adr inet6: ::1/128 Scope:Hôte
RX packets:48 errors:0 dropped:0 overruns:0 frame:0
TX packets:48 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:2960 (2.8 KiB) TX bytes:2960 (2.8 KiB)[/quote]
Elle est attribué à qui cette adresse ?
Elle ne répond pas au ping (je sait c’est évident, mais pourquoi se privé de tester ??).
