ssh remi@ordinateur-macpro Password: Last login: Tue Jan 3 08:47:27 2017 from pc21.home GNU bash, version 3.2.48(1)-release (x86_64-apple-darwin11)
Voila le probleme c qd je fais un scp de ma debian sur le mac de mon pere…la je suis en local, alors ca commence plutot mal.
scp -r remi@ordinateur-macpro:~/Pictures .
Password:
09:22 ryms@debian\:~$
mais ca fais rien du tout…
Voila donc en verbose 3
scp -vvv .bash_aliases_exemple remi@ordinateur-macpro:/Users/remi/
Executing: program /usr/bin/ssh host ordinateur-macpro, user remi, command scp -v -t /Users/remi/
OpenSSH_6.7p1 Debian-5+deb8u3, OpenSSL 1.0.1t 3 May 2016
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug2: ssh_connect: needpriv 0
debug1: Connecting to ordinateur-macpro [192.168.1.26] port 22.
debug1: Connection established.
debug1: key_load_public: No such file or directory
debug1: identity file /home/ryms/.ssh/id_rsa type -1
debug1: identity file /home/ryms/.ssh/id_rsa-cert type -1
debug1: identity file /home/ryms/.ssh/id_dsa type -1
debug1: identity file /home/ryms/.ssh/id_dsa-cert type -1
debug1: identity file /home/ryms/.ssh/id_ecdsa type -1
debug1: identity file /home/ryms/.ssh/id_ecdsa-cert type -1
debug1: identity file /home/ryms/.ssh/id_ed25519 type -1
debug1: identity file /home/ryms/.ssh/id_ed25519-cert type -1
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_6.7p1 Debian-5+deb8u3
debug1: Remote protocol version 2.0, remote software version OpenSSH_5.6
debug1: match: OpenSSH_5.6 pat OpenSSH_5* compat 0x0c000000
debug2: fd 3 setting O_NONBLOCK
debug3: load_hostkeys: loading entries for host "ordinateur-macpro" from file "/home/ryms/.ssh/known_hosts"
debug3: load_hostkeys: found key type RSA in file /home/ryms/.ssh/known_hosts:3
debug3: load_hostkeys: loaded 1 keys
debug3: order_hostkeyalgs: prefer hostkeyalgs: ssh-rsa-cert-v01@openssh.com,ssh-rsa-cert-v00@openssh.com,ssh-rsa
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug2: kex_parse_kexinit: curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1
debug2: kex_parse_kexinit: ssh-rsa-cert-v01@openssh.com,ssh-rsa-cert-v00@openssh.com,ssh-rsa,ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ssh-ed25519-cert-v01@openssh.com,ssh-dss-cert-v01@openssh.com,ssh-dss-cert-v00@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,ssh-ed25519,ssh-dss
debug2: kex_parse_kexinit: aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com,chacha20-poly1305@openssh.com,arcfour256,arcfour128,aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,arcfour,rijndael-cbc@lysator.liu.se
debug2: kex_parse_kexinit: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1,hmac-md5-etm@openssh.com,hmac-ripemd160-etm@openssh.com,hmac-sha1-96-etm@openssh.com,hmac-md5-96-etm@openssh.com,hmac-md5,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96
debug2: kex_parse_kexinit: none,zlib@openssh.com,zlib
debug2: kex_parse_kexinit: first_kex_follows 0
debug2: kex_parse_kexinit: reserved 0
debug2: kex_parse_kexinit: diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1
debug2: kex_parse_kexinit: ssh-rsa,ssh-dss
debug2: kex_parse_kexinit: aes128-ctr,aes192-ctr,aes256-ctr,arcfour256,arcfour128,aes128-cbc,3des-cbc,blowfish-cbc,cast128-cbc,aes192-cbc,aes256-cbc,arcfour,rijndael-cbc@lysator.liu.se
debug2: kex_parse_kexinit: hmac-md5,hmac-sha1,umac-64@openssh.com,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96
debug2: mac_setup: setup umac-64@openssh.com
debug1: kex: server->client aes128-ctr umac-64@openssh.com none
debug1: kex: client->server aes128-ctr umac-64@openssh.com none
debug1: SSH2_MSG_KEX_DH_GEX_REQUEST(1024<3072<8192) sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_GROUP
debug2: bits set: 1466/3072
debug1: SSH2_MSG_KEX_DH_GEX_INIT sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_REPLY
debug1: Server host key: RSA eb:94:5c:5b:b1:a0:c1:15:e6:44:0a:80:8d:26:33:1c
debug3: load_hostkeys: loading entries for host "192.168.1.26" from file "/home/ryms/.ssh/known_hosts"
debug3: load_hostkeys: found key type RSA in file /home/ryms/.ssh/known_hosts:2
debug1: Host 'ordinateur-macpro' is known and matches the RSA host key.
debug1: Found key in /home/ryms/.ssh/known_hosts:3
debug2: bits set: 1544/3072
debug2: kex_derive_keys
debug2: set_newkeys: mode 1
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug2: set_newkeys: mode 0
debug1: SSH2_MSG_NEWKEYS received
debug1: SSH2_MSG_SERVICE_REQUEST sent
debug2: service_accept: ssh-userauth
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug2: key: /home/ryms/.ssh/id_rsa ((nil)),
debug2: key: /home/ryms/.ssh/id_dsa ((nil)),
debug2: key: /home/ryms/.ssh/id_ecdsa ((nil)),
debug2: key: /home/ryms/.ssh/id_ed25519 ((nil)),
debug1: Authentications that can continue: publickey,keyboard-interactive
debug3: start over, passed a different list publickey,keyboard-interactive
debug3: preferred gssapi-keyex,gssapi-with-mic,publickey,keyboard-interactive,password
debug3: authmethod_lookup publickey
debug3: remaining preferred: keyboard-interactive,password
debug3: authmethod_is_enabled publickey
debug1: Next authentication method: publickey
debug1: Trying private key: /home/ryms/.ssh/id_rsa
debug3: no such identity: /home/ryms/.ssh/id_rsa: No such file or directory
debug1: Trying private key: /home/ryms/.ssh/id_dsa
debug3: no such identity: /home/ryms/.ssh/id_dsa: No such file or directory
debug1: Trying private key: /home/ryms/.ssh/id_ecdsa
debug3: no such identity: /home/ryms/.ssh/id_ecdsa: No such file or directory
debug1: Trying private key: /home/ryms/.ssh/id_ed25519
debug3: no such identity: /home/ryms/.ssh/id_ed25519: No such file or directory
debug2: we did not send a packet, disable method
debug3: authmethod_lookup keyboard-interactive
debug3: remaining preferred: password
debug3: authmethod_is_enabled keyboard-interactive
debug1: Next authentication method: keyboard-interactive
debug2: userauth_kbdint
debug2: we sent a keyboard-interactive packet, wait for reply
debug2: input_userauth_info_req
debug2: input_userauth_info_req: num_prompts 1
Password:
debug2: input_userauth_info_req: num_prompts 0
debug1: Authentication succeeded (keyboard-interactive).
Authenticated to ordinateur-macpro ([192.168.1.26]:22).
debug2: fd 4 setting O_NONBLOCK
debug2: fd 5 setting O_NONBLOCK
debug1: channel 0: new [client-session]
debug3: ssh_session2_open: channel_new: 0
debug2: channel 0: send open
debug1: Requesting no-more-sessions@openssh.com
debug1: Entering interactive session.
debug2: callback start
debug2: fd 3 setting TCP_NODELAY
debug3: packet_set_tos: set IP_TOS 0x08
debug2: client_session2_setup: id 0
debug1: Sending environment.
debug3: Ignored env XDG_VTNR
debug3: Ignored env ORBIT_SOCKETDIR
debug3: Ignored env SSH_AGENT_PID
debug3: Ignored env XDG_SESSION_ID
debug3: Ignored env TERMINATOR_UUID
debug3: Ignored env XDG_GREETER_DATA_DIR
debug3: Ignored env GPG_AGENT_INFO
debug3: Ignored env GLADE_PIXMAP_PATH
debug3: Ignored env SHELL
debug3: Ignored env XDG_MENU_PREFIX
debug3: Ignored env WINDOWID
debug3: Ignored env USER
debug3: Ignored env LS_COLORS
debug3: Ignored env QT_ACCESSIBILITY
debug3: Ignored env XDG_SESSION_PATH
debug3: Ignored env GLADE_MODULE_PATH
debug3: Ignored env XDG_SEAT_PATH
debug3: Ignored env SSH_AUTH_SOCK
debug3: Ignored env SESSION_MANAGER
debug3: Ignored env XDG_CONFIG_DIRS
debug3: Ignored env PATH
debug3: Ignored env DESKTOP_SESSION
debug3: Ignored env PWD
debug1: Sending env LANG = fr_FR.utf8
debug2: channel 0: request env confirm 0
debug3: Ignored env GCC_COLORS
debug3: Ignored env GDMSESSION
debug3: Ignored env SHLVL
debug3: Ignored env HOME
debug3: Ignored env LOGNAME
debug3: Ignored env XDG_DATA_DIRS
debug3: Ignored env DBUS_SESSION_BUS_ADDRESS
debug3: Ignored env LESSOPEN
debug3: Ignored env XDG_RUNTIME_DIR
debug3: Ignored env DISPLAY
debug3: Ignored env GLADE_CATALOG_PATH
debug3: Ignored env XDG_CURRENT_DESKTOP
debug3: Ignored env LESSCLOSE
debug3: Ignored env COLORTERM
debug3: Ignored env XAUTHORITY
debug3: Ignored env _
debug1: Sending command: scp -v -t /Users/remi/
debug2: channel 0: request exec confirm 1
debug2: callback done
debug2: channel 0: open confirm rwindow 0 rmax 32768
debug2: channel 0: rcvd adjust 2097152
debug2: channel_input_status_confirm: type 99 id 0
debug2: exec request accepted on channel 0
debug2: channel 0: read<=0 rfd 4 len 0
debug2: channel 0: read failed
debug2: channel 0: close_read
debug2: channel 0: input open -> drain
debug2: channel 0: ibuf empty
debug2: channel 0: send eof
debug2: channel 0: input drain -> closed
05:14 ryms@debian\:~$
debug2: channel 0: rcvd eof
debug2: channel 0: output open -> drain
debug2: channel 0: write failed
debug2: channel 0: close_write
debug2: channel 0: send eow
debug2: channel 0: output drain -> closed
debug1: client_input_channel_req: channel 0 rtype exit-status reply 0
debug2: channel 0: rcvd close
debug3: channel 0: will not send data after close
debug2: channel 0: almost dead
debug2: channel 0: gc: notify user
debug2: channel 0: gc: user detached
debug2: channel 0: send close
debug2: channel 0: is dead
debug2: channel 0: garbage collecting
debug1: channel 0: free: client-session, nchannels 1
debug3: channel 0: status: The following connections are open:
#0 client-session (t4 r0 i3/0 o3/0 fd -1/-1 cc -1)
debug1: fd 0 clearing O_NONBLOCK
debug1: fd 1 clearing O_NONBLOCK
Transferred: sent 3032, received 2616 bytes, in 0.1 seconds
Bytes per second: sent 28179.5, received 24313.2
debug1: Exit status 0
ca fais pareil du serveur a mon poste
mais ssh marche nickel j ai les droits sudo sur la machine distante
et j ai supprimer les echo"" au debut de mon bashrc… il parait que ca fait foirer le truc
merci
j arrive pas amettre la balise “`” , sorry
