Je possède un UPS MGE Ellipse Max 600, connecté USB sur un mini PC sous Debian 10 Buster utiilsé pour ma Domotique sous Jeedom.
J’ai créer mon serveur NUT (2.7.4-8), cependant quand l’UPS est connecté en USB, il fini par passer en OnLine Off, c’est à dire coupure de l’ondulé.
Non connecté en USB tout va bien.
voici ma configuration:
Fichier nut.conf
MODE=standalone
USPD_OPTIONS="-u root"
Fichier ups.conf
[Onduleur]
driver = usbhid-ups
port = /dev/ttyS0
default.battery.voltage.high = 14
default.battery.voltage.low = 11
Fichier upsd.conf
LISTEN 127.0.0.1 3493
MAXAGE 25
Fichier uspd.users
[admin]
password = *********
allowfrom = localhost
upsmon master
actions = SET
instcmds = ALL
[Nutsoft]
password = ********
actions = FSD
upsmon master
Fichier upsmon.conf
# Network UPS Tools: example upsmon configuration
# This file contains passwords, so keep it secure.
RUN_AS_USER nut
MONITOR Onduleur@localhost 1 Nutsoft ******** master
NOTIFYCMD /usr/local/bin/nutNotify.sh
#multiple instances running simultaneously
NOTIFYMSG ONLINE "ONLINE %s"
NOTIFYMSG ONBATT "ONBATT %s"
NOTIFYMSG LOWBATT "LOWBATT %s"
NOTIFYMSG FSD "FSD %s"
NOTIFYMSG COMMBAD "COMMBAD %s"
NOTIFYMSG COMMOK "COMMOK %s"
NOTIFYMSG SHUTDOWN "SHUTDOWN %s"
NOTIFYMSG REPLBATT "REPLBATT %s"
NOTIFYMSG NOCOMM "NOCOMM %s"
NOTIFYFLAG ONLINE SYSLOG+EXEC
NOTIFYFLAG ONBATT SYSLOG+EXEC
NOTIFYFLAG LOWBATT SYSLOG+WALL+EXEC
NOTIFYFLAG FSD SYSLOG+WALL+EXEC
NOTIFYFLAG COMMBAD SYSLOG+EXEC
NOTIFYFLAG COMMOK SYSLOG+EXEC
NOTIFYFLAG SHUTDOWN SYSLOG+WALL+EXEC
NOTIFYFLAG REPLBATT SYSLOG+EXEC
NOTIFYFLAG NOCOMM SYSLOG+EXEC
#NOTIFYMSG type message
POWERDOWNFLAG /var/lib/nutsoft/killpower
#POWERDOWNFLAG /var/tmp/killpower
#Dans la doc :
#POWERDOWNFLAG /etc/killpower
SHUTDOWNCMD "/sbin/shutdown -h +0"
FINALDELAY 2
MINSUPPLIES 1
RBWARNTIME 604800
NOCOMMWARNTIME 21600
POLLFREQ 15
POLLFREQALERT 30
HOSTSYNC 15
DEADTIME 45
Fichier upssched.conf
LOCKFN /var/lib/nut/upssched.lock
PIPEFN /var/lib/nut/upssched.pipe
CMDSCRIPT /bin/upssched-cmd
AT ONBATT * START-TIMER onbatt1 13
AT ONLINE * CANCEL-TIMER onbatt1
#AT ONBATT * START-TIMER earlyshutdown 30
#AT ONLINE * CANCEL-TIMER earlyshutdown
AT ONBATT * START-TIMER onbattwarn 30
AT ONLINE * CANCEL-TIMER onbattwarn
Les commandes dans un terminal:
lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 8087:0a2a Intel Corp.
Bus 001 Device 004: ID 0463:ffff MGE UPS Systems UPS
Bus 001 Device 003: ID 0403:6015 Future Technology Devices International, Ltd Bridge(I2C/SPI/UART/FIFO)
Bus 001 Device 002: ID 1cf1:0030 Dresden Elektronik
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
ls -l /dev/bus/usb/001
crw-rw-r-- 1 root root 189, 0 nov. 4 19:00 001
crw-rw-r-- 1 root root 189, 1 nov. 4 19:00 002
crw-rw-r-- 1 root root 189, 2 nov. 4 19:00 003
crw-rw-r-- 1 root nut 189, 3 nov. 8 11:05 004
crw-rw-r-- 1 root root 189, 4 nov. 4 19:00 005
/bin/upsc Onduleur@localhost
Init SSL without certificate database
battery.charge: 100
battery.charge.low: 20
battery.runtime: 2081
battery.type: PbAc
battery.voltage.high: 14
battery.voltage.low: 11
device.mfr: MGE UPS SYSTEMS
device.model: Ellipse MAX 600
device.serial: PbAc
device.type: ups
driver.name: usbhid-ups
driver.parameter.pollfreq: 30
driver.parameter.pollinterval: 2
driver.parameter.port: /dev/ttyS0
driver.parameter.synchronous: no
driver.version: 2.7.4
driver.version.data: MGE HID 1.39
driver.version.internal: 0.41
input.sensitivity: normal
input.transfer.boost.low: 185
input.transfer.high: 285
input.transfer.low: 165
input.transfer.trim.high: 265
input.voltage.extended: no
outlet.1.desc: PowerShare Outlet 1
outlet.1.id: 2
outlet.1.status: on
outlet.1.switchable: no
outlet.desc: Main Outlet
outlet.id: 1
outlet.switchable: no
output.frequency.nominal: 50
output.voltage: 230.0
output.voltage.nominal: 230
ups.beeper.status: enabled
ups.delay.shutdown: 20
ups.delay.start: 30
ups.firmware: 1.01
ups.load: 0
ups.mfr: MGE UPS SYSTEMS
ups.model: Ellipse MAX 600
ups.power.nominal: 600
ups.productid: ffff
ups.serial: PbAc
ups.status: OL
ups.timer.shutdown: 0
ups.timer.start: 0
ups.vendorid: 0463
upsc -l
Onduleur
/etc/init.d/ups-monitor status
Pas de résultats
sudo invoke-rc.d nut status
Unit nut.service could not be found.
invoke-rc.d: initscript nut, action « status » failed.
systemctl status nut-monitor.service
● nut-monitor.service - Network UPS Tools - power device monitor and shutdown controller
Loaded: loaded (/lib/systemd/system/nut-monitor.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2020-11-08 11:27:05 CET; 3h 46min ago
Process: 20912 ExecStart=/sbin/upsmon (code=exited, status=0/SUCCESS)
Main PID: 20914 (upsmon)
Tasks: 2 (limit: 4915)
Memory: 1.9M
CGroup: /system.slice/nut-monitor.service
├─20913 /lib/nut/upsmon
└─20914 /lib/nut/upsmon
nov. 08 14:44:06 jeedom-pc upsmon[20914]: COMMOK Onduleur@localhost
nov. 08 14:44:36 jeedom-pc upsmon[20914]: Poll UPS [Onduleur@localhost] failed - Data stale
nov. 08 14:44:36 jeedom-pc upsmon[20914]: COMMBAD Onduleur@localhost
nov. 08 14:44:51 jeedom-pc upsmon[20914]: Poll UPS [Onduleur@localhost] failed - Data stale
nov. 08 14:45:06 jeedom-pc upsmon[20914]: Poll UPS [Onduleur@localhost] failed - Data stale
nov. 08 14:45:21 jeedom-pc upsmon[20914]: Poll UPS [Onduleur@localhost] failed - Data stale
nov. 08 14:45:36 jeedom-pc upsmon[20914]: COMMOK Onduleur@localhost
nov. 08 14:45:51 jeedom-pc upsmon[20914]: Poll UPS [Onduleur@localhost] failed - Data stale
nov. 08 14:45:51 jeedom-pc upsmon[20914]: COMMBAD Onduleur@localhost
nov. 08 14:46:06 jeedom-pc upsmon[20914]: COMMOK Onduleur@localhost
