Problème SteamCMD et firewall
Voici mon Firewall:
[quote]# Vider les tables actuelles
iptables -t filter -F
Vider les règles personnelles
iptables -t filter -X
Interdire toute connexion entrante et sortante
iptables -t filter -P INPUT DROP
iptables -t filter -P FORWARD DROP
iptables -t filter -P OUTPUT DROP
Ne pas casser les connexions etablies
iptables -A INPUT -m state --state RELATED,ESTABLISHED -j ACCEPT
iptables -A OUTPUT -m state --state RELATED,ESTABLISHED -j ACCEPT
Autoriser loopback
iptables -t filter -A INPUT -i lo -j ACCEPT
iptables -t filter -A OUTPUT -o lo -j ACCEPT
ICMP (Ping)
iptables -t filter -A INPUT -p icmp -j ACCEPT
iptables -t filter -A OUTPUT -p icmp -j ACCEPT
SSH In
iptables -t filter -A INPUT -p tcp --dport 1567 -j ACCEPT
SSH Out
iptables -t filter -A OUTPUT -p tcp --dport 1567 -j ACCEPT
DNS In/Out
iptables -t filter -A OUTPUT -p tcp --dport 53 -j ACCEPT
iptables -t filter -A OUTPUT -p udp --dport 53 -j ACCEPT
iptables -t filter -A INPUT -p tcp --dport 53 -j ACCEPT
iptables -t filter -A INPUT -p udp --dport 53 -j ACCEPT
NTP Out
iptables -t filter -A OUTPUT -p udp --dport 123 -j ACCEPT
HTTP + HTTPS Out
iptables -t filter -A OUTPUT -p tcp --dport 80 -j ACCEPT
iptables -t filter -A OUTPUT -p tcp --dport 443 -j ACCEPT
HTTP + HTTPS In
iptables -t filter -A INPUT -p tcp --dport 80 -j ACCEPT
iptables -t filter -A INPUT -p tcp --dport 443 -j ACCEPT
iptables -t filter -A INPUT -p tcp --dport 8443 -j ACCEPT
FTP Out
iptables -t filter -A OUTPUT -p tcp --dport 20:21 -j ACCEPT
FTP In
modprobe ip_conntrack_ftp
iptables -t filter -A INPUT -p tcp --dport 20:21 -j ACCEPT
iptables -t filter -A INPUT -m state --state ESTABLISHED,RELATED -j ACCEPT
Mail SMTP:25
iptables -t filter -A INPUT -p tcp --dport 25 -j ACCEPT
iptables -t filter -A OUTPUT -p tcp --dport 25 -j ACCEPT
Mail POP3:110
iptables -t filter -A INPUT -p tcp --dport 110 -j ACCEPT
iptables -t filter -A OUTPUT -p tcp --dport 110 -j ACCEPT
Mail IMAP:143
iptables -t filter -A INPUT -p tcp --dport 143 -j ACCEPT
iptables -t filter -A OUTPUT -p tcp --dport 143 -j ACCEPT
Mail POP3S:995
iptables -t filter -A INPUT -p tcp --dport 995 -j ACCEPT
iptables -t filter -A OUTPUT -p tcp --dport 995 -j ACCEPT
TEAMSPEAK
iptables -A INPUT -p udp --dport 9987 -j ACCEPT
iptables -A INPUT -p udp --sport 9987 -j ACCEPT
#STEAMCMD
iptables -A INPUT -p udp -m udp --sport 27000:27030 --dport 1025:65355 -j ACCEPT
iptables -A INPUT -p udp -m udp --sport 4380 --dport 1025:65355 -j ACCEPT[/quote]
echo Firewall chargé
Mon problème est le suivant, je souhaite installer un serveur de jeu sur mon serveur dédié. J’utilises donc SteamCMD (doc: developer.valvesoftware.com/wiki/SteamCMD:fr)
Problème, quand je dois me connecter à mon compte Steam avec, j’obtiens l’erreur suivante:
Login Failure: no connection
Or, dans la documentation, il est écrit que si j’ai cette erreur, je dois entrer ces règles:
[quote]iptables -A INPUT -p udp -m udp --sport 27000:27030 --dport 1025:65355 -j ACCEPT
Entrées, mais elle ne résolvent pas mon problème… Des idées ?
Merci d’avance !
UP !
Personne n’a une piste… un moyen de déboguer la chose peut être… ?
Pour déboguer, tu peux ajouter une règle avec la cible LOG à la fin des chaînes INPUT et OUTPUT. Cela créera une ligne dans les logs du noyau pour chaque paquet qui arrive en fin de chaîne, donc n’a été accepté ou bloqué par aucun règle.
Quand tu parles de te connecter à ton compte Steam, s’agit-il d’une connexion d’une machine cliente à ton serveur ou de ton serveur à un service extérieur de Valve ?
Merci pour ton début d’aide.
Je penses que la connexion à mon compte Steam se passe de mon serveur à Valve, tout simplement.
J’arrives à avoir le numéro de port utilisé, mais ce port est aléatoire (il varie de 1025 à 65355 selon les sources).
Comment dois-je utiliser la règle ?
Comme cela ?
ou
Merci d’avance !
(Je suis débutant IPTables)
Juste ceci en fin de script.
iptables -A INPUT -j LOG iptables -A OUTPUT -j LOG
S’il s’agit d’une connexion sortante de ton serveur vers l’extérieur, il faut créer une règle correspondante dans la chaîne OUTPUT.
Note : Je trouve tes deux dernières règles pour SteamCMD bizarres, on dirait qu’elles servent à accepter des paquets de réponse (port source à peu près défini mais port destination large donc ce sont des passoires). Ton jeu de règles a déjà des règles pour cela avec ESTABLISHED. Je ne connais pas du tout Steam, mais je mettrais plutôt des règles comme ceci :
[code]# accepter les connexions Steam entrantes
iptables -A INPUT -p udp --dport 27000:27030 -j ACCEPT
iptables -A INPUT -p udp --dport 4380 -j ACCEPT
accepter les connexions Steam sortantes
iptables -A OUTPUT -p udp --dport 27000:27030 -j ACCEPT
iptables -A OUTPUT -p udp --dport 4380 -j ACCEPT[/code]
Merci pour tes règles, cela marche maintenant.
Les règles fournies viennent de Valve directement, je n’ai fais que suivre le Wiki Dev :stuck_out_tongue:
Merci encore à toi, les règles que tu m’as fourni sont qui plus est, simples à comprendre !
