Bonjour à tous, je rencontre un problème suite à la mise à jour vers kernel 4.9.0-7-amd64. L’interface graphique ne se lance plus. Erreur ci-dessous :
[ 9.030] (–) Log file renamed from “/var/log/Xorg.pid-845.log” to “/var/log/Xorg.0.log”
[ 9.031]
X.Org X Server 1.19.2
Release Date: 2017-03-02
[ 9.031] X Protocol Version 11, Revision 0
[ 9.031] Build Operating System: Linux 4.9.0-4-amd64 x86_64 Debian
[ 9.031] Current Operating System: Linux debian9 4.9.0-7-amd64 #1 SMP Debian 4.9.110-1 (2018-07-05) x86_64
[ 9.031] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-7-amd64 root=UUID=b8c01efa-c773-405c-8da8-26392c7f1d9b ro quiet
[ 9.031] Build Date: 16 October 2017 08:19:45AM
[ 9.031] xorg-server 2:1.19.2-1+deb9u2 (https://www.debian.org/support)
[ 9.031] Current version of pixman: 0.34.0
[ 9.031] Before reporting problems, check http://wiki.x.org
[ 9.031] Markers: (–) probed, () from config file, (==) default setting,
[ 9.031] (==) Log file: “/var/log/Xorg.0.log”, Time: Sun Jul 15 17:04:19 2018
[ 9.031] (==) Using config file: “/etc/X11/xorg.conf”
[ 9.031] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 9.031] (==) ServerLayout “Layout0”
[ 9.031] () |–>Screen “Screen0” (0)
[ 9.031] () | |–>Monitor “Monitor0”
[ 9.032] () | |–>Device “Device0”
[ 9.032] () |–>Input Device “Keyboard0”
[ 9.032] () |–>Input Device “Mouse0”
[ 9.032] (==) Automatically adding devices
[ 9.032] (==) Automatically enabling devices
[ 9.032] (==) Automatically adding GPU devices
[ 9.032] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 9.032] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 9.032] Entry deleted from font path.
[ 9.032] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 9.032] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 9.032] (WW) Hotplugging is on, devices using drivers ‘kbd’, ‘mouse’ or ‘vmmouse’ will be disabled.
[ 9.032] (WW) Disabling Keyboard0
[ 9.032] (WW) Disabling Mouse0
[ 9.032] (II) Loader magic: 0x55623c877e00
[ 9.032] (II) Module ABI versions:
[ 9.032] X.Org ANSI C Emulation: 0.4
[ 9.032] X.Org Video Driver: 23.0
[ 9.032] X.Org XInput driver : 24.1
[ 9.032] X.Org Server Extension : 10.0
[ 9.033] (++) using VT number 7
[ 9.033] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 9.034] (–) PCI:*(0:6:0:0) 10de:1287:1462:8a9f rev 161, Mem @ 0xfc000000/16777216, 0xe8000000/134217728, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x???/131072
[ 9.034] (II) LoadModule: “glx”
[ 9.034] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 9.036] (II) Module glx: vendor=“NVIDIA Corporation”
[ 9.036] compiled for 4.0.2, module version = 1.0.0
[ 9.036] Module class: X.Org Server Extension
[ 9.036] (II) NVIDIA GLX Module 390.25 Wed Jan 24 19:23:51 PST 2018
[ 9.036] (II) LoadModule: “nvidia”
[ 9.037] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 9.037] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 9.037] compiled for 4.0.2, module version = 1.0.0
[ 9.037] Module class: X.Org Video Driver
[ 9.037] (II) NVIDIA dlloader X Driver 390.25 Wed Jan 24 18:57:05 PST 2018
[ 9.037] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 9.042] (II) Loading sub module “fb”
[ 9.042] (II) LoadModule: “fb”
[ 9.042] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 9.042] (II) Module fb: vendor=“X.Org Foundation”
[ 9.042] compiled for 1.19.2, module version = 1.0.0
[ 9.042] ABI class: X.Org ANSI C Emulation, version 0.4
[ 9.042] (II) Loading sub module “wfb”
[ 9.042] (II) LoadModule: “wfb”
[ 9.042] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 9.042] (II) Module wfb: vendor=“X.Org Foundation”
[ 9.042] (II) Loading sub module “ramdac”
[ 9.042] (II) LoadModule: “ramdac”
[ 9.042] (II) Module “ramdac” already built-in
[ 9.045] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the
[ 9.045] (EE) NVIDIA: system’s kernel log for additional error messages and
[ 9.045] (EE) NVIDIA: consult the NVIDIA README for details.
[ 9.045] (EE) No devices detected.
[ 9.045] (EE)
Fatal server error:
[ 9.045] (EE) no screens found(EE)
[ 9.045] (EE)
Je n’ai pas vu d’autres erreurs dans le syslog
Si je démarre dans la version précédente (4.9.0-6-amd64) pas de problème.
Ma carte graphique est une Nvidia GeForce GT730.
Si quelqu’un a une idée pour résoudre cela, je le remercie par avance.
Bonne soirée
Thierry
