J’ai la même chose :
rt61pci 20960 0 - Live 0xf8a68000
crc_itu_t 2080 1 rt61pci, Live 0xf8a1a000
rt2x00pci 7648 1 rt61pci, Live 0xf8a2b000
rt2x00lib 22592 2 rt61pci,rt2x00pci, Live 0xf8a34000
eeprom_93cx6 2144 1 rt61pci, Live 0xf898f000
Je pense que l’installation du driver se fait bien, car je la vois bien :
debian:~# iwconfig
wlan0 IEEE 802.11 ESSID:""
Mode:Managed Frequency:2.412 GHz Access Point: Not-Associated
Tx-Power=0 dBm
Retry min limit:7 RTS thr:off Fragment thr=2352 B
Encryption key:off
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
debian:~# iwlist scan
wmaster0 Interface doesn’t support scanning.
wlan0 Interface doesn’t support scanning : Network is down
debian:~# dhclient wlan0
Internet Systems Consortium DHCP Client V3.1.1
Copyright 2004-2008 Internet Systems Consortium.
All rights reserved.
For info, please visit isc.org/sw/dhcp/
wmaster0: unknown hardware address type 801
Listening on LPF/wlan0/00:1c:f0:a0:48:13
Sending on LPF/wlan0/00:1c:f0:a0:48:13
Sending on Socket/fallback
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 4
et à la suite de ça, j’ai un message :
debian:~# tail /var/log/messages
Nov 11 18:56:06 debian kernel: [ 259.991776] firmware: requesting rt2561.bin
Nov 11 18:56:06 debian kernel: [ 260.073344] ADDRCONF(NETDEV_UP): wlan0: link is not ready
Voila les infos que je peux te donner.
