Sous Knoppix 3.4 avec noyau 2.6.6, je viens de m’apercevoir que mon fichier /var/log/kdm.log est rempli d’erreurs dont voici un court extrait :
XFree86 Version 4.3.0.1 (Debian 4.3.0.dfsg.1-1 20040428170728 fabbione@trider-g7.int.fabbione.net)
Release Date: 15 August 2003
X Protocol Version 11, Revision 0, Release 6.6
Build Operating System: Linux 2.4.23 i686 [ELF]
Build Date: 28 April 2004
Before reporting problems, check XFree86.Org/
Module Loader present
OS Kernel: Linux version 2.6.6 (root@Knoppix) (gcc version 2.95.4 20011002 (Debian prerelease)) #2 SMP Fri May 14 20:38:30 CEST 2004
Markers: (–) probed, (**) from config file, (==) default setting,
(==) Log file: “/var/log/XFree86.0.log”, Time: Mon Oct 25 10:11:17 2004
(==) Using config file: "/etc/X11/XF86Config-4"
Skipping “/usr/X11R6/lib/modules/extensions/libGLcore.a:m_debug_clip.o”: No symbols found
Skipping “/usr/X11R6/lib/modules/extensions/libGLcore.a:m_debug_norm.o”: No symbols found
Skipping “/usr/X11R6/lib/modules/extensions/libGLcore.a:m_debug_xform.o”: No symbols found
Skipping “/usr/X11R6/lib/modules/extensions/libGLcore.a:m_debug_vertex.o”: No symbols found
Skipping “/usr/X11R6/lib/modules/fonts/libspeedo.a:spencode.o”: No symbols found
(WW) NV(0): Failed to set up write-combining range (0xda000000,0x2000000)
Warning: font renderer for “.pcf” already registered at priority 0
Warning: font renderer for “.pcf.Z” already registered at priority 0
Warning: font renderer for “.pcf.gz” already registered at priority 0
Warning: font renderer for “.snf” already registered at priority 0
Warning: font renderer for “.snf.Z” already registered at priority 0
Warning: font renderer for “.snf.gz” already registered at priority 0
Warning: font renderer for “.bdf” already registered at priority 0
Warning: font renderer for “.bdf.Z” already registered at priority 0
Warning: font renderer for “.bdf.gz” already registered at priority 0
Warning: font renderer for “.pmf” already registered at priority 0
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 16x16/stock/chart not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 16x16/stock/code not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 16x16/stock/data not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 16x16/stock/form not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 16x16/stock/image not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 16x16/stock/io not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 16x16/stock/media not valid.
kdecore (KIconLoader): WARNING: Icon directory /usr/share/icons/hicolor/ group 16x16/stock/navigation not valid…
Il ne semble pas que cela créé d’instabilité mais je préférerai les éliminer.
J’avais tenté il y a quelques temps d’installer différents thèmes et icônes du site kde.look. Je me demande si mes problèmes ne viendraient pas de là ?
Pouvez-vous m’aider SVP ?
