Je viens de faire ce qui est indiqué sur cette page
smhteam.info/wiki/index.linux.php5?wiki=Lirc
Mais avec les sources lirc-0.8.1 kernel 2.6.18-3-k7 sur une debian.
Tous semble bien ce passer, à la fin j’obtiens:
ls -al /dev/lirc*
crw-rw-rw- 1 root root 61, 0 2007-02-08 19:57 /dev/lirc
crw-rw-rw- 1 root video 61, 0 2007-02-08 19:59 /dev/lirc0
srw-rw-rw- 1 root root 0 2007-02-08 19:59 /dev/lircd
prw-rw-rw- 1 root root 0 2007-02-07 21:43 /dev/lircm
Pas de message d’erreur à lancement:
lircd
lircmd /etc/lircd.conf
Mais en lançant irw, en appuyant sur les touches de la télécommandes je n’obtiens rien. Voila ce que j’ai dans /var/log/messages :
Feb 8 19:55:03 zeus kernel: lirc_atiusb[5]: usb remote disconnected
Feb 8 19:59:39 zeus kernel: lirc_dev: IR Remote Control driver registered, at major 61
Feb 8 19:59:39 zeus kernel: lirc_atiusb: USB remote driver for LIRC v0.5
Feb 8 19:59:39 zeus kernel: lirc_atiusb: Paul Miller pmiller9@users.sourceforge.net
Feb 8 19:59:39 zeus kernel: lirc_dev: lirc_register_plugin: sample_rate: 0
Feb 8 19:59:39 zeus kernel: lirc_atiusb[5]: X10 Wireless Technology Inc USB Receiver on usb1:5
Feb 8 19:59:39 zeus kernel: usbcore: registered new driver lirc_atiusb
Feb 8 20:00:15 zeus lircmd: invalid line 22 in config file ignored
Feb 8 20:00:15 zeus lircmd: invalid line 24 in config file ignored
Feb 8 20:00:15 zeus lircmd: invalid line 25 in config file ignored
Pourtant lircd tourne:
root 29288 1 0 19:59 ? 00:00:00 lircd
root 29330 1 0 20:00 ? 00:00:00 lircmd /etc/lircd.conf
root 29652 30141 0 20:34 pts/3 00:00:00 grep lirc
Bref ça coince sur le fichier le config qui a l’air bon:
this config file was automatically generated
using lirc-0.7.0-CVS(atiusb) on Tue Apr 27 23:51:09 2004
contributed by Paul Miller pmiller9@users.sourceforge.net
brand: ATI Remote Wonder
model no. of remote control: 5000015900A
devices being controlled by this remote: ATI USB Receiver
CHANNEL CODES
To change your channel, hold the hand button down until the
LED begins to blink. Then enter the channel number
(1 through 16) and press the hand again.
NOTE!! The lirc_atiusb driver now removes the channel code
from key-codes (by default). This effectively outputs codes
for remote channel 1. You can change this behavior by
loading the module with unique=1. Type modinfo lirc_atiusb
for details.
begin remote
name ATIUSB_5000015900A
bits 16
eps 30
aeps 100
one 0 0
zero 0 0
pre_data_bits 8
pre_data 0x14
post_data_bits 16
post_data 0x0
gap 139944
toggle_bit 0
begin codes
A 0x000000000000F500
B 0x000000000000F601
C 0x0000000000000E19
D 0x000000000000101B
A ce stade je séche?
Merci d’avance si vous voyez ou ça bloque.
