voici le dmesg :
19:52 gregoonix@debian ~% dmesg
Linux version 2.6.24 (root@debian) (gcc version 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)) #7 Wed Feb 20 21:01:17 CET 2008
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009f000 (usable)
BIOS-e820: 000000000009f000 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000d2000 - 00000000000d4000 (reserved)
BIOS-e820: 00000000000dc000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000005ff60000 (usable)
BIOS-e820: 000000005ff60000 - 000000005ff78000 (ACPI data)
BIOS-e820: 000000005ff78000 - 000000005ff7a000 (ACPI NVS)
BIOS-e820: 000000005ff80000 - 0000000060000000 (reserved)
BIOS-e820: 00000000ff800000 - 0000000100000000 (reserved)
639MB HIGHMEM available.
896MB LOWMEM available.
Entering add_active_range(0, 0, 393056) 0 entries of 256 used
Zone PFN ranges:
DMA 0 -> 4096
Normal 4096 -> 229376
HighMem 229376 -> 393056
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
0: 0 -> 393056
On node 0 totalpages: 393056
DMA zone: 32 pages used for memmap
DMA zone: 0 pages reserved
DMA zone: 4064 pages, LIFO batch:0
Normal zone: 1760 pages used for memmap
Normal zone: 223520 pages, LIFO batch:31
HighMem zone: 1278 pages used for memmap
HighMem zone: 162402 pages, LIFO batch:31
Movable zone: 0 pages used for memmap
DMI present.
ACPI: RSDP 000F6B40, 0024 (r2 IBM )
ACPI: XSDT 5FF6B321, 004C (r1 IBM TP-1Q 2140 LTP 0)
ACPI: FACP 5FF6B400, 00F4 (r3 IBM TP-1Q 2140 IBM 1)
ACPI Warning (tbfadt-0442): Optional field “Gpe1Block” has zero address or length: 000000000000102C/0 [20070126]
ACPI: DSDT 5FF6B5E7, C881 (r1 IBM TP-1Q 2140 MSFT 100000E)
ACPI: FACS 5FF79000, 0040
ACPI: SSDT 5FF6B5B4, 0033 (r1 IBM TP-1Q 2140 MSFT 100000E)
ACPI: ECDT 5FF77E68, 0052 (r1 IBM TP-1Q 2140 IBM 1)
ACPI: TCPA 5FF77EBA, 0032 (r1 IBM TP-1Q 2140 PTL 1)
ACPI: BOOT 5FF77FD8, 0028 (r1 IBM TP-1Q 2140 LTP 1)
ACPI: PM-Timer IO Port: 0x1008
Allocating PCI resources starting at 70000000 (gap: 60000000:9f800000)
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 389986
Kernel command line: root=/dev/hda1 ro
Enabling fast FPU save and restore… done.
Enabling unmasked SIMD FPU exception support… done.
Initializing CPU#0
PID hash table entries: 4096 (order: 12, 16384 bytes)
Detected 1398.847 MHz processor.
Console: colour VGA+ 80x25
console [tty0] enabled
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 1550204k/1572224k available (1620k kernel code, 20740k reserved, 663k data, 188k init, 654720k highmem)
virtual kernel memory layout:
fixmap : 0xfffe9000 - 0xfffff000 ( 88 kB)
pkmap : 0xff800000 - 0xffc00000 (4096 kB)
vmalloc : 0xf8800000 - 0xff7fe000 ( 111 MB)
lowmem : 0xc0000000 - 0xf8000000 ( 896 MB)
.init : 0xc033e000 - 0xc036d000 ( 188 kB)
.data : 0xc029537a - 0xc033b204 ( 663 kB)
.text : 0xc0100000 - 0xc029537a (1620 kB)
Checking if this processor honours the WP bit even in supervisor mode… Ok.
Calibrating delay using timer specific routine… 2798.56 BogoMIPS (lpj=1399281)
Security Framework initialized
SELinux: Disabled at boot.
Capability LSM initialized
Mount-cache hash table entries: 512
CPU: After generic identify, caps: a7e9f9bf 00000000 00000000 00000000 00000180 00000000 00000000 00000000
CPU: L1 I cache: 32K, L1 D cache: 32K
CPU: L2 cache: 1024K
CPU: After all inits, caps: a7e9f9bf 00000000 00000000 00002040 00000180 00000000 00000000 00000000
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
Compat vDSO mapped to ffffe000.
CPU: Intel® Pentium® M processor 1400MHz stepping 05
Checking ‘hlt’ instruction… OK.
Freeing SMP alternatives: 0k freed
ACPI: Core revision 20070126
ACPI: setting ELCR to 0200 (from 0800)
net_namespace: 64 bytes
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: PCI BIOS revision 2.10 entry at 0xfd8d6, last bus=8
PCI: Using configuration type 1
Setting up standard PCI resources
ACPI: EC: EC description table is found, configuring boot EC
ACPI: EC: non-query interrupt received, switching to interrupt mode
ACPI: Interpreter enabled
ACPI: (supports S0 S3 S5)
ACPI: Using PIC for interrupt routing
ACPI: EC: GPE = 0x1c, I/O: command/status = 0x66, data = 0x62
ACPI: EC: driver started in poll mode
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI quirk: region 1000-107f claimed by ICH4 ACPI/GPIO/TCO
PCI quirk: region 1180-11bf claimed by ICH4 GPIO
PCI: Transparent bridge - 0000:00:1e.0
ACPI: PCI Interrupt Routing Table [_SB_.PCI0.PRT]
ACPI: PCI Interrupt Routing Table [_SB.PCI0.AGP_.PRT]
ACPI: PCI Interrupt Routing Table [_SB.PCI0.PCI1._PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 10 *11)
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 9 10 *11)
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 10 *11)
ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 *11)
ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 11) *0, disabled.
ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 9 10 11) *0, disabled.
ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 9 10 *11)
ACPI: Power Resource [PUBS] (on)
Linux Plug and Play Support v0.97 © Adam Belay
pnp: PnP ACPI init
ACPI: bus type pnp registered
pnpacpi: exceeded the max number of mem resources: 12
pnp: PnP ACPI: found 12 devices
ACPI: ACPI bus type pnp unregistered
PnPBIOS: Disabled by ACPI PNP
PCI: Using ACPI for IRQ routing
PCI: If a device doesn’t work, try “pci=routeirq”. If it helps, post a report
NET: Registered protocol family 8
NET: Registered protocol family 20
Time: tsc clocksource has been installed.
system 00:00: iomem range 0x0-0x9ffff could not be reserved
system 00:00: iomem range 0xc0000-0xc3fff could not be reserved
system 00:00: iomem range 0xc4000-0xc7fff could not be reserved
system 00:00: iomem range 0xc8000-0xcbfff could not be reserved
system 00:00: iomem range 0xcc000-0xcffff could not be reserved
system 00:00: iomem range 0xd0000-0xd3fff could not be reserved
system 00:00: iomem range 0x0-0x0 could not be reserved
system 00:00: iomem range 0xdc000-0xdffff has been reserved
system 00:00: iomem range 0xe0000-0xe3fff could not be reserved
system 00:00: iomem range 0xe4000-0xe7fff could not be reserved
system 00:00: iomem range 0xe8000-0xebfff could not be reserved
system 00:02: ioport range 0x1000-0x107f has been reserved
system 00:02: ioport range 0x1180-0x11bf has been reserved
system 00:02: ioport range 0x15e0-0x15ef has been reserved
system 00:02: ioport range 0x1600-0x167f has been reserved
PCI: Bridge: 0000:00:01.0
IO window: 3000-3fff
MEM window: c0100000-c01fffff
PREFETCH window: e0000000-e7ffffff
PCI: Bus 3, cardbus bridge: 0000:02:00.0
IO window: 00004000-000040ff
IO window: 00004400-000044ff
PREFETCH window: e8000000-ebffffff
MEM window: c4000000-c7ffffff
PCI: Bus 7, cardbus bridge: 0000:02:00.1
IO window: 00004800-000048ff
IO window: 00004c00-00004cff
PREFETCH window: ec000000-efffffff
MEM window: c8000000-cbffffff
PCI: Bridge: 0000:00:1e.0
IO window: 4000-8fff
MEM window: c0200000-cfffffff
PREFETCH window: e8000000-efffffff
PCI: Setting latency timer of device 0000:00:1e.0 to 64
ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 11
PCI: setting IRQ 11 as level-triggered
ACPI: PCI Interrupt 0000:02:00.0[A] -> Link [LNKA] -> GSI 11 (level, low) -> IRQ 11
ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 11
ACPI: PCI Interrupt 0000:02:00.1[B] -> Link [LNKB] -> GSI 11 (level, low) -> IRQ 11
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 6, 262144 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
checking if image is initramfs…it isn’t (bad gzip magic numbers); looks like an initrd
Freeing initrd memory: 4936k freed
Simple Boot Flag at 0x35 set to 0x1
audit: initializing netlink socket (disabled)
audit(1203619691.188:1): initialized
highmem bounce pool size: 64 pages
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
Boot video device is 0000:01:00.0
PCI: Firmware left 0000:02:08.0 e100 interrupts enabled, disabling
isapnp: Scanning for PnP cards…
isapnp: No Plug & Play device found
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
serial 00:09: activated
00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a NS16550A
ACPI: PCI Interrupt 0000:00:1f.6[B] -> Link [LNKB] -> GSI 11 (level, low) -> IRQ 11
ACPI: PCI interrupt for device 0000:00:1f.6 disabled
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
PNP: PS/2 Controller [PNP0303:KBD,PNP0f13:MOU] at 0x60,0x64 irq 1,12
serio: i8042 KBD port at 0x60,0x64 irq 1
serio: i8042 AUX port at 0x60,0x64 irq 12
mice: PS/2 mouse device common for all mice
Linux telephony interface: v1.00
TCP bic registered
NET: Registered protocol family 17
Using IPI Shortcut mode
RAMDISK: cramfs filesystem found at block 0
RAMDISK: Loading 4936KiB [1 disk] into ram disk… done.
VFS: Mounted root (cramfs filesystem) readonly.
input: AT Translated Set 2 keyboard as /class/input/input0
Freeing unused kernel memory: 188k freed
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
ICH4: IDE controller (0x8086:0x24ca rev 0x01) at PCI slot 0000:00:1f.1
PCI: Enabling device 0000:00:1f.1 (0005 -> 0007)
ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 11
ACPI: PCI Interrupt 0000:00:1f.1[A] -> Link [LNKC] -> GSI 11 (level, low) -> IRQ 11
ICH4: not 100% native mode: will probe irqs later
ide0: BM-DMA at 0x1860-0x1867, BIOS settings: hda:DMA, hdb:pio
ide1: BM-DMA at 0x1868-0x186f, BIOS settings: hdc:pio, hdd:pio
Probing IDE interface ide0…
hda: IC25N040ATMR04-0, ATA DISK drive
hda: host max PIO4 wanted PIO255(auto-tune) selected PIO4
hda: UDMA/100 mode selected
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1…
hda: max request size: 128KiB
hda: 78140160 sectors (40007 MB) w/1740KiB Cache, CHS=65535/16/63
hda: cache flushes supported
hda: hda1 hda2 < hda5 hda6 >
You didn’t specify the type of your ufs filesystem
mount -t ufs -o ufstype=sun|sunx86|44bsd|ufs2|5xbsd|old|hp|nextstep|nextstep-cd|openstep …
WARNING<<< Wrong ufstype may corrupt your filesystem, default is ufstype=old
ufs_read_super: bad magic number
kjournald starting. Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
input: PC Speaker as /class/input/input1
Real Time Clock Driver v1.12ac
intel_rng: FWH not detected
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Linux agpgart interface v0.102
ACPI: CPU0 (power states: C1[C1] C2[C2] C3[C3])
ACPI: Processor [CPU] (supports 8 throttling states)
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
input: Power Button (FF) as /class/input/input2
ACPI: Power Button (FF) [PWRF]
input: Lid Switch as /class/input/input3
ACPI: Lid Switch [LID]
input: Sleep Button (CM) as /class/input/input4
ACPI: Sleep Button (CM) [SLPB]
agpgart: Detected an Intel 855PM Chipset.
agpgart: AGP aperture is 256M @ 0xd0000000
USB Universal Host Controller Interface driver v3.0
ACPI: PCI Interrupt 0000:00:1d.0[A] -> Link [LNKA] -> GSI 11 (level, low) -> IRQ 11
PCI: Setting latency timer of device 0000:00:1d.0 to 64
uhci_hcd 0000:00:1d.0: UHCI Host Controller
uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:1d.0: irq 11, io base 0x00001800
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 11
ACPI: PCI Interrupt 0000:00:1d.1[B] -> Link [LNKD] -> GSI 11 (level, low) -> IRQ 11
PCI: Setting latency timer of device 0000:00:1d.1 to 64
uhci_hcd 0000:00:1d.1: UHCI Host Controller
uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 2
uhci_hcd 0000:00:1d.1: irq 11, io base 0x00001820
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
ACPI: Thermal Zone [THM0] (23 C)
ACPI: PCI Interrupt 0000:00:1d.2[C] -> Link [LNKC] -> GSI 11 (level, low) -> IRQ 11
PCI: Setting latency timer of device 0000:00:1d.2 to 64
uhci_hcd 0000:00:1d.2: UHCI Host Controller
uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 3
uhci_hcd 0000:00:1d.2: irq 11, io base 0x00001840
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
IBM TrackPoint firmware: 0x0e, buttons: 3/3
input: TPPS/2 IBM TrackPoint as /class/input/input5
ACPI: PCI Interrupt Link [LNKH] enabled at IRQ 11
ACPI: PCI Interrupt 0000:00:1d.7[D] -> Link [LNKH] -> GSI 11 (level, low) -> IRQ 11
PCI: Setting latency timer of device 0000:00:1d.7 to 64
ehci_hcd 0000:00:1d.7: EHCI Host Controller
ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 4
ehci_hcd 0000:00:1d.7: debug port 1
PCI: cache line size of 32 is not supported by device 0000:00:1d.7
ehci_hcd 0000:00:1d.7: irq 11, io mem 0xc0000000
parport_pc 00:0a: activated
parport_pc 00:0a: reported by Plug and Play ACPI
parport0: PC-style at 0x3bc, irq 7 [PCSPP,TRISTATE]
ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb4: configuration #1 chosen from 1 choice
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 6 ports detected
ACPI: PCI Interrupt 0000:00:1f.3[B] -> Link [LNKB] -> GSI 11 (level, low) -> IRQ 11
ACPI: AC Adapter [AC] (on-line)
ACPI: Battery Slot [BAT0] (battery absent)
airo(): Probing for PCI adapters
ACPI: PCI Interrupt 0000:02:02.0[A] -> Link [LNKC] -> GSI 11 (level, low) -> IRQ 11
airo(): Found an MPI350 card
e100: Intel® PRO/100 Network Driver, 3.5.23-k4-NAPI
e100: Copyright© 1999-2006 Intel Corporation
usb 2-1: new low speed USB device using uhci_hcd and address 2
usb 2-1: configuration #1 chosen from 1 choice
Marking TSC unstable due to: possible TSC halt in C2.
Time: acpi_pm clocksource has been installed.
usbcore: registered new interface driver hiddev
input: Logitech Optical USB Mouse as /class/input/input6
input: USB HID v1.10 Mouse [Logitech Optical USB Mouse] on usb-0000:00:1d.1-1
usbcore: registered new interface driver usbhid
drivers/hid/usbhid/hid-core.c: v2.6:USB HID core driver
padlock: VIA PadLock not detected.
airo(): WPA is supported.
airo(eth0): MAC enabled 00:02:8a:dd:c0:51
airo(): Finished probing for PCI adapters
ACPI: PCI Interrupt Link [LNKE] enabled at IRQ 11
ACPI: PCI Interrupt 0000:02:08.0[A] -> Link [LNKE] -> GSI 11 (level, low) -> IRQ 11
e100: eth1: e100_probe: addr 0xc0204000, irq 11, MAC addr 00:0d:60:77:5a:91
PCI: Setting latency timer of device 0000:00:1f.6 to 64
Yenta: CardBus bridge found at 0000:02:00.0 [1014:0532]
Yenta: ISA IRQ mask 0x0438, PCI irq 11
Socket status: 30000006
pcmcia: parent PCI bridge I/O window: 0x4000 - 0x8fff
cs: IO port probe 0x4000-0x8fff: clean.
pcmcia: parent PCI bridge Memory window: 0xc0200000 - 0xcfffffff
pcmcia: parent PCI bridge Memory window: 0xe8000000 - 0xefffffff
Yenta: CardBus bridge found at 0000:02:00.1 [1014:0532]
ACPI: PCI Interrupt 0000:02:00.2[C] -> Link [LNKC] -> GSI 11 (level, low) -> IRQ 11
ohci1394: fw-host0: OHCI-1394 1.0 (PCI): IRQ=[11] MMIO=[c0205000-c02057ff] Max Packet=[2048] IR/IT contexts=[4/4]
ACPI: PCI Interrupt 0000:00:1f.5[B] -> Link [LNKB] -> GSI 11 (level, low) -> IRQ 11
PCI: Setting latency timer of device 0000:00:1f.5 to 64
cs: IO port probe 0x100-0x3af: clean.
cs: IO port probe 0x3e0-0x4ff: excluding 0x4d0-0x4d7
cs: IO port probe 0x820-0x8ff: clean.
cs: IO port probe 0xc00-0xcf7: clean.
cs: IO port probe 0xa00-0xaff: clean.
intel8x0_measure_ac97_clock: measured 50418 usecs
intel8x0: clocking to 48000
ieee1394: Host added: ID:BUS[0-00:1023] GUID[00061b020122403a]
Adding 1389580k swap on /dev/hda5. Priority:-1 extents:1 across:1389580k
EXT3 FS on hda1, internal journal
loop: module loaded
SCSI subsystem initialized
device-mapper: ioctl: 4.12.0-ioctl (2007-10-02) initialised: dm-devel@redhat.comkjournald starting. Commit interval 5 seconds
EXT3 FS on hda6, internal journal
Clocksource tsc unstable (delta = -249873388 ns)
e100: eth2: e100_watchdog: link up, 100Mbps, full-duplex
[drm] Initialized drm 1.1.0 20060810
ACPI: PCI Interrupt 0000:01:00.0[A] -> Link [LNKA] -> GSI 11 (level, low) -> IRQ 11
[drm] Initialized radeon 1.28.0 20060524 on minor 0
agpgart: Found an AGP 2.0 compliant device at 0000:00:00.0.
agpgart: Putting AGP V2 device at 0000:00:00.0 into 1x mode
agpgart: Putting AGP V2 device at 0000:01:00.0 into 1x mode
[drm] Setting GART location based on new memory map
[drm] writeback test succeeded in 2 usecs
