Probleme virtualbox
Je viens de migrer sur Jessie, j’ai importé mes VM, mais elles boot pas, j’ai une fenêtre “staring vm” avec une barre de progression qui reste bloqué à 20%.
Dans les log VBOXSVC.log j’ai ceci:
00:00:40.681326 nspr-2   Failed to open "/dev/vboxdrvu", errno=13, rc=VERR_VM_DRIVER_NOT_ACCESSIBLE
00:00:42.252938 nspr-2   ERROR [COM]: aRC=VBOX_E_INVALID_VM_STATE (0x80bb0002) aIID={480cf695-2d8d-4256-9c7c-cce4184fa048} aComponent={Machine} aText={Machine is not locked for session (session state: Unlocked)}, preserve=false
00:00:42.268551 nspr-5   Failed to open "/dev/vboxdrvu", errno=13, rc=VERR_VM_DRIVER_NOT_ACCESSIBLE
00:00:42.471989 nspr-2   Failed to open "/dev/vboxdrvu", errno=13, rc=VERR_VM_DRIVER_NOT_ACCESSIBLE
00:00:42.508032 nspr-3   ERROR [COM]: aRC=VBOX_E_OBJECT_NOT_FOUND (0x80bb0001) aIID={3295e6ce-b051-47b2-9514-2c588bfe7554} aComponent={ExtPackManager} aText={No extension pack by the name 'Oracle VM VirtualBox Extension Pack' was found}, preserve=false
00:00:42.516921 nspr-4   ERROR [COM]: aRC=VBOX_E_IPRT_ERROR (0x80bb0005) aIID={480cf695-2d8d-4256-9c7c-cce4184fa048} aComponent={SessionMachine} aText={Saved screenshot data is not available (VERR_NOT_SUPPORTED)}, preserve=false
00:00:42.555142 nspr-3   NetIfAdpCtlOut: VBoxNetAdpCtl: Error while retrieving link speed for wlan0: VBoxNetAdpCtl: ioctl failed: Operation not supported
00:00:42.576935 nspr-3   NetIfAdpCtlOut: VBoxNetAdpCtl: Error while retrieving link status for vboxnet0: VBoxNetAdpCtl: ioctl failed: Operation not supported
00:00:42.635400 nspr-4   Failed to open "/dev/vboxdrvu", errno=13, rc=VERR_VM_DRIVER_NOT_ACCESSIBLE
00:00:42.662413 nspr-4   Failed to open "/dev/vboxdrvu", errno=13, rc=VERR_VM_DRIVER_NOT_ACCESSIBLE
Et dans vbox.log
00:00:00.510277 Pulse: open PCM_IN rate=44100Hz channels=2 format=s16le
00:00:00.510283 Pulse: Requested record buffer attributes: maxlength=26460 fragsize=17640
00:00:00.537809 Pulse:  Obtained record buffer attributes: maxlength=26460 fragsize=8820
00:00:00.537846 Pulse: open PCM_OUT rate=44100Hz channels=2 format=s16le
00:00:00.537854 Pulse: Requested playback buffer attributes: maxlength=26460 tlength=17640 prebuf=-1 minreq=-1
00:00:00.553316 Pulse:  Obtained playback buffer attributes: maxlength=26460 tlength=12348 prebuf=8824 minreq=3528
00:00:00.554136 VUSB: attached 'HidMouse' to port 1
00:00:00.554493 DevPcBios: SATA LUN#0 LCHS=1024/255/63
00:00:00.554555 PGM: The CPU physical address width is 39 bits
00:00:00.554558 PGMR3InitFinalize: 4 MB PSE mask 0000007fffffffff
Les droits sur le device vboxdrvu semblent bon mo, user est dans le group vboxusers
ls -ld /dev/vboxdrvu
crw------- 1 root root 10, 55 avril  3 00:46 /dev/vboxdrvu
Si quelqu’un a une idée…
bonjour,
google est ton ami:
errno.h
ensuite, j’ai cela
crw-rw-rw- 1 root root 10, 58 Apr  3 08:15 /dev/vboxdrvu
alpha30:~ #
A+
JB1
J’ai fouillé errno.h, mais pas trouvé de correspondances avec les erreurs :
Quand à /dev/vboxdrvu j’ai eu beau le passer en 666, ca ne boot toujours pas, de plus sur une autre machine les droits sont en 600 et les VM boot bien. Ce n’est donc pas une problème de permissions.
bonjour.
vous avez migré de wheezy vers testing,virtualbox jessie est dans la version 4.3.18.Si vous récupérez le pack extension chez oracle il faut choisir le pack correspondant à la version 4.3.18.Vous n’avez pas indiqué quel système est virtualisé;xp,win7,linux,autres?dans tous les cas il faudra choisir les additions invitées pour la version 4.3.18 de virtualbox. Votre problème vient peut être de là.
avez vous installé virtualbox des dépôts ou virtualbox/Oracle?
J’ai des windows et linux de virtualisés. J’ai tout installé depuis les dépots ainsi que le package virtualbox-guest-additions-iso.
" 00:00:42.508032 nspr-3 ERROR [COM]: aRC=VBOX_E_OBJECT_NOT_FOUND (0x80bb0001) aIID={3295e6ce-b051-47b2-9514-2c588bfe7554} aComponent={ExtPackManager} aText={No extension pack by the name ‘Oracle VM VirtualBox Extension Pack’ was found}, preserve=false “”
c’est pas un problème avec Oracle VM VirtualBox Extension Pack?Quelle version de extpack est installée?
jette ton oeil à ceci:
/usr/include/asm-generic/errno-base.h
#ifndef _ASM_GENERIC_ERRNO_BASE_H
#define _ASM_GENERIC_ERRNO_BASE_H
#define EPERM        1  /* Operation not permitted */
#define ENOENT       2  /* No such file or directory */
#define ESRCH        3  /* No such process */
#define EINTR        4  /* Interrupted system call */
#define EIO      5  /* I/O error */
#define ENXIO        6  /* No such device or address */
#define E2BIG        7  /* Argument list too long */
#define ENOEXEC      8  /* Exec format error */
#define EBADF        9  /* Bad file number */
#define ECHILD      10  /* No child processes */
#define EAGAIN      11  /* Try again */
#define ENOMEM      12  /* Out of memory */
#define EACCES      13  /* Permission denied */
#define EFAULT      14  /* Bad address */
attention au 13 si tu es superticieux
A+
JB1
@avram
j’ai ces packages d’installés:
aptitude search virtualbo
i   virtualbox        - x86 virtualization solution - base binaries
p   virtualbox:i386        - x86 virtualization solution - base binaries
p   virtualbox-4.3        - Oracle VM VirtualBox
p   virtualbox-4.3:i386        - Oracle VM VirtualBox
p   virtualbox-dbg        - x86 virtualization solution - debugging symbols
p   virtualbox-dbg:i386        - x86 virtualization solution - debugging symbols
i   virtualbox-dkms        - x86 virtualization solution - kernel module sources for dkms
i   virtualbox-guest-additions-iso        - guest additions iso image for VirtualBox
i   virtualbox-guest-dkms        - x86 virtualization solution - guest addition module source for dkms
i   virtualbox-guest-source        - x86 virtualization solution - guest addition module source
i   virtualbox-guest-utils        - x86 virtualization solution - non-X11 guest utilities
p   virtualbox-guest-utils:i386        - x86 virtualization solution - non-X11 guest utilities
i   virtualbox-guest-x11        - x86 virtualization solution - X11 guest utilities
p   virtualbox-guest-x11:i386        - x86 virtualization solution - X11 guest utilities
p   virtualbox-nonfree        - Oracle Virtualbox virtualization software.
i   virtualbox-qt        - x86 virtualization solution - Qt based user interface
p   virtualbox-qt:i386        - x86 virtualization solution - Qt based user interface
p   virtualbox-source
Mais c’est possible que les guests non pas été installés depuis un package debian. (je récupère ces VM)
pt-cache policy virtualbox-guest-additions-iso
virtualbox-guest-additions-iso:
  Installé : 4.3.18-3
  Candidat : 4.3.18-3
 Table de version :
 *** 4.3.18-3 0
        500 http://ftp.us.debian.org/debian/ jessie/non-free amd64 Packages
        100 /var/lib/dpkg/status
@jb1 ok pour le 13 permission denied, j’ai mis le device en 666 ca ne boot pas, mais ca évite d’avoir ces erreurs dans les logs ^^ Ou il y a plusieurs problèmes
" virtualbox-4.3 - Oracle VM VirtualBox
virtualbox-nonfree - Oracle Virtualbox virtualization software. "
il y a des paquets qui viennent de chez Oracle et des paquets des dépôts officiels,mais Oracle ne fournit pas encore de paquets en version jessie,et vous avez fait une mise à jour vers jessie et là il y a certainement des incompatibilités entre les paquets VB de Jessie et les paquets VB de Oracle qui eux n’ont pas encore de mise à jour vers jessie.C’est pour ça que mon virtualbox ne provient QUE des dépôts officiels,quand j’avais mis à jour vers Jessie VB n’a pas bronché et je n’ai pas eu de couacs.
Quel est votre sources-list?
les packages venant d’oracle ne sont pas installer, je n’ai que ceux ci d’installer
aptitude search virtualbox | grep ^i
Le sourcelist
[code]
deb packages.linuxmint.com betsy main upstream import
deb ftp.us.debian.org/debian jessie main contrib non-free
deb ftp.us.debian.org/debian jessie-updates main contrib non-free
deb security.debian.org jessie/updates main contrib non-free
deb deb-multimedia.org jessie main non-free
deb extra.linuxmint.com betsy main
[code]
votre sources-list indique du debian-multimedia et linux mint c.à.d du ubuntu,je ne sais pas comment tout ça peut rester compatible en faisant une mise à jour vers testing et je ne peut pas vous aider plus avant.La seule expérience que j’ai ne concerne que des versions,stable ou testing,sans introduction de dépôts etrangers à debian,jamais de mélanges jamais de micmac.Désolé.
Normal, c’est une LMDE, c’est une jessie avec cinnamon fait par les mecs de Mint. Pour le reste ca marche pareil que jessie.
Les packages de virtualbox viennent des dépots de jessie et même le kernel:
apt-cache policy virtualbox
virtualbox:
  Installé : 4.3.18-dfsg-3
  Candidat : 4.3.18-dfsg-3
 Table de version :
 *** 4.3.18-dfsg-3 0
        500 http://ftp.us.debian.org/debian/ jessie/contrib amd64 Packages
apt-cache policy virtualbox-dkms
virtualbox-dkms:
 Table de version :
 *** 4.3.18-dfsg-3 0
apt-cache policy virtualbox-guest-source
virtualbox-guest-source:
  Installé : (aucun)
 Table de version :
     4.3.18-dfsg-3 0
apt-cache policy linux-image-3.16.0-4-amd64
linux-image-3.16.0-4-amd64:
  Installé : 3.16.7-ckt7-1
  Candidat : 3.16.7-ckt7-1
 Table de version :
 *** 3.16.7-ckt7-1 0
        500 http://ftp.us.debian.org/debian/ jessie/main amd64 Packages
C’est une jessie quoi.
ok,autant pour moi,je ne suis pas connaisseur de LMDE.On peut essayer un autre truc;normalement vos disques virtuels .vdi que vous aviez créés sous wheezy sont toujours présents et eux ne changent pas dans l’upgrade.L’idée serait de re-créer virtualbox/jessie à neuf avec tous les bons paquets qui vont bien et ensuite vous recréez vos machines virtuelles en utilisant les disques .vdi déjà existants.
[quote=“bloodaxe70”][strike]Normal[/strike], (…) c’est une jessie avec cinnamon fait par les mecs de Mint. [strike]Pour le reste ca marche pareil que jessie[/strike].
Le sourcelist
[code]deb http://packages.linuxmint.com betsy main upstream import
deb http://ftp.us.debian.org/debian jessie main contrib non-free
deb http://ftp.us.debian.org/debian jessie-updates main contrib non-free
deb http://security.debian.org jessie/updates main contrib non-free
deb http://www.deb-multimedia.org jessie main non-free
deb http://extra.linuxmint.com betsy main[/code][/quote]
Un rappel sommaire s’impose.
[mono]Jessie[/mono] à cette heure est toujours en l’état d’une [mono]Testing[/mono] et comme son pseudo l’indique, un pareil fichier [mono]sources.list[/mono] (en l’état) ne peut-être cohérent sans les sources [mono]stable[/mono] et [mono]unstable[/mono]. Voir même [mono]oldstable[/mono].
Et, quand bien même, un épinglage (pinning et [mono]apt-listbugs[/mono]) s’imposent !
J’ai tout viré, puis installer de nouveau les packages. Créer une nouvelle VM debian jessie 64 (une vrai, pas une LMDE =), même résultat :frowning:.
Pour info, je suis sur un lenovo t450s.
Voici les logs:
VirtualBox XPCOM Server 4.3.18_Debian r96516 linux.amd64 (Mar 14 2015 11:59:25) release log
00:00:00.000764 main     Log opened 2015-04-03T20:28:46.582612000Z
00:00:00.000767 main     Build Type: release
00:00:00.000770 main     OS Product: Linux
00:00:00.000771 main     OS Release: 3.16.0-4-amd64
00:00:00.000772 main     OS Version: #1 SMP Debian 3.16.7-ckt7-1 (2015-03-01)
00:00:00.000794 main     DMI Product Name: 20BX000TML
00:00:00.000801 main     DMI Product Version: ThinkPad T450s
00:00:00.000866 main     Host RAM: 11743MB total, 11160MB available
00:00:00.000869 main     Executable: /usr/lib/virtualbox/VBoxSVC
00:00:00.000870 main     Process ID: 10299
00:00:00.000871 main     Package type: LINUX_64BITS_GENERIC (OSE)
00:00:00.122196 nspr-2   NetIfAdpCtlOut: VBoxNetAdpCtl: Error while retrieving link speed for wlan0: VBoxNetAdpCtl: ioctl failed: Operation not supported
00:00:00.124228 nspr-2   HostDnsMonitorProxy: Host's DNS information updated:
00:00:00.124244 nspr-2   DNS server 1: 192.168.1.1
00:00:00.124251 nspr-2   DNS domain: usineabelfort.lan
00:00:00.124282 nspr-2   Failed to open "/dev/vboxdrvu", errno=13, rc=VERR_VM_DRIVER_NOT_ACCESSIBLE
00:00:00.124846 nspr-2   VDInit finished
00:00:00.124949 nspr-2   ERROR [COM]: aRC=NS_ERROR_FAILURE (0x80004005) aIID={1254a96a-ae57-4484-946a-22d86c1f98af} aComponent={SystemProperties} aText={Cannot determine default Guest Additions ISO location. Most likely they are not avail
able}, preserve=false
00:00:02.715395 nspr-2   Failed to open "/dev/vboxdrvu", errno=13, rc=VERR_VM_DRIVER_NOT_ACCESSIBLE
00:00:02.717032 nspr-2   Failed to open "/dev/vboxdrvu", errno=13, rc=VERR_VM_DRIVER_NOT_ACCESSIBLE
00:00:30.098842 nspr-3   WARNING [COM]: aRC=NS_ERROR_FAILURE (0x80004005) aIID={93269330-48ca-4096-b4a2-1189df336267} aComponent={Host} aText={VirtualBox is not currently allowed to access USB devices.  You can change this by adding your
user to the 'vboxusers' group.  Please see the user manual for a more detailed explanation}, preserve=true
00:00:30.150747 nspr-3   ERROR [COM]: aRC=NS_ERROR_FAILURE (0x80004005) aIID={480cf695-2d8d-4256-9c7c-cce4184fa048} aComponent={Machine} aText={This machine does not have any snapshots}, preserve=false
00:00:30.191522 nspr-2   WARNING [COM]: aRC=NS_ERROR_FAILURE (0x80004005) aIID={93269330-48ca-4096-b4a2-1189df336267} aComponent={Host} aText={VirtualBox is not currently allowed to access USB devices.  You can change this by adding your
00:00:30.213137 nspr-2   Failed to open "/dev/vboxdrvu", errno=13, rc=VERR_VM_DRIVER_NOT_ACCESSIBLE
00:00:30.288066 nspr-2   WARNING [COM]: aRC=NS_ERROR_FAILURE (0x80004005) aIID={93269330-48ca-4096-b4a2-1189df336267} aComponent={Host} aText={VirtualBox is not currently allowed to access USB devices.  You can change this by adding your
00:00:30.288744 nspr-2   WARNING [COM]: aRC=NS_ERROR_FAILURE (0x80004005) aIID={93269330-48ca-4096-b4a2-1189df336267} aComponent={Host} aText={VirtualBox is not currently allowed to access USB devices.  You can change this by adding your
00:00:32.224761 nspr-3   Failed to open "/dev/vboxdrvu", errno=13, rc=VERR_VM_DRIVER_NOT_ACCESSIBLE
00:00:32.382198 nspr-3   WARNING [COM]: aRC=NS_ERROR_FAILURE (0x80004005) aIID={93269330-48ca-4096-b4a2-1189df336267} aComponent={Host} aText={VirtualBox is not currently allowed to access USB devices.  You can change this by adding your
00:00:32.431119 nspr-3   Failed to open "/dev/vboxdrvu", errno=13, rc=VERR_VM_DRIVER_NOT_ACCESSIBLE
00:00:32.437023 nspr-3   NetIfAdpCtlOut: VBoxNetAdpCtl: Error while retrieving link speed for wlan0: VBoxNetAdpCtl: ioctl failed: Operation not supported
00:00:32.452404 nspr-3   NetIfAdpCtlOut: VBoxNetAdpCtl: Error while retrieving link speed for wlan0: VBoxNetAdpCtl: ioctl failed: Operation not supported
00:00:32.480866 nspr-2   WARNING [COM]: aRC=NS_ERROR_FAILURE (0x80004005) aIID={93269330-48ca-4096-b4a2-1189df336267} aComponent={Host} aText={VirtualBox is not currently allowed to access USB devices.  You can change this by adding your
00:00:32.585034 nspr-3   Failed to open "/dev/vboxdrvu", errno=13, rc=VERR_VM_DRIVER_NOT_ACCESSIBLE
00:00:32.599235 nspr-2   Failed to open "/dev/vboxdrvu", errno=13, rc=VERR_VM_DRIVER_NOT_ACCESSIBLE
00:00:32.648077 nspr-2   WARNING [COM]: aRC=NS_ERROR_FAILURE (0x80004005) aIID={93269330-48ca-4096-b4a2-1189df336267} aComponent={Host} aText={VirtualBox is not currently allowed to access USB devices.  You can change this by adding your
00:00:32.648718 nspr-2   WARNING [COM]: aRC=NS_ERROR_FAILURE (0x80004005) aIID={93269330-48ca-4096-b4a2-1189df336267} aComponent={Host} aText={VirtualBox is not currently allowed to access USB devices.  You can change this by adding your
00:01:10.598898 nspr-2   ERROR [COM]: aRC=VBOX_E_OBJECT_NOT_FOUND (0x80bb0001) aIID={480cf695-2d8d-4256-9c7c-cce4184fa048} aComponent={SessionMachine} aText={No storage device attached to device slot 0 on port 0 of controller 'IDE'}, pres
erve=false
00:01:10.640145 nspr-2   ERROR [COM]: aRC=VBOX_E_OBJECT_NOT_FOUND (0x80bb0001) aIID={480cf695-2d8d-4256-9c7c-cce4184fa048} aComponent={SessionMachine} aText={No storage device attached to device slot 0 on port 1 of controller 'IDE'}, pres
erve=false
00:01:10.641245 nspr-2   WARNING [COM]: aRC=NS_ERROR_FAILURE (0x80004005) aIID={93269330-48ca-4096-b4a2-1189df336267} aComponent={Host} aText={VirtualBox is not currently allowed to access USB devices.  You can change this by adding your
00:01:10.733667 nspr-2   Failed to open "/dev/vboxdrvu", errno=13, rc=VERR_VM_DRIVER_NOT_ACCESSIBLE
00:01:10.779666 nspr-3   WARNING [COM]: aRC=NS_ERROR_FAILURE (0x80004005) aIID={93269330-48ca-4096-b4a2-1189df336267} aComponent={Host} aText={VirtualBox is not currently allowed to access USB devices.  You can change this by adding your
00:01:10.780750 nspr-3   WARNING [COM]: aRC=NS_ERROR_FAILURE (0x80004005) aIID={93269330-48ca-4096-b4a2-1189df336267} aComponent={Host} aText={VirtualBox is not currently allowed to access USB devices.  You can change this by adding your
00:01:14.655150 nspr-2   ERROR [COM]: aRC=VBOX_E_INVALID_VM_STATE (0x80bb0002) aIID={480cf695-2d8d-4256-9c7c-cce4184fa048} aComponent={Machine} aText={Machine is not locked for session (session state: Unlocked)}, preserve=false
00:01:14.675235 nspr-2   Failed to open "/dev/vboxdrvu", errno=13, rc=VERR_VM_DRIVER_NOT_ACCESSIBLE
00:01:14.688410 nspr-3   WARNING [COM]: aRC=NS_ERROR_FAILURE (0x80004005) aIID={93269330-48ca-4096-b4a2-1189df336267} aComponent={Host} aText={VirtualBox is not currently allowed to access USB devices.  You can change this by adding your
00:01:14.688999 nspr-3   WARNING [COM]: aRC=NS_ERROR_FAILURE (0x80004005) aIID={93269330-48ca-4096-b4a2-1189df336267} aComponent={Host} aText={VirtualBox is not currently allowed to access USB devices.  You can change this by adding your
00:01:14.848507 nspr-2   Failed to open "/dev/vboxdrvu", errno=13, rc=VERR_VM_DRIVER_NOT_ACCESSIBLE
00:01:14.861199 nspr-3   WARNING [COM]: aRC=NS_ERROR_FAILURE (0x80004005) aIID={93269330-48ca-4096-b4a2-1189df336267} aComponent={Host} aText={VirtualBox is not currently allowed to access USB devices.  You can change this by adding your
00:01:14.861979 nspr-2   WARNING [COM]: aRC=NS_ERROR_FAILURE (0x80004005) aIID={93269330-48ca-4096-b4a2-1189df336267} aComponent={Host} aText={VirtualBox is not currently allowed to access USB devices.  You can change this by adding your
00:01:14.875279 nspr-3   WARNING [COM]: aRC=NS_ERROR_FAILURE (0x80004005) aIID={93269330-48ca-4096-b4a2-1189df336267} aComponent={Host} aText={VirtualBox is not currently allowed to access USB devices.  You can change this by adding your
00:01:14.881218 nspr-3   WARNING [COM]: aRC=NS_ERROR_FAILURE (0x80004005) aIID={93269330-48ca-4096-b4a2-1189df336267} aComponent={Host} aText={VirtualBox is not currently allowed to access USB devices.  You can change this by adding your
00:01:14.882668 nspr-3   ERROR [COM]: aRC=VBOX_E_OBJECT_NOT_FOUND (0x80bb0001) aIID={3295e6ce-b051-47b2-9514-2c588bfe7554} aComponent={ExtPackManager} aText={No extension pack by the name 'Oracle VM VirtualBox Extension Pack' was found},
preserve=false
00:01:14.886464 nspr-2   ERROR [COM]: aRC=VBOX_E_IPRT_ERROR (0x80bb0005) aIID={480cf695-2d8d-4256-9c7c-cce4184fa048} aComponent={SessionMachine} aText={Saved screenshot data is not available (VERR_NOT_SUPPORTED)}, preserve=false
00:01:14.892069 nspr-3   WARNING [COM]: aRC=NS_ERROR_FAILURE (0x80004005) aIID={93269330-48ca-4096-b4a2-1189df336267} aComponent={Host} aText={VirtualBox is not currently allowed to access USB devices.  You can change this by adding your
00:01:14.901458 nspr-2   WARNING [COM]: aRC=NS_ERROR_FAILURE (0x80004005) aIID={93269330-48ca-4096-b4a2-1189df336267} aComponent={Host} aText={VirtualBox is not currently allowed to access USB devices.  You can change this by adding your
00:01:14.951084 nspr-3   NetIfAdpCtlOut: VBoxNetAdpCtl: Error while retrieving link speed for wlan0: VBoxNetAdpCtl: ioctl failed: Operation not supported
00:01:14.985730 nspr-2   Failed to open "/dev/vboxdrvu", errno=13, rc=VERR_VM_DRIVER_NOT_ACCESSIBLE
00:01:14.990740 nspr-3   Failed to open "/dev/vboxdrvu", errno=13, rc=VERR_VM_DRIVER_NOT_ACCESSIBLE
00:01:14.998173 nspr-2   WARNING [COM]: aRC=NS_ERROR_FAILURE (0x80004005) aIID={93269330-48ca-4096-b4a2-1189df336267} aComponent={Host} aText={VirtualBox is not currently allowed to access USB devices.  You can change this by adding your
00:01:15.015997 nspr-3   WARNING [COM]: aRC=NS_ERROR_FAILURE (0x80004005) aIID={93269330-48ca-4096-b4a2-1189df336267} aComponent={Host} aText={VirtualBox is not currently allowed to access USB devices.  You can change this by adding your
00:01:15.016797 nspr-3   WARNING [COM]: aRC=NS_ERROR_FAILURE (0x80004005) aIID={93269330-48ca-4096-b4a2-1189df336267} aComponent={Host} aText={VirtualBox is not currently allowed to access USB devices.  You can change this by adding your
@BelZéButh je suis ok qu’elle est pas encore stable. Je l’ai sur une autre machine et j’ai pas de soucie avec virtualbox
êtes vous dans le groupe vboxusers?
Certes, mais ces nouvelles données reposent sur quoi ?
Des caractéristiques matériels identiques ([strike]au pire[/strike], plus ou moins similaire ?) ?
Le même [mono]sources.list[/mono] ?
Un défaut d’[mono]épinglage[/mono] ?
L’origine du noyau (la version, aussi) (les options du kernel ?) étant le même ?
Bref, c’est bien trop vague en guise de comparatif/référence.
@BelZéButh l’autre machine est une vrai jessie, pas le même matos certe, donc pas comparable à 100%.
@avram je suis bien dans le group vboxuser
[quote=“bloodaxe70”]@BelZéButh l’autre machine est [strike]une vrai[/strike] jessie
Et, d’après toi c’est quoi une [strike]vraie[/strike] [mono]Jessie[/mono] ?
Je disais quoi déjà …
Nous y voici.
Bref, tu ne réponds en rien à mes questions.
PS : mes voisins ont [strike]la même[/strike], ils ont simplement égaré les cochonnets …
Ouais, lais avec une jessie j’aurai les mêmes problèmes vu que c’est le même kernel et même version de vbox sur mon laptop.
Vu qu’il est récent, je penche pour une incompatibilité matériel, car la je séche…
Je vais insister encore un peu, sinon je vais tester la prochaine Ubuntu, je me sentirai sale mais tant pis ^^
