j’avais une problème kernel 5.4.0 amd64 sous vmware
sudo vmware-modconfig --console --install-all
[AppLoader] GLib does not have GSettings support.
(process:4576): GLib-CRITICAL **: 13:43:53.138: g_file_test: assertion 'filename != NULL' failed
Failed to setup build environment.
root@rodrigue7973-pc:/home/rodirgue7973/Téléchargements/vmware-host-modules# sudo modprobe vmnet
modprobe: FATAL: Module vmnet not found in directory /lib/modules/5.4.0-0.bpo.3-amd64
root@rodrigue7973-pc:/home/rodirgue7973/Téléchargements/vmware-host-modules# sudo modprobe vmmon
modprobe: FATAL: Module vmmon not found in directory /lib/modules/5.4.0-0.bpo.3-amd64
sudo /etc/init.d/vmware start
Starting VMware services:
Virtual machine monitor failed
Virtual machine communication interface done
VM communication interface socket family done
Blocking file system done
Virtual ethernet failed
VMware Authentication Daemon done
quoi faire ?
svp aide
