Probleme vmware
voici mon probleme :
19:46:21 root@Zalix:/usr/bin$ vmware
/usr/lib/vmware/bin/vmware: /usr/lib/vmware/lib/libpng12.so.0/libpng12.so.0: no version information available (required by /usr/lib/libcairo.so.2)
j’ai trouvé sur le net que certains avaient reparé en fesant :
vmware-config.pl
mais blocage !
CC [M] /tmp/vmware-config1/vmmon-only/vmcore/moduleloop.o
LD [M] /tmp/vmware-config1/vmmon-only/vmmon.o
Building modules, stage 2.
MODPOST
CC /tmp/vmware-config1/vmmon-only/vmmon.mod.o
LD [M] /tmp/vmware-config1/vmmon-only/vmmon.ko
make[1]: quittant le r�pertoire � /usr/src/linux-headers-2.6.18-4-686 �
cp -f vmmon.ko ./…/vmmon.o
make: quittant le r�pertoire � /tmp/vmware-config1/vmmon-only �
sh: line 1: 25814 Erreur de segmentation ‘insmod’ -p ‘/tmp/vmware-config1/vmmon.o’ >/dev/null 2>&1
Unable to make a vmmon module that can be loaded in the running kernel:
There is probably a slight difference in the kernel configuration between the
set of C header files you specified and your running kernel. You may want to
rebuild a kernel based on that directory, or specify another directory.
For more information on how to troubleshoot module-related problems, please
visit our Web site at “http://www.vmware.com/download/modules/modules.html” and
"http://www.vmware.com/support/reference/linux/prebuilt_modules_linux.html".
Execution aborted.
qqu a une idée ? ou a deja eu ce probleme ?
Bonsoir,
Il doit te manquer quelque chose.
Pour la debian etch, j’ai suivi le tuto suivant:
howtoforge.com/debian_etch_v … rver_howto
et tout s’est bien passé.
Vérifie en particulier que tous les paquets nécessaires sont présents.
Tyrtamos
