bonjour
j’ai installer wicd pour le wifi sous eeepc701 debian-sid kde4
j’ai droit a un :
could not connect to wicd's D-Bus interface
il me dit de regarder dans le fichier wicd.log mais celui ci n’existe pas …
bonjour
j’ai droit a un :
[quote=“Grhim”]
n’arrivant pas a se connecter j’ai ete sur le site de wicd j’ai finalement installer en backport le wicd 1.5
la fenetre s’ouvre mais il ne vois pas de connexions wifi alors que cela pullules…
voici le log :
2009/08/26 16:24:54 :: ---------------------------
2009/08/26 16:24:54 :: wicd initializing...
2009/08/26 16:24:55 :: Couldn't detect a wireless interface.
2009/08/26 16:24:55 :: found wireless_interface in configuration None
2009/08/26 16:24:55 :: setting wireless interface None
2009/08/26 16:24:55 :: automatically detected wired interface eth0
2009/08/26 16:24:55 :: found wired_interface in configuration eth0
2009/08/26 16:24:55 :: setting wired interface eth0
2009/08/26 16:24:55 :: found wpa_driver in configuration wext
2009/08/26 16:24:55 :: setting wpa driver wext
2009/08/26 16:24:55 :: found always_show_wired_interface in configuration False
2009/08/26 16:24:55 :: found use_global_dns in configuration False
2009/08/26 16:24:55 :: setting use global dns to False
2009/08/26 16:24:55 :: setting use global dns to boolean False
2009/08/26 16:24:55 :: found global_dns_1 in configuration None
2009/08/26 16:24:55 :: found global_dns_2 in configuration None
2009/08/26 16:24:55 :: found global_dns_3 in configuration None
2009/08/26 16:24:55 :: setting global dns
2009/08/26 16:24:55 :: global dns servers are None None None
2009/08/26 16:24:55 :: found auto_reconnect in configuration True
2009/08/26 16:24:55 :: setting automatically reconnect when connection drops
2009/08/26 16:24:55 :: found debug_mode in configuration False
2009/08/26 16:24:55 :: found wired_connect_mode in configuration 1
2009/08/26 16:24:55 :: found signal_display_type in configuration 0
2009/08/26 16:24:55 :: found dhcp_client in configuration 0
2009/08/26 16:24:55 :: Setting dhcp client to 0
2009/08/26 16:24:55 :: found link_detect_tool in configuration 0
2009/08/26 16:24:55 :: found flush_tool in configuration 0
2009/08/26 16:24:55 :: Wireless configuration file found...
2009/08/26 16:24:55 :: Wired configuration file found...
2009/08/26 16:24:55 :: chmoding configuration files 0600...
2009/08/26 16:24:55 :: chowning configuration files root:root...
2009/08/26 16:24:55 :: Using wired interface...eth0
2009/08/26 16:24:55 :: Using wireless interface...
2009/08/26 16:24:55 :: autoconnecting...
2009/08/26 16:24:55 :: Putting interface down
2009/08/26 16:24:55 :: Releasing DHCP leases...
2009/08/26 16:24:55 :: Attempting to autoconnect with wired interface...
2009/08/26 16:24:56 :: Setting false IP...
2009/08/26 16:24:56 :: Stopping wpa_supplicant and any DHCP clients
2009/08/26 16:24:56 :: Flushing the routing table...
2009/08/26 16:24:56 :: Putting interface up...
2009/08/26 16:24:56 :: Running DHCP
2009/08/26 16:24:56 :: Internet Systems Consortium DHCP Client V3.1.2p1
2009/08/26 16:24:56 :: Copyright 2004-2009 Internet Systems Consortium.
2009/08/26 16:24:56 :: All rights reserved.
2009/08/26 16:24:56 :: For info, please visit http://www.isc.org/sw/dhcp/
2009/08/26 16:24:57 :: Listening on LPF/eth0/00:1f:c6:88:13:51
2009/08/26 16:24:57 :: Sending on LPF/eth0/00:1f:c6:88:13:51
2009/08/26 16:24:57 :: Sending on Socket/fallback
2009/08/26 16:24:58 :: DHCPREQUEST on eth0 to 255.255.255.255 port 67
2009/08/26 16:24:58 :: DHCPACK from 192.168.1.1
2009/08/26 16:24:58 :: bound to 192.168.1.65 -- renewal in 32452 seconds.
2009/08/26 16:24:58 :: DHCP connection successful
2009/08/26 16:24:58 :: Connecting thread exiting.
2009/08/26 16:27:23 :: Creating ad-hoc network
2009/08/26 16:27:23 :: Killing dhclient and wpa_supplicant
2009/08/26 16:27:23 :: Putting wireless interface down
2009/08/26 16:27:23 :: Setting mode, channel, and essid
2009/08/26 16:27:23 :: Putting interface up
2009/08/26 16:27:23 :: Setting IP address
pour le moment je suis connecter via l’eeepc en ethernet
pourquoi tu ne vas pas directement éditer les fichier /etc/network/interfaces et /etc/wpa_supplicant/wpa_supplicant.conf (si tu es en WPA) directement à la main ? C’est tout aussi rapide que passer par un client comme wicd
salut ^^
j’ai editer le /etc/network/interfaces apparement il est tout a faire ok
par contre je n’ai pas de fichier : /etc/wpa_supplicant/wpa_supplicant.conf
faut-il le créer soi meme ???
Pour mon wifi je me suis basé sur l’excellent tuto d’Ashgenesis, sur son site (http://ashgenesis.debian-fr.net/tutorial/wifi/)… pour lequel j’obtiens un beau 404… je te mets donc la partie utile.
Nota : je n’ai pas de fichier /etc/wpa_supplicant/wpa_supplicant.conf (ni /etc/wpa_supplicant.conf.)… et tout baigne !
[quote=“Ashgenesis”]La configuration du cryptage WPA-PSK se fait souvent dans le fichier /etc/wpa_supplicant.conf. Mais il est aussi possible de
tout combiner dans le fichier interfaces.
D’abord, il nous faut récupérer la clé cryptée car il y a des problèmes de
connection si on met la clé en clair.
Donc, pour récupérer la clé cryptée, il nous faut utiliser wpa_passphrase compris dans
le paquet wpasupplicant.
La syntaxe de cette commande est
wpa_passphrase [passphrase]
l’essid étant “ashgenesis” et la clé wpa “password” :
ash@seal:~$ wpa_passphrase ashgenesis password
network={
ssid=“ashgenesis”
#psk="password"
psk=e6aed3c5be3d59343833537d3a877e628aad60014b20a06105cf5013c5287d38
Nous avons maintenant le nécessaire pour remplir le fichier /etc/network/interfaces.
Voici maintenant 2 types de
configuration, la première utilise le serveur dhcp pour les adresses alors que la deuxième a été définie completèment.
Utilisez celle dont vous avez besoin en la modifiant si nécessaire.
auto wlan0
iface wlan0 inet dhcp
wpa-conf managed
wpa-ap-scan 1
wpa-scan-ssid 1
wpa-ssid ashgenesis
wpa-key-mgmt WPA-PSK
#wpa-psk password ## A de forte chance de ne pas fonctionner
wpa-psk e6aed3c5be3d59343833537d3a877e628aad60014b20a06105cf5013c5287d38
auto wlan0
iface wlan0 inet static
address 192.168.0.2
netmask 255.255.255.0
network 192.168.1.0
broadcast 192.168.1.255
gateway 192.168.0.1
wpa-conf managed
wpa-ap-scan 1
wpa-scan-ssid 1
wpa-ssid ashgenesis
Il vous suffit donc maintenant de relancer le réseau de manière à ce qu’il prenne en compte les changements effectués.
/etc/init.d/networking restart
En espérant que celà pourra t’être utile…
salut ^^
j’ai fais mais il ne vois tujours pas de connection wifi
$ sudo ifconfig -a
eth0 Link encap:Ethernet HWaddr 00:1f:c6:88:13:51
inet adr:192.168.1.65 Bcast:192.168.1.255 Masque:255.255.255.0
adr inet6: fe80::21f:c6ff:fe88:1351/64 Scope:Lien
RX packets:839 errors:0 dropped:0 overruns:0 frame:0
TX packets:2885 errors:0 dropped:0 overruns:0 carrier:1
RX bytes:370872 (362.1 KiB) TX bytes:222797 (217.5 KiB)
Mémoire:fbfc0000-fc000000
lo Link encap:Boucle locale
adr inet6: ::1/128 Scope:Hôte
RX packets:402 errors:0 dropped:0 overruns:0 frame:0
TX packets:402 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:49977 (48.8 KiB) TX bytes:49977 (48.8 KiB)
lspci donne :
01:00.0 Ethernet controller: Atheros Communications Inc. AR5001 Wireless Network Adapter (rev 01)
03:00.0 Ethernet controller: Attansic Technology Corp. L2 100 Mbit Ethernet Adapter (rev a0)
ca a l’air d’aller pourtant ??
j’ai suivi le tuto dans truc et astuce de l’install debian sid eeepc je pige pas ce qui se passe
EDIT :je voir ici : wiki.debian.org/DebianEeePC/HowT … rosModules
EDIT 2 : installer linux-image 2.6.26.2 + madwifi correspondant = wifiradar voit enfin les spot dispo mais pas tres puissant je trouve , il cherche a se connecter mais ca tourne en rond
donc : 2.6.29 marche pas (pour eeepc 701)(no wifi & filaire) et pour le 2.6.30 juste le filaire evidement
si vous avez des infos concernant les madwifi compatible 2.6.30 je veux bien ^^
Plus besoin de madwifi pour les noyaux recents. Madwifi n’est plus mis à jour.
C’est ath5k qu’il te faut, en virant bien tout madwifi sinon ca rentre en conflit.
Bon courage
merci pour l’info
je teste cela !!! ^^
re -
j’ai passer le weekend a compiler le driver ath5k (4h50sur l’eeepc hihi)
virer les madwifi , je vois a present les spots dispo via wifiradar MAIS!! ^^
a la connection ca tourn" sans arriver a se connecter , il bloque sur aquisition de l’adresse IP
Edit final : j’ai bien fais comme le tuto plus haut mais rien , j’en ai un peu marre , j’ai resintaller backtrack sur mon eeepc
merci a tous pour l’aide
