Problème Wifi sous testing : interface non detectée
Tags: #<Tag:0x00007f3b907610b0>
Bonjour tous le monde,
Je viens ici car je viens de quitter Windows pour venir sur Debian hors je n’ai pas du tout le WIFI (Alors que quand j’ai testé Ubuntu je l’avais)
Voici mon matériel:
jeremy@Jeremy-LAP:~$ lspci -nn
00:00.0 Host bridge [0600]: Intel Corporation Sky Lake Host Bridge/DRAM Registers [8086:1904] (rev 08)
00:02.0 VGA compatible controller [0300]: Intel Corporation Sky Lake Integrated Graphics [8086:1916] (rev 07)
00:14.0 USB controller [0c03]: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller [8086:9d2f] (rev 21)
00:14.2 Signal processing controller [1180]: Intel Corporation Sunrise Point-LP Thermal subsystem [8086:9d31] (rev 21)
00:16.0 Communication controller [0780]: Intel Corporation Sunrise Point-LP CSME HECI [8086:9d3a] (rev 21)
00:17.0 SATA controller [0106]: Intel Corporation Sunrise Point-LP SATA Controller [AHCI mode] [8086:9d03] (rev 21)
00:1c.0 PCI bridge [0604]: Intel Corporation Sunrise Point-LP PCI Express Root Port [8086:9d14] (rev f1)
00:1c.5 PCI bridge [0604]: Intel Corporation Sunrise Point-LP PCI Express Root Port [8086:9d15] (rev f1)
00:1d.0 PCI bridge [0604]: Intel Corporation Device [8086:9d18] (rev f1)
00:1f.0 ISA bridge [0601]: Intel Corporation Sunrise Point-LP LPC Controller [8086:9d48] (rev 21)
00:1f.2 Memory controller [0580]: Intel Corporation Sunrise Point-LP PMC [8086:9d21] (rev 21)
00:1f.3 Audio device [0403]: Intel Corporation Sunrise Point-LP HD Audio [8086:9d70] (rev 21)
00:1f.4 SMBus [0c05]: Intel Corporation Sunrise Point-LP SMBus [8086:9d23] (rev 21)
**01:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 10)**
02:00.0 Network controller [0280]: Intel Corporation Intel Dual Band Wireless-AC 3165 Plus Bluetooth [8086:3166] (rev 99)
03:00.0 3D controller [0302]: NVIDIA Corporation GM108M [GeForce 940MX] [10de:134d] (rev a2)
J’ai installé les paquets suivants:
firmware-linux, firmware-realtek hors je n’ai aucun réseau wifi de detecté juste l’ethernet
Voici ce que donne un ifconfig !
root@Jeremy-LAP:/home/jeremy# ifconfig
enp1s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.1.56  netmask 255.255.255.0  broadcast 192.168.1.255
        inet6 fe80::ca5b:76ff:fe0f:e8c0  prefixlen 64  scopeid 0x20<link>
        ether c8:5b:76:0f:e8:c0  txqueuelen 1000  (Ethernet)
        RX packets 7076  bytes 9021992 (8.6 MiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 4748  bytes 431816 (421.6 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1  (Boucle locale)
        RX packets 171  bytes 13963 (13.6 KiB)
        TX packets 171  bytes 13963 (13.6 KiB)
Je vois donc l’interface Ethernet et Loop
Je suis sous Debian Testing avec le noyau 4.7.0-5 et je suis sous Gnome 3.22
Cordialement,
En fait, la puce wifi est le deuxième controleur réseau, et non pas celui que tu as mis en gras dans ton message.
Ca sent plutôt le pilote iwlwifi à installer :wink:
Sauf que si j’en crois la liste des périphériques supportés, il semble que la puce en question ne le soit pas …
Alors, si j’en crois cette page, installe-le depuis le dépôts Backports !!!
Sinon, il existe cette astuce, trouvée-la :
sudo apt-get update
sudo apt-get install git
git clone https://github.com/OpenELEC/iwlwifi-firmware
cd ~/iwlwifi-firmware/firmware
sudo cp iwlwifi-7265*  /lib/firmware
voili, voilou …
Alors, clairement, si je te dis que la Realtek est la carte Ethernet, donc RJ45 … et non pas le wifi … c’est que ce n’est pas le wifi.
La puce qui gère ton wifi est bel et bien la carte Intel - et souvent, c’est la même puce qui gère le BT !
Donc, maintenant à toi de voir si tu persistes et tu signes, ou au contraire, tu suis les informations données …
Merci d’avance :wink:
j’avais supprimé mon message car je savais que j’avais eu tord mais tu as eu le temps de le lire ^^ j’ai donc installé firmare-iwlwifi j’ai redémarrer Debian est hop cela fonctionne
C’est juste moi qui suit idiot de poser une question et de ne pas tenir compte des réponses désolé
Cordialement
Juste pour être sûr : tu l’as installé en version Jessie ou Jessie-Backports ?
Et, merci de ta correction :wink:
(j’apprécie)
Ahhh, non, je viens de voir ta précision : tu es sous Testing !!!
Oki, autant pour moi … et content de savoir que ça fonctionne, si simplement :stuck_out_tongue:
