Salut à tous, j’ai un debian 2.6.18-5-486, j’ai installez la 2.6.25-5-486
Mais voila sur la nouvelle version pas de connexion, le wifi fonctionne très bien, et vue que je veut pas perdre de temp je vous montre quelques sortit de commande.
[code]sh-3.2$ su
Mot de passe :
debian:/home/e101mk2# /etc/init.d/networking restart
- Reconfiguring network interfaces… Error for wireless request “Set Encode” (8B2A) :
SET failed on device eth0 ; No such device.
Error for wireless request “Set ESSID” (8B1A) :
Internet Software Consortium DHCP Client 2.0pl5
Copyright 1995, 1996, 1997, 1998, 1999 The Internet Software Consortium.
All rights reserved.
Please contribute if you find this software useful.
For info, please visit http://www.isc.org/dhcp-contrib.html
wmaster0: unknown hardware address type 801
eth0: ERROR while getting interface flags: No such device
- Starting the Firestarter firewall…
…done.
Bind socket to interface: No such device
exiting.
Failed to bring up eth0.
…done.
Listening on LPF/wlan0/00:0e:8e:0b:e6:7b
Sending on LPF/wlan0/00:0e:8e:0b:e6:7b
Sending on Socket/fallback/fallback-net
DHCPREQUEST on wlan0 to 255.255.255.255 port 67
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 8
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 11
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 14
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 6
No DHCPOFFERS received.
Trying recorded lease 192.168.1.3
PING 192.168.1.1 (192.168.1.1) 56(84) bytes of data.
— 192.168.1.1 ping statistics —
1 packets transmitted, 0 received, +1 errors, 100% packet loss, time 0ms
…done.
No working leases in persistent database. -
…done.
Exiting.
Failed to bring up wlan0.
[ ok ]
debian:/home/e101mk2# iwconfig
lo no wireless extensions.
wmaster0 no wireless extensions.
wlan0 IEEE 802.11g ESSID:"Alice-6a91"
Mode:Managed Frequency:2.442 GHz Access Point: 00:16:41:8F:17:B4
Bit Rate=18 Mb/s Tx-Power=27 dBm
Retry min limit:7 RTS thr:off Fragment thr=2352 B
Encryption key:593E-9F57-5226-7946-DEE1-1DC9-E3
Link Quality=30/100 Signal level=-59 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
debian:/home/e101mk2# ifconfig
lo Link encap:Boucle locale
adr inet6: ::1/128 Scope:Hôte
RX packets:27 errors:0 dropped:0 overruns:0 frame:0
TX packets:27 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:2495 (2.4 KiB) TX bytes:2495 (2.4 KiB)
Bon, une petite capture pour la route:
Voir la capture de la jolie debian de e101mk2
Merci de votre aide d’avance (normalement quand je dis sa, il y a jamais personne qui répond, fin bref)
