Problème wifi
Mon wifi perso (ESSID :“ricardowifi”) n’apparaît plus depuis l’arrivée de “FreeWifi” et plus moyen de s’y brancher :frowning:
ricardo@Dell-sid:~$ sudo iwconfig
wlan0     IEEE 802.11abgn  ESSID:"FreeWifi"
          Mode:Managed  Frequency:2.412 GHz  Access Point: 72:4C:36:06:0A:7A
          Bit Rate=1 Mb/s   Tx-Power=15 dBm
          Retry min limit:7   RTS thr:off   Fragment thr=2352 B
          Encryption key:off
          Power Management:off
          Link Quality=100/100  Signal level:-9 dBm  Noise level=-84 dBm
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
POURTANT :
ricardo@Dell-sid:~$ sudo iwlist scan
lo        Interface doesn't support scanning.
eth0      Interface doesn't support scanning.
wmaster0  Interface doesn't support scanning.
wlan0     Scan completed :
          Cell 01 - Address: 72:4C:36:06:0A:78
                    ESSID:"ricardowifi"
                    Mode:Master
                    Channel:1
                    Frequency:2.412 GHz (Channel 1)
                    Quality=100/100  Signal level:-10 dBm  Noise level=-127 dBm
                    Encryption key:on
                    IE: Unknown: 000B7269636172646F77696669
                    IE: Unknown: 010882848B961224486C
                    IE: Unknown: 030101
                    IE: Unknown: 2A0104
                    IE: Unknown: 32040C183060
                    IE: Unknown: 2D1A6E1017FFFF000001000000000000000000000000000000000000
                    IE: Unknown: 3D1601050400000000000000000000000000000000000000
                    IE: Unknown: 3E0100
                    IE: WPA Version 1
                        Group Cipher : TKIP
                        Pairwise Ciphers (2) : TKIP CCMP
                        Authentication Suites (1) : PSK
                    IE: Unknown: DD180050F2020101000003A4000027A4000042435E0062322F00
                    IE: Unknown: 7F0101
                    IE: Unknown: DD07000C4300000000
                    IE: Unknown: DD1E00904C336E1017FFFF000001000000000000000000000000000000000000
                    IE: Unknown: DD1A00904C3401050400000000000000000000000000000000000000
                    Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 9 Mb/s
                              18 Mb/s; 36 Mb/s; 54 Mb/s; 6 Mb/s; 12 Mb/s
                              24 Mb/s; 48 Mb/s
                    Extra:tsf=00000008deb5ed44
                    Extra: Last beacon: 7644ms ago
          Cell 02 - Address: 72:4C:36:06:0A:7A
                    ESSID:"FreeWifi"
                    Mode:Master
                    Channel:1
                    Encryption key:off
                    IE: Unknown: 00084672656557696669
                    IE: Unknown: 030101
                    IE: Unknown: 2A0104
                    IE: Unknown: 3E0100
                    IE: Unknown: 7F0101
                              24 Mb/s; 48 Mb/s
                    Extra:tsf=00000008df2a339b
                    Extra: Last beacon: 20ms ago
pan0      Interface doesn't support scanning.
LE SYSLOG
May 31 11:03:31 localhost kernel: [    7.547242] iwlagn: Intel(R) Wireless WiFi Link AGN driver for Linux, 1.3.27ks
May 31 11:03:31 localhost kernel: [    7.547324] iwlagn: Copyright(c) 2003-2008 Intel Corporation
May 31 11:03:31 localhost kernel: [    7.547514] iwlagn 0000:04:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
May 31 11:03:31 localhost kernel: [    7.547594] iwlagn 0000:04:00.0: setting latency timer to 64
May 31 11:03:31 localhost kernel: [    7.547747] iwlagn: Detected Intel Wireless WiFi Link 5100AGN REV=0x54
May 31 11:03:31 localhost kernel: [    7.550953] input: AlpsPS/2 ALPS GlidePoint as /devices/platform/i8042/serio1/input/input12
May 31 11:03:31 localhost kernel: [    7.569544] iwlagn: Tunable channels: 13 802.11bg, 24 802.11a channels
May 31 11:03:31 localhost kernel: [    7.571832] iwlagn 0000:04:00.0: PCI INT A disabled
May 31 11:03:31 localhost kernel: [    7.572167] wmaster0 (iwlagn): not using net_device_ops yet
May 31 11:03:31 localhost kernel: [    7.572440] phy0: Selected rate control algorithm 'iwl-agn-rs'
May 31 11:03:31 localhost kernel: [    7.667981] wlan0 (iwlagn): not using net_device_ops yet
May 31 11:03:31 localhost kernel: [    7.877752]   alloc irq_desc for 22 on cpu 0 node 0
May 31 11:03:31 localhost kernel: [    7.877755]   alloc kstat_irqs on cpu 0 node 0
PLUS BAS :
May 31 11:03:31 localhost kernel: [   13.153915] iwlagn 0000:04:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
May 31 11:03:31 localhost kernel: [   13.153998] iwlagn 0000:04:00.0: restoring config space at offset 0x1 (was 0x100102, writing 0x100106)
May 31 11:03:31 localhost kernel: [   13.154078]   alloc irq_desc for 30 on cpu 0 node 0
May 31 11:03:31 localhost kernel: [   13.154080]   alloc kstat_irqs on cpu 0 node 0
May 31 11:03:31 localhost kernel: [   13.154093] iwlagn 0000:04:00.0: irq 30 for MSI/MSI-X
May 31 11:03:31 localhost kernel: [   13.154150] iwlagn 0000:04:00.0: firmware: requesting iwlwifi-5000-1.ucode
May 31 11:03:31 localhost kernel: [   13.191426] iwlagn loaded firmware version 5.4.1.16
May 31 11:03:31 localhost kernel: [   13.347823] Registered led device: iwl-phy0:radio
May 31 11:03:31 localhost kernel: [   13.347837] Registered led device: iwl-phy0:assoc
May 31 11:03:31 localhost kernel: [   13.347851] Registered led device: iwl-phy0:RX
May 31 11:03:31 localhost kernel: [   13.347865] Registered led device: iwl-phy0:TX
May 31 11:03:31 localhost kernel: [   13.602523] tg3 0000:08:00.0: PME# disabled
May 31 11:03:31 localhost kernel: [   13.602823]   alloc irq_desc for 31 on cpu 0 node 0
May 31 11:03:31 localhost kernel: [   13.602825]   alloc kstat_irqs on cpu 0 node 0
May 31 11:03:31 localhost kernel: [   13.602836] tg3 0000:08:00.0: irq 31 for MSI/MSI-X
May 31 11:03:31 localhost kernel: [   15.306145] tg3: eth0: Link is up at 100 Mbps, full duplex.
May 31 11:03:31 localhost kernel: [   15.306147] tg3: eth0: Flow control is off for TX and off for RX.
May 31 11:03:31 localhost kernel: [   16.234128] wlan0: authenticate with AP 72:4c:36:06:0a:78
May 31 11:03:31 localhost kernel: [   16.236123] wlan0: authenticated
May 31 11:03:31 localhost kernel: [   16.236126] wlan0: associate with AP 72:4c:36:06:0a:78
May 31 11:03:31 localhost kernel: [   16.245107] wlan0: RX AssocResp from 72:4c:36:06:0a:78 (capab=0x411 status=0 aid=1)
May 31 11:03:31 localhost kernel: [   16.245110] wlan0: associated
ENCORE PLUS BAS
May 31 11:03:33 localhost avahi-daemon[3284]: Network interface enumeration completed.
May 31 11:03:33 localhost avahi-daemon[3284]: Registering new address record for 192.168.0.13 on wlan0.IPv4.
May 31 11:03:33 localhost avahi-daemon[3284]: Registering new address record for 192.168.0.10 on eth0.IPv4.
May 31 11:03:33 localhost avahi-daemon[3284]: Registering HINFO record with values 'X86_64'/'LINUX'.
May 31 11:03:34 localhost avahi-daemon[3284]: Server startup complete. Host name is Dell-sid.local. Local service cookie is 125856380.
May 31 11:03:35 localhost kernel: [   26.743312] IN=wlan0 OUT= MAC= SRC=192.168.0.13 DST=224.0.0.251 LEN=140 TOS=0x00 PREC=0x00 TTL=255
D=0 DF PROTO=UDP SPT=5353 DPT=5353 LEN=120
May 31 11:03:35 localhost kernel: [   26.743498] IN=eth0 OUT= MAC= SRC=192.168.0.10 DST=224.0.0.251 LEN=140 TOS=0x00 PREC=0x00 TTL=255 ID=0 DF PROTO=UDP SPT=5353 DPT=5353 LEN=120
May 31 11:03:35 localhost kernel: [   26.993452] IN=wlan0 OUT= MAC= SRC=192.168.0.13 DST=224.0.0.251 LEN=140 TOS=0x00 PREC=0x00 TTL=255 ID=0 DF PROTO=UDP SPT=5353 DPT=5353 LEN=120
May 31 11:03:35 localhost kernel: [   26.993627] IN=eth0 OUT= MAC= SRC=192.168.0.10 DST=224.0.0.251 LEN=140 TOS=0x00 PREC=0x00 TTL=255 ID=0 DF PROTO=UDP SPT=5353 DPT=5353 LEN=120
May 31 11:03:35 localhost kernel: [   27.194295] IN=wlan0 OUT= MAC= SRC=192.168.0.13 DST=224.0.0.251 LEN=201 TOS=0x00 PREC=0x00 TTL=255 ID=0 DF PROTO=UDP SPT=5353 DPT=5353 LEN=181
May 31 11:03:35 localhost kernel: [   27.194528] IN=eth0 OUT= MAC= SRC=192.168.0.10 DST=224.0.0.251 LEN=201 TOS=0x00 PREC=0x00 TTL=255 ID=0 DF PROTO=UDP SPT=5353 DPT=5353 LEN=181
May 31 11:03:35 localhost mysqld_safe[3454]: started
May 31 11:03:35 localhost kernel: [   27.440873] IN=wlan0 OUT= MAC= SRC=192.168.0.13 DST=224.0.0.251 LEN=118 TOS=0x00 PREC=0x00 TTL=255 ID=0 DF PROTO=UDP SPT=5353 DPT=5353 LEN=98
May 31 11:03:35 localhost kernel: [   27.441065] IN=eth0 OUT= MAC= SRC=192.168.0.10 DST=224.0.0.251 LEN=118 TOS=0x00 PREC=0x00 TTL=255 ID=0 DF PROTO=UDP SPT=5353 DPT=5353 LEN=98
May 31 11:03:36 localhost mysqld[3457]: 090531 11:03:36  InnoDB: Started; log sequence number 0 43655
May 31 11:03:36 localhost mysqld[3457]: 090531 11:03:36 [Note] /usr/sbin/mysqld: ready for connections.
May 31 11:03:36 localhost mysqld[3457]: Version: '5.0.81-1'  socket: '/var/run/mysqld/mysqld.sock'  port: 3306  (Debian)
May 31 11:03:36 localhost /etc/mysql/debian-start[3498]: Upgrading MySQL tables if necessary.
May 31 11:03:36 localhost kernel: [   28.443402] IN=wlan0 OUT= MAC= SRC=192.168.0.13 DST=224.0.0.251 LEN=201 TOS=0x00 PREC=0x00 TTL=255 ID=0 DF PROTO=UDP SPT=5353 DPT=5353 LEN=181
May 31 11:03:36 localhost kernel: [   28.443648] IN=eth0 OUT= MAC= SRC=192.168.0.10 DST=224.0.0.251 LEN=201 TOS=0x00 PREC=0x00 TTL=255 ID=0 DF PROTO=UDP SPT=5353 DPT=5353 LEN=181
May 31 11:03:51 localhost wpa_supplicant[2811]: CTRL-EVENT-SCAN-RESULTS
May 31 11:03:51 localhost avahi-daemon[3284]: Interface eth0.IPv4 no longer relevant for mDNS.
May 31 11:03:51 localhost avahi-daemon[3284]: Leaving mDNS multicast group on interface eth0.IPv4 with address 192.168.0.10.
May 31 11:03:51 localhost avahi-daemon[3284]: Withdrawing address record for 192.168.0.10 on eth0.
May 31 11:03:51 localhost dhclient: receive_packet failed on eth0: Network is down
May 31 11:03:51 localhost dhclient: Internet Systems Consortium DHCP Client V3.1.2
May 31 11:03:51 localhost dhclient: Copyright 2004-2008 Internet Systems Consortium.
May 31 11:03:51 localhost dhclient: All rights reserved.
May 31 11:03:51 localhost dhclient: For info, please visit http://www.isc.org/sw/dhcp/
May 31 11:03:51 localhost dhclient: wmaster0: unknown hardware address type 801
May 31 11:03:51 localhost dhclient: Bind socket to interface: No such device
May 31 11:03:51 localhost avahi-daemon[3284]: Withdrawing address record for 192.168.0.13 on wlan0.
May 31 11:03:51 localhost avahi-daemon[3284]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 192.168.0.13.
May 31 11:03:51 localhost avahi-daemon[3284]: Interface wlan0.IPv4 no longer relevant for mDNS.
APRES, il a accroché sur le eth0
May 31 11:03:53 localhost kernel: [   44.668611] tg3: eth0: Link is up at 100 Mbps, full duplex.
May 31 11:03:53 localhost kernel: [   44.668618] tg3: eth0: Flow control is off for TX and off for RX.
May 31 11:03:54 localhost dhclient: DHCPREQUEST on eth0 to 255.255.255.255 port 67
May 31 11:03:54 localhost dhclient: DHCPACK from 192.168.0.254
May 31 11:03:54 localhost avahi-daemon[3284]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.0.10.
May 31 11:03:54 localhost avahi-daemon[3284]: New relevant interface eth0.IPv4 for mDNS.
May 31 11:03:54 localhost avahi-daemon[3284]: Registering new address record for 192.168.0.10 on eth0.IPv4.
May 31 11:03:54 localhost dhclient: bound to 192.168.0.10 -- renewal in 378002 seconds.
May 31 11:03:54 localhost kernel: [   45.692541] IN=eth0 OUT= MAC= SRC=192.168.0.10 DST=224.0.0.251 LEN=232 TOS=0x00 PREC=0x00 TTL=255 ID=0 DF PROTO=UDP SPT=5353 DPT=5353 LEN=212
May 31 11:03:54 localhost kernel: [   45.692701] IN=eth0 OUT= MAC= SRC=192.168.0.10 DST=224.0.0.251 LEN=143 TOS=0x00 PREC=0x00 TTL=255 ID=0 DF PROTO=UDP SPT=5353 DPT=5353 LEN=123
May 31 11:03:54 localhost kernel: [   45.943610] IN=eth0 OUT= MAC= SRC=192.168.0.10 DST=224.0.0.251 LEN=232 TOS=0x00 PREC=0x00 TTL=255 ID=0 DF PROTO=UDP SPT=5353 DPT=5353 LEN=212
May 31 11:03:54 localhost kernel: [   46.194981] IN=eth0 OUT= MAC= SRC=192.168.0.10 DST=224.0.0.251 LEN=232 TOS=0x00 PREC=0x00 TTL=255 ID=0 DF PROTO=UDP SPT=5353 DPT=5353 LEN=212
Je me réponds à moi-même :
pas grave, problème de parefeu.
J’ai déconnecté le parefeu et là je poste depuis mon wifi “ricardowifi” avec le cable eth débranché.
[code]ricardo@Dell-sid:~$ sudo iwconfig
[sudo] password for ricardo:
lo no wireless extensions.
eth0 no wireless extensions.
wmaster0 no wireless extensions.
wlan0 IEEE 802.11abgn ESSID:“ricardowifi”
Mode:Managed Frequency:2.412 GHz Access Point: 72:4C:36:06:0A:78
Bit Rate=60 Mb/s Tx-Power=15 dBm
Encryption key:xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx[2] Security mode:open
Link Quality=100/100 Signal level:-13 dBm Noise level=-82 dBm
pan0 no wireless extensions.
On va donc terminer ici et ouvrir un autre fil pour voir ce qu’il convient de modifier dans le parefeu.
Là, je vais faire appel aux chefs et entre-autres à Pascal.
:smt006
