Problème X
Je viens de découvrir le monde de linux (je me suis installé une debian 6).
J’ai mis à jours mon pilote graphique (nvidia) et depuis mon serveur x ne veut plus se lancer.
Il m’affiche une erreur :
(EE) No devices detected.
Fatal server error:
no screens found
Voici mon fichier /var/log/Xorg.0.log
X.Org X Server 1.7.7
Release Date: 2010-05-04
X Protocol Version 11, Revision 0
Build Operating System: Linux 2.6.32.29-dsa-ia32 i686 Debian
Current Operating System: Linux biscuit 2.6.32-5-686 #1 SMP Tue Mar 8 21:36:00 UTC 2011 i686
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-5-686 root=UUID=63df3ab4-3e4c-463e-a1a3-396c1ae20b30 ro quiet
Build Date: 19 February 2011 02:37:36PM
xorg-server 2:1.7.7-13 (Cyril Brulebois kibi@debian.org)
Current version of pixman: 0.16.4
Before reporting problems, check wiki.x.org
Markers: (–) probed, () from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Sun May 1 15:50:13 2011
(==) Using config file: “/etc/X11/xorg.conf”
(==) Using system config directory “/usr/share/X11/xorg.conf.d”
(==) ServerLayout “Layout0”
) |–>Screen “Screen0” (0)
() | |–>Monitor “Monitor0”
) | |–>Device “Device0”
() |–>Input Device “Keyboard0”
) |–>Input Device “Mouse0”
(==) Automatically adding devices
(==) Automatically enabling devices
(WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
Entry deleted from font path.
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType,
built-ins
(==) ModulePath set to “/usr/lib/xorg/modules”
(WW) AllowEmptyInput is on, devices using drivers ‘kbd’, ‘mouse’ or ‘vmmouse’ will be disabled.
(WW) Disabling Keyboard0
(WW) Disabling Mouse0
(II) Loader magic: 0x81ecca0
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.4
X.Org Video Driver: 6.0
X.Org XInput driver : 7.0
X.Org Server Extension : 2.0
(–) using VT number 8
color=#FF0000 PCI:*(0:0:2:0) 8086:0116:1028:050e Intel Corporation Sandy Bridge Integrated Graphics Controller rev 9, Mem @ 0xf1400000/4194304, 0xe0000000/268435456, I/O @ 0x00004000/64
(–) PCI: (0:1:0:0) 10de:0df4:1028:050e nVidia Corporation rev 161, Mem @ 0xf0000000/16777216, [/color]
0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x00003000/128, BIOS @ 0x???/524288
(II) Open ACPI successful (/var/run/acpid.socket)
(II) LoadModule: “extmod”
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.0.0
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 2.0
(II) Loading extension SELinux
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: “dbe”
(II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: “glx”
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(II) Module glx: vendor="NVIDIA Corporation"
compiled for 4.0.2, module version = 1.0.0
(II) NVIDIA GLX Module 195.36.31 Tue Jun 1 23:22:44 PDT 2010
(II) Loading extension GLX
(II) LoadModule: “record”
(II) Loading /usr/lib/xorg/modules/extensions/librecord.so
(II) Module record: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: “dri”
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: “dri2”
(II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.1.0
(II) Loading extension DRI2
(II) LoadModule: “nvidia”
(II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
(II) Module nvidia: vendor="NVIDIA Corporation"
Module class: X.Org Video Driver
(II) NVIDIA dlloader X Driver 195.36.31 Tue Jun 1 22:21:58 PDT 2010
(II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
(II) Primary Device is: PCI 00@00:02:0
Fatal server error:
no screens found
Please consult the The X.Org Foundation support
at wiki.x.org
for help.
Please also check the log file at “/var/log/Xorg.0.log” for additional information.
Je pense que le problème vient du fait que j’ai 2 cartes graphiques et qu’il charge la Intel au lieu de la Nvidia.
Merci pour votre aide.
PS: j’ai installé mes pilotes nvidia via le module-assistant ^^
en désactivant dans le bios la carte qui ne te sert pas ?
Il faut que tu lui dise d’utilser la carte nvidia comme sortie principale.
Pour le moment il cherche un écran sur la sortie intel.
Soit tu fais comme le suggère Ponky si tu n’as pas besoin de l’autre carte, soit tu te fais un fichier de config xorg.conf qui convient à ton usage.
