probléme xorg depuis ce matin
Bonjour a tous
materiel :
carte nvidia en dual screen
depuis ce matin tous marcher bien est puis yas eu une mise a jour du xorg server
est la plus rien ne fonctionne
de que je lance beryl mon serveur x redemarre
si je tape glxinfo pareil ca reboot mon serveur
alors la je pige pas
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings:  version 1.0  (buildmeister@builder3)  Thu Dec 13 19:10:32 PST 2007
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 1.0  (buildmeister@builder3)  Thu Dec 13 19:09:35 PST 2007
# /etc/X11/xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
# (Type "man /etc/X11/xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
#   sudo dpkg-reconfigure -phigh xserver-xorg
Section "ServerLayout"
    Identifier     "Default Layout"
    Screen      0  "Screen0" 0 0
    InputDevice    "Generic Keyboard"
    InputDevice    "Configured Mouse"
EndSection
Section "Files"
	# path to defoma fonts
    FontPath        "/usr/share/fonts/X11/misc"
    FontPath        "/usr/X11R6/lib/X11/fonts/misc"
    FontPath        "/usr/share/fonts/X11/cyrillic"
    FontPath        "/usr/X11R6/lib/X11/fonts/cyrillic"
    FontPath        "/usr/share/fonts/X11/100dpi/:unscaled"
    FontPath        "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
    FontPath        "/usr/share/fonts/X11/75dpi/:unscaled"
    FontPath        "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
    FontPath        "/usr/share/fonts/X11/Type1"
    FontPath        "/usr/X11R6/lib/X11/fonts/Type1"
    FontPath        "/usr/share/fonts/X11/100dpi"
    FontPath        "/usr/X11R6/lib/X11/fonts/100dpi"
    FontPath        "/usr/share/fonts/X11/75dpi"
    FontPath        "/usr/X11R6/lib/X11/fonts/75dpi"
    FontPath        "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
    Load           "i2c"
    Load           "bitmap"
    Load           "ddc"
    Load           "extmod"
    Load           "freetype"
    Load           "glx"
    Load           "int10"
    Load           "vbe"
EndSection
Section "ServerFlags"
    Option         "Xinerama" "0"
EndSection
Section "InputDevice"
    Identifier     "Generic Keyboard"
    Driver         "kbd"
    Option         "CoreKeyboard"
    Option         "XkbRules" "xorg"
    Option         "XkbModel" "pc105"
    Option         "XkbLayout" "fr"
    Option         "XkbVariant" "latin9"
EndSection
    Identifier     "Configured Mouse"
    Driver         "mouse"
    Option         "CorePointer"
    Option         "Device" "/dev/input/mice"
    Option         "Protocol" "ImPS/2"
    Option         "Emulate3Buttons" "true"
EndSection
Section "Monitor"
    Identifier     "Écran générique"
    HorizSync       28.0 - 51.0
    VertRefresh     43.0 - 60.0
    Option         "DPMS"
EndSection
Section "Monitor"
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "AOC LM760"
    HorizSync       30.0 - 83.0
    VertRefresh     55.0 - 75.0
EndSection
Section "Device"
    Identifier     "Carte vidéo générique"
    Driver         "nvidia"
EndSection
Section "Device"
    Identifier     "Videocard0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
    BoardName      "GeForce 7600 GS"
EndSection
Section "Screen"
    Identifier     "Default Screen"
    Device         "Carte vidéo générique"
    Monitor        "Écran générique"
    DefaultDepth    24
    SubSection     "Display"
        Depth       1
        Modes      "1024x768" "800x600" "640x480"
    EndSubSection
        Depth       4
    EndSubSection
        Depth       8
    EndSubSection
        Depth       15
    EndSubSection
        Depth       16
    EndSubSection
        Depth       24
    EndSubSection
EndSection
Section "Screen"
# Removed Option "TwinView" "0"
# Removed Option "metamodes" "CRT-0: 1024x768 +0+0; CRT-0: 800x600 +0+0; CRT-0: 640x480 +0+0"
# Removed Option "metamodes" "CRT-0: 1024x768 +0+0, CRT-1: nvidia-auto-select +1024+0; CRT-0: 800x600 +0+0, CRT-1: nvidia-auto-select +800+0; CRT-0: 640x480 +0+0, CRT-1: nvidia-auto-select +640+0"
# Removed Option "metamodes" "CRT-0: 1024x768 +0+256, CRT-1: 1024x768 +1024+0; CRT-0: 640x480 +0+0, CRT-1: nvidia-auto-select +640+0"
    Identifier     "Screen0"
    Device         "Videocard0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "TwinView" "1"
    Option         "TwinViewXineramaInfoOrder" "CRT-0"
    Option         "metamodes" "CRT-0: 1024x768 +0+0, CRT-1: 1024x768 +1024+0"
EndSection
IOP,
t’as fait un
dpkg-reconfigure xserver-xorg??
Ou alors tente une réinstallation des pilotes nVidia. Il me semble avoir eu ça à l’époque, quand j’utilisais Beryl, à chaque mise à jour du serveur graphique… :confused:
ca yest j’ai reinstaller les milot de ma carte nvidia
mais maintenant jai un soucis avec amule
voila mon message d’erreur
Initialising aMule
Checking if there is an instance already running…
No other instances are running.
The program ‘amule’ received an X Window System error.
This probably reflects a bug in the program.
The error was ‘BadAlloc (insufficient resources for operation)’.
(Details: serial 772 error_code 11 request_code 146 minor_code 5)
(Note to programmers: normally, X errors are reported asynchronously;
that is, you will receive the error a while after causing it.
To debug your program, run it with the --sync command line
option to change this behavior. You can then get a meaningful
backtrace from your debugger if you break on the gdk_x_error() function.)
darksh3ll@debian:~$
je comprend pas ce qui ce passe
darkshall j’ai le meme probleme…et un ami aussi
depuis la mise a jour de xorg server…gros probleme
resintall pilote Nvidia…meme message d’erreur avec aMule…et …VLC !!!
tout les programmes utlisant une library gdk…
apparement bcp ds les forum americain ont le meme soucis…
bug xorg…je pense que ca devrais etre corriger demain matin …;enfin j’espere…
:unamused:
Oui merci
pour vlc j’ai la meme erreur
merci en tous cas
faut etre patient
et esperer…que l’on ne soit pas des cas isolé … :frowning:
Je vais peut-être attendre pour les MAJ de SID … :wink:
Simple curiosité : vous avez installé quels pilotes pour vos cartes ? Les deb ou le .run tout moche ? Ah et aussi en règle générale lors des mises à jour de noyau et/ou de serveur graphique on ne coupe pas à la réinstallation des pilotes (les kernel headers dont dépendent les drivers changeant).
deb ou run…pour moi je ne vois pas le hic.
avant xorg MAJ…tout fonctionner…
apres ca ne fonctionne plus…(du moins amule VLC et certain programmes)
j’utilise le.run et ils ne m’ont jamais posé aucun soucis.
ensuite…mon ami le .deb (nvidia-glx)…meme probleme.
c’est le Server X qui rencontre un probleme avec GDK…les pilotes ne sont pas en causes.(a priori)
je precise que je n’ai pas Compiz ni Beryl d’installer…;GNOME standard ^^
[quote]Je vais peut-être attendre pour les MAJ de SID …
meme probleme sous SID? car darkshall et moi meme somme sous Etch stable
(quoique quand on va sur report de bugs debian, lenny (la testing ) a aujourdhui moins de bug que Etch…c’est le monde a l’envers)
EDIT: secunia.com/advisories/28539/
j’ai rien dit la MAJ concerne sarge etch et Sid
Cordialement.
Comme quoi, dès que l’on utilise du pilote proprio, on a même plus de sécurité sur une Etch … (.run ou nvidia-glx, les dépots sont non-free), autant passer à SID dès que l’on est en desktop !
Si tu avais lu…SiD a le meme probleme…
sarge aussi…
j’attend demain…voir dimanche…si une mise a jour xorg retombe…je sais de qui je rirais :laughing:
car le message est bien parlant…GDM demarre, tout tourne…lecteur video aussi (totem)…;internet iceweasel icedove…klibido…meme wolfenstein et quake wars pour linux.
seul VLC et Amule rende une erreur avec conflit entre Xserver et gdk.
je maintiens que je ne vois pas le probleme entre les pilotes proprio et le probleme rencontrer.
Cordialement.
je faisais allusion au fait que d’utiliser une Etch avec des pilotes qui ne sont pas stable c’est finalement aussi hasardeux que d’utiliser SID, alos pourquoi se trainer Etch qui est quand même en retard d’une bonne année par rapport à SID …
C vrai…etch est super en retard meme a coté de lenny…
ca je suis d’accord avec toi !! totalement meme
Souci identique hier sur Etch…
Résolu aujourd’hui avec la mise à jour de xserver-xorg-core :smiley:
bon j’ai resolu le probléme j’ai desinstallé la nouvelle version est mis l’ancienne version
pour l’instant c’est ok
Bonjour moi j’ai resolu le probleme en passant sous Lenny/testing
incroyable mais toujours vrai selon les rapports de bugs debian, la Etch a 100 bugs de plus que la Testing/Lenny.
c’est fou :open_mouth:
resultat, Lenny nickel…xorg nickel…bref tout nickel.(plus plein de paquets bcp plus a jour)
Bonheur :smiley: , je reste sous lenny ^^
