Probleme Xserver
J’ai fais récement une “upgrade” de testing vers sid et depuis c’est le drame: X refuse de se lancer …
Pour info ma carte graphique est une ATI Mobility Radeon 9600 et la version de xserver-xorg est 7.4+1
Voici le log Xorg.0.log:
Et voici une copie de mon xorg.conf:
[quote]# xorg.conf (xorg X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the xorg.conf manual page.
(Type “man xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/input/mice"
Option “Protocol” "ImPS/2"
Option “Emulate3Buttons” "true"
EndSection
Identifier "Synaptics Touchpad"
Driver "synaptics"
Option “SendCoreEvents” "true"
Option “Device” "/dev/psaux"
Option “Protocol” "auto-dev"
Option “HorizScrollDelta” "0"
EndSection
Section "Device"
Identifier "Carte video generique"
Driver "ati"
BusID "PCI:1:0:0"
EndSection
Section "Monitor"
Identifier "Ecran generique"
Option "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Carte video generique"
Monitor "Ecran generique"
DefaultDepth 24
SubSection "Display"
Modes “1280x800” “1024x768” “800x600” "640x480"
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
InputDevice "Synaptics Touchpad"
EndSection
Ca fait 3 jours que je cherche (p-e mal ou pas assez) donc si quelqu’un pouvais me depanner ca serait sympa.
Merci.
y’a effectivement du changement à la fois de la part de Xorg et de la part d’ATI (qui ne cherchent plus à supporter les puces de plus de 3ans), donc c’est “normal” qu’il y ait des accros (j’ai eu des gros problèmes aussi :wink:).
La meilleurs chose à faire est à mon avis de sauvegarder ton xorg.conf actuel puis de le supprimer et de relancer Xorg. La nouvelle version d’Xorg s’autoconfigure désormais.
En espèrant que celà résolve ton problème.
