problèmes avec wireshark après passage sur Jessie
Je suis passé sous Jessie.
Toutes les commandes apt m’affichent ce message:
Setting up wireshark-common (1.12.1+g01b65bf-4) ... Executing "addgroup --quiet --system wireshark" failed. Most probably the wireshark group exists, but is not a system group. Please delete the existing group or re-create it as a system group and try configuring wireshark-common again. dpkg: error processing package wireshark-common (--configure): subprocess installed post-installation script returned error exit status 1 Errors were encountered while processing: wireshark-common E: Sub-process /usr/bin/dpkg returned an error code (1)
J’ai essayé pas mal de chose (reconfigure, purge, etc…) mais rien n’y fait
J’ai essayé de désinstaller wireshark mais refuse.
Bonsoir,
Je pense que tu devrais voir:
wireshark:x:wireshark
Si c’est le cas fait un:
Enfin, si tu n’as pas déja essayé.
J’ai fais:
Si je fais:
J’ai le message:
Je ne fais pas plus pour l’instant …
Dans quel contexte ?
Un retour (copier/coller) complet lors de l’utisation d’[mono]apt[/mono], [mono]apt-get[/mono] ou [mono]aptitude[/mono] s’impose.
En prime.
[code]$ dpkg -l |grep wireshark
find /etc/apt -name ‘.list’ -exec bash -c ‘echo -e “\n$1\n”; nl -ba “$1”’ _ ‘{}’ ;
$ apt-cache policy
$ uname -a && lsb_release -dirc[/code]
[code]apt-get install wireshark
Reading package lists… Done
Building dependency tree
Reading state information… Done
The following extra packages will be installed:
wireshark-common
The following NEW packages will be installed:
wireshark wireshark-common
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/952 kB of archives.
After this operation, 2,818 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Preconfiguring packages …
Selecting previously unselected package wireshark-common.
(Reading database … 213933 files and directories currently installed.)
Preparing to unpack …/wireshark-common_1.12.1+g01b65bf-4_amd64.deb …
Unpacking wireshark-common (1.12.1+g01b65bf-4) …
Selecting previously unselected package wireshark.
Preparing to unpack …/wireshark_1.12.1+g01b65bf-4_amd64.deb …
Unpacking wireshark (1.12.1+g01b65bf-4) …
Processing triggers for man-db (2.7.0.2-5) …
Processing triggers for hicolor-icon-theme (0.13-1) …
Processing triggers for menu (2.1.47) …
Processing triggers for desktop-file-utils (0.22-1) …
Processing triggers for mime-support (3.58) …
Processing triggers for shared-mime-info (1.3-1) …
Unknown media type in type 'all/all’
Unknown media type in type 'all/allfiles’
Unknown media type in type 'uri/mms’
Unknown media type in type 'uri/mmst’
Unknown media type in type 'uri/mmsu’
Unknown media type in type 'uri/pnm’
Unknown media type in type 'uri/rtspt’
Unknown media type in type 'uri/rtspu’
Setting up wireshark-common (1.12.1+g01b65bf-4) …
Executing “addgroup --quiet --system wireshark” failed.
dpkg: error processing package wireshark-common (–configure):
dpkg: dependency problems prevent configuration of wireshark:
wireshark depends on wireshark-common (= 1.12.1+g01b65bf-4); however:
Package wireshark-common is not configured yet.
dpkg: error processing package wireshark (–configure):
dependency problems - leaving unconfigured
wireshark-common
wireshark
En plus du conseil “delete user” j’ai deleté le groupe wireshark. Je ne pouvais pas avant.
Puis j’ai fais apt-get install wireshark: maintenant il n’y a plus d’erreurs MAIS “refresh interfaces” affiche aucun interface !
/etc/apt/sources.list
     1	deb http://mirror.switch.ch/ftp/mirror/debian/ wheezy main contrib non-free
     2	deb http://security.debian.org/ wheezy/updates main contrib non-free
     3
     4	deb http://mirror.switch.ch/ftp/mirror/debian/ jessie main contrib non-free
     5	deb http://security.debian.org/ jessie/updates main contrib non-free
apt-cache policy Package files: 100 /var/lib/dpkg/status release a=now 500 http://dl.google.com/linux/earth/deb/ stable/main i386 Packages release v=1.0,o=Google, Inc.,a=stable,n=stable,l=Google,c=main origin dl.google.com 500 http://dl.google.com/linux/earth/deb/ stable/main amd64 Packages release v=1.0,o=Google, Inc.,a=stable,n=stable,l=Google,c=main origin dl.google.com 500 http://security.debian.org/ jessie/updates/non-free Translation-en 500 http://security.debian.org/ jessie/updates/main Translation-en 500 http://security.debian.org/ jessie/updates/contrib Translation-en 500 http://security.debian.org/ jessie/updates/non-free i386 Packages release v=8,o=Debian,a=stable,n=jessie,l=Debian-Security,c=non-free origin security.debian.org 500 http://security.debian.org/ jessie/updates/contrib i386 Packages release v=8,o=Debian,a=stable,n=jessie,l=Debian-Security,c=contrib origin security.debian.org 500 http://security.debian.org/ jessie/updates/main i386 Packages release v=8,o=Debian,a=stable,n=jessie,l=Debian-Security,c=main origin security.debian.org 500 http://security.debian.org/ jessie/updates/non-free amd64 Packages release v=8,o=Debian,a=stable,n=jessie,l=Debian-Security,c=non-free origin security.debian.org 500 http://security.debian.org/ jessie/updates/contrib amd64 Packages release v=8,o=Debian,a=stable,n=jessie,l=Debian-Security,c=contrib origin security.debian.org 500 http://security.debian.org/ jessie/updates/main amd64 Packages release v=8,o=Debian,a=stable,n=jessie,l=Debian-Security,c=main origin security.debian.org 500 http://mirror.switch.ch/ftp/mirror/debian/ jessie/non-free Translation-en 500 http://mirror.switch.ch/ftp/mirror/debian/ jessie/main Translation-en 500 http://mirror.switch.ch/ftp/mirror/debian/ jessie/contrib Translation-en 500 http://mirror.switch.ch/ftp/mirror/debian/ jessie/non-free i386 Packages release v=8.0,o=Debian,a=stable,n=jessie,l=Debian,c=non-free origin mirror.switch.ch 500 http://mirror.switch.ch/ftp/mirror/debian/ jessie/contrib i386 Packages release v=8.0,o=Debian,a=stable,n=jessie,l=Debian,c=contrib origin mirror.switch.ch 500 http://mirror.switch.ch/ftp/mirror/debian/ jessie/main i386 Packages release v=8.0,o=Debian,a=stable,n=jessie,l=Debian,c=main origin mirror.switch.ch 500 http://mirror.switch.ch/ftp/mirror/debian/ jessie/non-free amd64 Packages release v=8.0,o=Debian,a=stable,n=jessie,l=Debian,c=non-free origin mirror.switch.ch 500 http://mirror.switch.ch/ftp/mirror/debian/ jessie/contrib amd64 Packages release v=8.0,o=Debian,a=stable,n=jessie,l=Debian,c=contrib origin mirror.switch.ch 500 http://mirror.switch.ch/ftp/mirror/debian/ jessie/main amd64 Packages release v=8.0,o=Debian,a=stable,n=jessie,l=Debian,c=main origin mirror.switch.ch 500 http://security.debian.org/ wheezy/updates/non-free Translation-en 500 http://security.debian.org/ wheezy/updates/main Translation-en 500 http://security.debian.org/ wheezy/updates/contrib Translation-en 500 http://security.debian.org/ wheezy/updates/non-free i386 Packages release v=7.0,o=Debian,a=oldstable,n=wheezy,l=Debian-Security,c=non-free origin security.debian.org 500 http://security.debian.org/ wheezy/updates/contrib i386 Packages release v=7.0,o=Debian,a=oldstable,n=wheezy,l=Debian-Security,c=contrib origin security.debian.org 500 http://security.debian.org/ wheezy/updates/main i386 Packages release v=7.0,o=Debian,a=oldstable,n=wheezy,l=Debian-Security,c=main origin security.debian.org 500 http://security.debian.org/ wheezy/updates/non-free amd64 Packages release v=7.0,o=Debian,a=oldstable,n=wheezy,l=Debian-Security,c=non-free origin security.debian.org 500 http://security.debian.org/ wheezy/updates/contrib amd64 Packages release v=7.0,o=Debian,a=oldstable,n=wheezy,l=Debian-Security,c=contrib origin security.debian.org 500 http://security.debian.org/ wheezy/updates/main amd64 Packages release v=7.0,o=Debian,a=oldstable,n=wheezy,l=Debian-Security,c=main origin security.debian.org 500 http://mirror.switch.ch/ftp/mirror/debian/ wheezy/non-free Translation-en 500 http://mirror.switch.ch/ftp/mirror/debian/ wheezy/main Translation-en 500 http://mirror.switch.ch/ftp/mirror/debian/ wheezy/contrib Translation-en 500 http://mirror.switch.ch/ftp/mirror/debian/ wheezy/non-free i386 Packages release v=7.8,o=Debian,a=oldstable,n=wheezy,l=Debian,c=non-free origin mirror.switch.ch 500 http://mirror.switch.ch/ftp/mirror/debian/ wheezy/contrib i386 Packages release v=7.8,o=Debian,a=oldstable,n=wheezy,l=Debian,c=contrib origin mirror.switch.ch 500 http://mirror.switch.ch/ftp/mirror/debian/ wheezy/main i386 Packages release v=7.8,o=Debian,a=oldstable,n=wheezy,l=Debian,c=main origin mirror.switch.ch 500 http://mirror.switch.ch/ftp/mirror/debian/ wheezy/non-free amd64 Packages release v=7.8,o=Debian,a=oldstable,n=wheezy,l=Debian,c=non-free origin mirror.switch.ch 500 http://mirror.switch.ch/ftp/mirror/debian/ wheezy/contrib amd64 Packages release v=7.8,o=Debian,a=oldstable,n=wheezy,l=Debian,c=contrib origin mirror.switch.ch 500 http://mirror.switch.ch/ftp/mirror/debian/ wheezy/main amd64 Packages release v=7.8,o=Debian,a=oldstable,n=wheezy,l=Debian,c=main origin mirror.switch.ch Pinned packages:
Linux debian 3.16.0-4-amd64 #1 SMP Debian 3.16.7-ckt9-3~deb8u1 (2015-04-24) x86_64 GNU/Linux
Distributor ID:	Debian
Description:	Debian GNU/Linux 8.0 (jessie)
Release:	8.0
Codename:	jessie
Jolie ligne de commande bash BelZéButh …
Que donne un:
apparemment c'est le user qui n'a pas la permission d'accéder à dumpcap
[code]ls -l dumpcap
-rwxr-xr-- 1 root wireshark 85664 Mar 26 21:01 dumpcap
Si je lance wireshark depuis un terminal root les interfaces sont visibles.
Reste plus à trouver comment un user peut accéder à dumpcap  :wink:
apparemment c’est le user qui n’a pas la permission d’accéder à dumpcap
ls -l dumpcap -rwxr-xr-- 1 root wireshark 85664 Mar 26 21:01 dumpcap
Pour avoir testé wireshark, je sais qu’il fonctionne beaucoup mieux avec quelques privilèges.
Rq: Je l’ai testé sous wheezy, mais je n’ai pas de goupe wireshark.
Tu peux faire:
puis:
Avec cette méthode, je n’ai qu’une erreur au lancement, mais ça semble fonctionner.
Peut être peux tu faire ??? A tester …
J’ai fais:
Moi aussi je l’utilisais sous wheezy. Apparemment il n’a pas supporté le passage sur jessie.
D’autre part je l’utilisais en root ce qui n’est pas bon.
Il n’y a pas besoin de gksu: suffit de lancer wireshark depuis un terminal root.
Je pense qu’il faut donner plus d’acces au groupe wireshark au fichier dumpcap -rwxrwxr-- mais est-ce la bonne solution ?
J’ai fais chmod 777 sur le fichier dumpcap et maintenant je vois les interfaces dans wireshark en étant non-root. Mais ce n’est surement pas la bonne solution !
Deux liens qui traitent de ce sujet:
http://blog.rom1v.com/2012/06/utiliser-wireshark-sous-debian/
http://kifeo.blogspot.fr/2012/03/faire-fonctionner-wireshark-en-non-root.html
Merci beaucoup !
