bonjour,
qui pourrait m’aider à interpréter ces logs :
[code]debian:~# tail -f /var/log/kern.log
May 26 18:26:15 localhost kernel: hdd: command error: status=0x51 { DriveReady SeekComplete Error }
May 26 18:26:15 localhost kernel: hdd: command error: error=0x54 { AbortedCommand LastFailedSense=0x05 }
May 26 18:26:15 localhost kernel: ide: failed opcode was: unknown
May 26 18:26:15 localhost kernel: end_request: I/O error, dev hdd, sector 64
May 26 18:26:15 localhost kernel: isofs_fill_super: bread failed, dev=hdd, iso_blknum=16, block=16
May 26 18:27:12 localhost kernel: hdd: command error: status=0x51 { DriveReady SeekComplete Error }
May 26 18:27:12 localhost kernel: hdd: command error: error=0x54 { AbortedCommand LastFailedSense=0x05 }
May 26 18:27:12 localhost kernel: ide: failed opcode was: unknown
May 26 18:27:12 localhost kernel: end_request: I/O error, dev hdd, sector 64
May 26 18:27:12 localhost kernel: isofs_fill_super: bread failed, dev=hdd, iso_blknum=16, block=16
[1]+ Stopped tail -f /var/log/kern.log
debian:~# mount /dev/cdrom1
mount: wrong fs type, bad option, bad superblock on /dev/hdd,
missing codepage or other error
In some cases useful info is found in syslog - try
dmesg | tail or so
et puis ça me gêne de pas pouvoir lire un cd audio au démarrage du cd, xmms se lance automatique, un click sur play et quedalle …
est-ce juste qu’on ne peut pas appliquer la commande mount sur un cd audio ? dixit : http://lists.debian.org/debian-user-french/2004/05/msg00411.html
