Problèmes de màj avec aptitude
[quote]root@debian:/home/belette# aptitude -s install vlc-plugin-pulse=2.2.1-3 vlc-plugin-notify=2.2.1-3 vlc-nox=2.2.1-3 vlc-data=2.2.1-3 vlc=2.2.1-3
The following packages will be DOWNGRADED:
vlc vlc-data vlc-nox vlc-plugin-notify vlc-plugin-pulse
The following NEW packages will be installed:
libebml4v5{ab} libgles1-mesa{a} libgles2-mesa{a} libgroupsock1{a} liblivemedia23{a} libmatroska6v5{ab} libpostproc-ffmpeg53{a} libqt5x11extras5{a}
libtag1v5{ab} libtag1v5-vanilla{ab} libusageenvironment1{a} vlc-plugin-samba{a}
0 packages upgraded, 12 newly installed, 5 downgraded, 0 to remove and 74 not upgraded.
Need to get 10.3 MB/10.3 MB of archives. After unpacking 1,598 kB will be used.
The following packages have unmet dependencies:
libmatroska6v5 : Breaks: libmatroska6 but 1.4.2-dmo2 is installed.
libtag1v5-vanilla : Breaks: libtag1-vanilla but 1.9.1-2.1 is installed.
libtag1v5 : Conflicts: libtag1c2a but 1.9.1-2.1 is installed.
libvlccore7 : Depends: vlc-data (>= 1:2.1.0) but 2.2.1-3 is to be installed.
libvlccore8 : Depends: vlc-data (>= 1:2.1.0) but 2.2.1-3 is to be installed.
libebml4v5 : Breaks: libebml4 but 1.3.1-dmo2 is installed.
libgroupsock4 : Conflicts: libgroupsock1 but 2014.01.13-1 is to be installed.
The following actions will resolve these dependencies:
  Remove the following packages:
  1.  libreoffice
  2.  libreoffice-avmedia-backend-vlc
  3.  libvlc5
  4.  libvlccore7
  5.  libvlccore8
  6.  vlc
  7.  vlc-nox
8) vlc-plugin-notify
9) vlc-plugin-pulse
  Keep the following packages at their current version:
  1. libebml4v5 [Not Installed]
  2. libgroupsock1 [Not Installed]
  3. libmatroska6v5 [Not Installed]
  4. libtag1v5 [Not Installed]
  5. libtag1v5-vanilla [Not Installed]
  6. vlc-plugin-samba [Not Installed]
    Leave the following dependencies unresolved:
  7. libreoffice-impress recommends libreoffice-avmedia-backend-gstreamer | libreoffice-avmedia-backend-vlc
  8. task-xfce-desktop recommends vlc
  9. task-xfce-desktop recommends libreoffice
Accept this solution? [Y/n/q/?] n
  1.  libgroupsock4
  2.  libreoffice
  3.  libreoffice-avmedia-backend-vlc
  4.  libvlc5
  5.  libvlccore7
  6.  libvlccore8
  7.  vlc
8) vlc-nox
9) vlc-plugin-notify
10) vlc-plugin-pulse
  2. libmatroska6v5 [Not Installed]
  3. libtag1v5 [Not Installed]
  4. libtag1v5-vanilla [Not Installed]
  5. vlc-plugin-samba [Not Installed]
  6. libreoffice-impress recommends libreoffice-avmedia-backend-gstreamer | libreoffice-avmedia-backend-vlc
  7. task-xfce-desktop recommends vlc
  8. task-xfce-desktop recommends libreoffice
  1.  libebml4
  2.  libmatroska6
  3.  libreoffice
  4.  libreoffice-avmedia-backend-vlc
  5.  libvlc5
  6.  libvlccore7
  7.  libvlccore8
8) vlc
9) vlc-nox
10) vlc-plugin-notify
11) vlc-plugin-pulse
  1. libgroupsock1 [Not Installed]
  2. libtag1v5 [Not Installed]
  3. libtag1v5-vanilla [Not Installed]
  4. vlc-plugin-samba [Not Installed]
  5. libreoffice-impress recommends libreoffice-avmedia-backend-gstreamer | libreoffice-avmedia-backend-vlc
  6. task-xfce-desktop recommends vlc
  7. task-xfce-desktop recommends libreoffice
  1.  libebml4
  2.  libgroupsock4
  3.  libmatroska6
  4.  libreoffice
  5.  libreoffice-avmedia-backend-vlc
  6.  libvlc5
  7.  libvlccore7
8) libvlccore8
9) vlc
10) vlc-nox
11) vlc-plugin-notify
12) vlc-plugin-pulse
  1. libtag1v5 [Not Installed]
  2. libtag1v5-vanilla [Not Installed]
  3. vlc-plugin-samba [Not Installed]
  4. libreoffice-impress recommends libreoffice-avmedia-backend-gstreamer | libreoffice-avmedia-backend-vlc
  5. task-xfce-desktop recommends vlc
  6. task-xfce-desktop recommends libreoffice
Accept this solution? [Y/n/q/?] y
The following packages will be REMOVED:
libebml4{a} libgroupsock4{a} libmatroska6{a} libreoffice{a} libreoffice-avmedia-backend-vlc{a} libvlc5{a} libvlccore7{a} libvlccore8{a} vlc{a} vlc-data{u}
vlc-nox{a} vlc-plugin-notify{a} vlc-plugin-pulse{a}
0 packages upgraded, 0 newly installed, 13 to remove and 74 not upgraded.
Need to get 0 B of archives. After unpacking 53.7 MB will be freed.
Do you want to continue? [Y/n/?]
Ce serait intéressant,on le fait sur un post à part?
[quote=“Gargamel”][code]Remove the following packages:
  1. libreoffice
  3. libvlc5
  4. libvlccore7
  5. libvlccore8 [/code][/quote]
$ dpkg -l |grep libreoffice $ dpkg -l |grep libvl
Ma fois, à la suite, si tu as la place.
La petite parenthèse :
root@debian:/home/belette# aptitude search ~c c apg - Automated Password Generator - Standalone version c coinor-libcbc3 - Coin-or branch-and-cut mixed integer programming solver (shared libraries) c coinor-libcgl1 - COIN-OR Cut Generation Library c coinor-libcoinmp1 - Simple C API for COIN-OR Solvers Clp and Cbc -- library c coinor-libcoinutils3 - Coin-or collection of utility classes (binaries and libraries) c coinor-libosi1 - COIN-OR Open Solver Interface c docutils-common - text processing system for reStructuredText - common data c foomatic-filters - OpenPrinting printer support - filters c gimp - The GNU Image Manipulation Program c gimp-data - Data files for GIMP c gnome-control-center - utilities to configure the GNOME desktop c gnome-control-center-data - configuration applets for GNOME - data files c gsfonts-x11 - Make Ghostscript fonts available to X11 c hplip - HP Linux Printing and Imaging System (HPLIP) c irqbalance - Daemon to balance interrupts for SMP systems c libabw-0.0-0 - library for reading and writing AbiWord(tm) documents c libaio1 - Linux kernel AIO access library - shared library c libamd2.2.0 - approximate minimum degree ordering library for sparse matrices c libart-2.0-2 - Library of functions for 2D graphics - runtime files c libass4 - library for SSA/ASS subtitles rendering c libatkmm-1.6-1 - C++ wrappers for ATK accessibility toolkit (shared libraries) c libavcodec-extra-56 - Libav codec library (additional codecs) c libavcodec-ffmpeg56 - FFmpeg library with de/encoders for audio/video codecs - runtime files c libavcodec54 - Library to encode decode multimedia streams - runtime files. c libavfilter3 - FFmpeg filter library. c libavformat54 - FFmpeg file format library. c libavresample-ffmpeg2 - FFmpeg compatibility library for resampling - runtime files c libavutil53 - Libav utility library c libbind9-80 - BIND9 Shared Library used by BIND c libboost-date-time1.49.0 - set of date-time libraries based on generic programming concepts c libboost-date-time1.54.0 - set of date-time libraries based on generic programming concepts c libboost-date-time1.55.0 - set of date-time libraries based on generic programming concepts c libboost-python1.54.0 - Boost.Python Library c libboost-system1.54.0 - Operating system (e.g. diagnostics support) library c libcairomm-1.0-1 - C++ wrappers for Cairo (shared libraries) c libcaribou0 - Configurable on screen keyboard with scanning mode - library c libcdr-0.0-0 - library for reading and converting Corel DRAW files c libcheese-gtk23 - tool to take pictures and videos from your webcam - widgets c libcheese7 - tool to take pictures and videos from your webcam - base library c libclucene-contribs1 - language specific text analyzers (runtime) c libclucene-core1 - core library for full-featured text search engine (runtime) c libclutter-1.0-0 - Open GL based interactive canvas library c libclutter-gst-2.0-0 - Open GL based interactive canvas library GStreamer elements c libclutter-gtk-1.0-0 - Open GL based interactive canvas library GTK+ widget c libcmis-0.3-3 - CMIS protocol client library c libcmis-0.4-4 - CMIS protocol client library c libcmis-0.5-5 - CMIS protocol client library c libcogl-pango12 - Object oriented GL/GLES Abstraction/Utility Layer c libcogl12 - Object oriented GL/GLES Abstraction/Utility Layer c libcolamd2.7.1 - column approximate minimum degree ordering library for sparse matrices c libcolorhug1 - library to access the ColorHug colourimeter -- runtime c libcwidget3 - high-level terminal interface library for C++ (runtime files) c libdee-1.0-4 - model to synchronize mutiple instances over DBus - shared lib c libdirac-encoder0 - open and royalty free high quality video codec - encoder library c libdnet - DECnet Libraries c libdns88 - DNS Shared Library used by BIND c libdns99 - DNS Shared Library used by BIND c libdvbpsi9 - library for MPEG TS and DVB PSI tables decoding and generating c libe-book-0.0-0 - library for reading and converting various e-book formats c libelfg0 - an ELF object file access library c libept1.4.12 - High-level library for managing Debian package information c libetonyek-0.0-0 - library for reading and converting Apple Keynote presentations c libfftw3-long3 - Library for computing Fast Fourier Transforms - Long precision c libfolks-eds25 - Evolution-data-server backend for libfolks c libfolks-telepathy25 - Telepathy backend for libfolks c libfolks25 - library to aggregates people into metacontacts c libfreehand-0.0-0 - Library for parsing the FreeHand file format structure c libfreerdp1 - RDP client for Windows Terminal Services (library) c libgdata13 - Library for accessing GData webservices - shared libraries c libgeoclue0 - C API for GeoClue c libgjs0c - Mozilla-based javascript bindings for the GNOME platform c libglew1.7 - OpenGL Extension Wrangler - runtime environment c libglib2.0-bin - Programs for the GLib library c libglibmm-2.4-1c2a - C++ wrapper for the GLib toolkit (shared libraries) c libgltf-0.0-0 - Library for rendering glTF models c libgnome-media-profiles-3.0-0 - GNOME Media Profiles library c libgoa-1.0-0 - library for GNOME Online Accounts c libgphoto2-2 - gphoto2 digital camera library c libgphoto2-port0 - gphoto2 digital camera port library c libgroupsock1 - multimedia RTSP streaming library (network interfaces and sockets) c libgsoap3 - Runtime libraries for gSOAP c libgsoap4 - Runtime libraries for gSOAP c libgsoap5 - Runtime libraries for gSOAP c libgssglue1 - mechanism-switch gssapi library c libgtkmm-2.4-1c2a - C++ wrappers for GTK+ (shared libraries) c libgtkmm-3.0-1 - C++ wrappers for GTK+ (shared libraries) c libgutenprint2 - runtime for the Gutenprint printer driver library c libharfbuzz0a - OpenType text shaping engine (shared library) c libhdb9-heimdal - Heimdal Kerberos - kadmin server library c libicu48 - International Components for Unicode c libidl0 - library for parsing CORBA IDL files c libirs-export91 - Exported IRS Shared Library c libisc84 - ISC Shared Library used by BIND c libisccc80 - Command Channel Library used by BIND c libisccfg-export90 - Exported ISC CFG Shared Library c libisccfg82 - Config File Handling Library used by BIND c libjim0.74 - small-footprint implementation of Tcl - shared library c libjim0.75 - small-footprint implementation of Tcl - shared library c libjim0debian2 - small-footprint implementation of Tcl - shared library c libkdc2-heimdal - Heimdal Kerberos - KDC support library c liblivemedia15 - multimedia RTSP streaming library c liblivemedia16 - multimedia RTSP streaming library c liblivemedia17 - multimedia RTSP streaming library c liblivemedia26 - multimedia RTSP streaming library c liblivemedia31 - multimedia RTSP streaming library c liblivemedia32 - multimedia RTSP streaming library c liblivemedia33 - multimedia RTSP streaming library c liblivemedia36 - multimedia RTSP streaming library c liblivemedia38 - multimedia RTSP streaming library c liblivemedia41 - multimedia RTSP streaming library c liblivemedia42 - multimedia RTSP streaming library c libllvm3.2 - Low-Level Virtual Machine (LLVM), runtime library c libllvm3.3 - Modular compiler and toolchain technologies, runtime library c libllvm3.4 - Modular compiler and toolchain technologies, runtime library c liblognorm1 - Log normalizing library c liblwres80 - Lightweight Resolver Library used by BIND c libmagickcore5 - low-level image manipulation library c libmagickwand5 - image manipulation library c libmbim-glib0 - Support library to use the MBIM protocol c libmediaart-1.0-0 - media art extraction and cache management library c libmetacity-private0a - library for the Metacity window manager c libmetacity-private1 - library for the Metacity window manager c libmetacity-private2 - library for the Metacity window manager c libmikmod2 - Portable sound library c libmission-control-plugins0 - management daemon for Telepathy (library for plugins) c libmspub-0.0-0 - library for parsing the mspub file structure c libmutter0 - window manager library from the Mutter window manager c libmwaw-0.1-1 - import library for some old mac text document c libmwaw-0.2-2 - import library for some old Mac text documents c libnuma1 - Libraries for controlling NUMA policy c libodfgen-0.0-0 - library to generate ODF documents c libopencv-calib3d2.4 - computer vision Camera Calibration library c libopencv-contrib2.4 - computer vision contrib library c libopencv-features2d2.4 - computer vision Feature Detection and Descriptor Extraction library c libopencv-highgui2.4 - computer vision High-level GUI and Media I/O library c libopencv-legacy2.4 - computer vision legacy library c libopencv-objdetect2.4 - computer vision Object Detection library c libopenvg1-mesa - free implementation of the OpenVG API -- runtime c liborbit2 - high-performance CORBA implementation - extra libraries c liborcus-0.10-0 - library for processing spreadsheet documents c liborcus-0.6-0 - library for processing spreadsheet documents c liborcus-0.8-0 - library for processing spreadsheet documents c libpangomm-1.4-1 - C++ Wrapper for pango (shared libraries) c libparted0debian1 - disk partition manipulator - shared library c libpoppler37 - PDF rendering library c libpoppler44 - PDF rendering library c libprocps1 - library for accessing process information from /proc c libprocps3 - library for accessing process information from /proc c libproxy0 - automatic proxy configuration management library (shared) c libqmi-glib0 - Support library to use the Qualcomm MSM Interface (QMI) protocol c libqpdf13 - runtime library for PDF transformation/inspection software c libqt4-svg - Qt 4 SVG module c libquicktime2 - Library for reading and writing Quicktime files c libreadline5 - GNU readline and history libraries, run-time libraries c libroar-compat2 - drop-in replacements for other sound libraries c libroar2 - foundation libraries for the RoarAudio sound server and clients c librtmp0 - toolkit for RTMP streams (shared library) c librygel-core-2.4-2 - GNOME UPnP/DLNA services - core library c librygel-renderer-2.4-2 - GNOME UPnP/DLNA services - renderer library c librygel-server-2.4-2 - GNOME UPnP/DLNA services - server library c libsane-hpaio - HP SANE backend for multi-function peripherals c libsigc++-2.0-0c2a - type-safe Signal Framework for C++ - runtime c libslp1 - OpenSLP shared library c libsoxr0 - High quality 1D sample-rate conversion library c libspice-server1 - Implements the server side of the SPICE protocol c libsubunit0 - Unit testing protocol - C/C++ shared library c libsystemd-daemon0 - systemd utility library (deprecated) c libsystemd-id128-0 - systemd 128 bit ID utility library (deprecated) c libt1-5 - Type 1 font rasterizer library - runtime c libtar0 - C library for manipulating tar archives c libtelepathy-logger3 - Telepathy logger service - utility library c libtk8.6 - Tk toolkit for Tcl and X11 v8.6 - run-time files c libtotem-plparser17 - Totem Playlist Parser library - runtime files c libts-0.0-0 - touch screen library c libturbojpeg1 - TurboJPEG runtime library - SIMD optimized c libumfpack5.4.0 - sparse LU factorization library c libupower-glib2 - abstraction for power management - shared library c libusageenvironment1 - multimedia RTSP streaming library (UsageEnvironment classes) c libutvideo14.2.1 - Ut Video Codec Suite library c libutvideo15.0.0 - Ut Video Codec Suite library c libutvideo15.0.1 - Ut Video Codec Suite library c libutvideo15.0.2 - Ut Video Codec Suite library c libvidstab0.9 - Video stabilization library. c libvisio-0.0-0 - library for parsing the visio file structure c libvlccore5 - base library for VLC and its modules c libvncclient0 - API to write one's own vnc server - client library c libvncserver0 - API to write one's own vnc server c libvtv0 - GNU vtable verification library (runtime) c libwebp4 - Lossy compression of digital photographic images. c libwpd-0.9-9 - Library for handling WordPerfect documents (shared library) c libwpg-0.2-2 - WordPerfect graphics import/convert library (shared library) c libwps-0.2-2 - Works text file format import filter library (shared library) c libwps-0.3-3 - Works text file format import filter library (shared library) c libwxbase2.8-0 - wxBase library (runtime) - non-GUI support classes of wxWidgets toolkit c libwxgtk2.8-0 - wxWidgets Cross-platform C++ GUI toolkit (GTK+ runtime) c libx264-133 - x264 video coding library c libx264-138 - x264 video coding library c libx264-140 - x264 video coding library c libx264-144 - x264 video coding library c libx265-13 - x264 video coding library. c libx265-21 - x264 video coding library. c libx265-25 - x264 video coding library. c libx265-35 - x265 video coding library c libx265-43 - x265 video coding library c libx265-51 - x265 video coding library c libx265-7 - x264 video coding library. c libxapian22 - Search engine library c libxatracker1 - X acceleration library -- runtime c libzeitgeist-1.0-1 - library to access Zeitgeist - shared library c libzeitgeist-2.0-0 - library to access Zeitgeist - shared library c linux-image-3.10-3-amd64 - Linux 3.10 for 64-bit PCs c linux-image-3.11-1-amd64 - Linux 3.11 for 64-bit PCs c linux-image-3.11-2-amd64 - Linux 3.11 for 64-bit PCs c linux-image-3.12-1-amd64 - Linux 3.12 for 64-bit PCs c linux-image-3.13-1-amd64 - Linux 3.13 for 64-bit PCs c linux-image-3.14-1-amd64 - Linux 3.14 for 64-bit PCs c linux-image-3.14-2-amd64 - Linux 3.14 for 64-bit PCs c linux-image-3.16-1-amd64 - Linux 3.16 for 64-bit PCs c linux-image-3.16-2-amd64 - Linux 3.16 for 64-bit PCs c opera - Fast and secure web browser and Internet suite c packagekit - Provides a package management service c printer-driver-gutenprint - printer drivers for CUPS c python-pygments - syntax highlighting package written in Python c python3-gi - Python 3 bindings for gobject-introspection libraries c python3.3 - Interactive high-level object-oriented language (version 3.3) c python3.3-minimal - Minimal subset of the Python language (version 3.3) c samba - SMB/CIFS file, print, and login server for Unix c samba-dsdb-modules - Samba Directory Services Database c sysvinit-core - System-V-like init utilities c tcl8.5 - Tcl (the Tool Command Language) v8.5 - shell c tix - Tix library for Tk -- runtime package c tk8.5 - Tk toolkit for Tcl and X11, v8.5 - windowing shell c tk8.6 - Tk toolkit for Tcl and X11 v8.6 - windowing shell c tsconf - touch screen library common files c zeitgeist-core - event logging framework - engine c zeitgeist-datahub - event logging framework - passive logging daemon
root@debian:/home/belette# aptitude purge ~c Package libavresample-ffmpeg2 is not installed, so it will not be removed Package liblwres80 is not installed, so it will not be removed Package libept1.4.12 is not installed, so it will not be removed Package linux-image-3.14-1-amd64 is not installed, so it will not be removed Package libboost-date-time1.55.0 is not installed, so it will not be removed Package libtotem-plparser17 is not installed, so it will not be removed Package libumfpack5.4.0 is not installed, so it will not be removed Package libpangomm-1.4-1 is not installed, so it will not be removed Package linux-image-3.16-2-amd64 is not installed, so it will not be removed Package libavformat54 is not installed, so it will not be removed Package libclutter-gtk-1.0-0 is not installed, so it will not be removed Package libcdr-0.0-0 is not installed, so it will not be removed Package apg is not installed, so it will not be removed Package libodfgen-0.0-0 is not installed, so it will not be removed Package hplip is not installed, so it will not be removed Package libxapian22 is not installed, so it will not be removed Package libavcodec-ffmpeg56 is not installed, so it will not be removed Package libgeoclue0 is not installed, so it will not be removed Package libtk8.6 is not installed, so it will not be removed Package liborcus-0.10-0 is not installed, so it will not be removed Package libmediaart-1.0-0 is not installed, so it will not be removed Package libgdata13 is not installed, so it will not be removed Package libavfilter3 is not installed, so it will not be removed Package libglew1.7 is not installed, so it will not be removed Package libsoxr0 is not installed, so it will not be removed Package libcogl-pango12 is not installed, so it will not be removed Package libopenvg1-mesa is not installed, so it will not be removed Package libidl0 is not installed, so it will not be removed Package libisccfg82 is not installed, so it will not be removed Package libcogl12 is not installed, so it will not be removed Package libaio1 is not installed, so it will not be removed Package linux-image-3.12-1-amd64 is not installed, so it will not be removed Package zeitgeist-core is not installed, so it will not be removed Package libgtkmm-2.4-1c2a is not installed, so it will not be removed Package libmbim-glib0 is not installed, so it will not be removed Package libreadline5 is not installed, so it will not be removed Package linux-image-3.14-2-amd64 is not installed, so it will not be removed Package libx265-13 is not installed, so it will not be removed Package libbind9-80 is not installed, so it will not be removed Package librygel-server-2.4-2 is not installed, so it will not be removed Package libx265-21 is not installed, so it will not be removed Package liblognorm1 is not installed, so it will not be removed Package libx265-25 is not installed, so it will not be removed Package tix is not installed, so it will not be removed Package libfreehand-0.0-0 is not installed, so it will not be removed Package libcheese7 is not installed, so it will not be removed Package libx265-35 is not installed, so it will not be removed Package libjim0.74 is not installed, so it will not be removed Package libcwidget3 is not installed, so it will not be removed Package libjim0.75 is not installed, so it will not be removed Package libturbojpeg1 is not installed, so it will not be removed Package libsane-hpaio is not installed, so it will not be removed Package libcmis-0.5-5 is not installed, so it will not be removed Package libx265-43 is not installed, so it will not be removed Package python3.3 is not installed, so it will not be removed Package libcairomm-1.0-1 is not installed, so it will not be removed Package librygel-renderer-2.4-2 is not installed, so it will not be removed Package libicu48 is not installed, so it will not be removed Package libx265-51 is not installed, so it will not be removed Package libass4 is not installed, so it will not be removed Package libvlccore5 is not installed, so it will not be removed Package libavcodec-extra-56 is not installed, so it will not be removed Package libfreerdp1 is not installed, so it will not be removed Package libutvideo14.2.1 is not installed, so it will not be removed Package libboost-date-time1.54.0 is not installed, so it will not be removed Package libboost-system1.54.0 is not installed, so it will not be removed Package libdvbpsi9 is not installed, so it will not be removed Package libqt4-svg is not installed, so it will not be removed Package libmspub-0.0-0 is not installed, so it will not be removed Package libroar-compat2 is not installed, so it will not be removed Package libwebp4 is not installed, so it will not be removed Package gimp is not installed, so it will not be removed Package libllvm3.2 is not installed, so it will not be removed Package libllvm3.3 is not installed, so it will not be removed Package libllvm3.4 is not installed, so it will not be removed Package libsubunit0 is not installed, so it will not be removed Package libwpg-0.2-2 is not installed, so it will not be removed Package libcolorhug1 is not installed, so it will not be removed Package libfolks25 is not installed, so it will not be removed Package libusageenvironment1 is not installed, so it will not be removed Package libart-2.0-2 is not installed, so it will not be removed Package libgphoto2-port0 is not installed, so it will not be removed Package sysvinit-core is not installed, so it will not be removed Package coinor-libcbc3 is not installed, so it will not be removed Package libglibmm-2.4-1c2a is not installed, so it will not be removed Package liborcus-0.6-0 is not installed, so it will not be removed Package samba is not installed, so it will not be removed Package libts-0.0-0 is not installed, so it will not be removed Package libsystemd-daemon0 is not installed, so it will not be removed Package libopencv-legacy2.4 is not installed, so it will not be removed Package libboost-date-time1.49.0 is not installed, so it will not be removed Package libmwaw-0.2-2 is not installed, so it will not be removed Package libvisio-0.0-0 is not installed, so it will not be removed Package libgroupsock1 is not installed, so it will not be removed Package libsigc++-2.0-0c2a is not installed, so it will not be removed Package libcmis-0.4-4 is not installed, so it will not be removed Package libgjs0c is not installed, so it will not be removed Package libwps-0.3-3 is not installed, so it will not be removed Package libnuma1 is not installed, so it will not be removed Package coinor-libcoinutils3 is not installed, so it will not be removed Package libhdb9-heimdal is not installed, so it will not be removed Package libprocps1 is not installed, so it will not be removed Package libmetacity-private0a is not installed, so it will not be removed Package libprocps3 is not installed, so it will not be removed Package libsystemd-id128-0 is not installed, so it will not be removed Package libmission-control-plugins0 is not installed, so it will not be removed Package libpoppler37 is not installed, so it will not be removed Package libslp1 is not installed, so it will not be removed Package libx265-7 is not installed, so it will not be removed Package libpoppler44 is not installed, so it will not be removed Package gnome-control-center is not installed, so it will not be removed Package libcaribou0 is not installed, so it will not be removed Package linux-image-3.10-3-amd64 is not installed, so it will not be removed Package libelfg0 is not installed, so it will not be removed Package libgutenprint2 is not installed, so it will not be removed Package docutils-common is not installed, so it will not be removed Package libfolks-eds25 is not installed, so it will not be removed Package packagekit is not installed, so it will not be removed Package libtelepathy-logger3 is not installed, so it will not be removed Package gsfonts-x11 is not installed, so it will not be removed Package libharfbuzz0a is not installed, so it will not be removed Package libcolamd2.7.1 is not installed, so it will not be removed Package libproxy0 is not installed, so it will not be removed Package librtmp0 is not installed, so it will not be removed Package samba-dsdb-modules is not installed, so it will not be removed Package libroar2 is not installed, so it will not be removed Package libclucene-core1 is not installed, so it will not be removed Package libquicktime2 is not installed, so it will not be removed Package zeitgeist-datahub is not installed, so it will not be removed Package libclutter-1.0-0 is not installed, so it will not be removed Package libqpdf13 is not installed, so it will not be removed Package coinor-libcgl1 is not installed, so it will not be removed Package librygel-core-2.4-2 is not installed, so it will not be removed Package libopencv-features2d2.4 is not installed, so it will not be removed Package libopencv-objdetect2.4 is not installed, so it will not be removed Package libtar0 is not installed, so it will not be removed Package libspice-server1 is not installed, so it will not be removed Package libwxbase2.8-0 is not installed, so it will not be removed Package libdns88 is not installed, so it will not be removed Package libfftw3-long3 is not installed, so it will not be removed Package gimp-data is not installed, so it will not be removed Package libclucene-contribs1 is not installed, so it will not be removed Package libmwaw-0.1-1 is not installed, so it will not be removed Package libparted0debian1 is not installed, so it will not be removed Package libdns99 is not installed, so it will not be removed Package linux-image-3.13-1-amd64 is not installed, so it will not be removed Package printer-driver-gutenprint is not installed, so it will not be removed Package libxatracker1 is not installed, so it will not be removed Package libcmis-0.3-3 is not installed, so it will not be removed Package libwps-0.2-2 is not installed, so it will not be removed Package libgtkmm-3.0-1 is not installed, so it will not be removed Package libwpd-0.9-9 is not installed, so it will not be removed Package libgoa-1.0-0 is not installed, so it will not be removed Package libvtv0 is not installed, so it will not be removed Package libzeitgeist-1.0-1 is not installed, so it will not be removed Package libvncserver0 is not installed, so it will not be removed Package libdnet is not installed, so it will not be removed Package libmagickwand5 is not installed, so it will not be removed Package libjim0debian2 is not installed, so it will not be removed Package libkdc2-heimdal is not installed, so it will not be removed Package libdirac-encoder0 is not installed, so it will not be removed Package coinor-libosi1 is not installed, so it will not be removed Package coinor-libcoinmp1 is not installed, so it will not be removed Package libcheese-gtk23 is not installed, so it will not be removed Package libdee-1.0-4 is not installed, so it will not be removed Package linux-image-3.11-1-amd64 is not installed, so it will not be removed Package libt1-5 is not installed, so it will not be removed Package libfolks-telepathy25 is not installed, so it will not be removed Package libgltf-0.0-0 is not installed, so it will not be removed Package libatkmm-1.6-1 is not installed, so it will not be removed Package libqmi-glib0 is not installed, so it will not be removed Package foomatic-filters is not installed, so it will not be removed Package libgphoto2-2 is not installed, so it will not be removed Package python-pygments is not installed, so it will not be removed Package python3-gi is not installed, so it will not be removed Package libopencv-highgui2.4 is not installed, so it will not be removed Package libzeitgeist-2.0-0 is not installed, so it will not be removed Package libclutter-gst-2.0-0 is not installed, so it will not be removed Package tk8.5 is not installed, so it will not be removed Package tk8.6 is not installed, so it will not be removed Package linux-image-3.11-2-amd64 is not installed, so it will not be removed Package tcl8.5 is not installed, so it will not be removed Package libutvideo15.0.0 is not installed, so it will not be removed Package libutvideo15.0.1 is not installed, so it will not be removed Package libutvideo15.0.2 is not installed, so it will not be removed Package opera is not installed, so it will not be removed Package libopencv-calib3d2.4 is not installed, so it will not be removed Package libmutter0 is not installed, so it will not be removed Package libmetacity-private1 is not installed, so it will not be removed Package libamd2.2.0 is not installed, so it will not be removed Package libmetacity-private2 is not installed, so it will not be removed Package libx264-133 is not installed, so it will not be removed Package libmagickcore5 is not installed, so it will not be removed Package libx264-138 is not installed, so it will not be removed Package libavcodec54 is not installed, so it will not be removed Package liblivemedia15 is not installed, so it will not be removed Package liblivemedia16 is not installed, so it will not be removed Package liblivemedia17 is not installed, so it will not be removed Package libx264-140 is not installed, so it will not be removed Package libx264-144 is not installed, so it will not be removed Package libgnome-media-profiles-3.0-0 is not installed, so it will not be removed Package libboost-python1.54.0 is not installed, so it will not be removed Package liblivemedia26 is not installed, so it will not be removed Package libgssglue1 is not installed, so it will not be removed Package liblivemedia31 is not installed, so it will not be removed Package liblivemedia32 is not installed, so it will not be removed Package liblivemedia33 is not installed, so it will not be removed Package liblivemedia36 is not installed, so it will not be removed Package libabw-0.0-0 is not installed, so it will not be removed Package liblivemedia38 is not installed, so it will not be removed Package libgsoap3 is not installed, so it will not be removed Package libgsoap4 is not installed, so it will not be removed Package libgsoap5 is not installed, so it will not be removed Package libe-book-0.0-0 is not installed, so it will not be removed Package libglib2.0-bin is not installed, so it will not be removed Package python3.3-minimal is not installed, so it will not be removed Package liblivemedia41 is not installed, so it will not be removed Package liblivemedia42 is not installed, so it will not be removed Package libopencv-contrib2.4 is not installed, so it will not be removed Package tsconf is not installed, so it will not be removed Package liborcus-0.8-0 is not installed, so it will not be removed Package linux-image-3.16-1-amd64 is not installed, so it will not be removed Package libetonyek-0.0-0 is not installed, so it will not be removed Package libisccfg-export90 is not installed, so it will not be removed Package libisccc80 is not installed, so it will not be removed Package libisc84 is not installed, so it will not be removed Package libvncclient0 is not installed, so it will not be removed Package libirs-export91 is not installed, so it will not be removed Package liborbit2 is not installed, so it will not be removed Package irqbalance is not installed, so it will not be removed Package libavutil53 is not installed, so it will not be removed Package libupower-glib2 is not installed, so it will not be removed Package libmikmod2 is not installed, so it will not be removed Package libvidstab0.9 is not installed, so it will not be removed Package gnome-control-center-data is not installed, so it will not be removed Package libwxgtk2.8-0 is not installed, so it will not be removed Package libavresample-ffmpeg2 is not installed, so it will not be removed Package liblwres80 is not installed, so it will not be removed Package libept1.4.12 is not installed, so it will not be removed Package linux-image-3.14-1-amd64 is not installed, so it will not be removed Package libboost-date-time1.55.0 is not installed, so it will not be removed Package libtotem-plparser17 is not installed, so it will not be removed Package libumfpack5.4.0 is not installed, so it will not be removed Package libpangomm-1.4-1 is not installed, so it will not be removed Package linux-image-3.16-2-amd64 is not installed, so it will not be removed Package libavformat54 is not installed, so it will not be removed Package libclutter-gtk-1.0-0 is not installed, so it will not be removed Package libcdr-0.0-0 is not installed, so it will not be removed Package apg is not installed, so it will not be removed Package libodfgen-0.0-0 is not installed, so it will not be removed Package hplip is not installed, so it will not be removed Package libxapian22 is not installed, so it will not be removed Package libavcodec-ffmpeg56 is not installed, so it will not be removed Package libgeoclue0 is not installed, so it will not be removed Package libtk8.6 is not installed, so it will not be removed Package liborcus-0.10-0 is not installed, so it will not be removed Package libmediaart-1.0-0 is not installed, so it will not be removed Package libgdata13 is not installed, so it will not be removed Package libavfilter3 is not installed, so it will not be removed Package libglew1.7 is not installed, so it will not be removed Package libsoxr0 is not installed, so it will not be removed Package libcogl-pango12 is not installed, so it will not be removed Package libopenvg1-mesa is not installed, so it will not be removed Package libidl0 is not installed, so it will not be removed Package libisccfg82 is not installed, so it will not be removed Package libcogl12 is not installed, so it will not be removed Package libaio1 is not installed, so it will not be removed Package linux-image-3.12-1-amd64 is not installed, so it will not be removed Package zeitgeist-core is not installed, so it will not be removed Package libgtkmm-2.4-1c2a is not installed, so it will not be removed Package libmbim-glib0 is not installed, so it will not be removed Package libreadline5 is not installed, so it will not be removed Package linux-image-3.14-2-amd64 is not installed, so it will not be removed Package libx265-13 is not installed, so it will not be removed Package libbind9-80 is not installed, so it will not be removed Package librygel-server-2.4-2 is not installed, so it will not be removed Package libx265-21 is not installed, so it will not be removed Package liblognorm1 is not installed, so it will not be removed Package libx265-25 is not installed, so it will not be removed Package tix is not installed, so it will not be removed Package libfreehand-0.0-0 is not installed, so it will not be removed Package libcheese7 is not installed, so it will not be removed Package libx265-35 is not installed, so it will not be removed Package libjim0.74 is not installed, so it will not be removed Package libcwidget3 is not installed, so it will not be removed Package libjim0.75 is not installed, so it will not be removed Package libturbojpeg1 is not installed, so it will not be removed Package libsane-hpaio is not installed, so it will not be removed Package libcmis-0.5-5 is not installed, so it will not be removed Package libx265-43 is not installed, so it will not be removed Package python3.3 is not installed, so it will not be removed Package libcairomm-1.0-1 is not installed, so it will not be removed Package librygel-renderer-2.4-2 is not installed, so it will not be removed Package libicu48 is not installed, so it will not be removed Package libx265-51 is not installed, so it will not be removed Package libass4 is not installed, so it will not be removed Package libvlccore5 is not installed, so it will not be removed Package libavcodec-extra-56 is not installed, so it will not be removed Package libfreerdp1 is not installed, so it will not be removed Package libutvideo14.2.1 is not installed, so it will not be removed Package libboost-date-time1.54.0 is not installed, so it will not be removed Package libboost-system1.54.0 is not installed, so it will not be removed Package libdvbpsi9 is not installed, so it will not be removed Package libqt4-svg is not installed, so it will not be removed Package libmspub-0.0-0 is not installed, so it will not be removed Package libroar-compat2 is not installed, so it will not be removed Package libwebp4 is not installed, so it will not be removed Package gimp is not installed, so it will not be removed Package libllvm3.2 is not installed, so it will not be removed Package libllvm3.3 is not installed, so it will not be removed Package libllvm3.4 is not installed, so it will not be removed Package libsubunit0 is not installed, so it will not be removed Package libwpg-0.2-2 is not installed, so it will not be removed Package libcolorhug1 is not installed, so it will not be removed Package libfolks25 is not installed, so it will not be removed Package libusageenvironment1 is not installed, so it will not be removed Package libart-2.0-2 is not installed, so it will not be removed Package libgphoto2-port0 is not installed, so it will not be removed Package sysvinit-core is not installed, so it will not be removed Package coinor-libcbc3 is not installed, so it will not be removed Package libglibmm-2.4-1c2a is not installed, so it will not be removed Package liborcus-0.6-0 is not installed, so it will not be removed Package samba is not installed, so it will not be removed Package libts-0.0-0 is not installed, so it will not be removed Package libsystemd-daemon0 is not installed, so it will not be removed Package libopencv-legacy2.4 is not installed, so it will not be removed Package libboost-date-time1.49.0 is not installed, so it will not be removed Package libmwaw-0.2-2 is not installed, so it will not be removed Package libvisio-0.0-0 is not installed, so it will not be removed Package libgroupsock1 is not installed, so it will not be removed Package libsigc++-2.0-0c2a is not installed, so it will not be removed Package libcmis-0.4-4 is not installed, so it will not be removed Package libgjs0c is not installed, so it will not be removed Package libwps-0.3-3 is not installed, so it will not be removed Package libnuma1 is not installed, so it will not be removed Package coinor-libcoinutils3 is not installed, so it will not be removed Package libhdb9-heimdal is not installed, so it will not be removed Package libprocps1 is not installed, so it will not be removed Package libmetacity-private0a is not installed, so it will not be removed Package libprocps3 is not installed, so it will not be removed Package libsystemd-id128-0 is not installed, so it will not be removed Package libmission-control-plugins0 is not installed, so it will not be removed Package libpoppler37 is not installed, so it will not be removed Package libslp1 is not installed, so it will not be removed Package libx265-7 is not installed, so it will not be removed Package libpoppler44 is not installed, so it will not be removed Package gnome-control-center is not installed, so it will not be removed Package libcaribou0 is not installed, so it will not be removed Package linux-image-3.10-3-amd64 is not installed, so it will not be removed Package libelfg0 is not installed, so it will not be removed Package libgutenprint2 is not installed, so it will not be removed Package docutils-common is not installed, so it will not be removed Package libfolks-eds25 is not installed, so it will not be removed Package packagekit is not installed, so it will not be removed Package libtelepathy-logger3 is not installed, so it will not be removed Package gsfonts-x11 is not installed, so it will not be removed Package libharfbuzz0a is not installed, so it will not be removed Package libcolamd2.7.1 is not installed, so it will not be removed Package libproxy0 is not installed, so it will not be removed Package librtmp0 is not installed, so it will not be removed Package samba-dsdb-modules is not installed, so it will not be removed Package libroar2 is not installed, so it will not be removed Package libclucene-core1 is not installed, so it will not be removed Package libquicktime2 is not installed, so it will not be removed Package zeitgeist-datahub is not installed, so it will not be removed Package libclutter-1.0-0 is not installed, so it will not be removed Package libqpdf13 is not installed, so it will not be removed Package coinor-libcgl1 is not installed, so it will not be removed Package librygel-core-2.4-2 is not installed, so it will not be removed Package libopencv-features2d2.4 is not installed, so it will not be removed Package libopencv-objdetect2.4 is not installed, so it will not be removed Package libtar0 is not installed, so it will not be removed Package libspice-server1 is not installed, so it will not be removed Package libwxbase2.8-0 is not installed, so it will not be removed Package libdns88 is not installed, so it will not be removed Package libfftw3-long3 is not installed, so it will not be removed Package gimp-data is not installed, so it will not be removed Package libclucene-contribs1 is not installed, so it will not be removed Package libmwaw-0.1-1 is not installed, so it will not be removed Package libparted0debian1 is not installed, so it will not be removed Package libdns99 is not installed, so it will not be removed Package linux-image-3.13-1-amd64 is not installed, so it will not be removed Package printer-driver-gutenprint is not installed, so it will not be removed Package libxatracker1 is not installed, so it will not be removed Package libcmis-0.3-3 is not installed, so it will not be removed Package libwps-0.2-2 is not installed, so it will not be removed Package libgtkmm-3.0-1 is not installed, so it will not be removed Package libwpd-0.9-9 is not installed, so it will not be removed Package libgoa-1.0-0 is not installed, so it will not be removed Package libvtv0 is not installed, so it will not be removed Package libzeitgeist-1.0-1 is not installed, so it will not be removed Package libvncserver0 is not installed, so it will not be removed Package libdnet is not installed, so it will not be removed Package libmagickwand5 is not installed, so it will not be removed Package libjim0debian2 is not installed, so it will not be removed Package libkdc2-heimdal is not installed, so it will not be removed Package libdirac-encoder0 is not installed, so it will not be removed Package coinor-libosi1 is not installed, so it will not be removed Package coinor-libcoinmp1 is not installed, so it will not be removed Package libcheese-gtk23 is not installed, so it will not be removed Package libdee-1.0-4 is not installed, so it will not be removed Package linux-image-3.11-1-amd64 is not installed, so it will not be removed Package libt1-5 is not installed, so it will not be removed Package libfolks-telepathy25 is not installed, so it will not be removed Package libgltf-0.0-0 is not installed, so it will not be removed Package libatkmm-1.6-1 is not installed, so it will not be removed Package libqmi-glib0 is not installed, so it will not be removed Package foomatic-filters is not installed, so it will not be removed Package libgphoto2-2 is not installed, so it will not be removed Package python-pygments is not installed, so it will not be removed Package python3-gi is not installed, so it will not be removed Package libopencv-highgui2.4 is not installed, so it will not be removed Package libzeitgeist-2.0-0 is not installed, so it will not be removed Package libclutter-gst-2.0-0 is not installed, so it will not be removed Package tk8.5 is not installed, so it will not be removed Package tk8.6 is not installed, so it will not be removed Package linux-image-3.11-2-amd64 is not installed, so it will not be removed Package tcl8.5 is not installed, so it will not be removed Package libutvideo15.0.0 is not installed, so it will not be removed Package libutvideo15.0.1 is not installed, so it will not be removed Package libutvideo15.0.2 is not installed, so it will not be removed Package opera is not installed, so it will not be removed Package libopencv-calib3d2.4 is not installed, so it will not be removed Package libmutter0 is not installed, so it will not be removed Package libmetacity-private1 is not installed, so it will not be removed Package libamd2.2.0 is not installed, so it will not be removed Package libmetacity-private2 is not installed, so it will not be removed Package libx264-133 is not installed, so it will not be removed Package libmagickcore5 is not installed, so it will not be removed Package libx264-138 is not installed, so it will not be removed Package libavcodec54 is not installed, so it will not be removed Package liblivemedia15 is not installed, so it will not be removed Package liblivemedia16 is not installed, so it will not be removed Package liblivemedia17 is not installed, so it will not be removed Package libx264-140 is not installed, so it will not be removed Package libx264-144 is not installed, so it will not be removed Package libgnome-media-profiles-3.0-0 is not installed, so it will not be removed Package libboost-python1.54.0 is not installed, so it will not be removed Package liblivemedia26 is not installed, so it will not be removed Package libgssglue1 is not installed, so it will not be removed Package liblivemedia31 is not installed, so it will not be removed Package liblivemedia32 is not installed, so it will not be removed Package liblivemedia33 is not installed, so it will not be removed Package liblivemedia36 is not installed, so it will not be removed Package libabw-0.0-0 is not installed, so it will not be removed Package liblivemedia38 is not installed, so it will not be removed Package libgsoap3 is not installed, so it will not be removed Package libgsoap4 is not installed, so it will not be removed Package libgsoap5 is not installed, so it will not be removed Package libe-book-0.0-0 is not installed, so it will not be removed Package libglib2.0-bin is not installed, so it will not be removed Package python3.3-minimal is not installed, so it will not be removed Package liblivemedia41 is not installed, so it will not be removed Package liblivemedia42 is not installed, so it will not be removed Package libopencv-contrib2.4 is not installed, so it will not be removed Package tsconf is not installed, so it will not be removed Package liborcus-0.8-0 is not installed, so it will not be removed Package linux-image-3.16-1-amd64 is not installed, so it will not be removed Package libetonyek-0.0-0 is not installed, so it will not be removed Package libisccfg-export90 is not installed, so it will not be removed Package libisccc80 is not installed, so it will not be removed Package libisc84 is not installed, so it will not be removed Package libvncclient0 is not installed, so it will not be removed Package libirs-export91 is not installed, so it will not be removed Package liborbit2 is not installed, so it will not be removed Package irqbalance is not installed, so it will not be removed Package libavutil53 is not installed, so it will not be removed Package libupower-glib2 is not installed, so it will not be removed Package libmikmod2 is not installed, so it will not be removed Package libvidstab0.9 is not installed, so it will not be removed Package gnome-control-center-data is not installed, so it will not be removed Package libwxgtk2.8-0 is not installed, so it will not be removed The following packages will be REMOVED: apg{p} coinor-libcbc3{p} coinor-libcgl1{p} coinor-libcoinmp1{p} coinor-libcoinutils3{p} coinor-libosi1{p} docutils-common{p} foomatic-filters{p} gimp{p} gimp-data{p} gnome-control-center{p} gnome-control-center-data{p} gsfonts-x11{p} hplip{p} irqbalance{p} libabw-0.0-0{p} libaio1{p} libamd2.2.0{p} libart-2.0-2{p} libass4{p} libatkmm-1.6-1{p} libavcodec-extra-56{p} libavcodec-ffmpeg56{p} libavcodec54{p} libavfilter3{p} libavformat54{p} libavresample-ffmpeg2{p} libavutil53{p} libbind9-80{p} libboost-date-time1.49.0{p} libboost-date-time1.54.0{p} libboost-date-time1.55.0{p} libboost-python1.54.0{p} libboost-system1.54.0{p} libcairomm-1.0-1{p} libcaribou0{p} libcdr-0.0-0{p} libcheese-gtk23{p} libcheese7{p} libclucene-contribs1{p} libclucene-core1{p} libclutter-1.0-0{p} libclutter-gst-2.0-0{p} libclutter-gtk-1.0-0{p} libcmis-0.3-3{p} libcmis-0.4-4{p} libcmis-0.5-5{p} libcogl-pango12{p} libcogl12{p} libcolamd2.7.1{p} libcolorhug1{p} libcwidget3{p} libdee-1.0-4{p} libdirac-encoder0{p} libdnet{p} libdns88{p} libdns99{p} libdvbpsi9{p} libe-book-0.0-0{p} libelfg0{p} libept1.4.12{p} libetonyek-0.0-0{p} libfftw3-long3{p} libfolks-eds25{p} libfolks-telepathy25{p} libfolks25{p} libfreehand-0.0-0{p} libfreerdp1{p} libgdata13{p} libgeoclue0{p} libgjs0c{p} libglew1.7{p} libglib2.0-bin{p} libglibmm-2.4-1c2a{p} libgltf-0.0-0{p} libgnome-media-profiles-3.0-0{p} libgoa-1.0-0{p} libgphoto2-2{p} libgphoto2-port0{p} libgroupsock1{p} libgsoap3{p} libgsoap4{p} libgsoap5{p} libgssglue1{p} libgtkmm-2.4-1c2a{p} libgtkmm-3.0-1{p} libgutenprint2{p} libharfbuzz0a{p} libhdb9-heimdal{p} libicu48{p} libidl0{p} libirs-export91{p} libisc84{p} libisccc80{p} libisccfg-export90{p} libisccfg82{p} libjim0.74{p} libjim0.75{p} libjim0debian2{p} libkdc2-heimdal{p} liblivemedia15{p} liblivemedia16{p} liblivemedia17{p} liblivemedia26{p} liblivemedia31{p} liblivemedia32{p} liblivemedia33{p} liblivemedia36{p} liblivemedia38{p} liblivemedia41{p} liblivemedia42{p} libllvm3.2{p} libllvm3.3{p} libllvm3.4{p} liblognorm1{p} liblwres80{p} libmagickcore5{p} libmagickwand5{p} libmbim-glib0{p} libmediaart-1.0-0{p} libmetacity-private0a{p} libmetacity-private1{p} libmetacity-private2{p} libmikmod2{p} libmission-control-plugins0{p} libmspub-0.0-0{p} libmutter0{p} libmwaw-0.1-1{p} libmwaw-0.2-2{p} libnuma1{p} libodfgen-0.0-0{p} libopencv-calib3d2.4{p} libopencv-contrib2.4{p} libopencv-features2d2.4{p} libopencv-highgui2.4{p} libopencv-legacy2.4{p} libopencv-objdetect2.4{p} libopenvg1-mesa{p} liborbit2{p} liborcus-0.10-0{p} liborcus-0.6-0{p} liborcus-0.8-0{p} libpangomm-1.4-1{p} libparted0debian1{p} libpoppler37{p} libpoppler44{p} libprocps1{p} libprocps3{p} libproxy0{p} libqmi-glib0{p} libqpdf13{p} libqt4-svg{p} libquicktime2{p} libreadline5{p} libroar-compat2{p} libroar2{p} librtmp0{p} librygel-core-2.4-2{p} librygel-renderer-2.4-2{p} librygel-server-2.4-2{p} libsane-hpaio{p} libsigc++-2.0-0c2a{p} libslp1{p} libsoxr0{p} libspice-server1{p} libsubunit0{p} libsystemd-daemon0{p} libsystemd-id128-0{p} libt1-5{p} libtar0{p} libtelepathy-logger3{p} libtk8.6{p} libtotem-plparser17{p} libts-0.0-0{p} libturbojpeg1{p} libumfpack5.4.0{p} libupower-glib2{p} libusageenvironment1{p} libutvideo14.2.1{p} libutvideo15.0.0{p} libutvideo15.0.1{p} libutvideo15.0.2{p} libvidstab0.9{p} libvisio-0.0-0{p} libvlccore5{p} libvncclient0{p} libvncserver0{p} libvtv0{p} libwebp4{p} libwpd-0.9-9{p} libwpg-0.2-2{p} libwps-0.2-2{p} libwps-0.3-3{p} libwxbase2.8-0{p} libwxgtk2.8-0{p} libx264-133{p} libx264-138{p} libx264-140{p} libx264-144{p} libx265-13{p} libx265-21{p} libx265-25{p} libx265-35{p} libx265-43{p} libx265-51{p} libx265-7{p} libxapian22{p} libxatracker1{p} libzeitgeist-1.0-1{p} libzeitgeist-2.0-0{p} linux-image-3.10-3-amd64{p} linux-image-3.11-1-amd64{p} linux-image-3.11-2-amd64{p} linux-image-3.12-1-amd64{p} linux-image-3.13-1-amd64{p} linux-image-3.14-1-amd64{p} linux-image-3.14-2-amd64{p} linux-image-3.16-1-amd64{p} linux-image-3.16-2-amd64{p} opera{p} packagekit{p} printer-driver-gutenprint{p} python-pygments{p} python3-gi{p} python3.3{p} python3.3-minimal{p} samba{p} samba-dsdb-modules{p} sysvinit-core{p} tcl8.5{p} tix{p} tk8.5{p} tk8.6{p} tsconf{p} zeitgeist-core{p} zeitgeist-datahub{p} 0 packages upgraded, 0 newly installed, 236 to remove and 74 not upgraded. Need to get 0 B of archives. After unpacking 0 B will be used. Do you want to continue? [Y/n/?]
[quote=“BelZéButh”][quote=“Gargamel”][code]Remove the following packages:
  1. libreoffice
  3. libvlc5
  4. libvlccore7
  5. libvlccore8 [/code][/quote][/quote]
root@debian:/home/belette# dpkg -l |grep libreoffice ii libreoffice 1:5.0.1-1 amd64 office productivity suite (metapackage) ii libreoffice-avmedia-backend-vlc 1:5.0.1-1 amd64 VLC backend for LibreOffice ii libreoffice-base 1:5.0.1-1 amd64 office productivity suite -- database ii libreoffice-base-core 1:5.0.1-1 amd64 office productivity suite -- shared library ii libreoffice-base-drivers 1:5.0.1-1 amd64 Database connectivity drivers for LibreOffice ii libreoffice-calc 1:5.0.1-1 amd64 office productivity suite -- spreadsheet ii libreoffice-common 1:5.0.1-1 all office productivity suite -- arch-independent files ii libreoffice-core 1:5.0.1-1 amd64 office productivity suite -- arch-dependent files ii libreoffice-draw 1:5.0.1-1 amd64 office productivity suite -- drawing ii libreoffice-gtk 1:5.0.1-1 amd64 office productivity suite -- GTK+ integration ii libreoffice-help-en-gb 1:5.0.1-1 all office productivity suite -- English_british help ii libreoffice-help-en-us 1:5.0.1-1 all office productivity suite -- English_american help ii libreoffice-impress 1:5.0.1-1 amd64 office productivity suite -- presentation ii libreoffice-java-common 1:5.0.1-1 all office productivity suite -- arch-independent Java support files ii libreoffice-l10n-en-gb 1:5.0.1-1 all office productivity suite -- English_british language package ii libreoffice-math 1:5.0.1-1 amd64 office productivity suite -- equation editor ii libreoffice-report-builder-bin 1:5.0.1-1 amd64 LibreOffice component for building database reports -- libraries ii libreoffice-sdbc-firebird 1:5.0.1-1 amd64 Firebird SDBC driver for LibreOffice ii libreoffice-sdbc-hsqldb 1:5.0.1-1 amd64 HSQLDB SDBC driver for LibreOffice ii libreoffice-style-galaxy 1:5.0.1-1 all office productivity suite -- Galaxy (Default) symbol style ii libreoffice-style-tango 1:5.0.1-1 all office productivity suite -- Tango symbol style ii libreoffice-writer 1:5.0.1-1 amd64 office productivity suite -- word processor root@debian:/home/belette#
root@debian:/home/belette# dpkg -l |grep libvl ii libvlc5 1:2.2.1-dmo10 amd64 multimedia player and streamer library rc libvlccore5 2.0.8-1+b2 amd64 base library for VLC and its modules ii libvlccore7 1:2.1.5-dmo2 amd64 base library for VLC and its modules ii libvlccore8 1:2.2.1-dmo10 amd64 base library for VLC and its modules root@debian:/home/belette#
Je reste admiratif sur ta façon de faire, ce travail de recherche et diagnostic m’épate. J’essaie de comprendre ta façon de faire mais pas c’est pas évident :slightly_smiling: :blush:
[quote=“Gargamel”][code]root@debian:/home/belette# aptitude purge ~c
(…)[/code][/quote]
Tu peux valider, sans souci, je viens d’en faire de même. (nettoyage)
[code][19:37:50] ~ # aptitude purge ~c
Le paquet libgpgme++2 n’est pas installé, il ne sera donc pas enlevé.
Le paquet libavformat53 n’est pas installé, il ne sera donc pas enlevé.
Le paquet coinor-libcbc3 n’est pas installé, il ne sera donc pas enlevé.
Le paquet libindi0b n’est pas installé, il ne sera donc pas enlevé.
Le paquet libkf5balooxapian1 n’est pas installé, il ne sera donc pas enlevé.
Le paquet coinor-libcoinutils3 n’est pas installé, il ne sera donc pas enlevé.
Le paquet coinor-libcgl1 n’est pas installé, il ne sera donc pas enlevé.
Le paquet libirs-export91 n’est pas installé, il ne sera donc pas enlevé.
Le paquet libavutil51 n’est pas installé, il ne sera donc pas enlevé.
coinor-libcbc3{p} coinor-libcgl1{p} coinor-libcoinmp1{p} coinor-libcoinutils3{p} coinor-libosi1{p} debtags{p} libavcodec53{p} libavformat53{p} libavutil51{p} libgltf-0.0-0{p}
libgpgme++2{p} libilmbase6{p} libindi0b{p} libirs-export91{p} libisccfg-export90{p} libkeduvocdocument4{p} libkf5baloo1{p} libkf5balooxapian1{p} libmsn0.3{p} libmusicbrainz3-6{p}
libokularcore5{p} libopencv-calib3d2.3{p} libopencv-contrib2.3{p} libopencv-features2d2.3{p} libopencv-highgui2.3{p} libopencv-legacy2.3{p} libopencv-ml2.3{p} libopencv-objdetect2.3{p}
libopenexr6{p} liborcus-0.10-0{p} libswscale2{p}
0 paquets mis à jour, 0 nouvellement installés, 31 à enlever et 24 non mis à jour.
Il est nécessaire de télécharger 0 o d’archives. Après dépaquetage, 0 o seront utilisés.
Voulez-vous continuer ? [Y/n/?] y
(Lecture de la base de données… 261966 fichiers et répertoires déjà installés.)
Suppression de coinor-libcbc3 (2.8.12-1) …
Purge des fichiers de configuration de coinor-libcbc3 (2.8.12-1) …
Suppression de coinor-libcgl1 (0.58.9-1) …
Suppression de coinor-libosi1 (0.106.9-1) …
Purge des fichiers de configuration de coinor-libosi1 (0.106.9-1) …
Suppression de debtags (2.0+nmu1) …
Suppression de libopencv-objdetect2.3 (2.3.1-11) …
Purge des fichiers de configuration de libopencv-objdetect2.3 (2.3.1-11) …
Suppression de libopenexr6:amd64 (1.6.1-8) …
Purge des fichiers de configuration de libopenexr6:amd64 (1.6.1-8) …
Suppression de liborcus-0.10-0 (0.9.2-1) …
Purge des fichiers de configuration de liborcus-0.10-0 (0.9.2-1) …
Suppression de libswscale2:amd64 (6:0.8.17-1) …
Purge des fichiers de configuration de libswscale2:amd64 (6:0.8.17-1) …
[19:41:06] ~ #[/code]
[quote=“Gargamel”][code]root@debian:/home/belette# dpkg -l |grep libvl
root@debian:/home/belette#[/code]
Ici, la situation va devenir intéressante, quatre refus maximum.
Est-ce de … l’amour, de l’art ou du cochon … :laughing:
* edit *
[code]root@debian:/home/belette# aptitude -s remove --purge libvlc5 libvlccore7 libvlccore8
0 packages upgraded, 0 newly installed, 3 to remove and 74 not upgraded.
Need to get 0 B of archives. After unpacking 2,208 kB will be freed.
vlc-plugin-notify : Depends: libvlccore8 but it is not going to be installed.
vlc-nox : Depends: libvlc5 but it is not going to be installed.
libreoffice-avmedia-backend-vlc : Depends: libvlc5 (>= 2.0.8) but it is not going to be installed.
vlc : Depends: libvlccore8 but it is not going to be installed.
  1. libreoffice
  3. vlc
  4. vlc-nox
  5. vlc-plugin-notify
  1. libreoffice-avmedia-backend-vlc
  2. vlc
  3. vlc-nox
  4. vlc-plugin-notify
    Install the following packages:
  5. libreoffice-avmedia-backend-gstreamer [1:5.0.1-1 (testing, unstable)]
  1. libvlc5 [1:2.2.1-dmo10 (now)]
  2. libvlccore8 [1:2.2.1-dmo10 (now)]
  1. libproxy1
  2. libproxy-tools [0.4.11-4.2 (testing, unstable)]
  3. libproxy1v5 [0.4.11-4.2 (testing, unstable)]
    Upgrade the following packages:
  4. glib-networking [2.44.0-2 (now) -> 2.44.0-2+b1 (testing, unstable)]
  5. glib-networking-services [2.44.0-2 (now) -> 2.44.0-2+b1 (testing, unstable)]
    Downgrade the following packages:
  6. libvlc5 [1:2.2.1-dmo10 (now) -> 2.2.1-3 (testing, unstable)]
  7. libvlccore8 [1:2.2.1-dmo10 (now) -> 2.2.1-3 (testing, unstable)]
  8. vlc-data [1:2.2.1-dmo10 (now) -> 2.2.1-3 (testing, unstable)]
The following actions will resolve these dependencies:
  1.   adwaita-icon-theme
  2.   alacarte
  3.   banshee
  4.   banshee-extension-duplicatesongdetector
  5.   banshee-extension-lyrics
  6.   banshee-extensions-common
  7.   brasero
  8.   default-jre
  9.   dleyna-server
  10.  evince
  11.  evince-gtk
  12.  exfalso
  13.  gcr
  14.  gir1.2-gtk-3.0
  15.  gir1.2-gtksource-3.0
  16.  gir1.2-nmgtk-1.0
  17.  gir1.2-panelapplet-4.0
  18.  gir1.2-soup-2.4
  19.  gir1.2-webkit-3.0
  20.  glib-networking
  21.  glib-networking-services
  22.  gnome-applets
  23.  gnome-bluetooth
  24.  gnome-flashback
  25.  gnome-icon-theme
  26.  gnome-icon-theme-symbolic
  27.  gnome-keyring
  28.  gnome-media
  29.  gnome-panel
  30.  gnome-power-manager
  31.  gnome-screensaver
  32.  gnome-session-bin
  33.  gnome-session-fallback
  34.  gnome-session-flashback
  35.  gnome-settings-daemon
  36.  gnome-system-monitor
  37.  gnome-themes-standard
  38.  gnome-themes-standard-data
  39.  gnome-user-guide
  40.  gstreamer0.10-plugins-good
  41.  gstreamer1.0-plugins-good
  42.  indicator-application
  43.  libappindicator3-1
  44.  libatk-wrapper-java-jni
  45.  libbrasero-media3-1
  46.  libcanberra-gtk3-0
  47.  libcanberra-gtk3-module
  48.  libdleyna-connector-dbus-1.0-1
  49.  libdleyna-core-1.0-3
  50.  libebackend-1.2-6
  51.  libebackend-1.2-7
  52.  libebook-1.2-14
  53.  libebook-contacts-1.2-0
  54.  libecal-1.2-15
  55.  libedata-book-1.2-17
  56.  libedata-book-1.2-20
  57.  libedata-cal-1.2-20
  58.  libedataserver-1.2-17
  59.  libedataserver-1.2-18
  60.  libevdocument3-4
  61.  libevview3-3
  62.  libgail-3-0
  63.  libgcr-ui-3-1
  64.  libgeocode-glib0
  65.  libgnome-bluetooth11
  66.  libgnome-bluetooth13
  67.  libgnome-desktop-3-10
  68.  libgnome-desktop-3-2
  69.  libgnomekbd8
  70.  libgssdp-1.0-3
  71.  libgtk-3-0
  72.  libgtk-3-bin
  73.  libgtk-3-common
  74.  libgtkmm-3.0-1v5
  75.  libgtksourceview-3.0-1
  76.  libgucharmap-2-90-7
  77.  libgupnp-1.0-4
  78.  libgupnp-av-1.0-2
  79.  libgweather-3-3
  80.  libgweather-3-6
  81.  libindicator3-7
  82.  libmetacity-private3
  83.  libnautilus-extension1a
  84.  libnm-gtk0
  85.  libpanel-applet-4-0
  86.  libproxy1
  87.  librest-0.7-0
  88.  librest-extras-0.7-0
  89.  librygel-core-2.6-2
  90.  librygel-renderer-2.6-2
  91.  librygel-server-2.6-2
  92.  libsocialweb-service
  93.  libsocialweb0
  94.  libsoup-gnome2.4-1
  95.  libsoup2.4-1
  96.  libtotem-plparser18
  97.  libvte-2.90-9
  98.  libwebkit2gtk-4.0-37
  99.  libwebkitgtk-1.0-0
  100. libwebkitgtk-3.0-0
  101. libwnck-3-0
  102. libyelp0
  103. lightdm
  104. lightdm-gtk-greeter
  105. metacity
  106. mousetweaks
  107. nautilus
  108. network-manager
  109. network-manager-gnome
  110. notification-daemon
  111. openjdk-7-jre
  112. osmo
  113. pinentry-gnome3
  114. policykit-1-gnome
  115. quodlibet
  116. rygel
  117. synaptic
  118. system-config-printer
  119. task-xfce-desktop
  120. xfce4-goodies
  121. xfce4-screenshooter
  122. xfce4-weather-plugin
  123. yelp
  124. zenity
  125. gcj-5-jre [5.2.1-17 (unstable)]
  126. gcj-5-jre-headless [5.2.1-17 (unstable)]
  127. gcj-5-jre-lib [5.2.1-17 (unstable)]
  128. libgcj-common [1:4.9.3-4 (testing, unstable)]
  129. libgcj16 [5.2.1-17 (unstable)]
  130. libgcj16-awt [5.2.1-17 (unstable)]
  131. libproxy-tools [0.4.11-4.2 (testing, unstable)]
  132. libproxy1v5 [0.4.11-4.2 (testing, unstable)]
  133. mate-polkit [1.10.1-1 (testing, unstable)]
  134. mate-polkit-common [1.10.1-1 (testing, unstable)]
  135. libvlc5 [1:2.2.1-dmo10 (now) -> 2.2.1-3 (testing, unstable)]
  136. libvlccore8 [1:2.2.1-dmo10 (now) -> 2.2.1-3 (testing, unstable)]
  137. vlc-data [1:2.2.1-dmo10 (now) -> 2.2.1-3 (testing, unstable)]
    Leave the following dependencies unresolved:
  138. iceweasel recommends gstreamer1.0-plugins-good
  139. libappindicator1 recommends indicator-application (>= 0.2.93)
  140. libsocialweb-client2 recommends libsocialweb0
  141. libsocialweb0 recommends libsocialweb-service
  142. glib-networking-common recommends glib-networking
  143. gnome-flashback recommends gnome-settings-daemon (>= 3.15.4)
  144. libpam-gnome-keyring recommends gnome-keyring
  145. gnome-screensaver recommends gnome-power-manager
  146. libgtk-3-common recommends libgtk-3-0
  147. libatk-wrapper-java recommends libatk-wrapper-java-jni
  148. lightdm-gtk-greeter recommends gnome-themes-standard
  149. lightdm-gtk-greeter recommends gnome-icon-theme-symbolic
  150. metacity recommends gnome-themes-standard
  151. nautilus recommends gnome-icon-theme-symbolic
  152. nautilus-data recommends nautilus
  153. network-manager-gnome recommends gnome-keyring
  154. quodlibet recommends gir1.2-gtksource-3.0
  155. task-desktop recommends task-gnome-desktop | task-xfce-desktop | task-kde-desktop | task-lxde-desktop | task-cinnamon-desktop | task-mate-desktop
  156. task-xfce-desktop recommends xfce4-goodies
  157. task-xfce-desktop recommends quodlibet
  158. task-xfce-desktop recommends evince-gtk | evince
  159. task-xfce-desktop recommends network-manager-gnome
  160. task-xfce-desktop recommends synaptic
  161. task-xfce-desktop recommends system-config-printer
  162. gnome-panel recommends gnome-session-fallback
  163. gnome-panel recommends gnome-icon-theme (>= 2.24)
  164. gnome-panel recommends alacarte
  165. gnome-panel-data recommends gnome-panel
  166. gnome-applets recommends gnome-system-monitor
  167. gnome-applets recommends gnome-media
Accept this solution? [Y/n/q/?] y
The following packages will be DOWNGRADED:
libvlc5 libvlccore8 vlc-data
The following NEW packages will be installed:
gcj-5-jre{a} gcj-5-jre-headless{a} gcj-5-jre-lib{a} libgcj-common{a} libgcj16{a} libgcj16-awt{a} libproxy-tools{a} libproxy1v5{a} mate-polkit{a}
mate-polkit-common{a}
adwaita-icon-theme{a} alacarte{a} banshee{a} banshee-extension-duplicatesongdetector{a} banshee-extension-lyrics{a} banshee-extensions-common{a} brasero{a}
default-jre{a} dleyna-server{a} evince{a} evince-gtk{a} exfalso{a} gcr{a} gir1.2-gtk-3.0{a} gir1.2-gtksource-3.0{a} gir1.2-networkmanager-1.0{pu}
gir1.2-nmgtk-1.0{a} gir1.2-panelapplet-4.0{a} gir1.2-soup-2.4{a} gir1.2-webkit-3.0{a} glib-networking{a} glib-networking-services{a} gnome-applets{a}
gnome-bluetooth{a} gnome-flashback{a} gnome-icon-theme{a} gnome-icon-theme-symbolic{a} gnome-keyring{a} gnome-media{a} gnome-panel{a} gnome-power-manager{a}
gnome-screensaver{a} gnome-session-bin{a} gnome-session-fallback{a} gnome-session-flashback{a} gnome-settings-daemon{a} gnome-system-monitor{a}
gnome-themes-standard{a} gnome-themes-standard-data{a} gnome-user-guide{a} gstreamer0.10-plugins-good{a} gstreamer1.0-plugins-good{a} indicator-application{a}
libappindicator3-1{a} libatk-wrapper-java-jni{a} libboo2.0.9-cil{pu} libboost-thread1.58.0{pu} libbrasero-media3-1{a} libcamel-1.2-49{pu} libcanberra-gtk3-0{a}
libcanberra-gtk3-module{a} libdbus-glib2.0-cil{pu} libdbus2.0-cil{pu} libdleyna-connector-dbus-1.0-1{a} libdleyna-core-1.0-3{a} libebackend-1.2-6{a}
libebackend-1.2-7{a} libebook-1.2-14{a} libebook-contacts-1.2-0{a} libecal-1.2-15{a} libedata-book-1.2-17{a} libedata-book-1.2-20{a} libedata-cal-1.2-20{a}
libedataserver-1.2-17{a} libedataserver-1.2-18{a} libevdocument3-4{a} libevview3-3{a} libgail-3-0{a} libgcr-ui-3-1{a} libgdata2.1-cil{pu} libgee-0.8-2{pu}
libgeocode-glib0{a} libgkeyfile1.0-cil{pu} libgnome-bluetooth11{a} libgnome-bluetooth13{a} libgnome-desktop-3-10{a} libgnome-desktop-3-2{a} libgnomekbd8{a}
libgringotts2{pu} libgssdp-1.0-3{a} libgtk-3-0{a} libgtk-3-bin{a} libgtk-3-common{a} libgtk-sharp-beans-cil{pu} libgtkmm-3.0-1v5{a} libgtksourceview-3.0-1{a}
libgtkspell0{pu} libgucharmap-2-90-7{a} libgudev1.0-cil{pu} libgupnp-1.0-4{a} libgupnp-av-1.0-2{a} libgupnp-dlna-2.0-3{pu} libgweather-3-3{a}
libgweather-3-6{a} libindicator3-7{a} libjavascriptcoregtk-1.0-0{pu} libkarma0{pu} libmcrypt4{pu} libmetacity-private3{a} libmono-addins0.2-cil{pu}
libmono-compilerservices-symbolwriter4.0-cil{pu} libmono-sharpzip4.84-cil{pu} libmono-system-numerics4.0-cil{pu} libmono-zeroconf1.0-cil{pu}
libnautilus-extension1a{a} libnewtonsoft-json5.0-cil{pu} libnm-gtk0{a} libnotify0.4-cil{pu} libpanel-applet-4-0{a} libphonenumber6{pu} libprotobuf9v5{pu}
libproxy1{a} librest-0.7-0{a} librest-extras-0.7-0{a} librygel-core-2.6-2{a} librygel-renderer-2.6-2{a} librygel-server-2.6-2{a} libsocialweb-service{a}
libsocialweb0{a} libsoup-gnome2.4-1{a} libsoup2.4-1{a} libtaglib2.1-cil{pu} libtotem-plparser18{a} libvlccore7 libvte-2.90-9{a} libwebkit2gtk-4.0-37{a}
libwebkitgtk-1.0-0{a} libwebkitgtk-1.0-common{pu} libwebkitgtk-3.0-0{a} libwnck-3-0{a} libyelp0{a} lightdm{a} lightdm-gtk-greeter{a} metacity{a} mousetweaks{a}
nautilus{a} network-manager{a} network-manager-gnome{a} notification-daemon{a} openjdk-7-jre{a} osmo{a} pinentry-gnome3{a} policykit-1-gnome{a} quodlibet{a}
rygel{a} synaptic{a} system-config-printer{a} task-xfce-desktop{a} xfce4-goodies{a} xfce4-screenshooter{a} xfce4-weather-plugin{a} yelp{a} zenity{a}
0 packages upgraded, 10 newly installed, 3 downgraded, 153 to remove and 65 not upgraded.
Need to get 25.8 MB of archives. After unpacking 404 MB will be freed.
mdr :smiley:
De l’art? :033
La commande change. ([mono]-s remove[/mono])
Ici, tu lances cette [mono]simulation[/mono], quatre fois.
La première, tu acceptes.
Deuxième, deux refus.
Troisième, trois refus.
Quatrième, quatre refus.
Des retours séparés, stp.
* edit *
En ce petit matin, lances un [mono]upgrade[/mono], si tu ne relèves aucun souci, [mono]valides[/mono].
Le retour d’[mono]apt-show-versions[/mono] (à installer si besoin) serait intéressant.
Hello,
La suite, la simulation, trés brève, le seul résultat que j’arrive à avoir:
root@debian:/home/belette# aptitude -s remove libebml4 libgroupsock4 libmatroska6 libreoffice libreoffice-avmedia-backend-vlc libvlc5 libvlccore7 libvlccore8 vlc vlc-data vlc-nox vlc-plugin-notify vlc-plugin-pulse The following packages will be REMOVED: libebml4 libgroupsock4 libmatroska6 libreoffice libreoffice-avmedia-backend-vlc libvlc5 libvlccore7 libvlccore8 vlc vlc-data vlc-nox vlc-plugin-notify vlc-plugin-pulse 0 packages upgraded, 0 newly installed, 13 to remove and 85 not upgraded. Need to get 0 B of archives. After unpacking 53.7 MB will be freed. Would download/install/remove packages. root@debian:/home/belette#
root@debian:/home/belette# apt-show-versions -u
bluez-obexd:amd64/testing 5.23-1 upgradeable to 5.33-1
filezilla:amd64/stable 3.9.0.5-1 upgradeable to 3.12.0.2-1
filezilla-common:all/stable 3.9.0.5-1 upgradeable to 3.12.0.2-1
gettext-base:amd64/testing 0.19.4-1 upgradeable to 0.19.5.1-1
glib-networking:amd64/testing 2.44.0-2 upgradeable to 2.44.0-2+b1
glib-networking-services:amd64/testing 2.44.0-2 upgradeable to 2.44.0-2+b1
gnome-applets:amd64/testing 3.8.1-1+b1 upgradeable to 3.16.1-3
gnome-applets-data:all/stable 3.8.1-1 upgradeable to 3.16.1-3
gnome-panel:amd64/testing 3.4.2.1-6 upgradeable to 3.16.1-4
gnome-panel-data:all/testing 3.4.2.1-6 upgradeable to 3.16.1-4
gnupg-agent:amd64/testing 2.0.28-3 upgradeable to 2.1.7-2
gstreamer0.10-plugins-good:amd64/stable 0.10.31-3+nmu4+b1 upgradeable to 0.10.31-3+nmu4+b2
gstreamer1.0-plugins-good:amd64/testing 1.4.5-2+b1 upgradeable to 1.4.5-2+b2
gstreamer1.0-plugins-ugly:amd64/testing 1.4.5-2+b1 upgradeable to 1.4.5-2+b2
libatk-wrapper-java:all/testing 0.33.0-5 upgradeable to 0.33.3-1
libatk-wrapper-java-jni:amd64/testing 0.33.0-5 upgradeable to 0.33.3-1
libaudit-common:all/testing 1:2.4.4-1 upgradeable to 1:2.4.4-2
libaudit1:amd64/testing 1:2.4.4-1 upgradeable to 1:2.4.4-2
libclamav6:amd64/testing 0.98.7+dfsg-2 upgradeable to 0.98.7+dfsg-3
libcurl3:amd64/testing 7.44.0-1 upgradeable to 7.44.0-2
libcurl3-gnutls:amd64/testing 7.44.0-1 upgradeable to 7.44.0-2
libgl1-mesa-dri:amd64/testing 10.6.3-1 upgradeable to 10.6.5-1
libgnutls-deb0-28:amd64/testing 3.3.15-6 upgradeable to 3.3.17-1
libgnutls-openssl27:amd64/testing 3.3.15-6 upgradeable to 3.3.17-1
libgstreamer-plugins-bad1.0-0:amd64/testing 1.4.5-2+b1 upgradeable to 1.4.5-3
libpixman-1-0:amd64/stable 0.32.6-3 upgradeable to 0.33.2-2
libtagc0:amd64/stable 1.9.1-2.1 upgradeable to 1.9.1-2.4
libxatracker2:amd64/testing 10.6.3-1 upgradeable to 10.6.5-1
mutter-common:all/testing 3.4.1-7 upgradeable to 3.16.3-1
openssl:amd64/stable *manually* upgradeable from 1.0.1k-3 to 1.0.2d-1
orage:amd64/testing 4.10.0-1+b1 upgradeable to 4.12.1-1+b1
osmo:amd64/testing 0.2.12-1 upgradeable to 0.2.14-1
python-apt:amd64/unstable 1.0.0~beta3.1 upgradeable to 1.0.0
python-apt-common:all/unstable 1.0.0~beta3.1 upgradeable to 1.0.0
python-pyasn1:all/testing 0.1.8-1 upgradeable to 0.1.8-2
thunar-media-tags-plugin:amd64/testing 0.2.1-1+b1 upgradeable to 0.2.1-1+b2
x11-xserver-utils:amd64/testing 7.7+4 upgradeable to 7.7+5
xfce4:all/stable 4.10.1 upgradeable to 4.12.1
xfce4-battery-plugin:amd64/stable 1.0.5-4 upgradeable to 1.0.5-4+b1
xfce4-clipman-plugin:amd64/stable 2:1.2.6-1 upgradeable to 2:1.2.6-1+b1
xfce4-cpufreq-plugin:amd64/stable 1.1.0-1 upgradeable to 1.1.2-1
xfce4-cpugraph-plugin:amd64/stable 1.0.5-1 upgradeable to 1.0.5-1+b1
xfce4-datetime-plugin:amd64/stable 0.6.2-2 upgradeable to 0.6.2-2+b1
xfce4-dict:amd64/stable 0.7.0-1 upgradeable to 0.7.1-1+b1
xfce4-diskperf-plugin:amd64/stable 2.5.4-3 upgradeable to 2.5.5-1+b1
xfce4-fsguard-plugin:amd64/stable 1.0.1-2 upgradeable to 1.0.2-1+b1
xfce4-genmon-plugin:amd64/stable 3.4.0-2 upgradeable to 3.4.0-2+b1
xfce4-goodies:amd64/stable 4.10 upgradeable to 4.12
xfce4-mailwatch-plugin:amd64/stable 1.2.0-2 upgradeable to 1.2.0-2+b1
xfce4-mixer:amd64/stable 4.10.0-3 upgradeable to 4.10.0-3+b1
xfce4-mount-plugin:amd64/stable 0.6.7-1 upgradeable to 0.6.7-1+b1
xfce4-netload-plugin:amd64/stable 1.2.0-1 upgradeable to 1.2.4-1+b1
xfce4-notes-plugin:amd64/stable 1.7.7-5 upgradeable to 1.8.1-1
xfce4-panel:amd64/stable 4.10.1-1 upgradeable to 4.12.0-3
xfce4-places-plugin:amd64/stable 1.6.0-1 upgradeable to 1.7.0-3
xfce4-power-manager-plugins:amd64/testing 1.4.1-2 upgradeable to 1.4.4-4
xfce4-quicklauncher-plugin:amd64/stable 1.9.4-11 upgradeable to 1.9.4-11+b1
xfce4-sensors-plugin:amd64/stable 1.2.5-2 upgradeable to 1.2.6-1+b1
xfce4-smartbookmark-plugin:amd64/stable 0.4.5-1 upgradeable to 0.4.6-1+b1
xfce4-systemload-plugin:amd64/stable 1.1.1-4 upgradeable to 1.1.2-1+b1
xfce4-timer-plugin:amd64/stable 1.6.0-1 upgradeable to 1.6.0-1+b1
xfce4-verve-plugin:amd64/stable 1.0.0-3 upgradeable to 1.0.1-1+b1
xfce4-wavelan-plugin:amd64/stable 0.5.11-3 upgradeable to 0.5.12-1
xfce4-weather-plugin:amd64/stable 0.8.3-2 upgradeable to 0.8.6-1
xfce4-xkb-plugin:amd64/stable 1:0.5.6-1 upgradeable to 1:0.7.1-2+b1
xserver-xorg-core:amd64/stable 2:1.16.4-1 upgradeable to 2:1.17.2-1.1
xserver-xorg-input-wacom:amd64/stable 0.26.0+20140918-1 upgradeable to 0.30.0-1
xserver-xorg-video-ati:amd64/stable 1:7.5.0-1 upgradeable to 1:7.5.0-1+b1
xserver-xorg-video-cirrus:amd64/stable 1:1.5.2-2+b1 upgradeable to 1:1.5.3-1
xserver-xorg-video-fbdev:amd64/stable 1:0.4.4-1+b2 upgradeable to 1:0.4.4-1+b3
xserver-xorg-video-intel:amd64/stable 2:2.21.15-2+b2 upgradeable to 2:2.99.917-2
xserver-xorg-video-mach64:amd64/stable 6.9.4-2 upgradeable to 6.9.5-1
xserver-xorg-video-mga:amd64/testing 1:1.6.4-1 upgradeable to 1:1.6.4-1+b1
xserver-xorg-video-neomagic:amd64/stable 1:1.2.8-1+b2 upgradeable to 1:1.2.9-1
xserver-xorg-video-nouveau:amd64/stable 1:1.0.11-1 upgradeable to 1:1.0.11-1+b1
xserver-xorg-video-openchrome:amd64/stable 1:0.3.3-1+b2 upgradeable to 1:0.3.3-1+b3
xserver-xorg-video-qxl:amd64/stable 0.1.1-2+b1 upgradeable to 0.1.4-3
xserver-xorg-video-r128:amd64/stable 6.9.2-1+b2 upgradeable to 6.10.0-1
xserver-xorg-video-radeon:amd64/stable 1:7.5.0-1 upgradeable to 1:7.5.0-1+b1
xserver-xorg-video-savage:amd64/stable 1:2.3.7-2+b2 upgradeable to 1:2.3.8-1
xserver-xorg-video-siliconmotion:amd64/stable 1:1.7.7-2+b2 upgradeable to 1:1.7.8-1
xserver-xorg-video-sisusb:amd64/stable 1:0.9.6-2+b2 upgradeable to 1:0.9.6-2+b3
xserver-xorg-video-tdfx:amd64/testing 1:1.4.6-1 upgradeable to 1:1.4.6-1+b1
xserver-xorg-video-trident:amd64/testing 1:1.3.7-1 upgradeable to 1:1.3.7-1+b1
xserver-xorg-video-vesa:amd64/stable 1:2.3.3-1+b3 upgradeable to 1:2.3.3-1+b4
xserver-xorg-video-vmware:amd64/testing 1:13.1.0-1 upgradeable to 1:13.1.0-2
root@debian:/home/belette# [/code]
[code]root@debian:/home/belette# aptitude  upgrade
Resolving dependencies...
  libnghttp2-14{a}
The following packages will be upgraded:
  libatk-wrapper-java libatk-wrapper-java-jni libaudit-common libaudit1 libcurl3 libcurl3-gnutls libpixman-1-0 python-apt python-apt-common python-pyasn1
  x11-xserver-utils
11 packages upgraded, 1 newly installed, 0 to remove and 74 not upgraded.
Need to get 1,759 kB of archives. After unpacking 228 kB will be used.
Do you want to continue? [Y/n/?] y
Get: 1 http://ftp.fr.debian.org/debian/ unstable/main libaudit-common all 1:2.4.4-2 [14.7 kB]
Get: 2 http://ftp.fr.debian.org/debian/ unstable/main libaudit1 amd64 1:2.4.4-2 [47.1 kB]
Get: 3 http://ftp.fr.debian.org/debian/ unstable/main python-apt-common all 1.0.0 [91.8 kB]
Get: 4 http://ftp.fr.debian.org/debian/ unstable/main python-apt amd64 1.0.0 [169 kB]
Get: 5 http://ftp.fr.debian.org/debian/ unstable/main libatk-wrapper-java all 0.33.3-1 [43.1 kB]
Get: 6 http://ftp.fr.debian.org/debian/ unstable/main libatk-wrapper-java-jni amd64 0.33.3-1 [36.1 kB]
Get: 7 http://ftp.fr.debian.org/debian/ unstable/main libnghttp2-14 amd64 1.3.1-0.3 [81.5 kB]
Get: 8 http://ftp.fr.debian.org/debian/ unstable/main libcurl3 amd64 7.44.0-2 [272 kB]
Get: 9 http://ftp.fr.debian.org/debian/ unstable/main libcurl3-gnutls amd64 7.44.0-2 [270 kB]
Get: 10 http://ftp.fr.debian.org/debian/ unstable/main libpixman-1-0 amd64 0.33.2-2 [523 kB]
Get: 11 http://ftp.fr.debian.org/debian/ unstable/main python-pyasn1 all 0.1.8-2 [52.2 kB]
Get: 12 http://ftp.fr.debian.org/debian/ unstable/main x11-xserver-utils amd64 7.7+5 [158 kB]
Fetched 1,759 kB in 2s (812 kB/s)
Retrieving bug reports... Done
Parsing Found/Fixed information... Done
Reading changelogs... Done
(Reading database ... 136464 files and directories currently installed.)
Preparing to unpack .../libaudit-common_1%3a2.4.4-2_all.deb ...
Unpacking libaudit-common (1:2.4.4-2) over (1:2.4.4-1) ...
Processing triggers for man-db (2.7.3-1) ...
Setting up libaudit-common (1:2.4.4-2) ...
Preparing to unpack .../libaudit1_1%3a2.4.4-2_amd64.deb ...
Unpacking libaudit1:amd64 (1:2.4.4-2) over (1:2.4.4-1) ...
Setting up libaudit1:amd64 (1:2.4.4-2) ...
Processing triggers for libc-bin (2.19-19) ...
Preparing to unpack .../python-apt-common_1.0.0_all.deb ...
Unpacking python-apt-common (1.0.0) over (1.0.0~beta3.1) ...
Preparing to unpack .../python-apt_1.0.0_amd64.deb ...
Unpacking python-apt (1.0.0) over (1.0.0~beta3.1) ...
Preparing to unpack .../libatk-wrapper-java_0.33.3-1_all.deb ...
Unpacking libatk-wrapper-java (0.33.3-1) over (0.33.0-5) ...
Preparing to unpack .../libatk-wrapper-java-jni_0.33.3-1_amd64.deb ...
Unpacking libatk-wrapper-java-jni:amd64 (0.33.3-1) over (0.33.0-5) ...
Selecting previously unselected package libnghttp2-14:amd64.
Preparing to unpack .../libnghttp2-14_1.3.1-0.3_amd64.deb ...
Unpacking libnghttp2-14:amd64 (1.3.1-0.3) ...
Preparing to unpack .../libcurl3_7.44.0-2_amd64.deb ...
Unpacking libcurl3:amd64 (7.44.0-2) over (7.44.0-1) ...
Preparing to unpack .../libcurl3-gnutls_7.44.0-2_amd64.deb ...
Unpacking libcurl3-gnutls:amd64 (7.44.0-2) over (7.44.0-1) ...
Preparing to unpack .../libpixman-1-0_0.33.2-2_amd64.deb ...
Unpacking libpixman-1-0:amd64 (0.33.2-2) over (0.32.6-3) ...
Preparing to unpack .../python-pyasn1_0.1.8-2_all.deb ...
Unpacking python-pyasn1 (0.1.8-2) over (0.1.8-1) ...
Preparing to unpack .../x11-xserver-utils_7.7+5_amd64.deb ...
Unpacking x11-xserver-utils (7.7+5) over (7.7+4) ...
Processing triggers for menu (2.1.47) ...
Setting up python-apt-common (1.0.0) ...
Setting up python-apt (1.0.0) ...
Setting up libatk-wrapper-java (0.33.3-1) ...
Setting up libatk-wrapper-java-jni:amd64 (0.33.3-1) ...
Setting up libnghttp2-14:amd64 (1.3.1-0.3) ...
Setting up libcurl3:amd64 (7.44.0-2) ...
Setting up libcurl3-gnutls:amd64 (7.44.0-2) ...
Setting up libpixman-1-0:amd64 (0.33.2-2) ...
Setting up python-pyasn1 (0.1.8-2) ...
Setting up x11-xserver-utils (7.7+5) ...
Current status: 74 updates [-11].
Bon dimanche :slightly_smiling:
Il faut savoir faire des concessions.
Alors, allons y gaiement mais, sûrement.
Tu [mono]valides[/mono].
Une mise à jour du cache ([mono]update[/mono]) suivit de :
Acceptes à la première offre.
Refuses trois fois.
Hello,
Je me suis permis un petit safe-upgrade en attendant le retour du site:
[code]root@debian:/home/belette# aptitude safe-upgrade
Resolving dependencies…
banshee file gettext-base libatk-bridge2.0-0 libc-bin libc-dev-bin libc6
libc6-dev libglu1-mesa libmagic1 libmwaw-0.3-3 libnghttp2-14 libpython2.7
libpython2.7-minimal libpython2.7-stdlib libxml2 locales
multiarch-support python-libxml2 python2.7 python2.7-minimal
21 packages upgraded, 0 newly installed, 0 to remove and 73 not upgraded.
Need to get 23.7 MB of archives. After unpacking 1,089 kB will be freed.
Get: 1 http://ftp.fr.debian.org/debian/ unstable/main libc6-dev amd64 2.19-20 [1,991 kB]
Get: 2 http://ftp.fr.debian.org/debian/ unstable/main libc-dev-bin amd64 2.19-20 [237 kB]
Get: 3 http://ftp.fr.debian.org/debian/ unstable/main libc-bin amd64 2.19-20 [1,284 kB]
Get: 4 http://ftp.fr.debian.org/debian/ unstable/main libc6 amd64 2.19-20 [4,650 kB]
Get: 5 http://ftp.fr.debian.org/debian/ unstable/main libpython2.7 amd64 2.7.10-4 [1,064 kB]
Get: 6 http://ftp.fr.debian.org/debian/ unstable/main python2.7 amd64 2.7.10-4 [259 kB]
Get: 7 http://ftp.fr.debian.org/debian/ unstable/main python2.7-minimal amd64 2.7.10-4 [1,310 kB]
Get: 8 http://ftp.fr.debian.org/debian/ unstable/main libpython2.7-stdlib amd64 2.7.10-4 [1,791 kB]
Get: 9 http://ftp.fr.debian.org/debian/ unstable/main libpython2.7-minimal amd64 2.7.10-4 [380 kB]
Get: 10 http://ftp.fr.debian.org/debian/ unstable/main multiarch-support amd64 2.19-20 [179 kB]
Get: 11 http://ftp.fr.debian.org/debian/ unstable/main file amd64 1:5.24-2 [61.2 kB]
Get: 12 http://ftp.fr.debian.org/debian/ unstable/main libmagic1 amd64 1:5.24-2 [255 kB]
Get: 13 http://ftp.fr.debian.org/debian/ unstable/main gettext-base amd64 0.19.6-1 [123 kB]
Get: 14 http://ftp.fr.debian.org/debian/ unstable/main libxml2 amd64 2.9.2+really2.9.1+dfsg1-0.2 [905 kB]
Get: 15 http://ftp.fr.debian.org/debian/ unstable/main locales all 2.19-20 [3,940 kB]
Get: 16 http://ftp.fr.debian.org/debian/ unstable/main banshee amd64 2.6.2-4 [2,778 kB]
Get: 17 http://ftp.fr.debian.org/debian/ unstable/main libatk-bridge2.0-0 amd64 2.16.0-2 [55.1 kB]
Get: 18 http://ftp.fr.debian.org/debian/ unstable/main libglu1-mesa amd64 9.0.0-2.1 [168 kB]
Get: 19 http://ftp.fr.debian.org/debian/ unstable/main libmwaw-0.3-3 amd64 0.3.6-1 [2,019 kB]
Get: 20 http://ftp.fr.debian.org/debian/ unstable/main libnghttp2-14 amd64 1.3.1-0.4 [81.1 kB]
Get: 21 http://ftp.fr.debian.org/debian/ unstable/main python-libxml2 amd64 2.9.2+really2.9.1+dfsg1-0.2 [193 kB]
Fetched 23.7 MB in 17s (1,363 kB/s)
Retrieving bug reports… Done
Parsing Found/Fixed information… Done
Reading changelogs… Done
Preconfiguring packages …
(Reading database … 136471 files and directories currently installed.)
Preparing to unpack …/libc6-dev_2.19-20_amd64.deb …
Unpacking libc6-dev:amd64 (2.19-20) over (2.19-19) …
Preparing to unpack …/libc-dev-bin_2.19-20_amd64.deb …
Unpacking libc-dev-bin (2.19-20) over (2.19-19) …
Preparing to unpack …/libc-bin_2.19-20_amd64.deb …
Unpacking libc-bin (2.19-20) over (2.19-19) …
Processing triggers for man-db (2.7.3-1) …
Setting up libc-bin (2.19-20) …
Preparing to unpack …/libc6_2.19-20_amd64.deb …
Unpacking libc6:amd64 (2.19-20) over (2.19-19) …
Setting up libc6:amd64 (2.19-20) …
Processing triggers for libc-bin (2.19-20) …
Preparing to unpack …/libpython2.7_2.7.10-4_amd64.deb …
Unpacking libpython2.7:amd64 (2.7.10-4) over (2.7.10-3) …
Preparing to unpack …/python2.7_2.7.10-4_amd64.deb …
Unpacking python2.7 (2.7.10-4) over (2.7.10-3) …
Preparing to unpack …/python2.7-minimal_2.7.10-4_amd64.deb …
Unpacking python2.7-minimal (2.7.10-4) over (2.7.10-3) …
Preparing to unpack …/libpython2.7-stdlib_2.7.10-4_amd64.deb …
Unpacking libpython2.7-stdlib:amd64 (2.7.10-4) over (2.7.10-3) …
Preparing to unpack …/libpython2.7-minimal_2.7.10-4_amd64.deb …
Unpacking libpython2.7-minimal:amd64 (2.7.10-4) over (2.7.10-3) …
Preparing to unpack …/multiarch-support_2.19-20_amd64.deb …
Unpacking multiarch-support (2.19-20) over (2.19-19) …
Processing triggers for menu (2.1.47) …
Processing triggers for mime-support (3.59) …
Processing triggers for gnome-menus (3.13.3-6) …
Processing triggers for desktop-file-utils (0.22-1) …
Setting up multiarch-support (2.19-20) …
Preparing to unpack …/file_1%3a5.24-2_amd64.deb …
Unpacking file (1:5.24-2) over (1:5.24-1) …
Preparing to unpack …/libmagic1_1%3a5.24-2_amd64.deb …
Unpacking libmagic1:amd64 (1:5.24-2) over (1:5.24-1) …
Preparing to unpack …/gettext-base_0.19.6-1_amd64.deb …
Unpacking gettext-base (0.19.6-1) over (0.19.4-1) …
Preparing to unpack …/libxml2_2.9.2+really2.9.1+dfsg1-0.2_amd64.deb …
Unpacking libxml2:amd64 (2.9.2+really2.9.1+dfsg1-0.2) over (2.9.2+really2.9.1+dfsg1-0.1) …
Preparing to unpack …/locales_2.19-20_all.deb …
Unpacking locales (2.19-20) over (2.19-19) …
Preparing to unpack …/banshee_2.6.2-4_amd64.deb …
Unpacking banshee (2.6.2-4) over (2.6.2-3) …
Preparing to unpack …/libatk-bridge2.0-0_2.16.0-2_amd64.deb …
Unpacking libatk-bridge2.0-0:amd64 (2.16.0-2) over (2.16.0-1) …
Preparing to unpack …/libglu1-mesa_9.0.0-2.1_amd64.deb …
Unpacking libglu1-mesa:amd64 (9.0.0-2.1) over (9.0.0-2) …
Preparing to unpack …/libmwaw-0.3-3_0.3.6-1_amd64.deb …
Unpacking libmwaw-0.3-3 (0.3.6-1) over (0.3.5-1) …
Preparing to unpack …/libnghttp2-14_1.3.1-0.4_amd64.deb …
Unpacking libnghttp2-14:amd64 (1.3.1-0.4) over (1.3.1-0.3) …
Preparing to unpack …/python-libxml2_2.9.2+really2.9.1+dfsg1-0.2_amd64.deb …
Unpacking python-libxml2 (2.9.2+really2.9.1+dfsg1-0.2) over (2.9.2+really2.9.1+dfsg1-0.1) …
Processing triggers for hicolor-icon-theme (0.13-1) …
Setting up libc-dev-bin (2.19-20) …
Setting up libc6-dev:amd64 (2.19-20) …
Setting up libpython2.7-minimal:amd64 (2.7.10-4) …
Setting up libpython2.7-stdlib:amd64 (2.7.10-4) …
Setting up libpython2.7:amd64 (2.7.10-4) …
Setting up python2.7-minimal (2.7.10-4) …
Setting up python2.7 (2.7.10-4) …
Setting up libmagic1:amd64 (1:5.24-2) …
Setting up file (1:5.24-2) …
Setting up gettext-base (0.19.6-1) …
Setting up libxml2:amd64 (2.9.2+really2.9.1+dfsg1-0.2) …
Setting up locales (2.19-20) …
Generating locales (this might take a while)…
en_GB.UTF-8… done
Generation complete.
Setting up banshee (2.6.2-4) …
Setting up libatk-bridge2.0-0:amd64 (2.16.0-2) …
Setting up libglu1-mesa:amd64 (9.0.0-2.1) …
Setting up libmwaw-0.3-3 (0.3.6-1) …
Setting up libnghttp2-14:amd64 (1.3.1-0.4) …
Setting up python-libxml2 (2.9.2+really2.9.1+dfsg1-0.2) …
Processing triggers for shared-mime-info (1.3-1) …
Current status: 73 updates [-21].
[code]root@debian:/home/belette# aptitude remove libebml4 libgroupsock4 libmatroska6 libreoffice libreoffice-avmedia-backend-vlc libvlc5 libvlccore7 libvlccore8 vlc vlc-data vlc-nox vlc-plugin-notify vlc-plugin-pulse
0 packages upgraded, 0 newly installed, 13 to remove and 73 not upgraded.
Removing vlc-plugin-notify (1:2.2.1-dmo6) …
Removing vlc-plugin-pulse (1:2.2.1-dmo10) …
Removing vlc (1:2.2.1-dmo6) …
Removing vlc-nox (1:2.2.1-dmo6) …
Removing libmatroska6:amd64 (1.4.2-dmo2) …
Removing libebml4:amd64 (1.3.1-dmo2) …
Removing libgroupsock4 (2:2015.06.09-dmo1) …
Removing libreoffice (1:5.0.1-1) …
Removing libreoffice-avmedia-backend-vlc (1:5.0.1-1) …
Removing libvlc5 (1:2.2.1-dmo10) …
Removing libvlccore7 (1:2.1.5-dmo2) …
Removing libvlccore8 (1:2.2.1-dmo10) …
Removing vlc-data (1:2.2.1-dmo10) …
Current status: 14716 new [-2].
[code]root@debian:/home/belette# aptitude -s full-upgrade
evolution{a} evolution-common{a} evolution-data-server{a} evolution-plugins{a} gir1.2-panelapplet-5.0{a} libcamel-1.2-52{a} libchamplain-0.12-0{a}
libchamplain-gtk-0.12-0{a} libclutter-1.0-0{a} libclutter-1.0-common{a} libclutter-gtk-1.0-0{a} libcogl-common{a} libcogl-pango20{a} libcogl-path20{a}
libcogl20{a} libcryptui0a{a} libebackend-1.2-10{a} libebook-1.2-16{a} libebook-contacts-1.2-1{a} libecal-1.2-18{a} libedata-book-1.2-25{a}
libedata-cal-1.2-27{a} libedataserver-1.2-20{a} libedataserverui-1.2-1{a} libevolution{a} libgdata-common{a} libgdata22{a} libgoa-1.0-0b{a} libgtkspell3-3-0{a}
libical1a{ab} libinput10{a} libllvm3.5v5{ab} libnpth0{a} libpanel-applet0{a} libproxy1v5{ab} libpst4{a} libsidplay1v5{ab} libtag1v5{ab} libtag1v5-vanilla{ab}
libtinyxml2.6.2v5{ab} libwxbase3.0-0v5{ab} libwxgtk3.0-0v5{ab} libytnef0{a} python3-gi{a} seahorse{a} seahorse-daemon{a} xfce4-whiskermenu-plugin{a}
bluez-obexd filezilla filezilla-common glib-networking glib-networking-services gnome-applets gnome-applets-data gnome-panel{b} gnome-panel-data gnupg-agent
gstreamer0.10-plugins-good gstreamer1.0-plugins-good gstreamer1.0-plugins-ugly libclamav6 libgl1-mesa-dri libgnutls-deb0-28{b} libgnutls-openssl27
libgstreamer-plugins-bad1.0-0 libtagc0 libxatracker2 mutter-common orage osmo thunar-media-tags-plugin xfce4 xfce4-battery-plugin xfce4-clipman-plugin
xfce4-cpufreq-plugin xfce4-cpugraph-plugin xfce4-datetime-plugin xfce4-dict xfce4-diskperf-plugin xfce4-fsguard-plugin xfce4-genmon-plugin xfce4-goodies
xfce4-mailwatch-plugin xfce4-mixer xfce4-mount-plugin xfce4-netload-plugin xfce4-notes-plugin xfce4-panel xfce4-places-plugin xfce4-power-manager-plugins
xfce4-quicklauncher-plugin xfce4-sensors-plugin xfce4-smartbookmark-plugin xfce4-systemload-plugin xfce4-timer-plugin xfce4-verve-plugin xfce4-wavelan-plugin
xfce4-weather-plugin xfce4-xkb-plugin xserver-xorg-core{b} xserver-xorg-input-wacom xserver-xorg-video-ati xserver-xorg-video-cirrus xserver-xorg-video-fbdev
xserver-xorg-video-intel xserver-xorg-video-mach64 xserver-xorg-video-mga xserver-xorg-video-neomagic xserver-xorg-video-nouveau xserver-xorg-video-openchrome
xserver-xorg-video-qxl xserver-xorg-video-r128 xserver-xorg-video-radeon xserver-xorg-video-savage xserver-xorg-video-siliconmotion xserver-xorg-video-sisusb
xserver-xorg-video-tdfx xserver-xorg-video-trident xserver-xorg-video-vesa xserver-xorg-video-vmware
The following packages are RECOMMENDED but will NOT be installed:
73 packages upgraded, 47 newly installed, 0 to remove and 0 not upgraded.
Need to get 64.8 MB/73.5 MB of archives. After unpacking 142 MB will be used.
The following packages have unmet dependencies:
libtag1v5-vanilla : Breaks: libtag1-vanilla but 1.9.1-2.1 is installed.
libtag1v5 : Conflicts: libtag1c2a but 1.9.1-2.1 is installed.
libgnutls-deb0-28 : Conflicts: libhogweed2 but 2.7.1-5 is installed.
Conflicts: libnettle4 but 2.7.1-5 is installed.
libical1a : Breaks: libical1 but 1.0-1.2 is installed.
xserver-xorg-core : Conflicts: xserver-xorg-video-modesetting but 0.9.0-2 is installed.
gnome-panel : Breaks: libpanel-applet-4-0 (< 3.14.0) but 3.8.1-7+b2 is installed.
libsidplay1v5 : Conflicts: libsidplay1 but 1.36.59-7 is installed.
libwxbase3.0-0v5 : Breaks: libwxbase3.0-0 but 3.0.2+dfsg-1 is installed.
libwxgtk3.0-0v5 : Breaks: libwxgtk3.0-0 but 3.0.2+dfsg-1 is installed.
libllvm3.5v5 : Conflicts: libllvm3.5 but 1:3.5.2-1 is installed.
gnupg2 : Depends: gnupg-agent (= 2.0.28-3) but 2.1.8-1 is to be installed.
libproxy1v5 : Conflicts: libproxy1 but 0.4.11-4+b2 is installed.
libtinyxml2.6.2v5 : Conflicts: libtinyxml2.6.2 but 2.6.2-2 is installed.
xserver-xorg-video-modesetting : Depends: xorg-video-abi-18 which is a virtual package.
open: 622; closed: 4049; defer: 77; conflict: 100 .The following actions will resolve these dependencies:
  1.  brasero
  2.  filezilla
  3.  gir1.2-panelapplet-4.0
  4.  gnupg2
  6.  libecal-1.2-15
  8.  libgmime-2.6-0
  9.  libgnutls28
  10. libgpgme11
  11. libhogweed2
  12. libical1
  13. libllvm3.5
  14. libnettle4
  15. libpanel-applet-4-0
  16. libproxy1
  17. libsidplay1
  18. libtag1-vanilla
  19. libtag1c2a
  20. libtotem-plparser18
  21. mutt
  22. xserver-xorg-video-modesetting
    Keep the following packages at their current version:
  23. evolution [Not Installed]
  24. evolution-plugins [Not Installed]
  25. libcryptui0a [Not Installed]
  26. libevolution [Not Installed]
  27. libtinyxml2.6.2v5 [Not Installed]
  28. libwxbase3.0-0v5 [Not Installed]
  29. libwxgtk3.0-0v5 [Not Installed]
  30. seahorse [Not Installed]
  31. seahorse-daemon [Not Installed]
  32. evolution-common recommends evolution
  33. banshee recommends brasero
Accept this solution? [Y/n/q/?] n
  1.  brasero
  2.  filezilla
  4.  gnupg2
  5.  gstreamer1.0-plugins-ugly
  6.  libbrasero-media3-1
  7.  libecal-1.2-15
  8.  libedata-cal-1.2-20
  9.  libgmime-2.6-0
  10. libgnutls28
  11. libgpgme11
  12. libhogweed2
  13. libical1
  14. libllvm3.5
  15. libnettle4
  16. libpanel-applet-4-0
  17. libproxy1
  18. libtag1-vanilla
  19. libtag1c2a
  21. mutt
  22. quodlibet
  23. xserver-xorg-video-modesetting
  24. evolution [Not Installed]
  25. evolution-plugins [Not Installed]
  26. libcryptui0a [Not Installed]
  27. libevolution [Not Installed]
  28. libsidplay1v5 [Not Installed]
  29. libtinyxml2.6.2v5 [Not Installed]
  30. libwxbase3.0-0v5 [Not Installed]
  31. libwxgtk3.0-0v5 [Not Installed]
  32. seahorse [Not Installed]
  33. seahorse-daemon [Not Installed]
  34. libbrasero-media3-1 recommends gstreamer1.0-plugins-ugly
  35. evolution-common recommends evolution
  36. rygel recommends gstreamer1.0-plugins-ugly
  37. task-xfce-desktop recommends quodlibet
  38. banshee recommends brasero
  1.  brasero
  2.  filezilla
  4.  gnupg2
  6.  libecal-1.2-15
  8.  libgmime-2.6-0
  9.  libgnutls28
  10. libgpgme11
  11. libhogweed2
  12. libical1
  13. libllvm3.5
  14. libnettle4
  16. libproxy1
  17. libsidplay1
  18. libtag1-vanilla
  19. libtag1c2a
  20. libtinyxml2.6.2
  21. libtotem-plparser18
  22. mutt
  1.  brasero
  2.  filezilla
  3.  gnome-applets
  4.  gnome-panel
  5.  gnome-session-fallback
  6.  gnome-session-flashback
  7.  gnupg2
  8.  libbrasero-media3-1
  9.  libecal-1.2-15
  10. libedata-cal-1.2-20
  11. libgmime-2.6-0
  12. libgnutls28
  13. libgpgme11
  14. libhogweed2
  15. libical1
  16. libllvm3.5
  17. libnettle4
  18. libproxy1
  19. libsidplay1
  20. libtag1-vanilla
  21. libtag1c2a
  22. libtotem-plparser18
  23. mutt
  24. xserver-xorg-video-modesetting
  25. evolution [Not Installed]
  26. evolution-plugins [Not Installed]
  27. libcryptui0a [Not Installed]
  28. libevolution [Not Installed]
  34. evolution-common recommends evolution
  35. gnome-panel-data recommends gnome-panel
  36. banshee recommends brasero
De quelles concessions fais-tu mention?
Content de te revoir.
Visiblement le développement de certains paquets tels que [mono]gnome-panel[/mono] et sa suite ont dû retard.
Dépend: gnome-menus (>= 3.1.4), gnome-panel-data (= 3.16.1-4), libatk1.0-0 (>= 1.12.4), libc6 (>= 2.14), libcairo-gobject2 (>= 1.10.0), libcairo2 (>= 1.10.0), libcamel-1.2-52 (>= 3.16.2), libdconf1 (>= 0.14.0), libecal-1.2-18 (>= 3.16.2), libedataserver-1.2-20 (>= 3.16.2), libgdk-pixbuf2.0-0 (>= 2.25.2), libglib2.0-0 (>= 2.41.1), libgnome-desktop-3-10 (>= 3.11.90), libgnome-menu-3-0 (>= 3.2.0.1), libgtk-3-0 (>= 3.16.2), libgweather-3-6 (>= 3.10.0), libical1a (>= 1.0), libnspr4 (>= 2:4.9-2~) | libnspr4-0d (>= 1.8.0.10), libnss3 (>= 2:3.13.4-2~) | libnss3-1d (>= 3.12.0~beta2), libpanel-applet0 (>= 3.4.1), libpango-1.0-0 (>= 1.18.0), libpangocairo-1.0-0 (>= 1.15.4), libpolkit-gobject-1-0 (>= 0.99), librsvg2-2 (>= 2.36.2), libsecret-1-0 (>= 0.7), libsoup2.4-1 (>= 2.4.0), libsqlite3-0 (>= 3.5.9), libtelepathy-glib0 (>= 0.14.0), libwnck-3-0 (>= 3.4.6), libx11-6, libxau6, libxext6, libxml2 (>= 2.6.27), libxrandr2 (>= 2:1.2.99.3) Recommande: alacarte, evolution-common (>= 3.4.3), evolution-data-server, gnome-applets, gnome-control-center, gnome-session-flashback (>= 3.14.0), gvfs
Dans ce cas précis, on ne peut qu’attendre les dev.
J’aimerai cependant vérifier un truc.
As-tu un fichier [mono]/etc/apt/apt.conf[/mono] et/où [mono]/etc/apt/apt.conf.d/…[/mono] ?
Même punition, trois refus ci-dessous.
$ aptitude -s remove --purge libtag1-vanilla $ aptitude -s remove --purge libsidplay1 $ aptitude -s remove --purge libwxbase3 $ aptitude -s remove --purge libwxgtk3 $ aptitude -s remove --purge libllvm3
[quote=“BelZéButh”]Salut,
Plaisir partagé, j’abandonne pas :033
root@debian:/home/belette# dpkg -l |grep libpanel ii libpanel-applet-4-0 3.8.1-7+b2 amd64 library for GNOME Panel applets root@debian:/home/belette#
Pas de apt.conf à l’horizon
root@debian:/etc/apt# ls apt.conf.d listbugs listchanges.conf preferences preferences.d sources.list sources.list~ sources.list.d trusted.gpg trusted.gpg~ trusted.gpg.d
root@debian:/etc/apt/apt.conf.d# ls 00CDMountPoint 00trustcdrom 01autoremove 01autoremove-kernels 10apt-listbugs 20apt-show-versions 20listchanges 70debconf 99-localepurge root@debian:/etc/apt/apt.conf.d#
root@debian:/etc/apt# dpkg -l |grep libtag ii libtag1-vanilla:amd64 1.9.1-2.1 amd64 audio meta-data library - vanilla flavour ii libtag1c2a:amd64 1.9.1-2.1 amd64 audio meta-data library ii libtagc0:amd64 1.9.1-2.1 amd64 audio meta-data library - C bindings ii libtaglib2.1-cil 2.1.0.0-3 all CLI library for accessing audio and video files metadata root@debian:/etc/apt#
la suite arrive
me suis emmeler les pinceaux…c’est lundi :mrgreen:
[code]root@debian:/home/belette# aptitude -s remove --purge libtag1-vanilla
libtag1-vanilla
0 packages upgraded, 0 newly installed, 1 to remove and 73 not upgraded.
Need to get 0 B of archives. After unpacking 1,135 kB will be freed.
libtag1c2a : Depends: libtag1-vanilla (= 1.9.1-2.1) but it is not going to be installed.
  1.  banshee
  2.  banshee-extension-duplicatesongdetector
  3.  banshee-extension-lyrics
  4.  banshee-extensions-common
  5.  gnome-media
  6.  gstreamer0.10-plugins-good
  7.  gstreamer1.0-plugins-good
  8.  libkarma0
  9.  libtag1c2a
  10. libtagc0
  11. quodlibet
  12. thunar-media-tags-plugin
  13. xfce4-goodies
  14. iceweasel recommends gstreamer1.0-plugins-good
  15. libbrasero-media3-1 recommends gstreamer1.0-plugins-good
  16. rygel recommends gstreamer1.0-plugins-good
  17. task-xfce-desktop recommends xfce4-goodies
  18. task-xfce-desktop recommends quodlibet
  19. libwebkitgtk-1.0-0 recommends gstreamer1.0-plugins-good
  20. libwebkitgtk-3.0-0 recommends gstreamer1.0-plugins-good
  21. libwebkit2gtk-4.0-37 recommends gstreamer1.0-plugins-good
  22. gnome-applets recommends gnome-media
  1. libtag1c2a
  2. libtag1v5 [1.9.1-2.4 (testing, unstable)]
  3. libtag1v5-vanilla [1.9.1-2.4 (testing, unstable)]
  4. gstreamer0.10-plugins-good [0.10.31-3+nmu4+b1 (now, stable) -> 0.10.31-3+nmu4+b2 (testing, unstable)]
  5. gstreamer1.0-plugins-good [1.4.5-2+b1 (now) -> 1.4.5-2+b2 (testing, unstable)]
  6. libtagc0 [1.9.1-2.1 (now, stable) -> 1.9.1-2.4 (testing, unstable)]
  7. thunar-media-tags-plugin [0.2.1-1+b1 (now) -> 0.2.1-1+b2 (testing, unstable)]
  1. libtag1c2a
  3. xfce4-goodies
  4. libtag1v5 [1.9.1-2.4 (testing, unstable)]
  5. libtag1v5-vanilla [1.9.1-2.4 (testing, unstable)]
  6. gstreamer0.10-plugins-good [0.10.31-3+nmu4+b1 (now, stable) -> 0.10.31-3+nmu4+b2 (testing, unstable)]
  7. gstreamer1.0-plugins-good [1.4.5-2+b1 (now) -> 1.4.5-2+b2 (testing, unstable)]
  8. libtagc0 [1.9.1-2.1 (now, stable) -> 1.9.1-2.4 (testing, unstable)]
  9. task-xfce-desktop recommends xfce4-goodies
  1. gnome-media
  2. gstreamer0.10-plugins-good
  3. libtag1c2a
  6. gstreamer1.0-plugins-good [1.4.5-2+b1 (now) -> 1.4.5-2+b2 (testing, unstable)]
  7. libtagc0 [1.9.1-2.1 (now, stable) -> 1.9.1-2.4 (testing, unstable)]
  8. thunar-media-tags-plugin [0.2.1-1+b1 (now) -> 0.2.1-1+b2 (testing, unstable)]
  9. gnome-applets recommends gnome-media
Accept this solution? [Y/n/q/?] q
Abandoning all efforts to resolve these dependencies.
Abort.
[code]root@debian:/home/belette# aptitude -s remove --purge libsidplay1
libsidplay1
Need to get 0 B of archives. After unpacking 242 kB will be freed.
gstreamer1.0-plugins-ugly : Depends: libsidplay1 but it is not going to be installed.
  1. gstreamer1.0-plugins-ugly
  2. quodlibet
  3. libbrasero-media3-1 recommends gstreamer1.0-plugins-ugly
  4. rygel recommends gstreamer1.0-plugins-ugly
  5. task-xfce-desktop recommends quodlibet
  1. libsidplay1v5 [1.36.59-8 (testing, unstable)]
  2. gstreamer1.0-plugins-ugly [1.4.5-2+b1 (now) -> 1.4.5-2+b2 (testing, unstable)]
  1. libsidplay1 [1.36.59-7 (now)]
  1. libsidplay1 [1.36.59-7 (now) -> 1.36.59-6 (stable)]
Abort.
root@debian:/home/belette# aptitude -s remove --purge libwxbase3 Couldn't find package "libwxbase3". However, the following packages contain "libwxbase3" in their name: libwxbase3.0-0v5-dbg libwxbase3.0-0 libwxbase3.0-0-dbg libwxbase3.0-0v5 libwxbase3.0-dev Couldn't find package "libwxbase3". However, the following packages contain "libwxbase3" in their name: libwxbase3.0-0v5-dbg libwxbase3.0-0 libwxbase3.0-0-dbg libwxbase3.0-0v5 libwxbase3.0-dev No packages will be installed, upgraded, or removed. 0 packages upgraded, 0 newly installed, 0 to remove and 73 not upgraded. Need to get 0 B of archives. After unpacking 0 B will be used. Would download/install/remove packages. root@debian:/home/belette#
root@debian:/home/belette# aptitude -s remove --purge libwxgtk3 Couldn't find package "libwxgtk3". However, the following packages contain "libwxgtk3" in their name: libwxgtk3.0-0v5-dbg libwxgtk3.0-0-dbg libwxgtk3.0-0v5 libwxgtk3.0-0 libwxgtk3.0-dev Couldn't find package "libwxgtk3". However, the following packages contain "libwxgtk3" in their name: libwxgtk3.0-0v5-dbg libwxgtk3.0-0-dbg libwxgtk3.0-0v5 libwxgtk3.0-0 libwxgtk3.0-dev No packages will be installed, upgraded, or removed. 0 packages upgraded, 0 newly installed, 0 to remove and 73 not upgraded. Need to get 0 B of archives. After unpacking 0 B will be used. Would download/install/remove packages. root@debian:/home/belette#
root@debian:/home/belette# aptitude -s remove --purge libllvm3 Couldn't find package "libllvm3". However, the following packages contain "libllvm3" in their name: libllvm3.5-dbg libllvm3.6-dbg libllvm3.4 libllvm3.5 libllvm3.7 libllvm3.8 libllvm3.7-dbg libllvm3.6v5 libllvm3.8-dbg libllvm3.5v5 libllvm3.4-dbg Couldn't find package "libllvm3". However, the following packages contain "libllvm3" in their name: libllvm3.5-dbg libllvm3.6-dbg libllvm3.4 libllvm3.5 libllvm3.7 libllvm3.8 libllvm3.7-dbg libllvm3.6v5 libllvm3.8-dbg libllvm3.5v5 libllvm3.4-dbg No packages will be installed, upgraded, or removed. 0 packages upgraded, 0 newly installed, 0 to remove and 73 not upgraded. Need to get 0 B of archives. After unpacking 0 B will be used. Would download/install/remove packages. root@debian:/home/belette#
Je savais bien que j’avais oublié quelque chose, l’autre gonze qui m’a chauffé … Alerte au malibu. :033
De part la suppression temporaire de [mono]vlc[/mono] et [mono]libreoffice[/mono]. Il y en aura peut-être d’autres.
Nous allons corrigé cela.
[quote=“Gargamel”]14) iceweasel recommends gstreamer1.0-plugins-good 15) libbrasero-media3-1 recommends gstreamer1.0-plugins-good 16) rygel recommends gstreamer1.0-plugins-good 17) task-xfce-desktop recommends xfce4-goodies 18) task-xfce-desktop recommends quodlibet 19) libwebkitgtk-1.0-0 recommends gstreamer1.0-plugins-good 20) libwebkitgtk-3.0-0 recommends gstreamer1.0-plugins-good 21) libwebkit2gtk-4.0-37 recommends gstreamer1.0-plugins-good 22) gnome-applets recommends gnome-media [/quote]
Tu crées un fichier en [mono]/etc/apt/apt.conf.d/local.conf[/mono] auquel tu colleras ce qui suit.
APT::Install-Suggests "false"; APT::Install-Recommends "false"; Aptitude::Recommends-Important "false"; Aptitude::Suggests-Important "false";
Voir [mono]$ man apt.conf[/mono] pour de plus ample information.
À la suite de quoi, tu relances un [mono]update[/mono].
Deux refus.
$ aptitude -s remove --purge gstreamer1.0-plugins-good
$ dpkg -l |grep libwx $ dpkg -l |grep libllv
$ aptitude -s safe-upgrade
[mono]grep -r “<expression>”[/mono], en réponse à ta question.
Fichier créé :slightly_smiling: youpi encore de la lecture :mrgreen:
Comment ça se fait que je l’avais pas? il est pas généré automatiquement?
[code]root@debian:/etc/apt/apt.conf.d# aptitude -s remove --purge gstreamer1.0-plugins-good
Need to get 0 B of archives. After unpacking 6,318 kB will be freed.
banshee : Depends: gstreamer1.0-plugins-good but it is not going to be installed.
quodlibet : Depends: gstreamer1.0-plugins-good but it is not going to be installed.
  1. banshee
  5. quodlibet
  1. libtag1-vanilla
  2. libtag1c2a
  3. thunar-media-tags-plugin
  4. xfce4-goodies
  5. libtag1v5 [1.9.1-2.4 (testing, unstable)]
  6. libtag1v5-vanilla [1.9.1-2.4 (testing, unstable)]
  7. gstreamer0.10-plugins-good [0.10.31-3+nmu4+b1 (now, stable) -> 0.10.31-3+nmu4+b2 (testing, unstable)]
  8. gstreamer1.0-plugins-good [1.4.5-2+b1 (now) -> 1.4.5-2+b2 (testing, unstable)]
  9. libtagc0 [1.9.1-2.1 (now, stable) -> 1.9.1-2.4 (testing, unstable)]
  1. libtag1-vanilla
  2. libtag1c2a
  3. libtag1v5 [1.9.1-2.4 (testing, unstable)]
  4. libtag1v5-vanilla [1.9.1-2.4 (testing, unstable)]
  5. gstreamer0.10-plugins-good [0.10.31-3+nmu4+b1 (now, stable) -> 0.10.31-3+nmu4+b2 (testing, unstable)]
root@debian:~# dpkg -l |grep libwx ii libwxbase3.0-0:amd64 3.0.2+dfsg-1 amd64 wxBase library (runtime) - non-GUI support classes of wxWidgets toolkit ii libwxgtk3.0-0:amd64 3.0.2+dfsg-1 amd64 wxWidgets Cross-platform C++ GUI toolkit (GTK+ runtime) root@debian:~#
root@debian:~# dpkg -l |grep libllv ii libllvm3.5:amd64 1:3.5.2-1 amd64 Modular compiler and toolchain technologies, runtime library
root@debian:~# aptitude -s safe-upgrade Resolving dependencies... No packages will be installed, upgraded, or removed. 0 packages upgraded, 0 newly installed, 0 to remove and 74 not upgraded. Need to get 0 B of archives. After unpacking 0 B will be used. Would download/install/remove packages. root@debian:~#
Non.
Tu [mono]valides[/mono], refuses deux fois puis acceptes.
Ici en simulation, trois refus et acceptes.
$ aptitude -s remove libwxbase3.0-0 $ aptitude -s remove libwxgtk3.0-0 $ aptitude -s remove libllvm3.5
Bien le bonjour,
je devrais être un peu plus présent aujourd’hui
petite màj du matin:
cups cups-browsed cups-bsd cups-client cups-common cups-core-drivers
cups-daemon cups-filters cups-filters-core-drivers cups-ppdc
cups-server-common libapparmor1 libcups2 libcupscgi1 libcupsfilters1
libcupsimage2 libcupsmime1 libcupsppdc1 libegl1-mesa libfluidsynth1
libfontembed1 libgbm1 libgl1-mesa-glx libglapi-mesa libgtk2-perl
libmodule-build-perl libwayland-egl1-mesa opera-stable
pepperflashplugin-nonfree printer-driver-gutenprint
28 packages upgraded, 0 newly installed, 0 to remove and 75 not upgraded.
Need to get 47.4 MB of archives. After unpacking 774 kB will be freed.
Get: 1 http://ftp.fr.debian.org/debian/ unstable/main libcupscgi1 amd64 2.1.0-3 [129 kB]
Get: 2 http://deb.opera.com/opera-stable/ stable/non-free opera-stable amd64 32.0.1948.25 [42.0 MB]
Get: 3 http://ftp.fr.debian.org/debian/ unstable/main libcupsimage2 amd64 2.1.0-3 [117 kB]
Get: 4 http://ftp.fr.debian.org/debian/ unstable/main libcupsfilters1 amd64 1.0.76-1 [112 kB]
Get: 5 http://ftp.fr.debian.org/debian/ unstable/main cups-filters-core-drivers amd64 1.0.76-1 [148 kB]
Get: 6 http://ftp.fr.debian.org/debian/ unstable/main cups-core-drivers amd64 2.1.0-3 [127 kB]
Get: 7 http://ftp.fr.debian.org/debian/ unstable/main libcupsmime1 amd64 2.1.0-3 [114 kB]
Get: 8 http://ftp.fr.debian.org/debian/ unstable/main cups-server-common all 2.1.0-3 [591 kB]
Get: 9 http://ftp.fr.debian.org/debian/ unstable/main libfontembed1 amd64 1.0.76-1 [78.6 kB]
Get: 10 http://ftp.fr.debian.org/debian/ unstable/main cups-bsd amd64 2.1.0-3 [35.1 kB]
Get: 11 http://ftp.fr.debian.org/debian/ unstable/main cups-client amd64 2.1.0-3 [235 kB]
Get: 12 http://ftp.fr.debian.org/debian/ unstable/main libcupsppdc1 amd64 2.1.0-3 [146 kB]
Get: 13 http://ftp.fr.debian.org/debian/ unstable/main cups-browsed amd64 1.0.76-1 [108 kB]
Get: 14 http://ftp.fr.debian.org/debian/ unstable/main cups-daemon amd64 2.1.0-3 [395 kB]
Get: 15 http://ftp.fr.debian.org/debian/ unstable/main libcups2 amd64 2.1.0-3 [296 kB]
Get: 16 http://ftp.fr.debian.org/debian/ unstable/main cups amd64 2.1.0-3 [296 kB]
Get: 17 http://ftp.fr.debian.org/debian/ unstable/main cups-filters amd64 1.0.76-1 [518 kB]
Get: 18 http://ftp.fr.debian.org/debian/ unstable/main cups-common all 2.1.0-3 [233 kB]
Get: 19 http://ftp.fr.debian.org/debian/ unstable/main cups-ppdc amd64 2.1.0-3 [128 kB]
Get: 20 http://ftp.fr.debian.org/debian/ unstable/main libapparmor1 amd64 2.10-2 [71.0 kB]
Get: 21 http://ftp.fr.debian.org/debian/ unstable/main libwayland-egl1-mesa amd64 10.6.7-1 [39.9 kB]
Get: 22 http://ftp.fr.debian.org/debian/ unstable/main libgbm1 amd64 10.6.7-1 [56.8 kB]
Get: 23 http://ftp.fr.debian.org/debian/ unstable/main libegl1-mesa amd64 10.6.7-1 [94.5 kB]
Get: 24 http://ftp.fr.debian.org/debian/ unstable/main libfluidsynth1 amd64 1.1.6-3 [158 kB]
Get: 25 http://ftp.fr.debian.org/debian/ unstable/main libgl1-mesa-glx amd64 10.6.7-1 [179 kB]
Get: 26 http://ftp.fr.debian.org/debian/ unstable/main libglapi-mesa amd64 10.6.7-1 [55.4 kB]
Get: 27 http://ftp.fr.debian.org/debian/ unstable/main libgtk2-perl amd64 2:1.2496-3 [671 kB]
Get: 28 http://ftp.fr.debian.org/debian/ unstable/main libmodule-build-perl all 0.421400-3 [259 kB]
Fetched 47.4 MB in 29s (1,592 kB/s)
(Reading database … 135712 files and directories currently installed.)
Preparing to unpack …/libcupscgi1_2.1.0-3_amd64.deb …
Unpacking libcupscgi1:amd64 (2.1.0-3) over (2.1.0-2) …
Preparing to unpack …/libcupsimage2_2.1.0-3_amd64.deb …
Unpacking libcupsimage2:amd64 (2.1.0-3) over (2.1.0-2) …
Preparing to unpack …/libcupsfilters1_1.0.76-1_amd64.deb …
Unpacking libcupsfilters1:amd64 (1.0.76-1) over (1.0.75-1) …
Preparing to unpack …/cups-filters-core-drivers_1.0.76-1_amd64.deb …
Unpacking cups-filters-core-drivers (1.0.76-1) over (1.0.75-1) …
Preparing to unpack …/cups-core-drivers_2.1.0-3_amd64.deb …
Unpacking cups-core-drivers (2.1.0-3) over (2.1.0-2) …
Preparing to unpack …/libcupsmime1_2.1.0-3_amd64.deb …
Unpacking libcupsmime1:amd64 (2.1.0-3) over (2.1.0-2) …
Preparing to unpack …/cups-server-common_2.1.0-3_all.deb …
Unpacking cups-server-common (2.1.0-3) over (2.1.0-2) …
Preparing to unpack …/libfontembed1_1.0.76-1_amd64.deb …
Unpacking libfontembed1:amd64 (1.0.76-1) over (1.0.75-1) …
Preparing to unpack …/cups-bsd_2.1.0-3_amd64.deb …
Unpacking cups-bsd (2.1.0-3) over (2.1.0-2) …
Preparing to unpack …/cups-client_2.1.0-3_amd64.deb …
Unpacking cups-client (2.1.0-3) over (2.1.0-2) …
Preparing to unpack …/libcupsppdc1_2.1.0-3_amd64.deb …
Unpacking libcupsppdc1:amd64 (2.1.0-3) over (2.1.0-2) …
Preparing to unpack …/cups-browsed_1.0.76-1_amd64.deb …
Unpacking cups-browsed (1.0.76-1) over (1.0.75-1) …
Preparing to unpack …/cups-daemon_2.1.0-3_amd64.deb …
Warning: Stopping cups.service, but it can still be activated by:
cups.socket
Unpacking cups-daemon (2.1.0-3) over (2.1.0-2) …
Preparing to unpack …/libcups2_2.1.0-3_amd64.deb …
Unpacking libcups2:amd64 (2.1.0-3) over (2.1.0-2) …
Preparing to unpack …/cups_2.1.0-3_amd64.deb …
Unpacking cups (2.1.0-3) over (2.1.0-2) …
Preparing to unpack …/cups-filters_1.0.76-1_amd64.deb …
Unpacking cups-filters (1.0.76-1) over (1.0.75-1) …
Preparing to unpack …/cups-common_2.1.0-3_all.deb …
Unpacking cups-common (2.1.0-3) over (2.1.0-2) …
Preparing to unpack …/cups-ppdc_2.1.0-3_amd64.deb …
Unpacking cups-ppdc (2.1.0-3) over (2.1.0-2) …
Preparing to unpack …/libapparmor1_2.10-2_amd64.deb …
Unpacking libapparmor1:amd64 (2.10-2) over (2.9.2-3) …
Setting up libapparmor1:amd64 (2.10-2) …
Processing triggers for systemd (226-1) …
Preparing to unpack …/libwayland-egl1-mesa_10.6.7-1_amd64.deb …
Unpacking libwayland-egl1-mesa:amd64 (10.6.7-1) over (10.6.5-1) …
Preparing to unpack …/libgbm1_10.6.7-1_amd64.deb …
Unpacking libgbm1:amd64 (10.6.7-1) over (10.6.5-1) …
Preparing to unpack …/libegl1-mesa_10.6.7-1_amd64.deb …
Unpacking libegl1-mesa:amd64 (10.6.7-1) over (10.6.5-1) …
Preparing to unpack …/libfluidsynth1_1.1.6-3_amd64.deb …
Unpacking libfluidsynth1:amd64 (1.1.6-3) over (1.1.6-2) …
Preparing to unpack …/libgl1-mesa-glx_10.6.7-1_amd64.deb …
Unpacking libgl1-mesa-glx:amd64 (10.6.7-1) over (10.6.5-1) …
Preparing to unpack …/libglapi-mesa_10.6.7-1_amd64.deb …
Unpacking libglapi-mesa:amd64 (10.6.7-1) over (10.6.5-1) …
Preparing to unpack …/libgtk2-perl_2%3a1.2496-3_amd64.deb …
Unpacking libgtk2-perl (2:1.2496-3) over (2:1.2495-1) …
Preparing to unpack …/libmodule-build-perl_0.421400-3_all.deb …
Unpacking libmodule-build-perl (0.421400-3) over (0.421400-2) …
Preparing to unpack …/opera-stable_32.0.1948.25_amd64.deb …
Unpacking opera-stable (32.0.1948.25) over (31.0.1889.174) …
Setting up libcups2:amd64 (2.1.0-3) …
Setting up libcupscgi1:amd64 (2.1.0-3) …
Setting up libcupsmime1:amd64 (2.1.0-3) …
Setting up cups-daemon (2.1.0-3) …
Setting up cups-server-common (2.1.0-3) …
Setting up libfontembed1:amd64 (1.0.76-1) …
Setting up cups-common (2.1.0-3) …
Setting up libcupsppdc1:amd64 (2.1.0-3) …
Setting up cups-browsed (1.0.76-1) …
Installing new version of config file /etc/apparmor.d/usr.sbin.cups-browsed …
Setting up cups-ppdc (2.1.0-3) …
Setting up libgbm1:amd64 (10.6.7-1) …
Setting up libegl1-mesa:amd64 (10.6.7-1) …
Setting up libwayland-egl1-mesa:amd64 (10.6.7-1) …
Setting up libfluidsynth1:amd64 (1.1.6-3) …
Setting up libglapi-mesa:amd64 (10.6.7-1) …
Setting up libgl1-mesa-glx:amd64 (10.6.7-1) …
Setting up libgtk2-perl (2:1.2496-3) …
Setting up libmodule-build-perl (0.421400-3) …
Setting up opera-stable (32.0.1948.25) …
Setting up libcupsfilters1:amd64 (1.0.76-1) …
Setting up libcupsimage2:amd64 (2.1.0-3) …
Setting up cups-filters-core-drivers (1.0.76-1) …
Setting up cups-core-drivers (2.1.0-3) …
Setting up cups-client (2.1.0-3) …
Setting up cups-bsd (2.1.0-3) …
Setting up cups-filters (1.0.76-1) …
Setting up cups (2.1.0-3) …
Updating PPD files for cups …
Updating PPD files for cups-filters …
Current status: 75 updates [-28].
Les exercices d’hier:
[code]root@debian:/home/belette# aptitude remove --purge gstreamer1.0-plugins-good
0 packages upgraded, 0 newly installed, 1 to remove and 74 not upgraded.
 Remove the following packages:
  1. banshee
  5. quodlibet
  1. libtag1-vanilla
  2. libtag1c2a
  4. xfce4-goodies
  1. libtag1-vanilla
  2. libtag1c2a
libtag1v5{a} libtag1v5-vanilla{a}
libtag1-vanilla{a} libtag1c2a{a}
gstreamer0.10-plugins-good gstreamer1.0-plugins-good libtagc0 thunar-media-tags-plugin
4 packages upgraded, 2 newly installed, 2 to remove and 71 not upgraded.
Need to get 4,784 kB of archives. After unpacking 238 kB will be used.
Get: 1 http://ftp.uk.debian.org/debian/ testing/main gstreamer1.0-plugins-good amd64 1.4.5-2+b2 [2,366 kB]
Get: 2 http://ftp.uk.debian.org/debian/ testing/main thunar-media-tags-plugin amd64 0.2.1-1+b2 [65.4 kB]
Get: 3 http://ftp.uk.debian.org/debian/ testing/main libtagc0 amd64 1.9.1-2.4 [22.8 kB]
Get: 4 http://ftp.uk.debian.org/debian/ testing/main gstreamer0.10-plugins-good amd64 0.10.31-3+nmu4+b2 [2,030 kB]
Get: 5 http://ftp.uk.debian.org/debian/ testing/main libtag1v5-vanilla amd64 1.9.1-2.4 [282 kB]
Get: 6 http://ftp.uk.debian.org/debian/ testing/main libtag1v5 amd64 1.9.1-2.4 [17.7 kB]
Fetched 4,784 kB in 3s (1,350 kB/s)
(Reading database … 135722 files and directories currently installed.)
Preparing to unpack …/gstreamer1.0-plugins-good_1.4.5-2+b2_amd64.deb …
Unpacking gstreamer1.0-plugins-good:amd64 (1.4.5-2+b2) over (1.4.5-2+b1) …
Preparing to unpack …/thunar-media-tags-plugin_0.2.1-1+b2_amd64.deb …
Unpacking thunar-media-tags-plugin (0.2.1-1+b2) over (0.2.1-1+b1) …
Preparing to unpack …/libtagc0_1.9.1-2.4_amd64.deb …
Unpacking libtagc0:amd64 (1.9.1-2.4) over (1.9.1-2.1) …
Preparing to unpack …/gstreamer0.10-plugins-good_0.10.31-3+nmu4+b2_amd64.deb …
Unpacking gstreamer0.10-plugins-good:amd64 (0.10.31-3+nmu4+b2) over (0.10.31-3+nmu4+b1) …
Removing libtag1c2a:amd64 (1.9.1-2.1) …
Removing libtag1-vanilla:amd64 (1.9.1-2.1) …
Selecting previously unselected package libtag1v5-vanilla:amd64.
Preparing to unpack …/libtag1v5-vanilla_1.9.1-2.4_amd64.deb …
Unpacking libtag1v5-vanilla:amd64 (1.9.1-2.4) …
Selecting previously unselected package libtag1v5:amd64.
Preparing to unpack …/libtag1v5_1.9.1-2.4_amd64.deb …
Unpacking libtag1v5:amd64 (1.9.1-2.4) …
Setting up libtag1v5-vanilla:amd64 (1.9.1-2.4) …
Setting up gstreamer1.0-plugins-good:amd64 (1.4.5-2+b2) …
Setting up libtag1v5:amd64 (1.9.1-2.4) …
Setting up libtagc0:amd64 (1.9.1-2.4) …
Setting up thunar-media-tags-plugin (0.2.1-1+b2) …
Setting up gstreamer0.10-plugins-good:amd64 (0.10.31-3+nmu4+b2) …
Current status: 71 updates [-4].
[code]root@debian:/home/belette# aptitude -s remove libwxbase3.0-0
libwxbase3.0-0
0 packages upgraded, 0 newly installed, 1 to remove and 71 not upgraded.
Need to get 0 B of archives. After unpacking 3,381 kB will be freed.
filezilla : Depends: libwxbase3.0-0 (>= 3.0.1) but it is not going to be installed.
libwxgtk3.0-0 : Depends: libwxbase3.0-0 (>= 3.0.2+dfsg) but it is not going to be installed.
  1. filezilla
  2. libwxgtk3.0-0
  1. libtinyxml2.6.2
  2. libwxgtk3.0-0
  3. libtinyxml2.6.2v5 [2.6.2-3 (testing, unstable)]
  4. libwxbase3.0-0v5 [3.0.2+dfsg-1.2 (testing, unstable)]
  5. libwxgtk3.0-0v5 [3.0.2+dfsg-1.2 (testing, unstable)]
  6. filezilla [3.9.0.5-1 (now, stable) -> 3.12.0.2-1 (unstable)]
  7. filezilla-common [3.9.0.5-1 (now, stable) -> 3.12.0.2-1 (unstable)]
  1. libwxbase3.0-0 [3.0.2+dfsg-1 (now, testing, unstable)]
  1. libwxbase3.0-0 [3.0.2+dfsg-1 (now, testing, unstable) -> 3.0.2-1+b1 (stable)]
  2. libwxgtk3.0-0 [3.0.2+dfsg-1 (now, testing, unstable) -> 3.0.2-1+b1 (stable)]
libwxbase3.0-0 libwxgtk3.0-0
0 packages upgraded, 0 newly installed, 2 downgraded, 0 to remove and 71 not upgraded.
Need to get 5,711 kB of archives. After unpacking 22.5 kB will be used.
[code]root@debian:/home/belette# aptitude -s remove libwxgtk3.0-0
libwxgtk3.0-0
Need to get 0 B of archives. After unpacking 19.4 MB will be freed.
filezilla : Depends: libwxgtk3.0-0 (>= 3.0.1) but it is not going to be installed.
  1. filezilla
  1. libtinyxml2.6.2
  2. libwxbase3.0-0
  1. libwxgtk3.0-0 [3.0.2+dfsg-1 (now, testing, unstable)]
  1. libwxgtk3.0-0 [3.0.2+dfsg-1 (now, testing, unstable) -> 3.0.2-1+b1 (stable)]
libwxgtk3.0-0
0 packages upgraded, 0 newly installed, 1 downgraded, 0 to remove and 71 not upgraded.
Need to get 4,608 kB of archives. After unpacking 5,120 B will be used.
[code]root@debian:/home/belette# aptitude -s remove libllvm3.5
libllvm3.5
Need to get 0 B of archives. After unpacking 30.6 MB will be freed.
libclamav6 : Depends: libllvm3.5 but it is not going to be installed.
libgl1-mesa-dri : Depends: libllvm3.5 but it is not going to be installed.
libxatracker2 : Depends: libllvm3.5 but it is not going to be installed.
  1.  clamav
  2.  clamav-freshclam
  3.  libclamav6
  4.  libgl1-mesa-dri
  5.  libxatracker2
  6.  task-desktop
  8.  xorg
  9.  xserver-xorg-video-all
  10. xserver-xorg-video-vmware
  1. libllvm3.5v5 [1:3.5.2-2 (unstable)]
  2. libclamav6 [0.98.7+dfsg-2 (now, testing) -> 0.98.7+dfsg-3 (unstable)]
  3. libgl1-mesa-dri [10.6.3-1 (now, testing) -> 10.6.7-1 (unstable)]
  4. libxatracker2 [10.6.3-1 (now, testing) -> 10.6.7-1 (unstable)]
  1. clamav
  2. clamav-freshclam
  3. libclamav6
  4. libllvm3.5v5 [1:3.5.2-2 (unstable)]
  5. libgl1-mesa-dri [10.6.3-1 (now, testing) -> 10.6.7-1 (unstable)]
  6. libxatracker2 [10.6.3-1 (now, testing) -> 10.6.7-1 (unstable)]
  1. libgl1-mesa-dri
  2. libxatracker2
  3. task-desktop
  4. task-xfce-desktop
  5. xorg
  6. xserver-xorg-video-all
  7. xserver-xorg-video-vmware
  8. libllvm3.5v5 [1:3.5.2-2 (unstable)]
  9. libclamav6 [0.98.7+dfsg-2 (now, testing) -> 0.98.7+dfsg-3 (unstable)]
libllvm3.5v5{a}
crda{u} dnsmasq-base{u} evince-gtk{u} exfalso{u} gir1.2-gst-plugins-base-1.0{u} gir1.2-gstreamer-1.0{u} gir1.2-gtksource-3.0{u} hyphen-en-us{u} iw{u}
libdevmapper-event1.02.1{u} libdiscid0{u} libgimp2.0{u} libgl1-mesa-dri{a} libgtksourceview-3.0-1{u} libgtksourceview-3.0-common{u} libjim0.76{u}
libjs-sphinxdoc{u} libjs-underscore{u} libllvm3.5 liblvm2app2.2{u} libmbim-glib4{u} libmbim-proxy{u} libmm-glib0{u} libndp0{u} libnetfilter-conntrack3{u}
libnl-3-200{u} libnl-genl-3-200{u} libnl-route-3-200{u} libqmi-glib1{u} libqmi-proxy{u} libreoffice-gtk{u} libreoffice-help-en-us{u} libteamdctl0{u}
libtidy-0.99-0{u} libxatracker2{a} mobile-broadband-provider-info{u} modemmanager{u} network-manager{u} network-manager-gnome{u} python-cddb{u}
python-feedparser{u} python-musicbrainz2{u} python-mutagen{u} python-pyinotify{u} python-utidylib{u} quodlibet{u} task-desktop{a} task-xfce-desktop{a}
udisks{u} usb-modeswitch{u} usb-modeswitch-data{u} wireless-regdb{u} wpasupplicant{u} xorg{a} xsane{u} xsane-common{u} xserver-xorg-video-all{a}
xserver-xorg-video-vmware{a}
libclamav6
1 packages upgraded, 1 newly installed, 58 to remove and 67 not upgraded.
Need to get 8,419 kB of archives. After unpacking 177 MB will be freed.
gir1.2-panelapplet-5.0{a} libcamel-1.2-52{a} libecal-1.2-18{a} libedataserver-1.2-20{a} libical1a{ab} libllvm3.5v5{ab} libnpth0{a} libpanel-applet0{a}
libproxy1v5{ab} libsidplay1v5{ab} libtinyxml2.6.2v5{ab} libwxbase3.0-0v5{ab} libwxgtk3.0-0v5{ab} python3-gi{a} xfce4-whiskermenu-plugin{a}
gstreamer1.0-plugins-ugly libclamav6 libgl1-mesa-dri libgnutls-deb0-28{b} libgnutls-openssl27 libgstreamer-plugins-bad1.0-0 libmpg123-0 libxatracker2
mutter-common orage osmo python-ply xfce4 xfce4-battery-plugin xfce4-clipman-plugin xfce4-cpufreq-plugin xfce4-cpugraph-plugin xfce4-datetime-plugin xfce4-dict
xfce4-diskperf-plugin xfce4-fsguard-plugin xfce4-genmon-plugin xfce4-goodies xfce4-mailwatch-plugin xfce4-mixer xfce4-mount-plugin xfce4-netload-plugin
xfce4-notes-plugin xfce4-panel xfce4-places-plugin xfce4-power-manager-plugins xfce4-quicklauncher-plugin xfce4-sensors-plugin xfce4-smartbookmark-plugin
xfce4-systemload-plugin xfce4-timer-plugin xfce4-verve-plugin xfce4-wavelan-plugin xfce4-weather-plugin xfce4-xkb-plugin xserver-xorg-core{b}
xserver-xorg-input-wacom xserver-xorg-video-ati xserver-xorg-video-cirrus xserver-xorg-video-fbdev xserver-xorg-video-intel xserver-xorg-video-mach64
xserver-xorg-video-mga xserver-xorg-video-neomagic xserver-xorg-video-nouveau xserver-xorg-video-openchrome xserver-xorg-video-qxl xserver-xorg-video-r128
xserver-xorg-video-radeon xserver-xorg-video-savage xserver-xorg-video-siliconmotion xserver-xorg-video-sisusb xserver-xorg-video-tdfx
evolution-common evolution-data-server gnome-control-center
71 packages upgraded, 15 newly installed, 0 to remove and 0 not upgraded.
Need to get 52.0 MB/52.0 MB of archives. After unpacking 51.1 MB will be used.
python-pycparser : Depends: python-ply (< 3.5) but 3.7-1 is to be installed. or
python-ply-yacc-3.2 which is a virtual package.
Depends: python-ply-lex-3.2 which is a virtual package.
  1.  brasero
  2.  deluge
  3.  deluge-common
  4.  deluge-gtk
  5.  filezilla
  6.  gir1.2-panelapplet-4.0
  7.  gnupg2
  8.  gstreamer1.0-plugins-ugly
  9.  libbrasero-media3-1
  10. libecal-1.2-15
  11. libedata-cal-1.2-20
  12. libgmime-2.6-0
  13. libgnutls28
  14. libgpgme11
  15. libhogweed2
  16. libical1
  17. libllvm3.5
  18. libnettle4
  19. libpanel-applet-4-0
  20. libproxy1
  22. mutt
  23. python-cffi
  24. python-cryptography
  25. python-openssl
  26. python-pycparser
  27. python-service-identity
  28. python-twisted-core
  29. python-twisted-web
  30. quodlibet
  31. xserver-xorg-video-modesetting
  32. libsidplay1v5 [Not Installed]
  33. libtinyxml2.6.2v5 [Not Installed]
  34. libwxbase3.0-0v5 [Not Installed]
  35. libwxgtk3.0-0v5 [Not Installed]
Abort.
Désolé, l’irl.
Ont y retournes.
En [mono]simulation[/mono], acceptes à la deuxième propositions.
$ aptitude -s remove --purge libwxbase3.0-0 $ aptitude -s remove libwxgtk3.0-0 $ aptitude -s remove libllvm3.5
