Problèmes de màj avec aptitude
Pas de soucis :wink:
[code]root@debian:/home/belette# aptitude -s remove --purge libwxbase3.0-0
The following packages will be REMOVED:
libwxbase3.0-0
0 packages upgraded, 0 newly installed, 1 to remove and 71 not upgraded.
Need to get 0 B of archives. After unpacking 3,381 kB will be freed.
The following packages have unmet dependencies:
filezilla : Depends: libwxbase3.0-0 (>= 3.0.1) but it is not going to be installed.
libwxgtk3.0-0 : Depends: libwxbase3.0-0 (>= 3.0.2+dfsg) but it is not going to be installed.
The following actions will resolve these dependencies:
 Remove the following packages:
  1. filezilla
  2. libwxgtk3.0-0
Accept this solution? [Y/n/q/?] n
  1. libtinyxml2.6.2
  2. libwxgtk3.0-0
    Install the following packages:
  3. libtinyxml2.6.2v5 [2.6.2-3 (testing, unstable)]
  4. libwxbase3.0-0v5 [3.0.2+dfsg-1.2 (testing, unstable)]
  5. libwxgtk3.0-0v5 [3.0.2+dfsg-1.2 (testing, unstable)]
    Upgrade the following packages:
  6. filezilla [3.9.0.5-1 (now, stable) -> 3.12.0.2-1 (unstable)]
  7. filezilla-common [3.9.0.5-1 (now, stable) -> 3.12.0.2-1 (unstable)]
Accept this solution? [Y/n/q/?] y
The following NEW packages will be installed:
libtinyxml2.6.2v5{a} libwxbase3.0-0v5{a} libwxgtk3.0-0v5{a}
libtinyxml2.6.2{a} libwxbase3.0-0 libwxgtk3.0-0{a}
The following packages will be upgraded:
filezilla filezilla-common
2 packages upgraded, 3 newly installed, 3 to remove and 69 not upgraded.
Need to get 9,114 kB of archives. After unpacking 298 kB will be freed.
Do you want to continue? [Y/n/?]
[code]root@debian:/home/belette# aptitude -s remove libwxgtk3.0-0
libwxgtk3.0-0
Need to get 0 B of archives. After unpacking 19.4 MB will be freed.
filezilla : Depends: libwxgtk3.0-0 (>= 3.0.1) but it is not going to be installed.
  1. filezilla
  1. libtinyxml2.6.2
  2. libwxbase3.0-0
libtinyxml2.6.2{a} libwxbase3.0-0{a} libwxgtk3.0-0
[code]root@debian:/home/belette# aptitude -s remove libllvm3.5
libllvm3.5
Need to get 0 B of archives. After unpacking 30.6 MB will be freed.
libclamav6 : Depends: libllvm3.5 but it is not going to be installed.
libgl1-mesa-dri : Depends: libllvm3.5 but it is not going to be installed.
libxatracker2 : Depends: libllvm3.5 but it is not going to be installed.
  1.  clamav
  2.  clamav-freshclam
  3.  libclamav6
  4.  libgl1-mesa-dri
  5.  libxatracker2
  6.  task-desktop
  7.  task-xfce-desktop
  8.  xorg
  9.  xserver-xorg-video-all
  10. xserver-xorg-video-vmware
  1. libllvm3.5v5 [1:3.5.2-2 (unstable)]
  2. libclamav6 [0.98.7+dfsg-2 (now, testing) -> 0.98.7+dfsg-3 (unstable)]
  3. libgl1-mesa-dri [10.6.3-1 (now, testing) -> 10.6.7-1 (unstable)]
  4. libxatracker2 [10.6.3-1 (now, testing) -> 10.6.7-1 (unstable)]
libllvm3.5v5{a}
libllvm3.5
libclamav6 libgl1-mesa-dri libxatracker2
3 packages upgraded, 1 newly installed, 1 to remove and 68 not upgraded.
Need to get 13.0 MB of archives. After unpacking 1,175 kB will be freed.
Voilà, ça se décante.
Tu [mono]valides[/mono], à la deuxième propositions.
[code]# aptitude remove --purge libwxbase3.0-0
aptitude remove --purge libwxgtk3.0-0
aptitude remove --purge libllvm3.5
Tu recharges le cache ([mono]update[/mono]) et relances :
$ aptitude -s upgrade $ aptitude -s safe-upgrade $ aptitude -s full-upgrade
[code]root@debian:/home/belette# aptitude remove --purge libwxbase3.0-0
libwxbase3.0-0
  1. filezilla
  2. libwxgtk3.0-0
  1. libtinyxml2.6.2
  2. libwxgtk3.0-0
Do you want to continue? [Y/n/?] y
Get: 1 http://ftp.uk.debian.org/debian/ testing/main libtinyxml2.6.2v5 amd64 2.6.2-3 [36.8 kB]
Get: 2 http://ftp.uk.debian.org/debian/ testing/main libwxbase3.0-0v5 amd64 3.0.2+dfsg-1.2 [1,075 kB]
Get: 3 http://ftp.uk.debian.org/debian/ testing/main libwxgtk3.0-0v5 amd64 3.0.2+dfsg-1.2 [4,488 kB]
Get: 4 http://ftp.fr.debian.org/debian/ unstable/main filezilla amd64 3.12.0.2-1 [1,479 kB]
Get: 5 http://ftp.fr.debian.org/debian/ unstable/main filezilla-common all 3.12.0.2-1 [2,035 kB]
Fetched 9,114 kB in 10s (882 kB/s)
Retrieving bug reports… Done
Parsing Found/Fixed information… Done
Reading changelogs… Done
(Reading database … 135722 files and directories currently installed.)
Preparing to unpack …/filezilla_3.12.0.2-1_amd64.deb …
Unpacking filezilla (3.12.0.2-1) over (3.9.0.5-1) …
Processing triggers for menu (2.1.47) …
Processing triggers for man-db (2.7.3-1) …
Processing triggers for mime-support (3.59) …
Processing triggers for gnome-menus (3.13.3-6) …
Processing triggers for desktop-file-utils (0.22-1) …
Removing libtinyxml2.6.2:amd64 (2.6.2-2) …
Processing triggers for libc-bin (2.19-20) …
Selecting previously unselected package libtinyxml2.6.2v5:amd64.
(Reading database … 135717 files and directories currently installed.)
Preparing to unpack …/libtinyxml2.6.2v5_2.6.2-3_amd64.deb …
Unpacking libtinyxml2.6.2v5:amd64 (2.6.2-3) …
Removing libwxgtk3.0-0:amd64 (3.0.2+dfsg-1) …
Removing libwxbase3.0-0:amd64 (3.0.2+dfsg-1) …
Selecting previously unselected package libwxbase3.0-0v5:amd64.
(Reading database … 135683 files and directories currently installed.)
Preparing to unpack …/libwxbase3.0-0v5_3.0.2+dfsg-1.2_amd64.deb …
Unpacking libwxbase3.0-0v5:amd64 (3.0.2+dfsg-1.2) …
Selecting previously unselected package libwxgtk3.0-0v5:amd64.
Preparing to unpack …/libwxgtk3.0-0v5_3.0.2+dfsg-1.2_amd64.deb …
Unpacking libwxgtk3.0-0v5:amd64 (3.0.2+dfsg-1.2) …
Preparing to unpack …/filezilla-common_3.12.0.2-1_all.deb …
Unpacking filezilla-common (3.12.0.2-1) over (3.9.0.5-1) …
Processing triggers for hicolor-icon-theme (0.13-1) …
Setting up libtinyxml2.6.2v5:amd64 (2.6.2-3) …
Setting up libwxbase3.0-0v5:amd64 (3.0.2+dfsg-1.2) …
Setting up libwxgtk3.0-0v5:amd64 (3.0.2+dfsg-1.2) …
Setting up filezilla-common (3.12.0.2-1) …
Setting up filezilla (3.12.0.2-1) …
Current status: 69 updates [-2].
[code]Current status: 69 updates [-2].
root@debian:/home/belette# aptitude remove --purge libwxgtk3.0-0
Package libwxgtk3.0-0 is not installed, so it will not be removed
No packages will be installed, upgraded, or removed.
0 packages upgraded, 0 newly installed, 0 to remove and 69 not upgraded.
Need to get 0 B of archives. After unpacking 0 B will be used.
Sur celui-là, j’ai vu passer xorg et xserver, pas de crainte à avoir?
root@debian:/home/belette# aptitude remove --purge libllvm3.5
libllvm3.5
0 packages upgraded, 0 newly installed, 1 to remove and 69 not upgraded.
  1.  clamav
  2.  clamav-freshclam
  3.  libclamav6
  4.  libgl1-mesa-dri
  5.  libxatracker2
  6.  task-desktop
  8.  xorg
libllvm3.5v5{a}
libllvm3.5
3 packages upgraded, 1 newly installed, 1 to remove and 66 not upgraded.
Get: 1 http://ftp.fr.debian.org/debian/ unstable/main libxatracker2 amd64 10.6.7-1 [959 kB]
Get: 2 http://ftp.fr.debian.org/debian/ unstable/main libgl1-mesa-dri amd64 10.6.7-1 [3,606 kB]
Get: 3 http://ftp.fr.debian.org/debian/ unstable/main libclamav6 amd64 0.98.7+dfsg-3 [930 kB]
Get: 4 http://ftp.fr.debian.org/debian/ unstable/main libllvm3.5v5 amd64 1:3.5.2-2 [7,489 kB]
Fetched 13.0 MB in 8s (1,604 kB/s)
(Reading database … 135846 files and directories currently installed.)
Preparing to unpack …/libxatracker2_10.6.7-1_amd64.deb …
Unpacking libxatracker2:amd64 (10.6.7-1) over (10.6.3-1) …
Preparing to unpack …/libgl1-mesa-dri_10.6.7-1_amd64.deb …
Unpacking libgl1-mesa-dri:amd64 (10.6.7-1) over (10.6.3-1) …
Preparing to unpack …/libclamav6_0.98.7+dfsg-3_amd64.deb …
Unpacking libclamav6 (0.98.7+dfsg-3) over (0.98.7+dfsg-2) …
Removing libllvm3.5:amd64 (1:3.5.2-1) …
Selecting previously unselected package libllvm3.5v5:amd64.
(Reading database … 135840 files and directories currently installed.)
Preparing to unpack …/libllvm3.5v5_1%3a3.5.2-2_amd64.deb …
Unpacking libllvm3.5v5:amd64 (1:3.5.2-2) …
Setting up libllvm3.5v5:amd64 (1:3.5.2-2) …
Setting up libxatracker2:amd64 (10.6.7-1) …
Setting up libgl1-mesa-dri:amd64 (10.6.7-1) …
Setting up libclamav6 (0.98.7+dfsg-3) …
Current status: 66 updates [-3].
Current status: 67 updates [+1]. root@debian:/home/belette# aptitude -s upgrade Resolving dependencies... The following packages will be upgraded: xdg-utils 1 packages upgraded, 0 newly installed, 0 to remove and 66 not upgraded. Need to get 68.2 kB of archives. After unpacking 0 B will be used. Do you want to continue? [Y/n/?]
Current status: 67 updates [+1]. root@debian:/home/belette# aptitude -s upgrade Resolving dependencies... The following packages will be upgraded: xdg-utils 1 packages upgraded, 0 newly installed, 0 to remove and 66 not upgraded. Need to get 68.2 kB of archives. After unpacking 0 B will be used. Do you want to continue? [Y/n/?] n Abort. root@debian:/home/belette# aptitude -s safe-upgrade Resolving dependencies... The following packages will be upgraded: xdg-utils 1 packages upgraded, 0 newly installed, 0 to remove and 66 not upgraded. Need to get 68.2 kB of archives. After unpacking 0 B will be used. Do you want to continue? [Y/n/?]
[code]root@debian:/home/belette# aptitude -s full-upgrade
gir1.2-panelapplet-5.0{a} libcamel-1.2-52{a} libecal-1.2-18{a} libedataserver-1.2-20{a} libical1a{ab} libnpth0{a} libpanel-applet0{a} libproxy1v5{ab}
libsidplay1v5{ab} python3-gi{a} xfce4-whiskermenu-plugin{a}
bluez-obexd glib-networking glib-networking-services gnome-applets gnome-applets-data gnome-panel{b} gnome-panel-data gnupg-agent gstreamer1.0-plugins-ugly
libgnutls-deb0-28{b} libgnutls-openssl27 libgstreamer-plugins-bad1.0-0 libmpg123-0 mutter-common orage osmo python-ply xdg-utils xfce4 xfce4-battery-plugin
xfce4-clipman-plugin xfce4-cpufreq-plugin xfce4-cpugraph-plugin xfce4-datetime-plugin xfce4-dict xfce4-diskperf-plugin xfce4-fsguard-plugin xfce4-genmon-plugin
xfce4-goodies xfce4-mailwatch-plugin xfce4-mixer xfce4-mount-plugin xfce4-netload-plugin xfce4-notes-plugin xfce4-panel xfce4-places-plugin
xfce4-power-manager-plugins xfce4-quicklauncher-plugin xfce4-sensors-plugin xfce4-smartbookmark-plugin xfce4-systemload-plugin xfce4-timer-plugin
xfce4-verve-plugin xfce4-wavelan-plugin xfce4-weather-plugin xfce4-xkb-plugin xserver-xorg-core{b} xserver-xorg-input-wacom xserver-xorg-video-ati
xserver-xorg-video-cirrus xserver-xorg-video-fbdev xserver-xorg-video-intel xserver-xorg-video-mach64 xserver-xorg-video-mga xserver-xorg-video-neomagic
xserver-xorg-video-nouveau xserver-xorg-video-openchrome xserver-xorg-video-qxl xserver-xorg-video-r128 xserver-xorg-video-radeon xserver-xorg-video-savage
xserver-xorg-video-siliconmotion xserver-xorg-video-sisusb xserver-xorg-video-tdfx xserver-xorg-video-trident xserver-xorg-video-vesa xserver-xorg-video-vmware
The following packages are RECOMMENDED but will NOT be installed:
evolution-common evolution-data-server gnome-control-center
67 packages upgraded, 11 newly installed, 0 to remove and 0 not upgraded.
Need to get 29.9 MB/29.9 MB of archives. After unpacking 914 kB will be freed.
libgnutls-deb0-28 : Conflicts: libhogweed2 but 2.7.1-5 is installed.
Conflicts: libnettle4 but 2.7.1-5 is installed.
python-pycparser : Depends: python-ply (< 3.5) but 3.7-1 is to be installed. or
python-ply-yacc-3.2 which is a virtual package.
Depends: python-ply-lex-3.2 which is a virtual package.
libical1a : Breaks: libical1 but 1.0-1.2 is installed.
xserver-xorg-core : Conflicts: xserver-xorg-video-modesetting but 0.9.0-2 is installed.
gnome-panel : Breaks: libpanel-applet-4-0 (< 3.14.0) but 3.8.1-7+b2 is installed.
libsidplay1v5 : Conflicts: libsidplay1 but 1.36.59-7 is installed.
gnupg2 : Depends: gnupg-agent (= 2.0.28-3) but 2.1.8-1 is to be installed.
libproxy1v5 : Conflicts: libproxy1 but 0.4.11-4+b2 is installed.
xserver-xorg-video-modesetting : Depends: xorg-video-abi-18 which is a virtual package.
  1.  brasero
  2.  deluge
  3.  deluge-common
  4.  deluge-gtk
  5.  gir1.2-panelapplet-4.0
  6.  gnupg2
  7.  gstreamer1.0-plugins-ugly
  8.  libbrasero-media3-1
  9.  libecal-1.2-15
  10. libedata-cal-1.2-20
  11. libgmime-2.6-0
  12. libgnutls28
  13. libgpgme11
  14. libhogweed2
  15. libical1
  16. libnettle4
  17. libpanel-applet-4-0
  18. libproxy1
  19. libtotem-plparser18
  20. mutt
  21. python-cffi
  22. python-cryptography
  23. python-openssl
  24. python-pycparser
  25. python-service-identity
  26. python-twisted-core
  27. python-twisted-web
  28. quodlibet
  29. xserver-xorg-video-modesetting
    Keep the following packages at their current version:
  30. libsidplay1v5 [Not Installed]
root@debian:/home/belette# apt-show-versions -u bluez-obexd:amd64/testing 5.23-1 upgradeable to 5.33-1 glib-networking:amd64/testing 2.44.0-2 upgradeable to 2.44.0-2+b1 glib-networking-services:amd64/testing 2.44.0-2 upgradeable to 2.44.0-2+b1 gnome-applets:amd64/testing 3.8.1-1+b1 upgradeable to 3.16.1-3 gnome-applets-data:all/stable 3.8.1-1 upgradeable to 3.16.1-3 gnome-panel:amd64/testing 3.4.2.1-6 upgradeable to 3.16.1-4 gnome-panel-data:all/testing 3.4.2.1-6 upgradeable to 3.16.1-4 gnupg-agent:amd64/testing 2.0.28-3 upgradeable to 2.1.8-1 gstreamer1.0-plugins-ugly:amd64/testing 1.4.5-2+b1 upgradeable to 1.4.5-2+b2 libgnutls-deb0-28:amd64/testing 3.3.15-6 upgradeable to 3.3.17-1 libgnutls-openssl27:amd64/testing 3.3.15-6 upgradeable to 3.3.17-1 libgstreamer-plugins-bad1.0-0:amd64/testing 1.4.5-2+b1 upgradeable to 1.4.5-3 libmpg123-0:amd64/testing 1.22.2-1 upgradeable to 1.22.3-1 mutter-common:all/testing 3.4.1-7 upgradeable to 3.16.3-1 openssl:amd64/stable *manually* upgradeable from 1.0.1k-3 to 1.0.2d-1 orage:amd64/testing 4.10.0-1+b1 upgradeable to 4.12.1-1+b1 osmo:amd64/testing 0.2.12-1 upgradeable to 0.2.14-1 python-ply:all/stable 3.4-5 upgradeable to 3.7-1 xdg-utils:all/testing 1.1.0~rc3+git20150907-1 upgradeable to 1.1.0~rc3+git20150907-2 xfce4:all/stable 4.10.1 upgradeable to 4.12.1 xfce4-battery-plugin:amd64/stable 1.0.5-4 upgradeable to 1.0.5-4+b1 xfce4-clipman-plugin:amd64/stable 2:1.2.6-1 upgradeable to 2:1.2.6-1+b1 xfce4-cpufreq-plugin:amd64/stable 1.1.0-1 upgradeable to 1.1.2-1 xfce4-cpugraph-plugin:amd64/stable 1.0.5-1 upgradeable to 1.0.5-1+b1 xfce4-datetime-plugin:amd64/stable 0.6.2-2 upgradeable to 0.6.2-2+b1 xfce4-dict:amd64/stable 0.7.0-1 upgradeable to 0.7.1-1+b1 xfce4-diskperf-plugin:amd64/stable 2.5.4-3 upgradeable to 2.5.5-1+b1 xfce4-fsguard-plugin:amd64/stable 1.0.1-2 upgradeable to 1.0.2-1+b1 xfce4-genmon-plugin:amd64/stable 3.4.0-2 upgradeable to 3.4.0-2+b1 xfce4-goodies:amd64/stable 4.10 upgradeable to 4.12 xfce4-mailwatch-plugin:amd64/stable 1.2.0-2 upgradeable to 1.2.0-2+b1 xfce4-mixer:amd64/stable 4.10.0-3 upgradeable to 4.10.0-3+b1 xfce4-mount-plugin:amd64/stable 0.6.7-1 upgradeable to 0.6.7-1+b1 xfce4-netload-plugin:amd64/stable 1.2.0-1 upgradeable to 1.2.4-1+b1 xfce4-notes-plugin:amd64/stable 1.7.7-5 upgradeable to 1.8.1-1 xfce4-panel:amd64/stable 4.10.1-1 upgradeable to 4.12.0-3 xfce4-places-plugin:amd64/stable 1.6.0-1 upgradeable to 1.7.0-3 xfce4-power-manager-plugins:amd64/testing 1.4.1-2 upgradeable to 1.4.4-4 xfce4-quicklauncher-plugin:amd64/stable 1.9.4-11 upgradeable to 1.9.4-11+b1 xfce4-sensors-plugin:amd64/stable 1.2.5-2 upgradeable to 1.2.6-1+b1 xfce4-smartbookmark-plugin:amd64/stable 0.4.5-1 upgradeable to 0.4.6-1+b1 xfce4-systemload-plugin:amd64/stable 1.1.1-4 upgradeable to 1.1.2-1+b1 xfce4-timer-plugin:amd64/stable 1.6.0-1 upgradeable to 1.6.0-1+b1 xfce4-verve-plugin:amd64/stable 1.0.0-3 upgradeable to 1.0.1-1+b1 xfce4-wavelan-plugin:amd64/stable 0.5.11-3 upgradeable to 0.5.12-1 xfce4-weather-plugin:amd64/stable 0.8.3-2 upgradeable to 0.8.6-1 xfce4-xkb-plugin:amd64/stable 1:0.5.6-1 upgradeable to 1:0.7.1-2+b1 xserver-xorg-core:amd64/stable 2:1.16.4-1 upgradeable to 2:1.17.2-1.1 xserver-xorg-input-wacom:amd64/stable 0.26.0+20140918-1 upgradeable to 0.30.0-1 xserver-xorg-video-ati:amd64/stable 1:7.5.0-1 upgradeable to 1:7.5.0-1+b1 xserver-xorg-video-cirrus:amd64/stable 1:1.5.2-2+b1 upgradeable to 1:1.5.3-1 xserver-xorg-video-fbdev:amd64/stable 1:0.4.4-1+b2 upgradeable to 1:0.4.4-1+b3 xserver-xorg-video-intel:amd64/stable 2:2.21.15-2+b2 upgradeable to 2:2.99.917-2 xserver-xorg-video-mach64:amd64/stable 6.9.4-2 upgradeable to 6.9.5-1 xserver-xorg-video-mga:amd64/testing 1:1.6.4-1 upgradeable to 1:1.6.4-1+b1 xserver-xorg-video-neomagic:amd64/stable 1:1.2.8-1+b2 upgradeable to 1:1.2.9-1 xserver-xorg-video-nouveau:amd64/stable 1:1.0.11-1 upgradeable to 1:1.0.11-1+b1 xserver-xorg-video-openchrome:amd64/stable 1:0.3.3-1+b2 upgradeable to 1:0.3.3-1+b3 xserver-xorg-video-qxl:amd64/stable 0.1.1-2+b1 upgradeable to 0.1.4-3 xserver-xorg-video-r128:amd64/stable 6.9.2-1+b2 upgradeable to 6.10.0-1 xserver-xorg-video-radeon:amd64/stable 1:7.5.0-1 upgradeable to 1:7.5.0-1+b1 xserver-xorg-video-savage:amd64/stable 1:2.3.7-2+b2 upgradeable to 1:2.3.8-1 xserver-xorg-video-siliconmotion:amd64/stable 1:1.7.7-2+b2 upgradeable to 1:1.7.8-1 xserver-xorg-video-sisusb:amd64/stable 1:0.9.6-2+b2 upgradeable to 1:0.9.6-2+b3 xserver-xorg-video-tdfx:amd64/testing 1:1.4.6-1 upgradeable to 1:1.4.6-1+b1 xserver-xorg-video-trident:amd64/testing 1:1.3.7-1 upgradeable to 1:1.3.7-1+b1 xserver-xorg-video-vesa:amd64/stable 1:2.3.3-1+b3 upgradeable to 1:2.3.3-1+b4 xserver-xorg-video-vmware:amd64/testing 1:13.1.0-1 upgradeable to 1:13.1.0-2 root@debian:/home/belette#
La suite.
$ aptitude -s remove --purge libhogweed2 libnettle4 $ aptitude -s remove --purge python-ply $ aptitude -s remove --purge xserver-xorg-video-modesetting
Vérifies si le paquet [mono]gnupg2[/mono] n’est pas épinglé en [mono]/etc/apt/preferences[/mono].
Dans le doute, j’ai fait N/N/Y
[code]root@debian:/home/belette# aptitude -s remove --purge libhogweed2 libnettle4
0 packages upgraded, 0 newly installed, 2 to remove and 67 not upgraded.
Need to get 0 B of archives. After unpacking 567 kB will be freed.
libgnutls28 : Depends: libhogweed2 (>= 2.7) but it is not going to be installed.
Depends: libnettle4 (>= 2.7) but it is not going to be installed.
  1. libgnutls28
  1. libhogweed2 [2.7.1-5 (now, stable)]
  2. libnettle4 [2.7.1-5 (now, stable)]
*** No more solutions available ***
0 packages upgraded, 0 newly installed, 0 to remove and 67 not upgraded.
Would download/install/remove packages.
[code]root@debian:/home/belette# aptitude -s remove --purge python-ply
python-ply
0 packages upgraded, 0 newly installed, 1 to remove and 66 not upgraded.
Need to get 0 B of archives. After unpacking 292 kB will be freed.
python-pycparser : Depends: python-ply (>= 3.2) but it is not going to be installed.
Depends: python-ply (< 3.5) but it is not going to be installed. or
  1.  deluge
  2.  deluge-common
  3.  deluge-gtk
  4.  python-cffi
  5.  python-cryptography
  6.  python-openssl
  7.  python-pycparser
  8.  python-service-identity
  9.  python-twisted-core
  10. python-twisted-web
  1. python-ply [3.4-5 (now, stable, testing)]
[code]root@debian:/home/belette# aptitude -s remove --purge xserver-xorg-video-modesetting
0 packages upgraded, 0 newly installed, 1 to remove and 67 not upgraded.
Need to get 0 B of archives. After unpacking 62.5 kB will be freed.
xserver-xorg-video-all : Depends: xserver-xorg-video-modesetting but it is not going to be installed.
  1. task-desktop
  2. task-xfce-desktop
  3. xserver-xorg-video-all
  1.  xserver-xorg-core [2:1.16.4-1 (now, stable) -> 2:1.17.2-1.1 (testing, unstable)]
  2.  xserver-xorg-video-ati [1:7.5.0-1 (now, stable) -> 1:7.5.0-1+b1 (testing, unstable)]
  3.  xserver-xorg-video-cirrus [1:1.5.2-2+b1 (now, stable) -> 1:1.5.3-1 (testing, unstable)]
  4.  xserver-xorg-video-fbdev [1:0.4.4-1+b2 (now, stable) -> 1:0.4.4-1+b3 (testing, unstable)]
  5.  xserver-xorg-video-intel [2:2.21.15-2+b2 (now, stable) -> 2:2.99.917-2 (testing, unstable)]
  6.  xserver-xorg-video-mach64 [6.9.4-2 (now, stable) -> 6.9.5-1 (testing, unstable)]
  7.  xserver-xorg-video-mga [1:1.6.4-1 (now) -> 1:1.6.4-1+b1 (testing, unstable)]
  8.  xserver-xorg-video-neomagic [1:1.2.8-1+b2 (now, stable) -> 1:1.2.9-1 (testing, unstable)]
  9.  xserver-xorg-video-nouveau [1:1.0.11-1 (now, stable) -> 1:1.0.11-1+b1 (testing, unstable)]
  10. xserver-xorg-video-openchrome [1:0.3.3-1+b2 (now, stable) -> 1:0.3.3-1+b3 (testing, unstable)]
  11. xserver-xorg-video-qxl [0.1.1-2+b1 (now, stable) -> 0.1.4-3 (testing, unstable)]
  12. xserver-xorg-video-r128 [6.9.2-1+b2 (now, stable) -> 6.10.0-1 (testing, unstable)]
  13. xserver-xorg-video-radeon [1:7.5.0-1 (now, stable) -> 1:7.5.0-1+b1 (testing, unstable)]
  14. xserver-xorg-video-savage [1:2.3.7-2+b2 (now, stable) -> 1:2.3.8-1 (testing, unstable)]
  15. xserver-xorg-video-siliconmotion [1:1.7.7-2+b2 (now, stable) -> 1:1.7.8-1 (unstable)]
  16. xserver-xorg-video-sisusb [1:0.9.6-2+b2 (now, stable) -> 1:0.9.6-2+b3 (testing, unstable)]
  17. xserver-xorg-video-tdfx [1:1.4.6-1 (now) -> 1:1.4.6-1+b1 (testing, unstable)]
  18. xserver-xorg-video-trident [1:1.3.7-1 (now) -> 1:1.3.7-1+b1 (testing, unstable)]
  19. xserver-xorg-video-vesa [1:2.3.3-1+b3 (now, stable) -> 1:2.3.3-1+b4 (testing, unstable)]
  20. xserver-xorg-video-vmware [1:13.1.0-1 (now) -> 1:13.1.0-2 (testing, unstable)]
  2.  xserver-xorg-core [2:1.16.4-1 (now, stable) -> 2:1.17.2-1.1 (testing, unstable)]
  3.  xserver-xorg-video-ati [1:7.5.0-1 (now, stable) -> 1:7.5.0-1+b1 (testing, unstable)]
  4.  xserver-xorg-video-cirrus [1:1.5.2-2+b1 (now, stable) -> 1:1.5.3-1 (testing, unstable)]
  5.  xserver-xorg-video-fbdev [1:0.4.4-1+b2 (now, stable) -> 1:0.4.4-1+b3 (testing, unstable)]
  6.  xserver-xorg-video-intel [2:2.21.15-2+b2 (now, stable) -> 2:2.99.917-2 (testing, unstable)]
  7.  xserver-xorg-video-mach64 [6.9.4-2 (now, stable) -> 6.9.5-1 (testing, unstable)]
  8.  xserver-xorg-video-mga [1:1.6.4-1 (now) -> 1:1.6.4-1+b1 (testing, unstable)]
  9.  xserver-xorg-video-neomagic [1:1.2.8-1+b2 (now, stable) -> 1:1.2.9-1 (testing, unstable)]
  10. xserver-xorg-video-nouveau [1:1.0.11-1 (now, stable) -> 1:1.0.11-1+b1 (testing, unstable)]
  11. xserver-xorg-video-openchrome [1:0.3.3-1+b2 (now, stable) -> 1:0.3.3-1+b3 (testing, unstable)]
xserver-xorg-video-modesetting xserver-xorg-video-qxl{a}
xserver-xorg-core xserver-xorg-video-ati xserver-xorg-video-cirrus xserver-xorg-video-fbdev xserver-xorg-video-intel xserver-xorg-video-mach64
xserver-xorg-video-mga xserver-xorg-video-neomagic xserver-xorg-video-nouveau xserver-xorg-video-openchrome xserver-xorg-video-r128 xserver-xorg-video-radeon
xserver-xorg-video-savage xserver-xorg-video-siliconmotion xserver-xorg-video-sisusb xserver-xorg-video-tdfx xserver-xorg-video-trident xserver-xorg-video-vesa
19 packages upgraded, 0 newly installed, 2 to remove and 47 not upgraded.
Need to get 7,045 kB of archives. After unpacking 275 kB will be used.
Gnupg2 n’est pas épinglé, je te mets le fichier, dès fois que tu trouves quelque à redire à son sujet :slightly_smiling:
[code]Package: *
Pin: release o=Debian,a=unstable,l=Debian
Pin-Priority: 900
Package: *
Pin: release o=Unofficial Multimedia Packages,a=unstable,l=Unofficial Multimedia Packages
Pin-Priority: 900
Package: *
Pin: release o=Debian,a=testing,l=Debian
Pin-Priority: 800
Package: *
Pin: release o=Debian,a=testing,l=Debian-Security
Pin-Priority: 800
Package: *
Pin: release o=Unofficial Multimedia Packages,a=testing,l=Unofficial Multimedia Packages
Pin-Priority: 800
Package: *
Pin: release o=Debian,a=stable,l=Debian
Pin-Priority: 700
Package: *
Pin: release o=Debian,a=stable,l=Debian-Security
Pin-Priority: 700
Package: *
Pin: release o=volatile.debian.org,a=stable,l=debian-volatile
Pin-Priority: 700
Package: *
Pin: release o=Unofficial Multimedia Packages,a=stable,l=Unofficial Multimedia Packages
Pin-Priority: 700
Package: *
Pin: release o=Unofficial Multimedia Packages,a=experimental,l=Unofficial Multimedia Packages
Pin-Priority: 1
Package: iceweasel iceweasel-l10n-* xulrunner-* libmozjs-*
Pin-Priority: 1000
Tu as bien fait, j’avais oublié.
Refuses trois fois.
$ dpkg -l |grep xserver-xorg $ dpkg -l |grep libgnutls $ apt-cache policy libgnutls28 $ apt-cache policy libgnutlsxx28
C’est digne d’un épinglage.
Question, rien en [mono]/etc/apt/preferences.d/[/mono] ? Je ne sais plus.
[code]root@debian:/home/belette# aptitude -s remove --purge python-pycparser
python-pycparser
Need to get 0 B of archives. After unpacking 409 kB will be freed.
python-cffi : Depends: python-pycparser but it is not going to be installed.
  1. deluge
  2. deluge-common
  3. deluge-gtk
  4. python-cffi
  6. python-openssl
  7. python-service-identity
  8. python-twisted-core
  9. python-twisted-web
  1. python-pycparser [2.14+dfsg-1 (now, testing, unstable)]
 Downgrade the following packages:
  1. python-pycparser [2.14+dfsg-1 (now, testing, unstable) -> 2.10+dfsg-3 (stable)]
Accept this solution? [Y/n/q/?] q
Abandoning all efforts to resolve these dependencies.
Abort.
root@debian:/home/belette# dpkg -l |grep xserver-xorg ii xserver-xorg 1:7.7+9 amd64 X.Org X server ii xserver-xorg-core 2:1.16.4-1 amd64 Xorg X server - core server ii xserver-xorg-input-all 1:7.7+9 amd64 X.Org X server -- input driver metapackage ii xserver-xorg-input-evdev 1:2.9.2-1 amd64 X.Org X server -- evdev input driver ii xserver-xorg-input-mouse 1:1.9.1-1 amd64 X.Org X server -- mouse input driver ii xserver-xorg-input-synaptics 1.8.2-1 amd64 Synaptics TouchPad driver for X.Org server ii xserver-xorg-input-vmmouse 1:13.0.99-1 amd64 X.Org X server -- VMMouse input driver to use with VMWare ii xserver-xorg-input-wacom 0.26.0+20140918-1 amd64 X.Org X server -- Wacom input driver ii xserver-xorg-video-all 1:7.7+9 amd64 X.Org X server -- output driver metapackage ii xserver-xorg-video-ati 1:7.5.0-1 amd64 X.Org X server -- AMD/ATI display driver wrapper ii xserver-xorg-video-cirrus 1:1.5.2-2+b1 amd64 X.Org X server -- Cirrus display driver ii xserver-xorg-video-fbdev 1:0.4.4-1+b2 amd64 X.Org X server -- fbdev display driver ii xserver-xorg-video-intel 2:2.21.15-2+b2 amd64 X.Org X server -- Intel i8xx, i9xx display driver ii xserver-xorg-video-mach64 6.9.4-2 amd64 X.Org X server -- ATI Mach64 display driver ii xserver-xorg-video-mga 1:1.6.4-1 amd64 X.Org X server -- MGA display driver ii xserver-xorg-video-modesetting 0.9.0-2 amd64 X.Org X server -- Generic modesetting driver ii xserver-xorg-video-neomagic 1:1.2.8-1+b2 amd64 X.Org X server -- Neomagic display driver ii xserver-xorg-video-nouveau 1:1.0.11-1 amd64 X.Org X server -- Nouveau display driver ii xserver-xorg-video-openchrome 1:0.3.3-1+b2 amd64 X.Org X server -- VIA display driver ii xserver-xorg-video-qxl 0.1.1-2+b1 amd64 X.Org X server -- QXL display driver ii xserver-xorg-video-r128 6.9.2-1+b2 amd64 X.Org X server -- ATI r128 display driver ii xserver-xorg-video-radeon 1:7.5.0-1 amd64 X.Org X server -- AMD/ATI Radeon display driver ii xserver-xorg-video-savage 1:2.3.7-2+b2 amd64 X.Org X server -- Savage display driver ii xserver-xorg-video-siliconmotion 1:1.7.7-2+b2 amd64 X.Org X server -- SiliconMotion display driver ii xserver-xorg-video-sisusb 1:0.9.6-2+b2 amd64 X.Org X server -- SiS USB display driver ii xserver-xorg-video-tdfx 1:1.4.6-1 amd64 X.Org X server -- tdfx display driver ii xserver-xorg-video-trident 1:1.3.7-1 amd64 X.Org X server -- Trident display driver ii xserver-xorg-video-vesa 1:2.3.3-1+b3 amd64 X.Org X server -- VESA display driver ii xserver-xorg-video-vmware 1:13.1.0-1 amd64 X.Org X server -- VMware display driver root@debian:/home/belette#
root@debian:/home/belette# dpkg -l |grep libgnutls ii libgnutls-deb0-28:amd64 3.3.15-6 amd64 GNU TLS library - main runtime library ii libgnutls-openssl27:amd64 3.3.15-6 amd64 GNU TLS library - OpenSSL wrapper ii libgnutls26:amd64 2.12.23-17 amd64 GNU TLS library - runtime library ii libgnutls28:amd64 3.2.15-1 amd64 GNU TLS library - main runtime library root@debian:/home/belette#
root@debian:/home/belette# apt-cache policy libgnutls28 libgnutls28: Installed: 3.2.15-1 Candidate: 3.2.15-1 Version table: *** 3.2.15-1 0 100 /var/lib/dpkg/status root@debian:/home/belette#
root@debian:/home/belette# apt-cache policy libgnutlsxx28 libgnutlsxx28: Installed: (none) Candidate: 3.3.17-1 Version table: 3.3.17-1 0 800 http://ftp.uk.debian.org/debian/ testing/main amd64 Packages 900 http://ftp.fr.debian.org/debian/ unstable/main amd64 Packages 3.3.8-6+deb8u3 0 700 http://ftp.fr.debian.org/debian/ stable/main amd64 Packages 3.3.8-6+deb8u2 0 700 http://security.debian.org/ stable/updates/main amd64 Packages root@debian:/home/belette#
Bingo, il était caché dans /etc/apt/preference.d
Savoir comment d’épingler correctement, je suis preneur
[code]Explanation: Pinned by apt-listbugs at 2015-05-01 10:58:14 +0200
Explanation: #781094: curl: relocation error on starting
Explanation: #769023: openssl: Removes symbol without SONAME bump
Explanation: #770278: openssl: Removes symbol without SONAME bump
Explanation: #771993: feh: relocation error: /usr/lib/i386-linux-gnu/libcurl.so.4: symbol SSLv3_client_method, version OPENSSL_1.0.0 not defined in file libssl.so.1.0.0 with link time reference
Explanation: #770605: openssl: Removes symbol without SONAME bump
Explanation: #768476: openssl: Removes symbol without SONAME bump
Explanation: #771169: openssl: Removes symbol without SONAME bump
Explanation: #781929: deluge-gtk: version OPENSSL_1.0.0 not defined in file libssl.so.1.0.0 with link time reference
Explanation: #768522: openssl: Removes symbol without SONAME bump
Package: openssl
Pin: version 1.0.1k-3
Pin-Priority: 1000
Explanation: Pinned by apt-listbugs at 2015-08-16 17:29:50 +0200
Explanation: #795639: assword fails with "Decryption error: Decryption failed"
Package: gnupg2
Pin: version 2.0.28-3
Pin-Priority: 30000
[quote=“Gargamel”][mono]root@debian:/home/belette# aptitude -s remove --purge python-pycparser
python-pycparser
  1. [b]deluge[/b][/mono][/quote]
[quote=“deluge”]Description : client bittorrent écrit en Python/PyGTK
Deluge est un client bittorrent complet, multiplate-forme, multi-interface utilisant libtorrent-rasterbar en arrière-plan, et présentant plusieurs interfaces utilisateur : GTK+, web et en
mode texte.[/quote]
Tu [mono]valides[/mono] au premier choix.
Ici, trois refus et tu acceptes.
Quel est le nom du fichier ?
Tu [mono]commentes[/mono] les lignes concernées.
Dans le cas présent, ses (ex) bugs ne sont plus, [mono]commentes[/mono] ces lignes.
[quote=“Gargamel”]Explanation: Pinned by apt-listbugs at 2015-05-01 10:58:14 +0200
Package: openssl
Pin-Priority: 1000[/quote]
[mono]openssl[/mono], relève du bug [mono]#778747 - openssl: RFC 7465 says RC4 is broken, never to be used[/mono].
Mise à jour ([mono]update[/mono]) et :
Hello,
Il s’appelle apt-listbugs, et il est tout seul
root@debian:/etc/apt/preferences.d# ls apt-listbugs
Il suffit juste de commenter? pas de possibilité de nettoyage automatique je présume?
Package: openssl
Pin-Priority: 1000
Package: gnupg2
Pin-Priority: 30000
La màj du jour:
[code]root@debian:/home/belette# aptitude safe-upgrade
Resolving dependencies…
cgmanager coinor-libosi1v5 dbus dbus-x11 gir1.2-gdkpixbuf-2.0 google-chrome-stable libcgmanager0 libdbus-1-3 libgdk-pixbuf2.0-0 libgdk-pixbuf2.0-common
libgoa-1.0-common libpam-systemd libsystemd0 libudev1 libusb-1.0-0 python-cupshelpers python-ply python-pycparser system-config-printer
system-config-printer-udev systemd systemd-sysv udev xdg-utils
24 packages upgraded, 0 newly installed, 0 to remove and 65 not upgraded.
Need to get 55.9 MB of archives. After unpacking 487 kB will be freed.
Get: 1 http://ftp.fr.debian.org/debian/ unstable/main libudev1 amd64 226-2 [95.4 kB]
Get: 2 http://dl.google.com/linux/chrome/deb/ stable/main google-chrome-stable amd64 45.0.2454.93-1 [48.1 MB]
Get: 3 http://ftp.fr.debian.org/debian/ unstable/main udev amd64 226-2 [1,034 kB]
Get: 4 http://ftp.fr.debian.org/debian/ unstable/main libpam-systemd amd64 226-2 [159 kB]
Get: 5 http://ftp.fr.debian.org/debian/ unstable/main libsystemd0 amd64 226-2 [242 kB]
Get: 6 http://ftp.fr.debian.org/debian/ unstable/main systemd amd64 226-2 [3,426 kB]
Get: 7 http://ftp.fr.debian.org/debian/ unstable/main dbus-x11 amd64 1.10.0-3 [82.4 kB]
Get: 8 http://ftp.fr.debian.org/debian/ unstable/main dbus amd64 1.10.0-3 [203 kB]
Get: 9 http://ftp.fr.debian.org/debian/ unstable/main libdbus-1-3 amd64 1.10.0-3 [187 kB]
Get: 10 http://ftp.fr.debian.org/debian/ unstable/main systemd-sysv amd64 226-2 [53.4 kB]
Get: 11 http://ftp.fr.debian.org/debian/ unstable/main libgdk-pixbuf2.0-0 amd64 2.31.7-1 [168 kB]
Get: 12 http://ftp.fr.debian.org/debian/ unstable/main libgdk-pixbuf2.0-common all 2.31.7-1 [310 kB]
Get: 13 http://ftp.fr.debian.org/debian/ unstable/main xdg-utils all 1.1.0~rc3+git20150907-2 [68.2 kB]
Get: 14 http://ftp.fr.debian.org/debian/ unstable/main libcgmanager0 amd64 0.39-1 [41.0 kB]
Get: 15 http://ftp.fr.debian.org/debian/ unstable/main cgmanager amd64 0.39-1 [84.0 kB]
Get: 16 http://ftp.fr.debian.org/debian/ unstable/main gir1.2-gdkpixbuf-2.0 amd64 2.31.7-1 [18.4 kB]
Get: 17 http://ftp.fr.debian.org/debian/ unstable/main libgoa-1.0-common all 3.16.4-1 [299 kB]
Get: 18 http://ftp.fr.debian.org/debian/ unstable/main libusb-1.0-0 amd64 2:1.0.20-1 [53.1 kB]
Get: 19 http://ftp.fr.debian.org/debian/ unstable/main system-config-printer-udev amd64 1.4.8-1 [97.3 kB]
Get: 20 http://ftp.fr.debian.org/debian/ unstable/main system-config-printer all 1.4.8-1 [730 kB]
Get: 21 http://ftp.fr.debian.org/debian/ unstable/main python-cupshelpers all 1.4.8-1 [111 kB]
Get: 22 http://ftp.fr.debian.org/debian/ unstable/main python-pycparser all 2.14+dfsg-2 [61.8 kB]
Get: 23 http://ftp.fr.debian.org/debian/ unstable/main python-ply all 3.7-1 [64.5 kB]
Get: 24 http://ftp.fr.debian.org/debian/ unstable/main coinor-libosi1v5 amd64 0.106.9-2+b1 [282 kB]
Fetched 55.9 MB in 38s (1,469 kB/s)
Preconfiguring packages …
Preparing to unpack …/libudev1_226-2_amd64.deb …
Unpacking libudev1:amd64 (226-2) over (226-1) …
Setting up libudev1:amd64 (226-2) …
Preparing to unpack …/archives/udev_226-2_amd64.deb …
Unpacking udev (226-2) over (226-1) …
Setting up udev (226-2) …
Installing new version of config file /etc/init.d/udev …
addgroup: The group input' already exists as a system group. Exiting. update-initramfs: deferring update (trigger activated) Processing triggers for systemd (226-1) ... Processing triggers for initramfs-tools (0.120) ... update-initramfs: Generating /boot/initrd.img-4.1.0-1-amd64 (Reading database ... 135846 files and directories currently installed.) Preparing to unpack .../libpam-systemd_226-2_amd64.deb ... Unpacking libpam-systemd:amd64 (226-2) over (226-1) ... Preparing to unpack .../libsystemd0_226-2_amd64.deb ... Unpacking libsystemd0:amd64 (226-2) over (226-1) ... Processing triggers for man-db (2.7.3-1) ... Setting up libsystemd0:amd64 (226-2) ... Processing triggers for libc-bin (2.19-20) ... (Reading database ... 135846 files and directories currently installed.) Preparing to unpack .../systemd_226-2_amd64.deb ... Unpacking systemd (226-2) over (226-1) ... Processing triggers for dbus (1.10.0-2) ... Processing triggers for man-db (2.7.3-1) ... Setting up systemd (226-2) ... addgroup: The groupsystemd-journal’ already exists as a system group. Exiting.
Preparing to unpack …/dbus-x11_1.10.0-3_amd64.deb …
Unpacking dbus-x11 (1.10.0-3) over (1.10.0-2) …
Preparing to unpack …/dbus_1.10.0-3_amd64.deb …
Unpacking dbus (1.10.0-3) over (1.10.0-2) …
Preparing to unpack …/libdbus-1-3_1.10.0-3_amd64.deb …
Unpacking libdbus-1-3:amd64 (1.10.0-3) over (1.10.0-2) …
Preparing to unpack …/systemd-sysv_226-2_amd64.deb …
Unpacking systemd-sysv (226-2) over (226-1) …
Processing triggers for systemd (226-2) …
Setting up systemd-sysv (226-2) …
Preparing to unpack …/libgdk-pixbuf2.0-0_2.31.7-1_amd64.deb …
Unpacking libgdk-pixbuf2.0-0:amd64 (2.31.7-1) over (2.31.5-1) …
Preparing to unpack …/libgdk-pixbuf2.0-common_2.31.7-1_all.deb …
Unpacking libgdk-pixbuf2.0-common (2.31.7-1) over (2.31.5-1) …
Preparing to unpack …/xdg-utils_1.1.0~rc3+git20150907-2_all.deb …
Unpacking xdg-utils (1.1.0~rc3+git20150907-2) over (1.1.0~rc3+git20150907-1) …
Preparing to unpack …/google-chrome-stable_45.0.2454.93-1_amd64.deb …
Unpacking google-chrome-stable (45.0.2454.93-1) over (45.0.2454.85-1) …
Preparing to unpack …/libcgmanager0_0.39-1_amd64.deb …
Unpacking libcgmanager0:amd64 (0.39-1) over (0.37-1) …
Preparing to unpack …/cgmanager_0.39-1_amd64.deb …
Unpacking cgmanager (0.39-1) over (0.37-1) …
Preparing to unpack …/gir1.2-gdkpixbuf-2.0_2.31.7-1_amd64.deb …
Unpacking gir1.2-gdkpixbuf-2.0:amd64 (2.31.7-1) over (2.31.5-1) …
Preparing to unpack …/libgoa-1.0-common_3.16.4-1_all.deb …
Unpacking libgoa-1.0-common (3.16.4-1) over (3.16.3-1) …
Preparing to unpack …/libusb-1.0-0_2%3a1.0.20-1_amd64.deb …
Unpacking libusb-1.0-0:amd64 (2:1.0.20-1) over (2:1.0.19-1) …
Preparing to unpack …/system-config-printer-udev_1.4.8-1_amd64.deb …
Unpacking system-config-printer-udev (1.4.8-1) over (1.4.6-1) …
Preparing to unpack …/system-config-printer_1.4.8-1_all.deb …
Unpacking system-config-printer (1.4.8-1) over (1.4.6-1) …
Preparing to unpack …/python-cupshelpers_1.4.8-1_all.deb …
Unpacking python-cupshelpers (1.4.8-1) over (1.4.6-1) …
Preparing to unpack …/python-pycparser_2.14+dfsg-2_all.deb …
Unpacking python-pycparser (2.14+dfsg-2) over (2.14+dfsg-1) …
Preparing to unpack …/python-ply_3.7-1_all.deb …
Unpacking python-ply (3.7-1) over (3.4-5) …
Preparing to unpack …/coinor-libosi1v5_0.106.9-2+b1_amd64.deb …
Unpacking coinor-libosi1v5 (0.106.9-2+b1) over (0.106.9-2) …
Processing triggers for libglib2.0-0:amd64 (2.44.1-1.1) …
Setting up libdbus-1-3:amd64 (1.10.0-3) …
Setting up dbus (1.10.0-3) …
A reboot is required to replace the running dbus-daemon.
Please reboot the system when convenient.
Setting up libpam-systemd:amd64 (226-2) …
Setting up dbus-x11 (1.10.0-3) …
Setting up libgdk-pixbuf2.0-common (2.31.7-1) …
Setting up libgdk-pixbuf2.0-0:amd64 (2.31.7-1) …
Setting up xdg-utils (1.1.0~rc3+git20150907-2) …
Setting up google-chrome-stable (45.0.2454.93-1) …
Setting up libcgmanager0:amd64 (0.39-1) …
Setting up cgmanager (0.39-1) …
Setting up gir1.2-gdkpixbuf-2.0:amd64 (2.31.7-1) …
Setting up libgoa-1.0-common (3.16.4-1) …
Setting up libusb-1.0-0:amd64 (2:1.0.20-1) …
Setting up python-cupshelpers (1.4.8-1) …
Setting up system-config-printer-udev (1.4.8-1) …
Setting up system-config-printer (1.4.8-1) …
Setting up python-ply (3.7-1) …
Setting up python-pycparser (2.14+dfsg-2) …
Setting up coinor-libosi1v5 (0.106.9-2+b1) …
Current status: 65 updates [-24].
snif, deluge :open_mouth: :cry:
[code]root@debian:~# aptitude remove --purge python-pycparser
python-pycparser
0 packages upgraded, 0 newly installed, 1 to remove and 65 not upgraded.
Need to get 0 B of archives. After unpacking 406 kB will be freed.
  1. deluge
  2. deluge-common
  3. deluge-gtk
  4. python-cffi
  6. python-openssl
deluge{a} deluge-common{a} deluge-gtk{a} fonts-freefont-ttf{pu} libboost-python1.58.0{pu} libfluidsynth1{pu} libmikmod3{pu} libopenal-data{pu} libopenal1{pu}
libportmidi0{pu} libsdl-mixer1.2{pu} libsdl-ttf2.0-0{pu} libsmpeg0{pu} libtorrent-rasterbar8{pu} python-cffi{a} python-cffi-backend{pu}
python-characteristic{pu} python-cryptography{a} python-enum34{pu} python-idna{pu} python-ipaddress{pu} python-libtorrent{pu} python-openssl{a} python-pam{pu}
python-ply{pu} python-pyasn1{pu} python-pyasn1-modules{pu} python-pycparser python-pygame{pu} python-serial{pu} python-service-identity{a}
python-twisted-bin{pu} python-twisted-core{a} python-twisted-web{a} python-zope.interface{pu}
0 packages upgraded, 0 newly installed, 35 to remove and 65 not upgraded.
Need to get 0 B of archives. After unpacking 45.5 MB will be freed.
(Reading database … 135848 files and directories currently installed.)
Removing deluge (1.3.10-3) …
Removing deluge-gtk (1.3.10-3) …
Removing deluge-common (1.3.10-3) …
(Reading database … 135041 files and directories currently installed.)
Removing python-pygame (1.9.1release+dfsg-10+b1) …
Removing fonts-freefont-ttf (20120503-4) …
Removing python-libtorrent (1.0.6-2) …
Removing libboost-python1.58.0 (1.58.0+dfsg-3) …
Purging configuration files for libboost-python1.58.0 (1.58.0+dfsg-3) …
Removing libsdl-mixer1.2:amd64 (1.2.12-11+b1) …
Purging configuration files for libsdl-mixer1.2:amd64 (1.2.12-11+b1) …
Removing libfluidsynth1:amd64 (1.1.6-3) …
Purging configuration files for libfluidsynth1:amd64 (1.1.6-3) …
Removing libmikmod3:amd64 (3.3.7-1) …
Purging configuration files for libmikmod3:amd64 (3.3.7-1) …
Removing libopenal1:amd64 (1:1.16.0-3) …
Purging configuration files for libopenal1:amd64 (1:1.16.0-3) …
Removing libopenal-data (1:1.16.0-3) …
Purging configuration files for libopenal-data (1:1.16.0-3) …
Removing libportmidi0 (1:184-2.2) …
Purging configuration files for libportmidi0 (1:184-2.2) …
Removing libsdl-ttf2.0-0:amd64 (2.0.11-3) …
Purging configuration files for libsdl-ttf2.0-0:amd64 (2.0.11-3) …
Removing libsmpeg0:amd64 (0.4.5+cvs20030824-7.1) …
Purging configuration files for libsmpeg0:amd64 (0.4.5+cvs20030824-7.1) …
Removing libtorrent-rasterbar8 (1.0.6-2) …
Purging configuration files for libtorrent-rasterbar8 (1.0.6-2) …
Processing triggers for fontconfig (2.11.0-6.3) …
(Reading database … 134482 files and directories currently installed.)
Removing python-twisted-web (15.2.1-1) …
Removing python-twisted-core (15.2.1-1) …
Removing python-service-identity (14.0.0-1) …
Removing python-openssl (0.15.1-2) …
Removing python-cryptography (1.0.1-1) …
Removing python-cffi (1.1.2-1) …
(Reading database … 133593 files and directories currently installed.)
Removing python-cffi-backend (1.1.2-1) …
Removing python-characteristic (14.3.0-1) …
Removing python-enum34 (1.0.4-2) …
Removing python-idna (2.0-3) …
Removing python-ipaddress (1.0.14-2) …
Removing python-pam (0.4.2-13.2) …
(Reading database … 133531 files and directories currently installed.)
Removing python-pycparser (2.14+dfsg-2) …
(Reading database … 133429 files and directories currently installed.)
Removing python-ply (3.7-1) …
Removing python-pyasn1-modules (0.0.7-0.1) …
Removing python-pyasn1 (0.1.8-2) …
Removing python-serial (2.7-1) …
Removing python-twisted-bin (15.2.1-1) …
Removing python-zope.interface (4.1.2-1) …
root@debian:~#
root@debian:~# aptitude -s remove --purge libgnutls28 The following packages will be REMOVED: libgnutls28 0 packages upgraded, 0 newly installed, 1 to remove and 65 not upgraded. Need to get 0 B of archives. After unpacking 1,912 kB will be freed. Would download/install/remove packages. root@debian:~#
root@debian:~# aptitude -s upgrade Resolving dependencies... No packages will be installed, upgraded, or removed. 0 packages upgraded, 0 newly installed, 0 to remove and 65 not upgraded. Need to get 0 B of archives. After unpacking 0 B will be used. Would download/install/remove packages. root@debian:~#
root@debian:~# aptitude -s safe-upgrade Resolving dependencies... No packages will be installed, upgraded, or removed. 0 packages upgraded, 0 newly installed, 0 to remove and 65 not upgraded. Need to get 0 B of archives. After unpacking 0 B will be used. Would download/install/remove packages. root@debian:~#
[code]root@debian:~# aptitude -s full-upgrade
libgnutls-deb0-28{b} libgnutls-openssl27 libgstreamer-plugins-bad1.0-0 libmpg123-0 mutter-common orage osmo xfce4 xfce4-battery-plugin xfce4-clipman-plugin
xfce4-cpufreq-plugin xfce4-cpugraph-plugin xfce4-datetime-plugin xfce4-dict xfce4-diskperf-plugin xfce4-fsguard-plugin xfce4-genmon-plugin xfce4-goodies
xfce4-mailwatch-plugin xfce4-mixer xfce4-mount-plugin xfce4-netload-plugin xfce4-notes-plugin xfce4-panel xfce4-places-plugin xfce4-power-manager-plugins
xfce4-quicklauncher-plugin xfce4-sensors-plugin xfce4-smartbookmark-plugin xfce4-systemload-plugin xfce4-timer-plugin xfce4-verve-plugin xfce4-wavelan-plugin
xfce4-weather-plugin xfce4-xkb-plugin xserver-xorg-core{b} xserver-xorg-input-wacom xserver-xorg-video-ati xserver-xorg-video-cirrus xserver-xorg-video-fbdev
xserver-xorg-video-intel xserver-xorg-video-mach64 xserver-xorg-video-mga xserver-xorg-video-neomagic xserver-xorg-video-nouveau xserver-xorg-video-openchrome
xserver-xorg-video-qxl xserver-xorg-video-r128 xserver-xorg-video-radeon xserver-xorg-video-savage xserver-xorg-video-siliconmotion xserver-xorg-video-sisusb
65 packages upgraded, 11 newly installed, 0 to remove and 0 not upgraded.
Need to get 29.8 MB/29.8 MB of archives. After unpacking 900 kB will be freed.
  1.  brasero
  2.  gir1.2-panelapplet-4.0
  3.  gnupg2
  4.  gstreamer1.0-plugins-ugly
  5.  libbrasero-media3-1
  6.  libecal-1.2-15
  7.  libedata-cal-1.2-20
  8.  libgmime-2.6-0
  9.  libgnutls28
  10. libgpgme11
  11. libhogweed2
  12. libical1
  13. libnettle4
  14. libpanel-applet-4-0
  15. libproxy1
  16. libtotem-plparser18
  17. mutt
  18. quodlibet
  19. xserver-xorg-video-modesetting
  20. libsidplay1v5 [Not Installed]
Oui mais, toutes les lignes concernées, voir ci-dessous.
#Explanation: Pinned by apt-listbugs at 2015-05-01 10:58:14 +0200 #Explanation: #781094: curl: relocation error on starting #Explanation: #769023: openssl: Removes symbol without SONAME bump #Explanation: #770278: openssl: Removes symbol without SONAME bump #Explanation: #771993: feh: relocation error: /usr/lib/i386-linux-gnu/libcurl.so.4: symbol SSLv3_client_method, version OPENSSL_1.0.0 not defined in file libssl.so.1.0.0 with link time reference #Explanation: #770605: openssl: Removes symbol without SONAME bump #Explanation: #768476: openssl: Removes symbol without SONAME bump #Explanation: #771169: openssl: Removes symbol without SONAME bump #Explanation: #781929: deluge-gtk: version OPENSSL_1.0.0 not defined in file libssl.so.1.0.0 with link time reference #Explanation: #768522: openssl: Removes symbol without SONAME bump #Package: openssl #Pin: version 1.0.1k-3 #Pin-Priority: 1000
C’est une intervention manuelle.
Des [mono]concessions[/mono], disait-il.
Par la suite, il sera à réinstaller, tout comme [mono]vlc[/mono] et [mono]libreoffice[/mono].
Tu [mono]valides[/mono].
Simulation, trois refus et acceptation.
$ aptitude -s remove --purge libhogweed2 $ aptitude -s remove --purge libnettle4
[code]root@debian:/home/belette# aptitude remove --purge libgnutls28
libgnutls28
0 packages upgraded, 0 newly installed, 1 to remove and 68 not upgraded.
(Reading database … 133210 files and directories currently installed.)
Removing libgnutls28:amd64 (3.2.15-1) …
root@debian:/home/belette# dpkg -l |grep libical ii libical0 0.48-2 amd64 iCalendar library implementation in C (runtime) ii libical1 1.0-1.2 amd64 iCalendar library implementation in C (runtime) root@debian:/home/belette#
root@debian:/home/belette# aptitude -s remove --purge libhogweed2 The following packages will be REMOVED: libhogweed2 0 packages upgraded, 0 newly installed, 1 to remove and 68 not upgraded. Need to get 0 B of archives. After unpacking 228 kB will be freed. Would download/install/remove packages. root@debian:/home/belette#
[code]root@debian:/home/belette# aptitude -s remove --purge libnettle4
libnettle4
Need to get 0 B of archives. After unpacking 339 kB will be freed.
libhogweed2 : Depends: libnettle4 (= 2.7.1-5) but it is not going to be installed.
  1. libhogweed2
  1. libnettle4 [2.7.1-5 (now, stable)]
0 packages upgraded, 0 newly installed, 0 to remove and 68 not upgraded.
Pour les épinglés, c’est bon. Je te rajoute le compte-rendu pour ton info. J’ai préféré attendre ton approbation pour la validation.
Je suis pas encore allé sur bugzilla pour lire tous les retours de ces bugs.
root@debian:/home/belette# aptitude safe-upgrade Resolving dependencies... The following NEW packages will be installed: libnpth0{a} The following packages will be upgraded: gnupg-agent gnupg2 lsof openssl The following packages are RECOMMENDED but will NOT be installed: dirmngr 4 packages upgraded, 1 newly installed, 0 to remove and 64 not upgraded. Need to get 2,773 kB/2,787 kB of archives. After unpacking 167 kB will be freed. Do you want to continue? [Y/n/?] y Get: 1 http://ftp.fr.debian.org/debian/ unstable/main lsof amd64 4.89+dfsg-0.1 [313 kB] Get: 2 http://ftp.uk.debian.org/debian/ testing/main openssl amd64 1.0.2d-1 [695 kB] Get: 3 http://ftp.fr.debian.org/debian/ unstable/main gnupg-agent amd64 2.1.8-1 [287 kB] Get: 4 http://ftp.fr.debian.org/debian/ unstable/main gnupg2 amd64 2.1.8-1 [1,477 kB] Fetched 2,773 kB in 2s (1,362 kB/s) Retrieving bug reports... Done Parsing Found/Fixed information... Done grave bugs of gnupg2 (2.0.28-3 → 2.1.8-1) <Outstanding> b1 - #795639 - automated secret key import process for gpg2.1 skips some keys serious bugs of gnupg-agent (2.0.28-3 → 2.1.8-1) <Outstanding> b2 - #796931 - gnupg-agent: no longer writes $GNUPGHOME/gpg-agent-info-$(hostname) file serious bugs of openssl (1.0.1k-3 → 1.0.2d-1) <Resolved in some Version> b3 - #768476 - openssl: Removes symbol without SONAME bump (Fixed: openssl/1.0.2d-2) Merged with: 768522 769023 770278 770605 771169 771993 781094 781929 787712 Summary: gnupg-agent(1 bug), gnupg2(1 bug), openssl(1 bug) Are you sure you want to install/upgrade the above packages? [Y/n/?/...] n Abort. root@debian:/home/belette#
Ok.
En simulation. Trois refus et acceptes.
Tu [mono]valides[/mono] à la première proposition.
[quote=“Gargamel”]
Summary: gnupg-agent(1 bug), gnupg2(1 bug), openssl(1 bug) Are you sure you want to install/upgrade the above packages? [Y/n/?/...] n Abort.[/quote]
Tu semble ne pas savoir utiliser [mono]apt-listbugs[/mono]. Jettes un œil sur le wiki.
Lances un [mono]update[/mono].
Deux refus puis acceptes.
[code]aptitude -s remove --purge libical1
libical1
Need to get 0 B of archives. After unpacking 708 kB will be freed.
orage : Depends: libical1 (>= 1.0) but it is not going to be installed.
osmo : Depends: libical1 (>= 1.0) but it is not going to be installed.
bluez-obexd : Depends: libical1 (>= 1.0) but it is not going to be installed.
libecal-1.2-15 : Depends: libical1 (>= 1.0) but it is not going to be installed.
libedata-cal-1.2-20 : Depends: libical1 (>= 1.0) but it is not going to be installed.
  1.  bluez-obexd
  2.  gnome-applets
  3.  gnome-bluetooth
  4.  gnome-panel
  5.  gnome-session-fallback
  6.  gnome-session-flashback
  7.  libecal-1.2-15
  8.  libedata-cal-1.2-20
  9.  orage
  10. osmo
  11. task-xfce-desktop
  12. xfce4
  1.  gnome-applets
  2.  gnome-panel
  3.  gnome-session-fallback
  4.  gnome-session-flashback
  5.  libecal-1.2-15
  6.  libedata-cal-1.2-20
  7.  xfce4-goodies
  8.  xfce4-xkb-plugin
  9.  libical1a [1.0.1-0.1 (testing, unstable)]
  10. bluez-obexd [5.23-1 (now) -> 5.33-1 (testing, unstable)]
  11. orage [4.10.0-1+b1 (now) -> 4.12.1-1+b1 (testing, unstable)]
  12. osmo [0.2.12-1 (now) -> 0.2.14-1 (testing, unstable)]
  13. xfce4-battery-plugin [1.0.5-4 (now, stable) -> 1.0.5-4+b1 (testing, unstable)]
  14. xfce4-clipman-plugin [2:1.2.6-1 (now, stable) -> 2:1.2.6-1+b1 (testing, unstable)]
  15. xfce4-cpufreq-plugin [1.1.0-1 (now, stable) -> 1.1.2-1 (testing, unstable)]
  16. xfce4-cpugraph-plugin [1.0.5-1 (now, stable) -> 1.0.5-1+b1 (testing, unstable)]
  17. xfce4-datetime-plugin [0.6.2-2 (now, stable) -> 0.6.2-2+b1 (testing, unstable)]
  18. xfce4-dict [0.7.0-1 (now, stable) -> 0.7.1-1+b1 (testing, unstable)]
  19. xfce4-diskperf-plugin [2.5.4-3 (now, stable) -> 2.5.5-1+b1 (testing, unstable)]
  20. xfce4-fsguard-plugin [1.0.1-2 (now, stable) -> 1.0.2-1+b1 (testing, unstable)]
  21. xfce4-genmon-plugin [3.4.0-2 (now, stable) -> 3.4.0-2+b1 (testing, unstable)]
  22. xfce4-mailwatch-plugin [1.2.0-2 (now, stable) -> 1.2.0-2+b1 (testing, unstable)]
  23. xfce4-mixer [4.10.0-3 (now, stable) -> 4.10.0-3+b1 (testing, unstable)]
  24. xfce4-mount-plugin [0.6.7-1 (now, stable) -> 0.6.7-1+b1 (testing, unstable)]
  25. xfce4-netload-plugin [1.2.0-1 (now, stable) -> 1.2.4-1+b1 (testing, unstable)]
  26. xfce4-notes-plugin [1.7.7-5 (now, stable) -> 1.8.1-1 (testing, unstable)]
  27. xfce4-panel [4.10.1-1 (now, stable) -> 4.12.0-3 (testing, unstable)]
  28. xfce4-places-plugin [1.6.0-1 (now, stable) -> 1.7.0-3 (testing, unstable)]
  29. xfce4-power-manager-plugins [1.4.1-2 (now) -> 1.4.4-4 (testing, unstable)]
  30. xfce4-quicklauncher-plugin [1.9.4-11 (now, stable) -> 1.9.4-11+b1 (testing, unstable)]
  31. xfce4-sensors-plugin [1.2.5-2 (now, stable) -> 1.2.6-1+b1 (testing, unstable)]
  32. xfce4-smartbookmark-plugin [0.4.5-1 (now, stable) -> 0.4.6-1+b1 (testing, unstable)]
  33. xfce4-systemload-plugin [1.1.1-4 (now, stable) -> 1.1.2-1+b1 (testing, unstable)]
  34. xfce4-timer-plugin [1.6.0-1 (now, stable) -> 1.6.0-1+b1 (testing, unstable)]
  35. xfce4-verve-plugin [1.0.0-3 (now, stable) -> 1.0.1-1+b1 (testing, unstable)]
  36. xfce4-wavelan-plugin [0.5.11-3 (now, stable) -> 0.5.12-1 (testing, unstable)]
  37. xfce4-weather-plugin [0.8.3-2 (now, stable) -> 0.8.6-1 (testing, unstable)]
  1.  gnome-applets
  2.  gnome-panel
  5.  libecal-1.2-15
  7.  xfce4-goodies
  8.  xfce4-weather-plugin
  37. xfce4-xkb-plugin [1:0.5.6-1 (now, stable) -> 1:0.7.1-2+b1 (testing, unstable)]
  1.  gnome-applets
  2.  gnome-panel
  5.  libecal-1.2-15
  7.  xfce4-goodies
  8.  xfce4-wavelan-plugin
  36. xfce4-weather-plugin [0.8.3-2 (now, stable) -> 0.8.6-1 (testing, unstable)]
libical1a{a}
gnome-applets{a} gnome-panel{a} gnome-session-fallback{a} gnome-session-flashback{a} libecal-1.2-15{a} libedata-cal-1.2-20{a} libical1 xfce4-goodies{a}
xfce4-wavelan-plugin{a}
bluez-obexd orage osmo xfce4-battery-plugin xfce4-clipman-plugin xfce4-cpufreq-plugin xfce4-cpugraph-plugin xfce4-datetime-plugin xfce4-dict
xfce4-diskperf-plugin xfce4-fsguard-plugin xfce4-genmon-plugin xfce4-mailwatch-plugin xfce4-mixer xfce4-mount-plugin xfce4-netload-plugin xfce4-notes-plugin
xfce4-panel xfce4-places-plugin xfce4-power-manager-plugins xfce4-quicklauncher-plugin xfce4-sensors-plugin xfce4-smartbookmark-plugin xfce4-systemload-plugin
xfce4-timer-plugin xfce4-verve-plugin xfce4-weather-plugin xfce4-xkb-plugin
28 packages upgraded, 1 newly installed, 9 to remove and 36 not upgraded.
Need to get 8,080 kB of archives. After unpacking 7,864 kB will be freed.
[code]root@debian:/home/belette# aptitude remove --purge libhogweed2
libhogweed2
(Reading database … 133184 files and directories currently installed.)
Removing libhogweed2:amd64 (2.7.1-5) …
libhogweed2
root@debian:/home/belette# aptitude remove --purge libnettle4
libnettle4
(Reading database … 133181 files and directories currently installed.)
Removing libnettle4:amd64 (2.7.1-5) …
bluez-obexd glib-networking glib-networking-services gnome-applets gnome-applets-data gnome-panel{b} gnome-panel-data gnupg-agent gnupg2
gstreamer1.0-plugins-ugly libgnutls-deb0-28 libgnutls-openssl27 libgstreamer-plugins-bad1.0-0 libmpg123-0 lsof mutter-common openssl orage osmo xfce4
xfce4-battery-plugin xfce4-clipman-plugin xfce4-cpufreq-plugin xfce4-cpugraph-plugin xfce4-datetime-plugin xfce4-dict xfce4-diskperf-plugin
xfce4-fsguard-plugin xfce4-genmon-plugin xfce4-goodies xfce4-mailwatch-plugin xfce4-mixer xfce4-mount-plugin xfce4-netload-plugin xfce4-notes-plugin
xfce4-timer-plugin xfce4-verve-plugin xfce4-wavelan-plugin xfce4-weather-plugin xfce4-xkb-plugin xserver-xorg-core{b} xserver-xorg-input-wacom
xserver-xorg-video-ati xserver-xorg-video-cirrus xserver-xorg-video-fbdev xserver-xorg-video-intel xserver-xorg-video-mach64 xserver-xorg-video-mga
xserver-xorg-video-neomagic xserver-xorg-video-nouveau xserver-xorg-video-openchrome xserver-xorg-video-qxl xserver-xorg-video-r128 xserver-xorg-video-radeon
dirmngr evolution-common evolution-data-server gnome-control-center
68 packages upgraded, 11 newly installed, 0 to remove and 0 not upgraded.
Need to get 29.5 MB/32.3 MB of archives. After unpacking 1,165 kB will be freed.
  1.  gir1.2-panelapplet-4.0
  2.  gstreamer1.0-plugins-ugly
  3.  libecal-1.2-15
  4.  libedata-cal-1.2-20
  5.  libical1
  6.  libpanel-applet-4-0
  7.  libproxy1
  8.  quodlibet
  10. libsidplay1v5 [Not Installed]
  2. libecal-1.2-15
  3. libedata-cal-1.2-20
  4. libical1
  5. libpanel-applet-4-0
  6. libproxy1
  7. libsidplay1
  8. xserver-xorg-video-modesetting
  1.  gnome-applets
  2.  gnome-panel
  5.  gstreamer1.0-plugins-ugly
  6.  libecal-1.2-15
  8.  libical1
  9.  libproxy1
  10. quodlibet
  11. xserver-xorg-video-modesetting
  12. libsidplay1v5 [Not Installed]
libical1a{a} libnpth0{a} libproxy1v5{a} xfce4-whiskermenu-plugin{a}
gnome-applets{a} gnome-panel{a} gnome-session-fallback{a} gnome-session-flashback{a} gstreamer1.0-plugins-ugly{a} libecal-1.2-15{a} libedata-cal-1.2-20{a}
libical1{a} libproxy1{a} quodlibet{a} xserver-xorg-video-modesetting{a}
bluez-obexd glib-networking glib-networking-services gnome-applets-data gnome-panel-data gnupg-agent gnupg2 libgnutls-deb0-28 libgnutls-openssl27
libgstreamer-plugins-bad1.0-0 libmpg123-0 lsof mutter-common openssl orage osmo xfce4 xfce4-battery-plugin xfce4-clipman-plugin xfce4-cpufreq-plugin
xfce4-cpugraph-plugin xfce4-datetime-plugin xfce4-dict xfce4-diskperf-plugin xfce4-fsguard-plugin xfce4-genmon-plugin xfce4-goodies xfce4-mailwatch-plugin
xfce4-mixer xfce4-mount-plugin xfce4-netload-plugin xfce4-notes-plugin xfce4-panel xfce4-places-plugin xfce4-power-manager-plugins xfce4-quicklauncher-plugin
xfce4-sensors-plugin xfce4-smartbookmark-plugin xfce4-systemload-plugin xfce4-timer-plugin xfce4-verve-plugin xfce4-wavelan-plugin xfce4-weather-plugin
xfce4-xkb-plugin xserver-xorg-core xserver-xorg-input-wacom xserver-xorg-video-ati xserver-xorg-video-cirrus xserver-xorg-video-fbdev xserver-xorg-video-intel
xserver-xorg-video-mach64 xserver-xorg-video-mga xserver-xorg-video-neomagic xserver-xorg-video-nouveau xserver-xorg-video-openchrome xserver-xorg-video-qxl
xserver-xorg-video-r128 xserver-xorg-video-radeon xserver-xorg-video-savage xserver-xorg-video-siliconmotion xserver-xorg-video-sisusb xserver-xorg-video-tdfx
dirmngr
65 packages upgraded, 4 newly installed, 11 to remove and 0 not upgraded.
Need to get 26.6 MB/29.4 MB of archives. After unpacking 11.3 MB will be freed.
Pas à la perfection oui. Je suis allé voir le wiki, l’option -a? n’installe pas les paquets bugés? Je sais pas comment interpreter correctement cette phrase: [mono]a - continuer l’installation avec APT en ignorant les bogues ci-dessus[/mono]
Haha …
Refuses une fois et acceptes.
D’où sort elle ?
  3.  libecal-1.2-15
  5.  libical1
  7.  libproxy1
  8.  quodlibet
  2. libecal-1.2-15
  4. libical1
  6. libproxy1
  7. libsidplay1
  1.  gnome-applets
  2.  gnome-panel
  6.  libecal-1.2-15
  8.  libical1
  9.  libproxy1
  10. quodlibet
  1.  gnome-applets
  2.  gnome-panel
  5.  libecal-1.2-15
  7.  libical1
  8.  libproxy1
  9.  libsidplay1
  10. xserver-xorg-video-modesetting
libical1a{a} libnpth0{a} libproxy1v5{a} libsidplay1v5{a} xfce4-whiskermenu-plugin{a}
gnome-applets{a} gnome-panel{a} gnome-session-fallback{a} gnome-session-flashback{a} libecal-1.2-15{a} libedata-cal-1.2-20{a} libical1{a} libproxy1{a}
libsidplay1{a} xserver-xorg-video-modesetting{a}
bluez-obexd glib-networking glib-networking-services gnome-applets-data gnome-panel-data gnupg-agent gnupg2 gstreamer1.0-plugins-ugly libgnutls-deb0-28
libgnutls-openssl27 libgstreamer-plugins-bad1.0-0 libmpg123-0 lsof mutter-common openssl orage osmo xfce4 xfce4-battery-plugin xfce4-clipman-plugin
xfce4-weather-plugin xfce4-xkb-plugin xserver-xorg-core xserver-xorg-input-wacom xserver-xorg-video-ati xserver-xorg-video-cirrus xserver-xorg-video-fbdev
dirmngr
66 packages upgraded, 5 newly installed, 10 to remove and 0 not upgraded.
Need to get 27.0 MB/29.8 MB of archives. After unpacking 10.1 MB will be freed.
Tu t’es planté.
[quote=“moi”]Haha …
Refuses [mono]une fois[/mono] et acceptes.
D’où sort elle ?
oups :blush:
  3.  libecal-1.2-15
  5.  libical1
  7.  libproxy1
  8.  quodlibet
  2. libecal-1.2-15
  4. libical1
  6. libproxy1
  7. libsidplay1
gir1.2-panelapplet-5.0{a} libcamel-1.2-52{a} libecal-1.2-18{a} libedataserver-1.2-20{a} libical1a{a} libnpth0{a} libpanel-applet0{a} libproxy1v5{a}
libsidplay1v5{a} python3-gi{a} xfce4-whiskermenu-plugin{a}
gir1.2-panelapplet-4.0{a} libecal-1.2-15{a} libedata-cal-1.2-20{a} libical1{a} libpanel-applet-4-0{a} libproxy1{a} libsidplay1{a}
bluez-obexd glib-networking glib-networking-services gnome-applets gnome-applets-data gnome-panel gnome-panel-data gnupg-agent gnupg2 gstreamer1.0-plugins-ugly
libgnutls-deb0-28 libgnutls-openssl27 libgstreamer-plugins-bad1.0-0 libmpg123-0 lsof mutter-common openssl orage osmo xfce4 xfce4-battery-plugin
xfce4-verve-plugin xfce4-wavelan-plugin xfce4-weather-plugin xfce4-xkb-plugin xserver-xorg-core xserver-xorg-input-wacom xserver-xorg-video-ati
68 packages upgraded, 11 newly installed, 8 to remove and 0 not upgraded.
Need to get 29.5 MB/32.3 MB of archives. After unpacking 3,777 kB will be freed.
Et le wiki en question:
isalo.org/wiki.debian-fr/Apt-listbugs
[mono]Full-upgrade[/mono], terminé !
Tu refuses [mono]une fois[/mono] et tu [mono]valides[/mono] la deuxième.
* edit *
En ce petit matin, les précautions d’usages sont :
[mono]update[/mono], un [mono]safe-upgrade[/mono] validé et tu reprends la simulation [mono]-s full-upgrade[/mono].
Tout est passé
[code]root@debian:/home/belette# aptitude full-upgrade
libproxy1v5{ab} libsidplay1v5{ab} python3-gi{a}
binutils bluez-obexd cgmanager cups cups-bsd cups-client cups-common
cups-core-drivers cups-daemon cups-ppdc cups-server-common
firebird2.5-common firebird2.5-common-doc firebird2.5-server-common
fonts-lyx glib-networking glib-networking-services gnome-applets
gstreamer1.0-plugins-ugly libcgmanager0 libcups2 libcupscgi1
libcupsimage2 libcupsmime1 libcupsppdc1 libfbclient2 libfbembed2.5
libgusb2 libmpg123-0 lsof mutter-common openssl orage osmo rsyslog xfce4
printer-driver-gutenprint
92 packages upgraded, 11 newly installed, 0 to remove and 0 not upgraded.
Need to get 40.0 MB/42.8 MB of archives. After unpacking 1,124 kB will be freed.
The following packages have unmet dependencies:
The following actions will resolve these dependencies:
  Remove the following packages:
  3.  libecal-1.2-15
  5.  libical1
  7.  libproxy1
  8.  quodlibet
Accept this solution? [Y/n/q/?] n
  2. libecal-1.2-15
  4. libical1
  6. libproxy1
  7. libsidplay1
Accept this solution? [Y/n/q/?] y
libproxy1v5{a} libsidplay1v5{a} python3-gi{a} xfce4-whiskermenu-plugin{a}
92 packages upgraded, 11 newly installed, 8 to remove and 0 not upgraded.
Need to get 40.0 MB/42.8 MB of archives. After unpacking 3,736 kB will be freed.
Get: 1 http://ftp.uk.debian.org/debian/ testing/main gnome-panel amd64 3.16.1-4 [463 kB]
Get: 2 http://ftp.fr.debian.org/debian/ unstable/main xserver-xorg-video-siliconmotion amd64 1:1.7.8-1 [84.3 kB]
Get: 3 http://ftp.fr.debian.org/debian/ unstable/main libcupscgi1 amd64 2.1.0-4 [129 kB]
Get: 4 http://ftp.uk.debian.org/debian/ testing/main gnome-applets amd64 3.16.1-3 [216 kB]
Get: 5 http://ftp.fr.debian.org/debian/ unstable/main cups-core-drivers amd64 2.1.0-4 [127 kB]
Get: 6 http://ftp.uk.debian.org/debian/ testing/main gnome-panel-data all 3.16.1-4 [1,054 kB]
Get: 7 http://ftp.fr.debian.org/debian/ unstable/main libcupsmime1 amd64 2.1.0-4 [115 kB]
Get: 8 http://ftp.fr.debian.org/debian/ unstable/main cups-server-common all 2.1.0-4 [593 kB]
Get: 9 http://ftp.uk.debian.org/debian/ testing/main libcamel-1.2-52 amd64 3.16.5-1 [492 kB]
Get: 10 http://ftp.fr.debian.org/debian/ unstable/main libcupsimage2 amd64 2.1.0-4 [117 kB]
Get: 11 http://ftp.fr.debian.org/debian/ unstable/main libcupsppdc1 amd64 2.1.0-4 [147 kB]
Get: 12 http://ftp.uk.debian.org/debian/ testing/main libedataserver-1.2-20 amd64 3.16.5-1 [335 kB]
Get: 13 http://ftp.fr.debian.org/debian/ unstable/main cups-common all 2.1.0-4 [233 kB]
Get: 14 http://ftp.uk.debian.org/debian/ testing/main bluez-obexd amd64 5.33-1 [192 kB]
Get: 15 http://ftp.uk.debian.org/debian/ testing/main xfce4-power-manager-plugins amd64 1.4.4-4 [150 kB]
Get: 16 http://ftp.fr.debian.org/debian/ unstable/main cups-ppdc amd64 2.1.0-4 [128 kB]
Get: 17 http://ftp.uk.debian.org/debian/ testing/main xfce4-xkb-plugin amd64 1:0.7.1-2+b1 [449 kB]
Get: 18 http://ftp.fr.debian.org/debian/ unstable/main cups-bsd amd64 2.1.0-4 [35.2 kB]
Get: 19 http://ftp.fr.debian.org/debian/ unstable/main cups-client amd64 2.1.0-4 [236 kB]
Get: 20 http://ftp.uk.debian.org/debian/ testing/main xfce4-weather-plugin amd64 0.8.6-1 [2,446 kB]
Get: 21 http://ftp.fr.debian.org/debian/ unstable/main cups-daemon amd64 2.1.0-4 [395 kB]
Get: 22 http://ftp.fr.debian.org/debian/ unstable/main libcups2 amd64 2.1.0-4 [298 kB]
Get: 23 http://ftp.fr.debian.org/debian/ unstable/main cups amd64 2.1.0-4 [297 kB]
Get: 24 http://ftp.uk.debian.org/debian/ testing/main xfce4-wavelan-plugin amd64 0.5.12-1 [54.8 kB]
Get: 25 http://ftp.uk.debian.org/debian/ testing/main xfce4-verve-plugin amd64 1.0.1-1+b1 [52.8 kB]
Get: 26 http://ftp.fr.debian.org/debian/ unstable/main rsyslog amd64 8.12.0-3 [520 kB]
Get: 27 http://ftp.uk.debian.org/debian/ testing/main xfce4-timer-plugin amd64 1.6.0-1+b1 [45.5 kB]
Get: 28 http://ftp.uk.debian.org/debian/ testing/main xfce4-systemload-plugin amd64 1.1.2-1+b1 [60.8 kB]
Get: 29 http://ftp.uk.debian.org/debian/ testing/main xfce4-smartbookmark-plugin amd64 0.4.6-1+b1 [33.0 kB]
Get: 30 http://ftp.uk.debian.org/debian/ testing/main xfce4-sensors-plugin amd64 1.2.6-1+b1 [117 kB]
Get: 31 http://ftp.uk.debian.org/debian/ testing/main xfce4-quicklauncher-plugin amd64 1.9.4-11+b1 [22.6 kB]
Get: 32 http://ftp.uk.debian.org/debian/ testing/main xfce4-places-plugin amd64 1.7.0-3 [72.9 kB]
Get: 33 http://ftp.uk.debian.org/debian/ testing/main xfce4-notes-plugin amd64 1.8.1-1 [68.8 kB]
Get: 34 http://ftp.fr.debian.org/debian/ unstable/main binutils amd64 2.25.1-2 [3,608 kB]
Get: 35 http://ftp.uk.debian.org/debian/ testing/main xfce4-netload-plugin amd64 1.2.4-1+b1 [77.6 kB]
Get: 36 http://ftp.uk.debian.org/debian/ testing/main xfce4-mount-plugin amd64 0.6.7-1+b1 [97.0 kB]
Get: 37 http://ftp.uk.debian.org/debian/ testing/main xfce4-mixer amd64 4.10.0-3+b1 [161 kB]
Get: 38 http://ftp.uk.debian.org/debian/ testing/main libgnutls-openssl27 amd64 3.3.17-1 [160 kB]
Get: 39 http://ftp.uk.debian.org/debian/ testing/main libgnutls-deb0-28 amd64 3.3.17-1 [716 kB]
Get: 40 http://ftp.uk.debian.org/debian/ testing/main xfce4-mailwatch-plugin amd64 1.2.0-2+b1 [184 kB]
Get: 41 http://ftp.uk.debian.org/debian/ testing/main xfce4-genmon-plugin amd64 3.4.0-2+b1 [44.2 kB]
Get: 42 http://ftp.uk.debian.org/debian/ testing/main xfce4-fsguard-plugin amd64 1.0.2-1+b1 [82.6 kB]
Get: 43 http://ftp.uk.debian.org/debian/ testing/main xfce4-diskperf-plugin amd64 2.5.5-1+b1 [66.6 kB]
Get: 44 http://ftp.uk.debian.org/debian/ testing/main xfce4-dict amd64 0.7.1-1+b1 [177 kB]
Get: 45 http://ftp.uk.debian.org/debian/ testing/main xfce4-datetime-plugin amd64 0.6.2-2+b1 [30.8 kB]
Get: 46 http://ftp.uk.debian.org/debian/ testing/main xfce4-cpugraph-plugin amd64 1.0.5-1+b1 [72.0 kB]
Get: 47 http://ftp.uk.debian.org/debian/ testing/main xfce4-cpufreq-plugin amd64 1.1.2-1 [73.2 kB]
Get: 48 http://ftp.uk.debian.org/debian/ testing/main xfce4-clipman-plugin amd64 2:1.2.6-1+b1 [38.5 kB]
Get: 49 http://ftp.uk.debian.org/debian/ testing/main xfce4-battery-plugin amd64 1.0.5-4+b1 [114 kB]
Get: 50 http://ftp.uk.debian.org/debian/ testing/main orage amd64 4.12.1-1+b1 [1,719 kB]
Get: 51 http://ftp.fr.debian.org/debian/ unstable/main libcgmanager0 amd64 0.39-2 [41.0 kB]
Get: 52 http://ftp.fr.debian.org/debian/ unstable/main cgmanager amd64 0.39-2 [84.1 kB]
Get: 53 http://ftp.fr.debian.org/debian/ unstable/main libfbclient2 amd64 2.5.4.26856.ds4-2 [359 kB]
Get: 54 http://ftp.uk.debian.org/debian/ testing/main xfce4-panel amd64 4.12.0-3 [729 kB]
Get: 55 http://ftp.fr.debian.org/debian/ unstable/main libfbembed2.5 amd64 2.5.4.26856.ds4-2 [1,553 kB]
Get: 56 http://ftp.uk.debian.org/debian/ testing/main osmo amd64 0.2.14-1 [532 kB]
Get: 57 http://ftp.uk.debian.org/debian/ testing/main libical1a amd64 1.0.1-0.1 [172 kB]
Get: 58 http://ftp.uk.debian.org/debian/ testing/main libecal-1.2-18 amd64 3.16.5-1 [287 kB]
Get: 59 http://ftp.uk.debian.org/debian/ testing/main libpanel-applet0 amd64 3.16.1-4 [118 kB]
Get: 60 http://ftp.uk.debian.org/debian/ testing/main gnome-applets-data all 3.16.1-3 [6,998 kB]
Get: 61 http://ftp.fr.debian.org/debian/ unstable/main firebird2.5-server-common amd64 2.5.4.26856.ds4-2 [547 kB]
Get: 62 http://ftp.fr.debian.org/debian/ unstable/main firebird2.5-common all 2.5.4.26856.ds4-2 [13.5 kB]
Get: 63 http://ftp.fr.debian.org/debian/ unstable/main firebird2.5-common-doc all 2.5.4.26856.ds4-2 [658 kB]
Get: 64 http://ftp.fr.debian.org/debian/ unstable/main fonts-lyx all 2.1.4-2 [202 kB]
Get: 65 http://ftp.fr.debian.org/debian/ unstable/main libmpg123-0 amd64 1.22.3-1 [138 kB]
Get: 66 http://ftp.fr.debian.org/debian/ unstable/main libgusb2 amd64 0.2.7-1 [21.6 kB]
Get: 67 http://ftp.uk.debian.org/debian/ testing/main python3-gi amd64 3.16.2-1 [460 kB]
Get: 68 http://ftp.uk.debian.org/debian/ testing/main gir1.2-panelapplet-5.0 amd64 3.16.1-4 [100 kB]
Get: 69 http://ftp.uk.debian.org/debian/ testing/main glib-networking-services amd64 2.44.0-2+b1 [18.6 kB]
Get: 70 http://ftp.uk.debian.org/debian/ testing/main glib-networking amd64 2.44.0-2+b1 [53.9 kB]
Get: 71 http://ftp.uk.debian.org/debian/ testing/main libproxy1v5 amd64 0.4.11-4.2 [53.7 kB]
Get: 72 http://ftp.uk.debian.org/debian/ testing/main gstreamer1.0-plugins-ugly amd64 1.4.5-2+b2 [373 kB]
Get: 73 http://ftp.uk.debian.org/debian/ testing/main libsidplay1v5 amd64 1.36.59-8 [67.0 kB]
Get: 74 http://ftp.uk.debian.org/debian/ testing/main xserver-xorg-video-tdfx amd64 1:1.4.6-1+b1 [43.4 kB]
Get: 75 http://ftp.uk.debian.org/debian/ testing/main xserver-xorg-video-trident amd64 1:1.3.7-1+b1 [68.0 kB]
Get: 76 http://ftp.uk.debian.org/debian/ testing/main xserver-xorg-video-vmware amd64 1:13.1.0-2 [108 kB]
Get: 77 http://ftp.uk.debian.org/debian/ testing/main xserver-xorg-video-mga amd64 1:1.6.4-1+b1 [94.1 kB]
Get: 78 http://ftp.uk.debian.org/debian/ testing/main xserver-xorg-video-vesa amd64 1:2.3.3-1+b4 [29.9 kB]
Get: 79 http://ftp.uk.debian.org/debian/ testing/main xserver-xorg-video-sisusb amd64 1:0.9.6-2+b3 [47.4 kB]
Get: 80 http://ftp.uk.debian.org/debian/ testing/main xserver-xorg-video-savage amd64 1:2.3.8-1 [91.2 kB]
Get: 81 http://ftp.uk.debian.org/debian/ testing/main xserver-xorg-video-r128 amd64 6.10.0-1 [183 kB]
Get: 82 http://ftp.uk.debian.org/debian/ testing/main xserver-xorg-video-qxl amd64 0.1.4-3 [136 kB]
Get: 83 http://ftp.uk.debian.org/debian/ testing/main xserver-xorg-video-openchrome amd64 1:0.3.3-1+b3 [200 kB]
Get: 84 http://ftp.uk.debian.org/debian/ testing/main xserver-xorg-video-nouveau amd64 1:1.0.11-1+b1 [312 kB]
Get: 85 http://ftp.uk.debian.org/debian/ testing/main xserver-xorg-video-neomagic amd64 1:1.2.9-1 [41.5 kB]
Get: 86 http://ftp.uk.debian.org/debian/ testing/main xserver-xorg-video-mach64 amd64 6.9.5-1 [190 kB]
Get: 87 http://ftp.uk.debian.org/debian/ testing/main xserver-xorg-video-intel amd64 2:2.99.917-2 [1,620 kB]
Get: 88 http://ftp.uk.debian.org/debian/ testing/main xserver-xorg-video-fbdev amd64 1:0.4.4-1+b3 [23.2 kB]
Get: 89 http://ftp.uk.debian.org/debian/ testing/main xserver-xorg-video-cirrus amd64 1:1.5.3-1 [41.2 kB]
Get: 90 http://ftp.uk.debian.org/debian/ testing/main xserver-xorg-video-radeon amd64 1:7.5.0-1+b1 [418 kB]
Get: 91 http://ftp.uk.debian.org/debian/ testing/main xserver-xorg-video-ati amd64 1:7.5.0-1+b1 [303 kB]
Get: 92 http://ftp.uk.debian.org/debian/ testing/main xserver-xorg-core amd64 2:1.17.2-1.1 [3,146 kB]
Get: 93 http://ftp.uk.debian.org/debian/ testing/main mutter-common all 3.16.3-1 [516 kB]
Get: 94 http://ftp.uk.debian.org/debian/ testing/main xfce4 all 4.12.1 [7,940 B]
Get: 95 http://ftp.uk.debian.org/debian/ testing/main xfce4-whiskermenu-plugin amd64 1.5.0-2+b1 [147 kB]
Get: 96 http://ftp.uk.debian.org/debian/ testing/main xfce4-goodies amd64 4.12 [4,932 B]
Get: 97 http://ftp.uk.debian.org/debian/ testing/main xserver-xorg-input-wacom amd64 0.30.0-1 [90.8 kB]
Get: 98 http://ftp.uk.debian.org/debian/ testing/main libgstreamer-plugins-bad1.0-0 amd64 1.4.5-3 [1,330 kB]
Fetched 40.0 MB in 26s (1,502 kB/s)
Retrieving bug reports… Done
Parsing Found/Fixed information… Done
Summary:
Are you sure you want to install/upgrade the above packages? [Y/n/?/…] y
Reading changelogs… Done
Extracting templates from packages: 100%
dpkg: libpanel-applet-4-0: dependency problems, but removing anyway as you requested:
gnome-applets depends on libpanel-applet-4-0 (>= 3.2.1).
gnome-panel depends on libpanel-applet-4-0 (>= 3.4.1).
gir1.2-panelapplet-4.0 depends on libpanel-applet-4-0 (>= 3.4.1).
(Reading database … 133173 files and directories currently installed.)
Removing libpanel-applet-4-0 (3.8.1-7+b2) …
Processing triggers for libc-bin (2.19-20) …
(Reading database … 133163 files and directories currently installed.)
Preparing to unpack …/gnome-panel_3.16.1-4_amd64.deb …
Unpacking gnome-panel (3.16.1-4) over (3.4.2.1-6) …
Preparing to unpack …/gnome-applets_3.16.1-3_amd64.deb …
Unpacking gnome-applets (3.16.1-3) over (3.8.1-1+b1) …
Processing triggers for mime-support (3.59) …
Processing triggers for gnome-menus (3.13.3-6) …
Processing triggers for desktop-file-utils (0.22-1) …
Processing triggers for man-db (2.7.3-1) …
Processing triggers for gconf2 (3.2.6-3) …
(Reading database … 133143 files and directories currently installed.)
Removing gir1.2-panelapplet-4.0 (3.8.1-7+b2) …
(Reading database … 133134 files and directories currently installed.)
Preparing to unpack …/gnome-panel-data_3.16.1-4_all.deb …
Unpacking gnome-panel-data (3.16.1-4) over (3.4.2.1-6) …
Selecting previously unselected package libcamel-1.2-52.
Preparing to unpack …/libcamel-1.2-52_3.16.5-1_amd64.deb …
Unpacking libcamel-1.2-52 (3.16.5-1) …
Selecting previously unselected package libedataserver-1.2-20.
Preparing to unpack …/libedataserver-1.2-20_3.16.5-1_amd64.deb …
Unpacking libedataserver-1.2-20 (3.16.5-1) …
Preparing to unpack …/bluez-obexd_5.33-1_amd64.deb …
Unpacking bluez-obexd (5.33-1) over (5.23-1) …
Preparing to unpack …/xfce4-power-manager-plugins_1.4.4-4_amd64.deb …
Unpacking xfce4-power-manager-plugins (1.4.4-4) over (1.4.1-2) …
Preparing to unpack …/xfce4-xkb-plugin_1%3a0.7.1-2+b1_amd64.deb …
Unpacking xfce4-xkb-plugin (1:0.7.1-2+b1) over (1:0.5.6-1) …
Preparing to unpack …/xfce4-weather-plugin_0.8.6-1_amd64.deb …
Unpacking xfce4-weather-plugin (0.8.6-1) over (0.8.3-2) …
Preparing to unpack …/xfce4-wavelan-plugin_0.5.12-1_amd64.deb …
Unpacking xfce4-wavelan-plugin (0.5.12-1) over (0.5.11-3) …
Preparing to unpack …/xfce4-verve-plugin_1.0.1-1+b1_amd64.deb …
Unpacking xfce4-verve-plugin (1.0.1-1+b1) over (1.0.0-3) …
Preparing to unpack …/xfce4-timer-plugin_1.6.0-1+b1_amd64.deb …
Unpacking xfce4-timer-plugin (1.6.0-1+b1) over (1.6.0-1) …
Preparing to unpack …/xfce4-systemload-plugin_1.1.2-1+b1_amd64.deb …
Unpacking xfce4-systemload-plugin (1.1.2-1+b1) over (1.1.1-4) …
Preparing to unpack …/xfce4-smartbookmark-plugin_0.4.6-1+b1_amd64.deb …
Unpacking xfce4-smartbookmark-plugin (0.4.6-1+b1) over (0.4.5-1) …
Preparing to unpack …/xfce4-sensors-plugin_1.2.6-1+b1_amd64.deb …
Unpacking xfce4-sensors-plugin (1.2.6-1+b1) over (1.2.5-2) …
Preparing to unpack …/xfce4-quicklauncher-plugin_1.9.4-11+b1_amd64.deb …
Unpacking xfce4-quicklauncher-plugin (1.9.4-11+b1) over (1.9.4-11) …
Preparing to unpack …/xfce4-places-plugin_1.7.0-3_amd64.deb …
Unpacking xfce4-places-plugin (1.7.0-3) over (1.6.0-1) …
Preparing to unpack …/xfce4-notes-plugin_1.8.1-1_amd64.deb …
Unpacking xfce4-notes-plugin (1.8.1-1) over (1.7.7-5) …
Preparing to unpack …/xfce4-netload-plugin_1.2.4-1+b1_amd64.deb …
Unpacking xfce4-netload-plugin (1.2.4-1+b1) over (1.2.0-1) …
Preparing to unpack …/xfce4-mount-plugin_0.6.7-1+b1_amd64.deb …
Unpacking xfce4-mount-plugin (0.6.7-1+b1) over (0.6.7-1) …
Preparing to unpack …/xfce4-mixer_4.10.0-3+b1_amd64.deb …
Unpacking xfce4-mixer (4.10.0-3+b1) over (4.10.0-3) …
Preparing to unpack …/libgnutls-openssl27_3.3.17-1_amd64.deb …
Unpacking libgnutls-openssl27:amd64 (3.3.17-1) over (3.3.15-6) …
Preparing to unpack …/libgnutls-deb0-28_3.3.17-1_amd64.deb …
Unpacking libgnutls-deb0-28:amd64 (3.3.17-1) over (3.3.15-6) …
Preparing to unpack …/xfce4-mailwatch-plugin_1.2.0-2+b1_amd64.deb …
Unpacking xfce4-mailwatch-plugin (1.2.0-2+b1) over (1.2.0-2) …
Preparing to unpack …/xfce4-genmon-plugin_3.4.0-2+b1_amd64.deb …
Unpacking xfce4-genmon-plugin (3.4.0-2+b1) over (3.4.0-2) …
Preparing to unpack …/xfce4-fsguard-plugin_1.0.2-1+b1_amd64.deb …
Unpacking xfce4-fsguard-plugin (1.0.2-1+b1) over (1.0.1-2) …
Preparing to unpack …/xfce4-diskperf-plugin_2.5.5-1+b1_amd64.deb …
Unpacking xfce4-diskperf-plugin (2.5.5-1+b1) over (2.5.4-3) …
Preparing to unpack …/xfce4-dict_0.7.1-1+b1_amd64.deb …
Unpacking xfce4-dict (0.7.1-1+b1) over (0.7.0-1) …
Preparing to unpack …/xfce4-datetime-plugin_0.6.2-2+b1_amd64.deb …
Unpacking xfce4-datetime-plugin (0.6.2-2+b1) over (0.6.2-2) …
Preparing to unpack …/xfce4-cpugraph-plugin_1.0.5-1+b1_amd64.deb …
Unpacking xfce4-cpugraph-plugin (1.0.5-1+b1) over (1.0.5-1) …
Preparing to unpack …/xfce4-cpufreq-plugin_1.1.2-1_amd64.deb …
Unpacking xfce4-cpufreq-plugin (1.1.2-1) over (1.1.0-1) …
Preparing to unpack …/xfce4-clipman-plugin_2%3a1.2.6-1+b1_amd64.deb …
Unpacking xfce4-clipman-plugin (2:1.2.6-1+b1) over (2:1.2.6-1) …
Preparing to unpack …/xfce4-battery-plugin_1.0.5-4+b1_amd64.deb …
Unpacking xfce4-battery-plugin (1.0.5-4+b1) over (1.0.5-4) …
Preparing to unpack …/orage_4.12.1-1+b1_amd64.deb …
Unpacking orage (4.12.1-1+b1) over (4.10.0-1+b1) …
Preparing to unpack …/xfce4-panel_4.12.0-3_amd64.deb …
Unpacking xfce4-panel (4.12.0-3) over (4.10.1-1) …
Preparing to unpack …/osmo_0.2.14-1_amd64.deb …
Unpacking osmo (0.2.14-1) over (0.2.12-1) …
Processing triggers for hicolor-icon-theme (0.13-1) …
Processing triggers for menu (2.1.47) …
(Reading database … 133115 files and directories currently installed.)
Removing libedata-cal-1.2-20 (3.8.5-3+b2) …
Removing libecal-1.2-15 (3.8.5-3+b2) …
Removing libical1 (1.0-1.2) …
Selecting previously unselected package libical1a.
(Reading database … 133082 files and directories currently installed.)
Preparing to unpack …/libical1a_1.0.1-0.1_amd64.deb …
Unpacking libical1a (1.0.1-0.1) …
Selecting previously unselected package libecal-1.2-18.
Preparing to unpack …/libecal-1.2-18_3.16.5-1_amd64.deb …
Unpacking libecal-1.2-18 (3.16.5-1) …
Selecting previously unselected package libpanel-applet0.
Preparing to unpack …/libpanel-applet0_3.16.1-4_amd64.deb …
Unpacking libpanel-applet0 (3.16.1-4) …
Preparing to unpack …/gnome-applets-data_3.16.1-3_all.deb …
Unpacking gnome-applets-data (3.16.1-3) over (3.8.1-1) …
Selecting previously unselected package python3-gi.
Preparing to unpack …/python3-gi_3.16.2-1_amd64.deb …
Unpacking python3-gi (3.16.2-1) …
Selecting previously unselected package gir1.2-panelapplet-5.0.
Preparing to unpack …/gir1.2-panelapplet-5.0_3.16.1-4_amd64.deb …
Unpacking gir1.2-panelapplet-5.0 (3.16.1-4) …
Preparing to unpack …/glib-networking-services_2.44.0-2+b1_amd64.deb …
Unpacking glib-networking-services (2.44.0-2+b1) over (2.44.0-2) …
Preparing to unpack …/glib-networking_2.44.0-2+b1_amd64.deb …
Unpacking glib-networking:amd64 (2.44.0-2+b1) over (2.44.0-2) …
Processing triggers for dbus (1.10.0-3) …
(Reading database … 133135 files and directories currently installed.)
Removing libproxy1:amd64 (0.4.11-4+b2) …
Selecting previously unselected package libproxy1v5:amd64.
(Reading database … 133128 files and directories currently installed.)
Preparing to unpack …/libproxy1v5_0.4.11-4.2_amd64.deb …
Unpacking libproxy1v5:amd64 (0.4.11-4.2) …
Preparing to unpack …/gstreamer1.0-plugins-ugly_1.4.5-2+b2_amd64.deb …
Unpacking gstreamer1.0-plugins-ugly:amd64 (1.4.5-2+b2) over (1.4.5-2+b1) …
Removing libsidplay1 (1.36.59-7) …
Selecting previously unselected package libsidplay1v5.
Preparing to unpack …/libsidplay1v5_1.36.59-8_amd64.deb …
Unpacking libsidplay1v5 (1.36.59-8) …
Preparing to unpack …/xserver-xorg-video-tdfx_1%3a1.4.6-1+b1_amd64.deb …
Unpacking xserver-xorg-video-tdfx (1:1.4.6-1+b1) over (1:1.4.6-1) …
Preparing to unpack …/xserver-xorg-video-trident_1%3a1.3.7-1+b1_amd64.deb …
Unpacking xserver-xorg-video-trident (1:1.3.7-1+b1) over (1:1.3.7-1) …
Preparing to unpack …/xserver-xorg-video-vmware_1%3a13.1.0-2_amd64.deb …
Unpacking xserver-xorg-video-vmware (1:13.1.0-2) over (1:13.1.0-1) …
Preparing to unpack …/xserver-xorg-video-mga_1%3a1.6.4-1+b1_amd64.deb …
Unpacking xserver-xorg-video-mga (1:1.6.4-1+b1) over (1:1.6.4-1) …
Preparing to unpack …/xserver-xorg-video-vesa_1%3a2.3.3-1+b4_amd64.deb …
Unpacking xserver-xorg-video-vesa (1:2.3.3-1+b4) over (1:2.3.3-1+b3) …
Preparing to unpack …/xserver-xorg-video-sisusb_1%3a0.9.6-2+b3_amd64.deb …
Unpacking xserver-xorg-video-sisusb (1:0.9.6-2+b3) over (1:0.9.6-2+b2) …
Preparing to unpack …/xserver-xorg-video-siliconmotion_1%3a1.7.8-1_amd64.deb …
Unpacking xserver-xorg-video-siliconmotion (1:1.7.8-1) over (1:1.7.7-2+b2) …
Preparing to unpack …/xserver-xorg-video-savage_1%3a2.3.8-1_amd64.deb …
Unpacking xserver-xorg-video-savage (1:2.3.8-1) over (1:2.3.7-2+b2) …
Preparing to unpack …/xserver-xorg-video-r128_6.10.0-1_amd64.deb …
Unpacking xserver-xorg-video-r128 (6.10.0-1) over (6.9.2-1+b2) …
Preparing to unpack …/xserver-xorg-video-qxl_0.1.4-3_amd64.deb …
Unpacking xserver-xorg-video-qxl (0.1.4-3) over (0.1.1-2+b1) …
Preparing to unpack …/xserver-xorg-video-openchrome_1%3a0.3.3-1+b3_amd64.deb …
Unpacking xserver-xorg-video-openchrome (1:0.3.3-1+b3) over (1:0.3.3-1+b2) …
Preparing to unpack …/xserver-xorg-video-nouveau_1%3a1.0.11-1+b1_amd64.deb …
Unpacking xserver-xorg-video-nouveau (1:1.0.11-1+b1) over (1:1.0.11-1) …
Preparing to unpack …/xserver-xorg-video-neomagic_1%3a1.2.9-1_amd64.deb …
Unpacking xserver-xorg-video-neomagic (1:1.2.9-1) over (1:1.2.8-1+b2) …
Preparing to unpack …/xserver-xorg-video-mach64_6.9.5-1_amd64.deb …
Unpacking xserver-xorg-video-mach64 (6.9.5-1) over (6.9.4-2) …
Preparing to unpack …/xserver-xorg-video-intel_2%3a2.99.917-2_amd64.deb …
Unpacking xserver-xorg-video-intel (2:2.99.917-2) over (2:2.21.15-2+b2) …
Preparing to unpack …/xserver-xorg-video-fbdev_1%3a0.4.4-1+b3_amd64.deb …
Unpacking xserver-xorg-video-fbdev (1:0.4.4-1+b3) over (1:0.4.4-1+b2) …
Preparing to unpack …/xserver-xorg-video-cirrus_1%3a1.5.3-1_amd64.deb …
Unpacking xserver-xorg-video-cirrus (1:1.5.3-1) over (1:1.5.2-2+b1) …
Preparing to unpack …/xserver-xorg-video-radeon_1%3a7.5.0-1+b1_amd64.deb …
Unpacking xserver-xorg-video-radeon (1:7.5.0-1+b1) over (1:7.5.0-1) …
Preparing to unpack …/xserver-xorg-video-ati_1%3a7.5.0-1+b1_amd64.deb …
Unpacking xserver-xorg-video-ati (1:7.5.0-1+b1) over (1:7.5.0-1) …
dpkg: xserver-xorg-video-modesetting: dependency problems, but removing anyway as you requested:
xserver-xorg-video-all depends on xserver-xorg-video-modesetting; however:
Package xserver-xorg-video-modesetting is to be removed.
(Reading database … 133138 files and directories currently installed.)
Removing xserver-xorg-video-modesetting (0.9.0-2) …
(Reading database … 133129 files and directories currently installed.)
Preparing to unpack …/xserver-xorg-core_2%3a1.17.2-1.1_amd64.deb …
Unpacking xserver-xorg-core (2:1.17.2-1.1) over (2:1.16.4-1) …
Preparing to unpack …/libcupscgi1_2.1.0-4_amd64.deb …
Unpacking libcupscgi1:amd64 (2.1.0-4) over (2.1.0-3) …
Preparing to unpack …/cups-core-drivers_2.1.0-4_amd64.deb …
Unpacking cups-core-drivers (2.1.0-4) over (2.1.0-3) …
Preparing to unpack …/libcupsmime1_2.1.0-4_amd64.deb …
Unpacking libcupsmime1:amd64 (2.1.0-4) over (2.1.0-3) …
Preparing to unpack …/cups-server-common_2.1.0-4_all.deb …
Unpacking cups-server-common (2.1.0-4) over (2.1.0-3) …
Preparing to unpack …/libcupsimage2_2.1.0-4_amd64.deb …
Unpacking libcupsimage2:amd64 (2.1.0-4) over (2.1.0-3) …
Preparing to unpack …/libcupsppdc1_2.1.0-4_amd64.deb …
Unpacking libcupsppdc1:amd64 (2.1.0-4) over (2.1.0-3) …
Preparing to unpack …/cups-common_2.1.0-4_all.deb …
Unpacking cups-common (2.1.0-4) over (2.1.0-3) …
Preparing to unpack …/cups-ppdc_2.1.0-4_amd64.deb …
Unpacking cups-ppdc (2.1.0-4) over (2.1.0-3) …
Preparing to unpack …/cups-bsd_2.1.0-4_amd64.deb …
Unpacking cups-bsd (2.1.0-4) over (2.1.0-3) …
Preparing to unpack …/cups-client_2.1.0-4_amd64.deb …
Unpacking cups-client (2.1.0-4) over (2.1.0-3) …
Preparing to unpack …/cups-daemon_2.1.0-4_amd64.deb …
Warning: Stopping cups.service, but it can still be activated by:
cups.socket
Unpacking cups-daemon (2.1.0-4) over (2.1.0-3) …
Preparing to unpack …/libcups2_2.1.0-4_amd64.deb …
Unpacking libcups2:amd64 (2.1.0-4) over (2.1.0-3) …
Preparing to unpack …/cups_2.1.0-4_amd64.deb …
Unpacking cups (2.1.0-4) over (2.1.0-3) …
Selecting previously unselected package libnpth0:amd64.
Preparing to unpack …/libnpth0_1.2-1_amd64.deb …
Unpacking libnpth0:amd64 (1.2-1) …
Preparing to unpack …/rsyslog_8.12.0-3_amd64.deb …
Unpacking rsyslog (8.12.0-3) over (8.12.0-1) …
Preparing to unpack …/lsof_4.89+dfsg-0.1_amd64.deb …
Unpacking lsof (4.89+dfsg-0.1) over (4.86+dfsg-1) …
Preparing to unpack …/binutils_2.25.1-2_amd64.deb …
Unpacking binutils (2.25.1-2) over (2.25.1-1) …
Preparing to unpack …/libcgmanager0_0.39-2_amd64.deb …
Unpacking libcgmanager0:amd64 (0.39-2) over (0.39-1) …
Preparing to unpack …/cgmanager_0.39-2_amd64.deb …
Unpacking cgmanager (0.39-2) over (0.39-1) …
Preparing to unpack …/libfbclient2_2.5.4.26856.ds4-2_amd64.deb …
Unpacking libfbclient2:amd64 (2.5.4.26856.ds4-2) over (2.5.4.26856.ds4-1+b1) …
Preparing to unpack …/libfbembed2.5_2.5.4.26856.ds4-2_amd64.deb …
Unpacking libfbembed2.5 (2.5.4.26856.ds4-2) over (2.5.4.26856.ds4-1+b1) …
Preparing to unpack …/firebird2.5-server-common_2.5.4.26856.ds4-2_amd64.deb …
Unpacking firebird2.5-server-common (2.5.4.26856.ds4-2) over (2.5.4.26856.ds4-1+b1) …
Preparing to unpack …/firebird2.5-common_2.5.4.26856.ds4-2_all.deb …
Unpacking firebird2.5-common (2.5.4.26856.ds4-2) over (2.5.4.26856.ds4-1) …
Preparing to unpack …/firebird2.5-common-doc_2.5.4.26856.ds4-2_all.deb …
Unpacking firebird2.5-common-doc (2.5.4.26856.ds4-2) over (2.5.4.26856.ds4-1) …
Preparing to unpack …/fonts-lyx_2.1.4-2_all.deb …
Unpacking fonts-lyx (2.1.4-2) over (2.1.4-1) …
Preparing to unpack …/gnupg-agent_2.1.8-1_amd64.deb …
Unpacking gnupg-agent (2.1.8-1) over (2.0.28-3) …
Preparing to unpack …/gnupg2_2.1.8-1_amd64.deb …
Unpacking gnupg2 (2.1.8-1) over (2.0.28-3) …
Preparing to unpack …/libmpg123-0_1.22.3-1_amd64.deb …
Unpacking libmpg123-0:amd64 (1.22.3-1) over (1.22.2-1) …
Preparing to unpack …/mutter-common_3.16.3-1_all.deb …
Unpacking mutter-common (3.16.3-1) over (3.4.1-7) …
Preparing to unpack …/openssl_1.0.2d-1_amd64.deb …
Unpacking openssl (1.0.2d-1) over (1.0.1k-3) …
Preparing to unpack …/archives/xfce4_4.12.1_all.deb …
Unpacking xfce4 (4.12.1) over (4.10.1) …
Selecting previously unselected package xfce4-whiskermenu-plugin.
Preparing to unpack …/xfce4-whiskermenu-plugin_1.5.0-2+b1_amd64.deb …
Unpacking xfce4-whiskermenu-plugin (1.5.0-2+b1) …
Preparing to unpack …/xfce4-goodies_4.12_amd64.deb …
Unpacking xfce4-goodies (4.12) over (4.10) …
Preparing to unpack …/xserver-xorg-input-wacom_0.30.0-1_amd64.deb …
Unpacking xserver-xorg-input-wacom (0.30.0-1) over (0.26.0+20140918-1) …
Preparing to unpack …/libgstreamer-plugins-bad1.0-0_1.4.5-3_amd64.deb …
Unpacking libgstreamer-plugins-bad1.0-0:amd64 (1.4.5-3) over (1.4.5-2+b1) …
Preparing to unpack …/libgusb2_0.2.7-1_amd64.deb …
Unpacking libgusb2:amd64 (0.2.7-1) over (0.2.6-1) …
Processing triggers for install-info (6.0.0.dfsg.1-3) …
Setting up gnome-panel-data (3.16.1-4) …
Setting up libcamel-1.2-52 (3.16.5-1) …
Setting up libedataserver-1.2-20 (3.16.5-1) …
Setting up libical1a (1.0.1-0.1) …
Setting up libecal-1.2-18 (3.16.5-1) …
Setting up libpanel-applet0 (3.16.1-4) …
Setting up gnome-panel (3.16.1-4) …
Setting up gnome-applets-data (3.16.1-3) …
Installing new version of config file /etc/dbus-1/system.d/org.gnome.CPUFreqSelector.conf …
Setting up python3-gi (3.16.2-1) …
Setting up gir1.2-panelapplet-5.0 (3.16.1-4) …
Setting up gnome-applets (3.16.1-3) …
Setting up bluez-obexd (5.33-1) …
Setting up xfce4-panel (4.12.0-3) …
Setting up xfce4-power-manager-plugins (1.4.4-4) …
Setting up xfce4-xkb-plugin (1:0.7.1-2+b1) …
Setting up xfce4-weather-plugin (0.8.6-1) …
Setting up xfce4-wavelan-plugin (0.5.12-1) …
Setting up xfce4-verve-plugin (1.0.1-1+b1) …
Setting up xfce4-timer-plugin (1.6.0-1+b1) …
Setting up xfce4-systemload-plugin (1.1.2-1+b1) …
Setting up xfce4-smartbookmark-plugin (0.4.6-1+b1) …
Setting up xfce4-sensors-plugin (1.2.6-1+b1) …
Setting up xfce4-quicklauncher-plugin (1.9.4-11+b1) …
Setting up xfce4-places-plugin (1.7.0-3) …
Setting up xfce4-notes-plugin (1.8.1-1) …
Setting up xfce4-netload-plugin (1.2.4-1+b1) …
Setting up xfce4-mount-plugin (0.6.7-1+b1) …
Setting up xfce4-mixer (4.10.0-3+b1) …
Setting up libgnutls-deb0-28:amd64 (3.3.17-1) …
Setting up libgnutls-openssl27:amd64 (3.3.17-1) …
Setting up xfce4-mailwatch-plugin (1.2.0-2+b1) …
Setting up xfce4-genmon-plugin (3.4.0-2+b1) …
Setting up xfce4-fsguard-plugin (1.0.2-1+b1) …
Setting up xfce4-diskperf-plugin (2.5.5-1+b1) …
Setting up xfce4-dict (0.7.1-1+b1) …
Setting up xfce4-datetime-plugin (0.6.2-2+b1) …
Setting up xfce4-cpugraph-plugin (1.0.5-1+b1) …
Setting up xfce4-cpufreq-plugin (1.1.2-1) …
Setting up xfce4-clipman-plugin (2:1.2.6-1+b1) …
Setting up xfce4-battery-plugin (1.0.5-4+b1) …
Setting up orage (4.12.1-1+b1) …
Setting up osmo (0.2.14-1) …
Setting up libproxy1v5:amd64 (0.4.11-4.2) …
Setting up glib-networking-services (2.44.0-2+b1) …
Setting up glib-networking:amd64 (2.44.0-2+b1) …
Setting up libsidplay1v5 (1.36.59-8) …
Setting up gstreamer1.0-plugins-ugly:amd64 (1.4.5-2+b2) …
Setting up xserver-xorg-core (2:1.17.2-1.1) …
Setting up xserver-xorg-video-tdfx (1:1.4.6-1+b1) …
Setting up xserver-xorg-video-trident (1:1.3.7-1+b1) …
Setting up xserver-xorg-video-vmware (1:13.1.0-2) …
Setting up xserver-xorg-video-mga (1:1.6.4-1+b1) …
Setting up xserver-xorg-video-vesa (1:2.3.3-1+b4) …
Setting up xserver-xorg-video-sisusb (1:0.9.6-2+b3) …
Setting up xserver-xorg-video-siliconmotion (1:1.7.8-1) …
Setting up xserver-xorg-video-savage (1:2.3.8-1) …
Setting up xserver-xorg-video-r128 (6.10.0-1) …
Setting up xserver-xorg-video-qxl (0.1.4-3) …
Setting up xserver-xorg-video-openchrome (1:0.3.3-1+b3) …
Setting up xserver-xorg-video-nouveau (1:1.0.11-1+b1) …
Setting up xserver-xorg-video-neomagic (1:1.2.9-1) …
Setting up xserver-xorg-video-mach64 (6.9.5-1) …
Setting up xserver-xorg-video-intel (2:2.99.917-2) …
Setting up xserver-xorg-video-fbdev (1:0.4.4-1+b3) …
Setting up xserver-xorg-video-cirrus (1:1.5.3-1) …
Setting up xserver-xorg-video-radeon (1:7.5.0-1+b1) …
Setting up xserver-xorg-video-ati (1:7.5.0-1+b1) …
Setting up libcups2:amd64 (2.1.0-4) …
Setting up libcupscgi1:amd64 (2.1.0-4) …
Setting up libcupsmime1:amd64 (2.1.0-4) …
Setting up cups-daemon (2.1.0-4) …
Setting up cups-core-drivers (2.1.0-4) …
Setting up cups-server-common (2.1.0-4) …
Setting up libcupsimage2:amd64 (2.1.0-4) …
Setting up libcupsppdc1:amd64 (2.1.0-4) …
Setting up cups-common (2.1.0-4) …
Setting up cups-ppdc (2.1.0-4) …
Setting up cups-client (2.1.0-4) …
Setting up cups-bsd (2.1.0-4) …
Setting up cups (2.1.0-4) …
Updating PPD files for cups …
Setting up libnpth0:amd64 (1.2-1) …
Setting up rsyslog (8.12.0-3) …
Setting up lsof (4.89+dfsg-0.1) …
Setting up binutils (2.25.1-2) …
Setting up libcgmanager0:amd64 (0.39-2) …
Setting up cgmanager (0.39-2) …
Setting up firebird2.5-common-doc (2.5.4.26856.ds4-2) …
Setting up firebird2.5-common (2.5.4.26856.ds4-2) …
Setting up libfbclient2:amd64 (2.5.4.26856.ds4-2) …
Setting up firebird2.5-server-common (2.5.4.26856.ds4-2) …
Setting up libfbembed2.5 (2.5.4.26856.ds4-2) …
Setting up fonts-lyx (2.1.4-2) …
Setting up gnupg-agent (2.1.8-1) …
Installing new version of config file /etc/X11/Xsession.d/90gpg-agent …
Setting up gnupg2 (2.1.8-1) …
Setting up libmpg123-0:amd64 (1.22.3-1) …
Setting up mutter-common (3.16.3-1) …
Setting up openssl (1.0.2d-1) …
Setting up xfce4 (4.12.1) …
Setting up xfce4-whiskermenu-plugin (1.5.0-2+b1) …
Setting up xfce4-goodies (4.12) …
Setting up xserver-xorg-input-wacom (0.30.0-1) …
Setting up libgstreamer-plugins-bad1.0-0:amd64 (1.4.5-3) …
Setting up libgusb2:amd64 (0.2.7-1) …
Current status: 0 updates [-92], 14825 new [-1].
fiou…
