je suis nouveau sous debian (6 mois d’utilisation) et j’ai un fâcheux problème que je n’arrive pas à résoudre :
Je suis en dual screen avec radeon 1300pro silent. Hélas sur le deuxième écran, j’ai de petits soucis de pointeur de souris (le point de cliquage est décalé par rapport à la flèche)
J’ai tenter de corriger le xorg.conf sans succès. Un pro peut-il m’éclairer ?
et le xorg.conf :
[code]# /etc/X11/xorg.conf (xorg X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
(Type “man /etc/X11/xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section "Module"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/input/mice"
Option “Protocol” "ImPS/2"
EndSection
Section "Device"
Identifier "radeon0"
Driver "fglrx"
BusID "PCI:1:0:0"
Screen 0
Option “DDCMode” "True"
Option “MonitorLayout” "TMDS,TMDS"
EndSection
Section "Device"
Identifier "radeon1
Driver "fglrx"
BusID "PCI:1:0:0"
Screen 1
EndSection
Section "Monitor"
Identifier "HP"
Option "DPMS"
EndSection
Section "Monitor"
Identifier "ASUS MM17T"
Option "DPMS"
EndSection
Section "Screen"
Identifier "screen1"
Device "radeon0
Monitor "HP"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes “1280x1024” “1024x768” “800x600” "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Default Screen"
Device "radeon1
Monitor "ASUS MM17T"
DefaultDepth 24
Depth 1
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen 0 "Default Screen"
Screen 1 “screen1” LeftOf "Default Screen"
Option “xinerama” "on"
Option “clone” "off"
InputDevice "Generic Keyboard"
InputDevice “Configured Mouse”
EndSection
Section "DRI"
Mode 0666
EndSection
Section "Extensions"
Option “Composite” "enable"
EndSection
