Je rencontrais ce problème avec le package locale (et perl?) :
sudo dpkg-reconfigure locales
perl: warning: Setting locale failed. perl: warning: Please check that your locale settings: LANGUAGE = (unset),
LC_ALL = (unset),
LANG = "fr_FR.UTF-8"
are supported and installed on your system. perl: warning: Falling back to the standard locale ("C").
Donc après quelques recherches j’essaye de désinstaller le packet locales et de le reinstaller. Mais après désinstallation impossible de le réinstaller.
Message d’erreur :
[code]root@kalinux:~# apt-get install locales-all
Reading package lists… Done
Building dependency tree
Reading state information… Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libc6 : Breaks: locales-all (< 2.19)
Breaks: locales-all:i386 (< 2.19)
libcurl3-gnutls : Depends: libgcrypt11 (>= 1.4.5) but it is not going to be installed
Depends: libgnutls26 (>= 2.12.17-0) but it is not going to be installed
Depends: libgssapi-krb5-2 (>= 1.10+dfsg~) but it is not going to be installed
Depends: libidn11 (>= 1.13) but it is not going to be installed
Depends: libldap-2.4-2 (>= 2.4.7) but it is not going to be installed
Depends: librtmp0 (>= 2.3) but it is not going to be installed
Depends: libssh2-1 (>= 1.2.6) but it is not going to be installed
PreDepends: multiarch-support
Recommends: ca-certificates but it is not going to be installed
libgcc1 : PreDepends: multiarch-support
libqt4-dbus : Depends: qdbus (= 4:4.8.2+dfsg-11)
Depends: libqtdbus4 (= 4:4.8.2+dfsg-11) but it is not going to be installed
libqt4-network : Depends: libqtdbus4 (= 4:4.8.2+dfsg-11) but it is not going to be installed
libqtcore4 : Depends: libglib2.0-0 (>= 2.22.0) but it is not going to be installed
libqtgui4 : Depends: fontconfig
Depends: libaudio2 but it is not going to be installed
Depends: libfontconfig1 (>= 2.9.0) but it is not going to be installed
Depends: libfreetype6 (>= 2.3.5) but it is not going to be installed
Depends: libglib2.0-0 (>= 2.12.0) but it is not going to be installed
Depends: libice6 (>= 1:1.0.0) but it is not going to be installed
Depends: libjpeg8 (>= 8c) but it is not going to be installed
Depends: libmng1 (>= 1.0.10) but it is not going to be installed
Depends: libpng12-0 (>= 1.2.13-4) but it is not going to be installed
Depends: libsm6 but it is not going to be installed
Depends: libtiff4 (> 3.9.5-3~) but it is not going to be installed
Depends: libx11-6 but it is not going to be installed
Depends: libxext6 but it is not going to be installed
Depends: libxrender1 but it is not going to be installed
Recommends: libcups2 but it is not going to be installed
libssl1.0.0 : Depends: debconf (>= 0.5) but it is not going to be installed or
debconf-2.0
libstdc++6 : PreDepends: multiarch-support
locales-all : Depends: glibc-2.13-1
ruby : Depends: ruby1.9.1 (>= 1.9.3.194-1) but it is not going to be installed
transmission-qt : Depends: libevent-2.0-5 (>= 2.0.10-stable) but it is not going to be installed
zlib1g : PreDepends: multiarch-support
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
Je dois avouer que c’est assez problèmatique comme problème non, ce packet est essentiel je suppose, donc comment le réinstaller car là j’ai même pas oser éteindre l’ordinateur depuis hier par peur qu’il ne peut plus redémarer.
Merci de votre temps et de votre aider,
Cordialement
…)[/quote]
