Problemes mplayer
Bonjour les amis,
alors voila j’ai un petit problemes dont je ne voix la solution.
Je peut faciment lire mes vidéo en utilisant la commande mplayer (sa fais quand même bien geek ^^) parcontre quand je passe par l’interface graphique une jolie petite erreur aparait:
Error opening/initializing the selected video_out (-vo) device
résultat en ligne de commande.
[code] mplayer ./Desktop/1001\ Pattes.avi
MPlayer dev-SVN-r26940
CPU: Intel® Core™2 CPU 6400 @ 2.13GHz (Family: 6, Model: 15, Stepping: 2)
CPUflags: MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
Compiled with runtime CPU detection.
Can’t open joystick device /dev/input/js0: No such file or directory
Can’t init input joystick
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing ./Desktop/1001 Pattes.avi.
AVI file format detected.
[aviheader] Video stream found, -vid 0
[aviheader] Audio stream found, -aid 1
VIDEO: [XVID] 720x416 24bpp 25.000 fps 963.7 kbps (117.6 kbyte/s)
open: No such file or directory
[MGA] Couldn’t open: /dev/mga_vid
[VO_TDFXFB] Can’t open /dev/fb0: No such file or directory.
s3fb: can’t open /dev/fb0: No such file or directory
Opening video decoder: [ffmpeg] FFmpeg’s libavcodec codec family
Selected video codec: [ffodivx] vfm: ffmpeg (FFmpeg MPEG-4)
Opening audio decoder: [mp3lib] MPEG layer-2, layer-3
AUDIO: 48000 Hz, 2 ch, s16le, 96.0 kbit/6.25% (ratio: 12000->192000)
Selected audio codec: [mp3] afm: mp3lib (mp3lib MPEG layer-2, layer-3)
AO: [alsa] 48000Hz 2ch s16le (2 bytes per sample)
Starting playback…
[mpeg4 @ 0x87a0f90]looks like this file was encoded with (divx4/(old)xvid/opendivx) -> forcing low_delay flag
VDec: vo config request - 720 x 416 (preferred colorspace: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.73:1 - prescaling to correct movie aspect.
VO: [xv] 720x416 => 720x416 Planar YV12
A: 3.5 V: 3.5 A-V: 0.000 ct: 0.000 89/ 89 3% 0% 0.5% 0 0
Exiting… (Quit)
si quelle qu’un peut me filer un coup de main.
je pensse quesa doit être un petit souci de configuration mais je voix pas ou quoi comment pk ???
grace a mon ami google et nos cousin de chez ubuntu j’ai trouver un début de solution.
forum.ubuntu-fr.org/viewtopic.php?id=115771
dsl de mettre précipiter sur le forum sans avoir vraiment fait des recherches …
avant de publier ma second erreur je vais faire des recherhce cette fois promis ^^
