Le problème de l’horloge à été résolu avec la méthode d’Oberon.
Merci encore
Sinon voici le /var/log/boot de mon noyau 2.6.24
Tue Feb 12 10:54:01 2008: .
Tue Feb 12 10:54:01 2008: Setting preliminary keymap...done.
Tue Feb 12 10:54:01 2008: Setting parameters of disc: (none).
Tue Feb 12 10:54:01 2008: Setting the system clock.
Tue Feb 12 10:54:01 2008: Activating swap...done.
Tue Feb 12 10:54:01 2008: Checking root file system...fsck 1.40.6 (09-Feb-2008)
Tue Feb 12 10:54:01 2008: /dev/sda3: clean, 143973/610800 files, 1244045/2441872 blocks
Tue Feb 12 10:54:01 2008: done.
Tue Feb 12 10:54:02 2008: Cleaning up ifupdown....
Tue Feb 12 10:54:02 2008: Loading kernel modules...done.
Tue Feb 12 10:54:02 2008: Checking file systems...fsck 1.40.6 (09-Feb-2008)
Tue Feb 12 10:54:02 2008: /dev/sda4: clean, 3981/1851392 files, 744631/7403956 blocks (check after next mount)
Tue Feb 12 10:54:02 2008: done.
Tue Feb 12 10:54:02 2008: Setting kernel variables...done.
Tue Feb 12 10:54:02 2008: Invalidating stale software suspend images... done.
Tue Feb 12 10:54:02 2008: Mounting local filesystems...done.
Tue Feb 12 10:54:03 2008: Activating swapfile swap...done.
Tue Feb 12 10:54:03 2008: Setting up resolvconf...done.
Tue Feb 12 10:54:03 2008: Setting up networking....
Tue Feb 12 10:54:10 2008: ^[[33m*^[[39;49m Not starting ipw3945 regulatory daemon, driver not loaded.
Tue Feb 12 10:54:10 2008: Configuring network interfaces...done.
Tue Feb 12 10:54:11 2008: Starting portmap daemon....
Tue Feb 12 10:54:12 2008: Starting NFS common utilities: statd.
Tue Feb 12 10:54:12 2008: Setting console screen modes and fonts.
Tue Feb 12 10:54:12 2008: ^[]R^[[9;30]^[[14;30]Setting up console font and keymap...done.
Tue Feb 12 10:54:13 2008: INIT: Entering runlevel: 2
Tue Feb 12 10:54:13 2008: Loading cpufreq kernel modules...done (acpi-cpufreq).
Tue Feb 12 10:54:13 2008: Saving VESA state....
Tue Feb 12 10:54:13 2008: Starting virtual private network daemon:.
Tue Feb 12 10:54:13 2008: Starting automounter: loading autofs4 kernel module, no automount maps defined.
Tue Feb 12 10:54:13 2008: CPUFreq Utilities: Setting ondemand CPUFreq governor...CPU0...CPU1...done.
Tue Feb 12 10:54:13 2008: Starting process accounting: Turning on process accounting, file set to '/var/log/account/pacct'.
Tue Feb 12 10:54:13 2008: acct.
Tue Feb 12 10:54:14 2008: Loading ACPI modules....
Tue Feb 12 10:54:14 2008: Starting Advanced Configuration and Power Interface daemon...acpid: starting up
Tue Feb 12 10:54:14 2008: .
Tue Feb 12 10:54:14 2008: Starting Common Unix Printing System: cupsdacpid: 73 rules loaded
Tue Feb 12 10:54:15 2008: .
Tue Feb 12 10:54:15 2008: Starting system message bus: dbus.
Tue Feb 12 10:54:15 2008: Starting System Tools Backends: system-tools-backends.
Tue Feb 12 10:54:15 2008: Starting MTA: exim4.
Tue Feb 12 10:54:16 2008: Starting NFS common utilities: statd.
Tue Feb 12 10:54:16 2008: Starting internet superserver: inetd.
Tue Feb 12 10:54:16 2008: Starting VirtualBox host networking ...done.
Tue Feb 12 10:54:17 2008: Starting Xprint servers: Xprt.
Tue Feb 12 10:54:17 2008: Starting file alteration monitor: FAM.
Tue Feb 12 10:54:17 2008: Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon.
Tue Feb 12 10:54:18 2008: Starting DHCP D-Bus daemon: dhcdbd.
Tue Feb 12 10:54:18 2008: dhcdbd: Started up.
Tue Feb 12 10:54:18 2008: Starting Hardware abstraction layer: haldacpid: client connected from 3552[106:112]
Tue Feb 12 10:54:19 2008:
Tue Feb 12 10:54:19 2008: acpid: 1 client rule loaded
Tue Feb 12 10:54:20 2008: .
Tue Feb 12 10:54:20 2008: Starting GNOME Display Manager: gdm.
Tue Feb 12 10:54:20 2008: Starting kernel log daemon....
Tue Feb 12 10:54:20 2008: acpid: client connected from 3584[0:0]
Tue Feb 12 10:54:20 2008: acpid: 1 client rule loaded
Tue Feb 12 10:54:21 2008: Starting system log daemon....
Tue Feb 12 10:54:21 2008: Stopping any running daemons...
Tue Feb 12 10:54:21 2008: Starting wicd daemon...
Tue Feb 12 10:54:24 2008: /opt/wicd
Tue Feb 12 10:54:24 2008: wicd daemon: pid 3627
Tue Feb 12 10:54:24 2008: Starting anac(h)ronistic cron: anacron.
Tue Feb 12 10:54:24 2008: Starting deferred execution scheduler: atd.
Tue Feb 12 10:54:26 2008: Starting periodic command scheduler: crond.
Tue Feb 12 10:54:26 2008: Enabling additional executable binary formats: binfmt-support.
Tue Feb 12 10:54:26 2008: Checking battery state...
Tue Feb 12 10:54:27 2008: /dev/sda:
Tue Feb 12 10:54:27 2008: setting Advanced Power Management level to 0xfe (254)
Tue Feb 12 10:54:27 2008: .
Je crois qu’il y a quelques services inutiles là dedans mais je ne crois pas que c’est à cause d’eux que mon démarrage est si long.
Il me semble aussi qu’avant de m’afficher tout ça, il me dit un truc genre
kinit : no image to load
kinit : starting default configuration
