Problemme instalation paquets
bonjour a tous,
Quand je veux installer un packet par exemple vlc j’ai l’erreur suivante
The following NEW packages will be installed:
  liba52-0.7.4{a} libaa1{a} libass4{a} libavc1394-0{a} libavcodec53{a}
  libavformat53{a} libavutil51{a} libcddb2{a} libdc1394-22{a} libdca0{a}
  libdirac-decoder0{a} libdirac-encoder0{a} libdvbpsi7{a} libdvdnav4{a}
  libdvdread4{a} libebml3{a} libenca0{a} libfaad2{a} libfribidi0{a}
  libgpm2{a} libgsm1{a} libiso9660-8{a} libkate1{a} liblircclient0{a}
  liblua5.1-0{a} libmatroska5{a} libmodplug1{a} libmp3lame0{a}
  libmpcdec6{a} libmpeg2-4{a} libmtp-common{a} libmtp-runtime{a} libmtp9{a}
  libopenjpeg2{a} libpostproc52{a} libraw1394-11{a} libresid-builder0c2a{a}
  libschroedinger-1.0-0{a} libshout3{a} libsidplay2{a} libspeex1{a}
  libspeexdsp1{a} libswscale2{a} libtag1-vanilla{a} libtag1c2a{a}
  libtar0{a} libtheora0{a} libtwolame0{a} libupnp6{a} libv4l-0{a}
  libv4lconvert0{a} libva-x11-1{a} libva1{a} libvcdinfo0{a} libvlc5{a}
  libvlccore5{a} libvpx1{a} libx264-123{a} libxcb-composite0{a}
  libxcb-keysyms1{a} libxcb-randr0{a} libxcb-xfixes0{a} libxcb-xv0{a}
  libxvidcore4{a} libzvbi-common{a} libzvbi0{a} vlc vlc-data{a} vlc-nox{a}
  vlc-plugin-notify{a} vlc-plugin-pulse{a}
0 packages upgraded, 71 newly installed, 0 to remove and 81 not upgraded.
Need to get 0 B/17.9 MB of archives. After unpacking 61.9 MB will be used.
Do you want to continue? [Y/n/?] y
Extracting templates from packages: 100%
dpkg: error: parsing file '/var/lib/dpkg/available' near line 1960 package 'xpdf':
 duplicate value for `Section' field
E: Sub-process /usr/bin/dpkg returned an error code (2)
A package failed to install.  Trying to recover:
PS: je suis sous raspbian
Essai un # apt-get clean puis un # apt-get autoclean
Donne nous le contenu de ton sources.list
Cela dit il t’indique qu’il y a une erreur dans le fichier /var/lib/dpkg/available à la ligne 1960…
Merci de ta reponse,
Voici le contenu de mon sources.list
deb http://archive.raspbian.org/raspbian wheezy main contrib non-free rpi
deb-src http://archive.raspbian.org/raspbian wheezy main contrib non-free rpi
Et voici la ligne 1960 de avaliable
Section: libs
Il faut nettoyer le fichier “available”:
dpkg --clear-avail apt-get update
Merci beaucoup ca marche !
c’est toujours bon à savoir,je n’avais jamais été confronté à ce genre de panne de apt :wink:
Je vous avouerais que je ne connaissais pas avant ce soir…
Merci mon moteur de recherche. :wink:
