bonjour,
j’ai vu plusieures documentations sur proftp mais je ne trouve pas la solution à mon problème: je voudrais faire un serveur ftp avec juste une connexion anonymous. voici le fichier /etc/proftpd/proftpd.conf:
[code]#
/etc/proftpd/proftpd.conf – This is a basic ProFTPD configuration file.
To really apply changes reload proftpd after modifications.
Includes DSO modules
Include /etc/proftpd/modules.conf
Set off to disable IPv6 support which is annoying on IPv4 only boxes.
UseIPv6 off
If set on you can experience a longer connection delay in many cases.
IdentLookups off
ServerName "Mathieu"
ServerType standalone
DeferWelcome on
MultilineRFC2228 on
DefaultServer on
ShowSymlinks on
TimeoutNoTransfer 600
TimeoutStalled 600
TimeoutIdle 1200
DisplayLogin welcome.msg
DisplayChdir .message true
ListOptions “-l”
DenyFilter *.*/
Use this to jail all users in their homes
DefaultRoot ~
IdentLookups off
ServerIdent on “FTP Server ready.”
Users require a valid shell listed in /etc/shells to login.
Use this directive to release that constrain.
RequireValidShell off
Port 21 is the standard FTP port.
Port 21
In some cases you have to specify passive ports range to by-pass
firewall limitations. Ephemeral ports can be used for that, but
feel free to use a more narrow range.
PassivePorts 49152 65534
If your host was NATted, this option is useful in order to
allow passive tranfers to work. You have to use your public
address and opening the passive ports used on your firewall as well.
MasqueradeAddress
This is useful for masquerading address with dynamic IPs:
refresh any configured MasqueradeAddress directives every 8 hours
DynMasqRefresh 28800To prevent DoS attacks, set the maximum number of child processes
to 30. If you need to allow more than 30 concurrent connections
at once, simply increase this value. Note that this ONLY works
in standalone mode, in inetd mode you should use an inetd server
that allows you to limit maximum number of processes per service
(such as xinetd)
MaxInstances 30
Set the user and group that the server normally runs at.
User proftpd
Group nogroup
Umask 022 is a good standard umask to prevent new files and dirs
(second parm) from being group and world writable.
Umask 022 022
Normally, we want files to be overwriteable.
AllowOverwrite on
Uncomment this if you are using NIS or LDAP via NSS to retrieve passwords:
PersistentPasswd off
This is required to use both PAM-based authentication and local passwords
AuthOrder mod_auth_pam.c* mod_auth_unix.c
Be warned: use of this directive impacts CPU average load!
Uncomment this if you like to see progress and transfer rate with ftpwho
in downloads. That is not needed for uploads rates.
UseSendFile off
TransferLog /var/log/proftpd/xferlog
SystemLog /var/log/proftpd/proftpd.log
Delay engine reduces impact of the so-called Timing Attack described in
http://security.lss.hr/index.php?page=details&ID=LSS-2004-10-02
It is on by default.
DelayEngine on ControlsEngine off ControlsMaxClients 2 ControlsLog /var/log/proftpd/controls.log ControlsInterval 5 ControlsSocket /var/run/proftpd/proftpd.sock AdminControlsEngine offAlternative authentication frameworks
#Include /etc/proftpd/ldap.conf
#Include /etc/proftpd/sql.conf
This is used for FTPS connections
#Include /etc/proftpd/tls.conf
Useful to keep VirtualHost/VirtualRoot directives separated
#Include /etc/proftpd/virtuals.con
A basic anonymous configuration, no upload directories.
<Anonymous ~ftp>
User ftp
Group nogroup
# We want clients to be able to login with “anonymous” as well as “ftp”
UserAlias anonymous ftp
# Cosmetic changes, all files belongs to ftp user
DirFakeUser on ftp
DirFakeGroup on ftp
# Limit the maximum number of anonymous logins
MaxClients 10
# We want ‘welcome.msg’ displayed at login, and ‘.message’ displayed
# in each newly chdired directory.
# Limit WRITE everywhere in the anonymous chroot
<Directory *>
DenyAll
# Uncomment this if you’re brave.
# # Umask 022 is a good standard umask to prevent new files and dirs
# # (second parm) from being group and world writable.
# Umask 022 022
# DenyAll
# AllowAll
voici ce que me met filezilla quand j’essaye de me connecter avec mon adresse ip publique:
Statut : Connexion à XX.XX.XX.XX:21...
Statut : Échec de la tentative de connexion avec "EHOSTUNREACH - No route to host".
Erreur : Impossible d'établir une connexion au serveur
Statut : Attente avant nouvel essai...
et voici avec mon adresse privé:
Statut : Connexion à 192.168.XX.XX:21...
Statut : Connexion établie, attente du message d'accueil...
Réponse : 220 ProFTPD 1.3.3a Server ready.
Commande : USER anonymous
Réponse : 331 Authentification anonyme OK, envoyez votre adresse de courriel complète comme mot de passe
Commande : PASS **************
Réponse : 530-Unable to set anonymous privileges.
Réponse : 530 Authentification incorrecte.
Erreur : Erreur critique
[code]cat /etc/passwd | grep nobody
nobody:x:1003:1003::/:/bin/false
cat /etc/passwd | grep ftp
ftp:x:1002:65534::/home/ftp:/bin/false
proftpd:x:109:65534::/var/run/proftpd:/bin/false
cat /etc/group | grep nobody
nobody:x:1003:
cat /etc/group | grep nogroup
nogroup:x:65534:
cat /etc/group | grep ftp
ftp:x:1004:
cat /etc/shells
/etc/shells: valid login shells
/bin/csh
/bin/sh
/usr/bin/es
/usr/bin/ksh
/bin/ksh
/usr/bin/rc
/usr/bin/tcsh
/bin/tcsh
/usr/bin/esh
/bin/dash
/bin/bash
/bin/rbash
/bin/false
quelqu’un a une idée?
