bonjour,
je viens d’installer project-x ( deb-multimedia); ce programme ne se lance pas .
C’etait ok avec squeeze
voila le script:
jjr@crunchbang:~$ projectx
Exception in thread "main" java.lang.UnsupportedClassVersionError: net/sourceforge/dvb/projectx/common/Start : Unsupported major.minor version 51.0
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:634)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:277)
at java.net.URLClassLoader.access$000(URLClassLoader.java:73)
at java.net.URLClassLoader$1.run(URLClassLoader.java:212)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:205)
at java.lang.ClassLoader.loadClass(ClassLoader.java:321)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:294)
at java.lang.ClassLoader.loadClass(ClassLoader.java:266)
Could not find the main class: net.sourceforge.dvb.projectx.common.Start. Program will exit.
jjr@crunchbang:~$
Problème avec environnement java?
Merci pour l’aide
