Bonjours,
J’ai installé postfix, courier et roundcube mais quand j’essaye d’envoyer un mail j’ai cette erreur :
j’ai testé imap avec l’installation de roundcube et j’avais : IMAP connect: OK(SORT capability: yes). SMTP fonctionne aussi : SMTP send: OK.
j’ai bien le dossier monemail.com dans le repertoire /var/spool/vmail. J’ai aussi essayé de recevoir des email mais ça ne marche pas non plus.
voici mes configuration :
master.cf :
[code]#
Postfix master process configuration file. For details on the format
of the file, see the master(5) manual page (command: “man 5 master”).
Do not forget to execute “postfix reload” after editing this file.
service type private unpriv chroot wakeup maxproc command + args
(yes) (yes) (yes) (never) (100)
smtp inet n - - - - smtpd
#submission inet n - - - - smtpd
-o smtpd_tls_security_level=encrypt
-o smtpd_sasl_auth_enable=yes
-o smtpd_client_restrictions=permit_sasl_authenticated,reject
-o milter_macro_daemon_name=ORIGINATING
#smtps inet n - - - - smtpd
-o smtpd_tls_wrappermode=yes
#628 inet n - - - - qmqpd
pickup fifo n - - 60 1 pickup
cleanup unix n - - - 0 cleanup
qmgr fifo n - n 300 1 qmgr
#qmgr fifo n - - 300 1 oqmgr
tlsmgr unix - - - 1000? 1 tlsmgr
rewrite unix - - - - - trivial-rewrite
bounce unix - - - - 0 bounce
defer unix - - - - 0 bounce
trace unix - - - - 0 bounce
verify unix - - - - 1 verify
flush unix n - - 1000? 0 flush
proxymap unix - - n - - proxymap
proxywrite unix - - n - 1 proxymap
smtp unix - - - - - smtp
When relaying mail as backup MX, disable fallback_relay to avoid MX loops
relay unix - - - - - smtp
-o smtp_fallback_relay=
-o smtp_helo_timeout=5 -o smtp_connect_timeout=5
showq unix n - - - - showq
error unix - - - - - error
retry unix - - - - - error
discard unix - - - - - discard
local unix - n n - - local
virtual unix - n n - - virtual
lmtp unix - - - - - lmtp
anvil unix - - - - 1 anvil
scache unix - - - - 1 scache
Interfaces to non-Postfix software. Be sure to examine the manual
pages of the non-Postfix software to find out what options it wants.
Many of the following services use the Postfix pipe(8) delivery
agent. See the pipe(8) man page for information about ${recipient}
and other message envelope options.
maildrop. See the Postfix MAILDROP_README file for details.
Also specify in main.cf: maildrop_destination_recipient_limit=1
maildrop unix - n n - - pipe
flags=DRhu user=vmail argv=/usr/bin/maildrop -d ${recipient}
Recent Cyrus versions can use the existing “lmtp” master.cf entry.
Specify in cyrus.conf:
lmtp cmd=“lmtpd -a” listen=“localhost:lmtp” proto=tcp4
Specify in main.cf one or more of the following:
mailbox_transport = lmtp:inet:localhost
virtual_transport = lmtp:inet:localhost
Cyrus 2.1.5 (Amos Gouaux)
Also specify in main.cf: cyrus_destination_recipient_limit=1
#cyrus unix - n n - - pipe
user=cyrus argv=/cyrus/bin/deliver -e -r ${sender} -m ${extension} ${user}
Old example of delivery via Cyrus.
#old-cyrus unix - n n - - pipe
flags=R user=cyrus argv=/cyrus/bin/deliver -e -m ${extension} ${user}
See the Postfix UUCP_README file for configuration details.
uucp unix - n n - - pipe
flags=Fqhu user=uucp argv=uux -r -n -z -a$sender - $nexthop!rmail ($recipient)
Other external delivery methods.
ifmail unix - n n - - pipe
flags=F user=ftn argv=/usr/lib/ifmail/ifmail -r $nexthop ($recipient)
bsmtp unix - n n - - pipe
flags=Fq. user=bsmtp argv=/usr/lib/bsmtp/bsmtp -t$nexthop -f$sender $recipient
scalemail-backend unix - n n - 2 pipe
flags=R user=scalemail argv=/usr/lib/scalemail/bin/scalemail-store ${nexthop} ${user} ${extension}
mailman unix - n n - - pipe
flags=FR user=list argv=/usr/lib/mailman/bin/postfix-to-mailman.py
${nexthop} ${user}
main.cf :
[code]smtpd_banner = $myhostname ESMTP $mail_name (Debian/GNU)
biff = no
disable_vrfy_command = yes
smtpd_helo_required = yes
appending .domain is the MUA’s job.
append_dot_mydomain = no
Pour faire simple, il est conseillé d’utiliser le reverse DNS de votre serveur.
myhostname = monipalenvers.in-addr.arpa
myorigin = monipalenvers.in-addr.arpa
mydestination = monipalenvers.in-addr.arpa, localhost.localdomain, localhost
relayhost =
mynetworks = 127.0.0.0/8, monip
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
virtual_alias_maps = mysql:/etc/postfix/mysql-virtual_aliases.cf,mysql:/etc/postfix/mysql-virtual_aliases_comptes.cf
virtual_mailbox_domains = mysql:/etc/postfix/mysql-virtual_domaines.cf
virtual_mailbox_maps = mysql:/etc/postfix/mysql-virtual_comptes.cf
virtual_mailbox_base = /var/spool/vmail/
virtual_uid_maps = static:5000
virtual_gid_maps = static:5000
virtual_create_maildirsize = yes
virtual_mailbox_extended = yes
virtual_mailbox_limit_maps = mysql:/etc/postfix/mysql-virtual_quotas.cf
virtual_mailbox_limit_override = yes
virtual_maildir_limit_message = "La boite mail de votre destinataire est pleine, merci de reessayez plus tard."
virtual_overquota_bounce = yes
adresses d’expedition
smtpd_sender_restrictions =
permit_mynetworks,
warn_if_reject reject_unverified_sender
adresses de destination
smtpd_recipient_restrictions =
permit_mynetworks,
reject_unauth_destination,
reject_non_fqdn_recipient
client
smtpd_client_restrictions =
permit_mynetworks[/code]
Est il possible que mon nom de domaine soit mal configurer ? ou que mon FAI bloque le port 25 ?
mon nom de domaine est un tk (dot.tk/) , bloquerai-t-il les mail ?
Comment résoudre ce problème ?
merci d’avance.
