Bonjour, je suis un utilisateur de Kali.
Linux Kali 3.18.0-kali3-amd64 #1 SMP Debian 3.18.6-1~kali2 (2015-03-02) x86_64 GNU/Linux
Kali Linux 1.1.0
Kali GNU/Linux 1.1.0 \n \l
Je voudrais utilisé Putty pour me connecter à mes SWITCH. D-Link 3526 par exemple. Sa m’emmrd
sincérement de faire un Multi-boot Windows juste pour un truc qui ne fonctionne pas. Je me retourne donc vers vous.
J’ai utilisé cette doc essentiellement:
Le matériel est bien détecter, je pense.
root@Kali:/home/james# lsusb
Bus 001 Device 004: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 003: ID 0c45:64d0 Microdia
Bus 001 Device 002: ID 8087:8000 Intel Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 003: ID 046d:c077 Logitech, Inc.
Bus 002 Device 004: ID 067b:2303 Prolific Technology, Inc. PL2303 Serial Port
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
[39238.883476] usb 2-1: new full-speed USB device number 4 using xhci_hcd
[39239.012112] usb 2-1: New USB device found, idVendor=067b, idProduct=2303
[39239.012121] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[39239.012126] usb 2-1: Product: USB-Serial Controller D
[39239.012129] usb 2-1: Manufacturer: Prolific Technology Inc.
[39239.130959] usbcore: registered new interface driver usbserial
[39239.130974] usbcore: registered new interface driver usbserial_generic
[39239.130992] usbserial: USB Serial support registered for generic
[39239.135411] usbcore: registered new interface driver pl2303
[39239.135427] usbserial: USB Serial support registered for pl2303
[39239.135449] pl2303 2-1:1.0: pl2303 converter detected
[39239.136154] usb 2-1: pl2303 converter now attached to ttyUSB0
[39241.059281] dell_wmi: Received unknown WMI event (0x0)
[39241.683543] dell_wmi: Received unknown WMI event (0x0)
[39242.066839] dell_wmi: Received unknown WMI event (0x0)
[39257.439667] dell_wmi: Received unknown WMI event (0x0)
[39348.361367] e1000e: eth0 NIC Link is Up 100 Mbps Full Duplex, Flow Control: None
[39348.361376] e1000e 0000:00:19.0 eth0: 10/100 speed: disabling TSO
[39348.361406] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[39353.398576] dell_wmi: Received unknown WMI event (0x0)
Mais je n’arrive pas a me connecter au SWITCH.
Mes câbles fonctionne. J’ai tester sur un W$ Server 2003 et 2008.
Je dois rater quelques choses, je ne fais pas un truc correctement.
Pouvez-vous m’aider, en recommencent du début même!
Merci d’avance.
