petit question technique:
[quote]If you are using the hibernate script with vanilla swsusp or TuxOnIce, then it
is strongly recommended that you install the script init.d/hibernate-cleanup.sh
into /etc/init.d (or the relevant place on your distribution), and arrange for
it to be run on boot from rcS.d, somewhere before enabling swap or clearing out
/var/run, but after mounting your filesystems (/var in particular).[/quote]
Je voudrais savoir quel service mettre en en-tête de script pour qu’il soit au bon moment. Je n’arrive pas à savoir qui monte la swap et nettoie /var/run… une idée ?
