Depuis que j’utilise une mini enceinte bluetooth ça ma obligé à creuser le fonctionnement.
j’ai épuré les outils pour ne garder que gnome-bluetooth
apt list --installed | grep blue
bluetooth/testing,testing,unstable,unstable,now 5.50-1 all [installé]
bluewho/stable,stable,testing,testing,unstable,unstable,now 0.1-2 all [installé]
bluez/testing,unstable,now 5.50-1 amd64 [installé]
bluez-obexd/testing,unstable,now 5.50-1 amd64 [installé]
gir1.2-gnomebluetooth-1.0/testing,unstable,now 3.28.2-2 amd64 [installé, automatique]
gnome-bluetooth/testing,unstable,now 3.28.2-2 amd64 [installé]
libbluetooth3/testing,unstable,now 5.50-1 amd64 [installé]
libgnome-bluetooth13/testing,unstable,now 3.28.2-2 amd64 [installé]
pulseaudio-module-bluetooth/testing,unstable,now 12.2-2 amd64 [installé]
python-bluez/testing,unstable,now 0.22-2 amd64 [installé, automatique]
Mon soucis était l’activation erratique et pas moyen d’activer bluetooth par le menu gnome dans la barre d’état
Après recherche j’ai mis l’activation à 1 dans /etc/default/bluetooth
# Defaults for bluez
# start bluetooth on boot?
# compatibility note: if this variable is _not_ found bluetooth will start
BLUETOOTH_ENABLED=1
# This setting used to switch HID devices (e.g mouse/keyboad) to HCI mode, that
# is you will have bluetooth functionality from your dongle instead of only
# HID. This is accomplished for supported devices by udev in
# /lib/udev/rules.d/62-bluez-hid2hci.rules by invoking hid2hci with correct
# parameters.
# See /usr/share/doc/bluez/NEWS.Debian.gz for further information.
# Older daemons like pand dund and hidd can be found in bluez-compat package as
# they are deprecated and provided for backward compatibility only.
# Note that not every bluetooth dongle is capable of switching back to HID mode,
# see http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=355497
HID2HCI_ENABLED=0
HID2HCI_UNDO=0
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2018-09-22 10:12:12 CEST; 11min ago
Docs: man:bluetoothd(8)
Main PID: 548 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 4317)
Memory: 3.0M
CGroup: /system.slice/bluetooth.service
└─548 /usr/lib/bluetooth/bluetoothd
sept. 22 10:12:08 debian bluetoothd[548]: Bluetooth daemon 5.50
sept. 22 10:12:12 debian systemd[1]: Started Bluetooth service.
sept. 22 10:12:12 debian bluetoothd[548]: Starting SDP server
sept. 22 10:12:12 debian bluetoothd[548]: Version mismatch for sixaxis
sept. 22 10:12:12 debian bluetoothd[548]: Bluetooth management interface 1.14 initialized
sept. 22 10:12:13 debian bluetoothd[548]: Sap driver initialization failed.
sept. 22 10:12:13 debian bluetoothd[548]: sap-server: Operation not permitted (1)
sept. 22 10:12:47 debian bluetoothd[548]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSource
sept. 22 10:12:47 debian bluetoothd[548]: Endpoint registered: sender=:1.38 path=/MediaEndpoint/A2DPSink
sept. 22 10:15:56 debian bluetoothd[548]: /org/bluez/hci0/dev_F4_4E_FD_A7_12_0D/fd0: fd(32) ready
hciconfig
hci0: Type: Primary Bus: USB
BD Address: CC:52:AF:67:BA:34 ACL MTU: 1021:8 SCO MTU: 64:1
UP RUNNING PSCAN
RX bytes:1124 acl:0 sco:0 events:63 errors:0
TX bytes:3653 acl:0 sco:0 commands:63 errors:0
Donc c’est nickel, lorsque j’allume mon enceinte bluetooth le son bascule automatiquement des haut-parleurs du PC vers l’enceinte bluetooth et le logo bluetooth apparait dans la barre d’état.
