[quote=“M3t4linux”]Question, sans rapport direct avec ta question :
Pourquoi ne passes tu pas par un safe-upgrade plutôt que par full-upgrade??
Pour ma sid, je la mets quotidiennement à jour avec # aptitude update et # aptitude safe-upgrade
Je me suis laissé dire que full-upgrade met à jour complètement (“full”) le système sans vérifier la cohérence des dépendances…
Suis je dans l’erreur??
Excuses moi de poser une question alors que tu attends des réponses
[code]safe-upgrade
Upgrades installed packages to their most recent version. Installed packages will not be removed unless they are
unused (see the section « Managing Automatically Installed Packages » in the aptitude reference manual). Packages
which are not currently installed may be installed to resolve dependencies unless the --no-new-installs
command-line option is supplied.
It is sometimes necessary to remove one package in order to upgrade another; this command is not able to upgrade
packages in such situations. Use the full-upgrade command to upgrade as many packages as possible.
full-upgrade
Upgrades installed packages to their most recent version, removing or installing packages as necessary. This
command is less conservative than safe-upgrade and thus more likely to perform unwanted actions. However, it is
capable of upgrading packages that safe-upgrade cannot upgrade.
