Quel pilote graphique pour mon Ibook ?
J’essaie d’installer une debian sur un IBook.
Comme il n’y a pas de version stretch, j’ai installé la dernière version de jessie "PowerPC. Les problèmes rencontrés sont listés ci-dessous.
La machine :
System: Host: X Kernel: 3.16.0-4-powerpc ppc (32 bit) Desktop: N/A
Distro: Debian GNU/Linux 8
Machine: No /sys/class/dmi machine data: try newer kernel, or install dmidecode
CPU: Single core 7447A altivec supported (-UP-) cache: N/A
clocked at 1420 MHz
Graphics: Card: Advanced Micro Devices[AMD/ATI]RV360/M12 [Mobility Radeon 9550]
Display Server: X.org 1.16.4 drivers: ati,radeon (unloaded: fbdev)
tty size: 80x24 Advanced Data: N/A for root
Audio: Card SoundByLayout driver: AppleOnbdAudio
Sound: Advanced Linux Sound Architecture v: k3.16.0-4-powerpc
Network: Card-1: Broadcom BCM4318 [AirForce One 54g] 802.11g Wireless LAN Controller
driver: b43-pci-bridge
IF: N/A state: N/A mac: N/A
Card-2: Apple UniNorth 2 GMAC (Sun GEM) driver: gem
IF: N/A state: N/A speed: N/A duplex: N/A mac: N/A
Drives: HDD Total Size: 140.1GB (5.3% used)
ID-1: /dev/sda model: FUJITSU_MHV2060A size: 60.0GB
ID-2: USB /dev/sdb model: Storage_Device size: 80.1GB
Partition: ID-1: / size: 6.3G used: 2.7G (46%) fs: ext4 dev: /dev/sda3
ID-2: /home size: 47G used: 71M (1%) fs: ext4 dev: /dev/sda5
ID-3: swap-1 size: 2.24GB used: 0.00GB (0%) fs: swap dev: /dev/sda4
Sensors: None detected - is lm-sensors installed and configured?
Info: Processes: 142 Uptime: 2 min Memory: 175.2/1005.5MB[
Le anomalies au démarrage :
2.386876] rtc-generic rtc-generic: hctosys: unable to read the hardware clock
7.497606] sd 2:0:0:0: [sdb] No Caching mode page found
[ 7.506689] sd 2:0:0:0: [sdb] Assuming drive cache: write through13.820856] radeon 0000:00:10.0: Invalid ROM contents
[ 13.820880] radeon 0000:00:10.0: Invalid ROM contents
[ 13.820895] [drm:radeon_get_bios] ERROR Unable to locate a BIOS ROM
13.914914] radeon 0000:00:10.0: firmware: failed to load radeon/R300_cp.bin (-2)
[ 13.914961] [drm:r100_cp_init] ERROR Failed to load firmware!
[ 13.914974] radeon 0000:00:10.0: failed initializing CP (-2).
[ 13.914984] radeon 0000:00:10.0: Disabling GPU acceleration
13.917672] radeon 0000:00:10.0: Invalid ROM contents
[ 13.917697] radeon 0000:00:10.0: Invalid ROM contents
[ 13.917712] [drm:radeon_get_bios] ERROR Unable to locate a BIOS ROM
13.931353] radeon 0000:00:10.0: firmware: failed to load radeon/R300_cp.bin (-2)
[ 13.931372] [drm:r100_cp_init] ERROR Failed to load firmware!
[ 13.931383] radeon 0000:00:10.0: failed initializing CP (-2).
[ 13.931393] radeon 0000:00:10.0: Disabling GPU acceleration
