[quote=“Knucky”][quote=“panthere”]bon j’ai tester avec -std-vga
resulta c’est trop GRAND sa dépasse la résolution de l’affichage de l’hote arf
Ahahah
Utilises le bon vieux xrandr si tu utilises X sur la machine virtuelle, et modifie /etc/X11/xorg.conf de façon appropriée par la suite pour ne pas avoir à le refaire
ben sur l’hote j’ai :
xrandr
Screen 0: minimum 320 x 240, current 1680 x 1050, maximum 1680 x 1050
default connected 1680x1050+0+0 0mm x 0mm
1680x1050 50.0*
1600x1024 51.0
1440x900 52.0
1400x1050 53.0
1280x1024 54.0 55.0
1280x960 56.0
1280x800 57.0
1280x768 58.0
1152x864 59.0
1024x768 60.0 61.0 62.0
960x600 63.0
840x525 64.0
832x624 65.0
800x600 66.0 67.0 68.0 69.0 70.0 71.0
800x512 72.0
720x450 73.0
700x525 74.0 75.0 76.0
640x512 77.0 78.0
640x480 79.0 80.0 81.0 82.0
640x400 83.0
640x384 84.0
576x432 85.0
512x384 86.0 87.0 88.0
416x312 89.0
400x300 90.0 91.0 92.0 93.0
320x240 94.0 95.0 96.0
et dans la wm
euh pas moyen de faire un copier coller depuis la vm :(
mai pas plus de 800*600
le xog.conf de l’hote
cat /etc/X11/xorg.conf
# xorg.conf (X.Org X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the xorg.conf manual page.
# (Type "man xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
# sudo dpkg-reconfigure -phigh xserver-xorg
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "ch"
Option "XkbVariant" "fr"
Option "XkbOptions" "lv3:ralt_switch"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
EndSection
Section "Device"
Identifier "Configured Video Device"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce 8800 GTX"
VideoRam 768
Option "NoLogo" "true"
EndSection
Section "Monitor"
Identifier "Configured Monitor"
EndSection
Section "Screen"
Identifier "Default Screen"
Monitor "Configured Monitor"
EndSection
celui de la wm est light
# package.
Driver "kbd"
EndSection
Driver "mouse"
EndSection
Section "Device"
EndSection
Section "Monitor"
EndSection
Section "Screen"
EndSection
