[code]#!/bin/bash
XINIT=which xinit
XSERVER=which X
EVCALIBRATE=which ev_calibrate || echo ./ev_calibrate
UDI=$(hal-find-by-property --key input.x11_driver --string evtouch)
MYDPY=":1.0"
ZENITY=which zenity
KDIALOG=which kdialog
XDIALOG=which Xdialog
INFO=“You have selected to (re)calibrate your touchscreen.\n\n
Move your pen around all edges on the following screen.\n\n
If you are done and touched all edges, hit the enter key and wait until
the top left crosshair turns red.\nOnce you tap the red crosshair,
the next one will turn red going from the top left to the
bottom right.\nIf you miss a tap, the right mouse button will
take you back one step.\n\n
If you tapped the last (bottom right) crosshair, the program will
return to your session. Note that changes only take effect after
restarting the session.”
RESTARTINFO=“Touchscreen calibration done\nPlease restart your
session to \nmake the changes take effect”
FAILINFO=“No evtouch capable device found, if you are sure you have \n
an evtouch capable touchscreen, please mail the
resulting file of the command “lshal > evtouch_hal.out” to the\n
ubuntu-mobile@lists.ubuntu.com mailing list, so support for your
device can be added.”
if [ -z “$UDI” ];then
if [ -x “${ZENITY}” ]; then
$ZENITY --info --text="${FAILINFO}"
elif [ -x “${XDIALOG}” ]; then
$XDIALOG --fill --msgbox “${FAILINFO}” 20 40
elif [ -x “${KDIALOG}” ]; then
$KDIALOG --msgbox "${FAILINFO}"
fi
exit 0
fi
$ZENITY --info --text="${INFO}"
$XDIALOG --fill --msgbox “${INFO}” 30 40
$KDIALOG --msgbox "${INFO}"
fi
echo $EVCALIBRATE
if [ -n “$DISPLAY” ]; then
DPY=$(echo $DISPLAY|sed -e ‘s/[a-z:]*//g’|cut -d’.’ -f1)
MYDPY=":$(($DPY+1)).0"
fi
if ! [ -x “$EVCALIBRATE” ] ; then
echo "ev_calibrate not found exiting …"
exit 1;
fi
echo “evalibrate located at $EVCALIBRATE”
if [ -z “$XINIT” ]; then
echo "xinit not found exiting …"
exit 1;
fi
echo "xinit located at $XINIT"
if [ -z “$XSERVER” ]; then
echo "X not found exiting …"
exit 1;
fi
echo "xserver located at $XSERVER"
if [ -e /tmp/ev_calibrate ]; then
rm /tmp/ev_calibrate;
fi
echo "Creating FIFO…"
mknod /tmp/ev_calibrate p
#for development only
#cp evtouch_drv.o /usr/X11R6/lib/modules/input
#xinit /usr/bin/ddd ev_calibrate – /usr/X11R6/bin/X
echo "Starting calibration program…"
sleep 2
hal-set-property --udi $UDI --key input.x11_options.calibrate --string “1”
$XINIT $EVCALIBRATE – $XSERVER $MYDPY -auth /dev/null
hal-set-property --remove --udi $UDI --key input.x11_options.calibrate
invoke-rc.d --quiet xserver-xorg-input-evtouch start
$ZENITY --info --text="${RESTARTINFO}"
$XDIALOG --fill --msgbox “${RESTARTINFO}” 10 40
$KDIALOG --msgbox "${RESTARTINFO}"
fi
exit 0[/code]
