Ralink rt61pci et 2.6.26
Je vous écrit (d’une main) depuis le 2.6.25, puisque le nouveau noyau 2.6.26 ne veut pas faire fonctionner mon wifi ! j’ai récupéré qqs infos que je vous livre :
$ dmesg | grep firmware
[   16.040478] firmware: requesting rt2561s.bin
$ dmesg | grep wlan0
[   16.861848] wlan0: Initial auth_alg=0
[   16.861854] wlan0: authenticate with AP 00:16:cf:6e:33:a0
[   16.862595] wlan0: RX authentication from 00:16:cf:6e:33:a0 (alg=0 transaction=2 status=0)
[   16.862595] wlan0: authenticated
[   16.862595] wlan0: associate with AP 00:16:cf:6e:33:a0
[   16.862595] wlan0: RX AssocResp from 00:16:cf:6e:33:a0 (capab=0x411 status=0 aid=1)
[   16.862595] wlan0: associated
[   16.862595] wlan0: switched to short barker preamble (BSSID=00:16:cf:6e:33:a0)
[   31.212886] wlan0: no IPv6 routers present
[   57.684219] wlan0: Initial auth_alg=0
[   57.684227] wlan0: authenticate with AP 00:16:cf:6e:33:a0
[   57.684615] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   57.881258] wlan0: authenticate with AP 00:16:cf:6e:33:a0
[   58.100957] wlan0: authenticate with AP 00:16:cf:6e:33:a0
[   58.305884] wlan0: authentication with AP 00:16:cf:6e:33:a0 timed out
[  280.468881] wlan0: Initial auth_alg=0
[  280.468881] wlan0: authenticate with AP 00:16:cf:6e:33:a0
[  280.471343] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[  280.671178] wlan0: authenticate with AP 00:16:cf:6e:33:a0
[  280.903153] wlan0: authenticate with AP 00:16:cf:6e:33:a0
[  281.103152] wlan0: authentication with AP 00:16:cf:6e:33:a0 timed out
# iwlist s
lo        Interface doesn't support scanning.
wmaster0  Interface doesn't support scanning.
wlan0     No scan result.
Ça vaut ce que ça vaut, mais j’ai eu moi aussi des problèmes avec 2 cartes ralink.
Pour faire fonctionner le wifi, je désinstalle completement network-manager, et le réinstalle.
Ça ne manque jamais.
Mais c’est vrai que je voudrai bien comprendre pourquoi, et ne pas avoir à faire de “manipulation”.
Peut être que ça marchera pour toi aussi.
personne n’a de probs entre rt61 et 2.6.26 ?
Mon PC ayant un chipset rt61 est actuellement en 2.6.25 (Lenny). J’installerais le kernel 2.6.26 pour tester dans la journée :wink:
up. Je viens de tester et aucun problème. J’ai installé le kernel 2.6.26 qui est présent en Sid actuellement, rebooté et aucun souci, j’ai accès au net.
(d’ailleurs, c’est pas mal d’avoir le nvidia-kernel directement sans recompilation. Une bonne solution de fainéant comme je les aime !)
A propos des messages :
dmesg | grep firmware me renvoie le même résultat.
dmesg | grep wlan0 est similaire au départ, mais je n’ai pas de time out.
et iwlist fonctionne correctement.
Il y a eu une mise à jour du firmware-ralink il y a peu de temps, cela vient peut-être de là (je l’ai appliqué pour ma part).
Moi je commence avec le D-link 510.
J’ai le rt61 et le firmware de base de sid.
Mais :
[code]ifup wlan0
Internet Systems Consortium DHCP Client V3.1.1
Copyright 2004-2008 Internet Systems Consortium.
All rights reserved.
For info, please visit http://www.isc.org/sw/dhcp/
wmaster0: unknown hardware address type 801
Listening on LPF/wlan0/00:1c:f0:94:32:02
Sending on LPF/wlan0/00:1c:f0:94:32:02
Sending on Socket/fallback
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 8
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 12
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 21
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 17
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 3
No DHCPOFFERS received.
No working leases in persistent database - sleeping.[/code]
Je suis en WPA.
J’ai testé le RT61 sous 2.6.26, pas de problème.
Mais je suis repasser en 2.6.25 à cause de l’ACPI wakeup qui ne fonctionne pas en 2.6.26.
Je remonte le fil, puisque ça ne fonctionne toujours pas dans le dmesg j’ai ça:
j’ai supprimé les firmwares de /lib/firmware et j’ai réinstallé firmware-ralink mais j’ai toujours le même problème.
C’est tout ce que dmesg te sort concernant wlan0 ?
T’inquiètes pour ce message, j’ai ça à chaque boot et ça fonctionne très bien. Tu peux faire un :
en root et coller le résultat ?
J’ai aussi des problêmes en 2.6.26 avec mon chip embarqué iwl3945 et >aussi< mon chip externe rt73usb . Donc pour l’instant, tant que je n’ai pas isolé plus le pb, je suis en 2.6.24-etch-and-a-half.
Pour le reste, le 2.6.26 a l’air bien, pour ce que j’en ai vu…
je n’ai pas de carte à base de chip Ralink mais mon ipw3945 intégrée fonctionne à merveille avec le 2.6.26…
lorsque j’avais fait l’install de mon portable (en janvier) je n’avais installé que
iwlwifi firmware-iwlwifi network-manager-kde wireless-tools wpasupplicant
mais je viens de m’apercevoir que le paquet iwlwifi ne semble plus exister dans mes dépôts.
dmesg | grep wlan me renvoie :
[ 76.383810] ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 188.626518] wlan0: Initial auth_alg=0 [ 188.626518] wlan0: authenticate with AP XX:XX:XX:XX:XX:XX [ 188.628173] wlan0: RX authentication from XX:XX:XX:XX:XX:XX (alg=0 transaction=2 status=0) [ 188.628173] wlan0: authenticated [ 188.628173] wlan0: associate with AP XX:XX:XX:XX:XX:XX [ 188.630428] wlan0: RX AssocResp from XX:XX:XX:XX:XX:XX (capab=0x411 status=0 aid=1) [ 188.630434] wlan0: associated [ 188.630442] wlan0: switched to short barker preamble (BSSID=XX:XX:XX:XX:XX:XX) [ 188.632201] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready [ 209.038405] wlan0: no IPv6 routers present
Oui. Mon 3945 aussi fonctionne. Mais il ne détecte pas mon hotspot perso, n’accroche pas le dhcp de mon ap fon (c’est peut être un pb de config au niveau de mon routeur, ceci dit), ni dans mon hotel quand je vais en Belgique, ni quand je suis au bureau là bas. Par contre, il fonctionne dans le Thalys, et chez un pôte. Mais j’ai toujours eu des soucis avec ce chip quelle que soit la version de noyau et le systême de connection choisi. En particulier jamais réussi quelle que soit la méthode à me connecter à un réseau complètement ouvert. En 2.6.24, j’ai trouvé à minimiser les spots ou je ne pouvais pas me connecter.
Pour le ralink usb, pareil, en 2.6.26 il ne détecte pas tous les réseaux (pas forcément les mêmes que le 3945). En 2.6.24, il me sert de secours quand le 3945 ne passe pas.
Je suis à 1,50m de la Livebox … Plus près je l’ai sur les genoux !! (déjà que je n’ai plus qu’un bras :wink: )
J’ai vraiment l’impression que le noyau est bancale.
Bon je continue le post car celui-ci m’interresse. Voici ce que ça donne quand je fais un iwpriv wlan0 :
debian:~# iwpriv wlan0
wlan0 no private ioctls.
Merci de votre aide.
Depuis une mise à jour du noyau courant septembre, je crois, je n’ai plus ce problème, cela venait bien de lui !
ça n’est pas plutôt depuis qu’on ta retiré tes broches (qui parasitaient le truc :slightly_smiling:)
Qui sait ? :wink:
