[code][ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] random: get_random_bytes called from start_kernel+0x50/0x404 with crng_init=0
[ 0.000000] Linux version 4.13.0-1-arm64 (debian-kernel@lists.debian.org) (gcc version 6.4.0 20170920 (Debian 6.4.0-7)) #1 SMP Debian 4.13.4-1 (2017-10-01)
[ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[ 0.000000] Machine model: Raspberry Pi 3 Model B Rev 1.2[/code]
Le retour complet est :[code][ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] On node 0 totalpages: 242688
[ 0.000000] DMA zone: 3792 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 242688 pages, LIFO batch:31
[ 0.000000] percpu: Embedded 25 pages/cpu @ffff9257bb379000 s63384 r8192 d30824 u102400
[ 0.000000] pcpu-alloc: s63384 r8192 d30824 u102400 alloc=25*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 238896
[ 0.000000] Kernel command line: earlyprintk console=ttyAMA0 bcm2708_fb.fbwidth=1360 bcm2708_fb.fbheight=768 bcm2708_fb.fbswap=1 dma.dmachans=0x7f35 bcm2709.boardrev=0xa02082 bcm2709.serial=0x542df5ab bcm2709.uart_clock=48000000 smsc95xx.macaddr=B8:27:EB:2D:F5:AB vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 root=/dev/mmcblk0p2 rw elevator=deadline fsck.repair=yes net.ifnames=0 rootwait
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.000000] Memory: 918104K/970752K available (7740K kernel code, 1406K rwdata, 2580K rodata, 4288K init, 608K bss, 52648K reserved, 0K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffff000000000000 - 0xffff000008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffff000008000000 - 0xffff7dffbfff0000 (129022 GB)
[ 0.000000] .text : 0xffff0a533a880000 - 0xffff0a533b010000 ( 7744 KB)
[ 0.000000] .rodata : 0xffff0a533b010000 - 0xffff0a533b2a0000 ( 2624 KB)
[ 0.000000] .init : 0xffff0a533b2a0000 - 0xffff0a533b6d0000 ( 4288 KB)
[ 0.000000] .data : 0xffff0a533b6d0000 - 0xffff0a533b82fa00 ( 1407 KB)
[ 0.000000] .bss : 0xffff0a533b82fa00 - 0xffff0a533b8c7b90 ( 609 KB)
[ 0.000000] fixed : 0xffff7dfffe7fd000 - 0xffff7dfffec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffff7dfffee00000 - 0xffff7dffffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffff7e0000000000 - 0xffff800000000000 ( 2048 GB maximum)
[ 0.000000] 0xffff7e495e000000 - 0xffff7e495eed0000 ( 14 MB actual)
[ 0.000000] memory : 0xffff925780000000 - 0xffff9257bb400000 ( 948 MB)
[ 0.000000] ftrace: allocating 29376 entries in 115 pages
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] arch_timer: WARNING: Invalid trigger for IRQ2, assuming level low
[ 0.000000] arch_timer: WARNING: Please fix your firmware
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000550] Console: colour dummy device 80x25
[ 0.000583] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[ 0.000599] pid_max: default: 32768 minimum: 301
[ 0.000871] Security Framework initialized
[ 0.000883] Yama: disabled by default; enable with sysctl kernel.yama.*
[ 0.000918] AppArmor: AppArmor disabled by boot time parameter
[ 0.001016] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.001042] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.002530] ASID allocator initialised with 65536 entries
[ 0.002639] Hierarchical SRCU implementation.
[ 0.004665] EFI services will not be available.
[ 0.005001] smp: Bringing up secondary CPUs ...
[ 0.005657] Detected VIPT I-cache on CPU1
[ 0.005711] arch_timer: WARNING: Invalid trigger for IRQ2, assuming level low
[ 0.005714] arch_timer: WARNING: Please fix your firmware
[ 0.005728] CPU1: Booted secondary processor [410fd034]
[ 0.006481] Detected VIPT I-cache on CPU2
[ 0.006515] arch_timer: WARNING: Invalid trigger for IRQ2, assuming level low
[ 0.006518] arch_timer: WARNING: Please fix your firmware
[ 0.006528] CPU2: Booted secondary processor [410fd034]
[ 0.007226] Detected VIPT I-cache on CPU3
[ 0.007258] arch_timer: WARNING: Invalid trigger for IRQ2, assuming level low
[ 0.007260] arch_timer: WARNING: Please fix your firmware
[ 0.007271] CPU3: Booted secondary processor [410fd034]
[ 0.007390] smp: Brought up 1 node, 4 CPUs
[ 0.007440] SMP: Total of 4 processors activated.
[ 0.007451] CPU features: detected feature: 32-bit EL0 Support
[ 0.007653] CPU: All CPU(s) started at EL2
[ 0.007683] alternatives: patching kernel code
[ 0.009032] devtmpfs: initialized
[ 0.014689] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.014713] futex hash table entries: 1024 (order: 5, 131072 bytes)
[ 0.015050] pinctrl core: initialized pinctrl subsystem
[ 0.015872] DMI not present or invalid.
[ 0.016288] NET: Registered protocol family 16
[ 0.019505] cpuidle: using governor ladder
[ 0.019646] cpuidle: using governor menu
[ 0.020284] vdso: 2 pages (1 code @ ffff0a533b016000, 1 data @ ffff0a533b6d5000)
[ 0.020306] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.020763] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.020994] Serial: AMBA PL011 UART driver
[ 0.034126] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.035277] ACPI: Interpreter disabled.
[ 0.035721] vgaarb: loaded
[ 0.036004] EDAC MC: Ver: 3.0.0
[ 0.036369] dmi: Firmware registration failed.
[ 0.037690] clocksource: Switched to clocksource arch_sys_counter
[ 0.107296] VFS: Disk quotas dquot_6.6.0
[ 0.107393] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.108284] simple-framebuffer 3e9fc000.framebuffer: framebuffer at 0x3e9fc000, 0x1fe000 bytes, mapped to 0xffff000008200000
[ 0.108300] simple-framebuffer 3e9fc000.framebuffer: format=r5g6b5, mode=1360x768x16, linelength=2720
[ 0.121768] Console: switching to colour frame buffer device 170x48
[ 0.134559] simple-framebuffer 3e9fc000.framebuffer: fb0: simplefb registered!
[ 0.134612] pnp: PnP ACPI: disabled
[ 0.144294] NET: Registered protocol family 2
[ 0.145106] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.145223] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
[ 0.145441] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.145653] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.145741] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.145997] NET: Registered protocol family 1
[ 0.146034] PCI: CLS 0 bytes, default 128
[ 0.146271] Unpacking initramfs...
[ 1.663846] Freeing initrd memory: 17444K
[ 1.669035] kvm [1]: 8-bit VMID
[ 1.669050] kvm [1]: IDMAP page: 7f8000
[ 1.669059] kvm [1]: HYP VA range: 800000000000:ffffffffffff
[ 1.669919] kvm [1]: Hyp mode initialized successfully
[ 1.669959] kvm [1]: Invalid trigger for IRQ4, assuming level low
[ 1.669985] kvm [1]: virtual timer IRQ4
[ 1.672200] audit: initializing netlink subsys (disabled)
[ 1.672370] audit: type=2000 audit(1.670:1): state=initialized audit_enabled=0 res=1
[ 1.672916] workingset: timestamp_bits=46 max_order=18 bucket_order=0
[ 1.673100] zbud: loaded
[ 3.817532] random: fast init done
[ 3.820101] Key type asymmetric registered
[ 3.820114] Asymmetric key parser 'x509' registered
[ 3.820230] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 3.820371] io scheduler noop registered
[ 3.820381] io scheduler deadline registered (default)
[ 3.820432] io scheduler cfq registered
[ 3.820441] io scheduler mq-deadline registered
[ 3.833224] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 3.834863] console [ttyS0] disabled
[ 3.834929] 3f215040.serial: ttyS0 at MMIO 0x0 (irq = 61, base_baud = 31250000) is a 16550
[ 4.596978] console [ttyS0] enabled
[ 4.601123] Serial: AMBA driver
[ 4.604616] msm_serial: driver initialized
[ 4.609253] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 4.615956] mousedev: PS/2 mouse device common for all mice
[ 4.623199] ledtrig-cpu: registered to indicate activity on CPUs
[ 4.629321] dmi-sysfs: dmi entry is absent.
[ 4.633989] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 4.640056] NET: Registered protocol family 10
[ 4.645519] Segment Routing with IPv6
[ 4.649310] mip6: Mobile IPv6
[ 4.652335] NET: Registered protocol family 17
[ 4.656863] mpls_gso: MPLS GSO support
[ 4.661057] Registered cp15_barrier emulation handler
[ 4.666200] Registered setend emulation handler
[ 4.671533] registered taskstats version 1
[ 4.675779] zswap: loaded using pool lzo/zbud
[ 4.680386] ima: No TPM chip found, activating TPM-bypass! (rc=-19)
[ 4.690523] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 72, base_baud = 0) is a PL011 rev2
[ 7.218357] console [ttyAMA0] enabled
[ 7.234299] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-10-06 13:56
[ 7.267506] hctosys: unable to open rtc device (rtc0)
[ 7.287895] PM: Hibernation image not present or could not be loaded.
[ 7.295042] Freeing unused kernel memory: 4288K
[ 7.648684] sdhci: Secure Digital Host Controller Interface driver
[ 7.673579] sdhci: Copyright(c) Pierre Ossman
[ 7.679735] usbcore: registered new interface driver usbfs
[ 7.679803] usbcore: registered new interface driver hub
[ 7.679975] usbcore: registered new device driver usb
[ 7.755916] sdhci-pltfm: SDHCI platform and OF driver helper
[ 7.757783] sdhost-bcm2835 3f202000.mmc: loaded - DMA enabled (>1)
[ 7.758347] i2c-bcm2835 3f805000.i2c: Could not read clock-frequency property
[ 7.786831] OF: /soc/usb@7e980000: could not get #phy-cells for /phy
[ 7.786890] dwc2 3f980000.usb: 3f980000.usb supply vusb_d not found, using dummy regulator
[ 7.786986] dwc2 3f980000.usb: 3f980000.usb supply vusb_a not found, using dummy regulator
[ 7.837508] dwc2 3f980000.usb: DWC OTG Controller
[ 7.837562] dwc2 3f980000.usb: new USB bus registered, assigned bus number 1
[ 7.837605] dwc2 3f980000.usb: irq 41, io mem 0x3f980000
[ 7.837962] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 7.837971] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.837977] usb usb1: Product: DWC OTG Controller
[ 7.837984] usb usb1: Manufacturer: Linux 4.13.0-1-arm64 dwc2_hsotg
[ 7.837990] usb usb1: SerialNumber: 3f980000.usb
[ 7.838768] hub 1-0:1.0: USB hub found
[ 7.838819] hub 1-0:1.0: 1 port detected
[ 7.852602] mmc0: host does not support reading read-only switch, assuming write-enable
[ 7.854499] mmc0: new high speed SDHC card at address 59b4
[ 7.854986] bounce: isa pool size: 16 pages
[ 7.855177] mmcblk0: mmc0:59b4 USD 14.7 GiB
[ 7.857248] mmcblk0: p1 p2
[ 8.225723] usb 1-1: new high-speed USB device number 2 using dwc2
[ 8.313793] mmc1: SDHCI controller on 3f300000.sdhci [3f300000.sdhci] using PIO
[ 8.366808] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 8.391782] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 8.415619] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 8.438033] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 8.440851] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 8.487003] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 8.516551] hub 1-1:1.0: USB hub found
[ 8.531791] hub 1-1:1.0: 5 ports detected
[ 8.542376] mmc1: new high speed SDIO card at address 0001
[ 8.575962] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 8.861743] usb 1-1.1: new high-speed USB device number 3 using dwc2
[ 8.986073] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 9.013701] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 9.242019] systemd[1]: System time before build time, advancing clock.
[ 9.269730] usb 1-1.4: new low-speed USB device number 4 using dwc2
[ 9.404470] usb 1-1.4: New USB device found, idVendor=04fc, idProduct=05d8
[ 9.413169] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 9.453375] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.482700] usb 1-1.4: Product: Trust Keyboard 14909
[ 9.502604] usb 1-1.4: Manufacturer: MLK
[ 9.520128] systemd[1]: systemd 234 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN default-hierarchy=hybrid)
[ 9.603668] systemd[1]: Detected architecture arm64.
[ 9.646804] systemd[1]: Set hostname to <rpi3>.
[ 9.762731] uart-pl011 3f201000.serial: no DMA platform data
[ 10.072180] systemd[1]: Created slice User and Session Slice.
[ 10.110157] systemd[1]: Listening on Journal Socket.
[ 10.146622] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 10.202711] systemd[1]: Created slice System Slice.
[ 10.244253] systemd[1]: Starting Load Kernel Modules...
[ 10.277160] random: crng init done
[ 10.295094] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 10.354073] systemd[1]: Mounting Huge Pages File System...
[ 10.883603] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 10.939242] EXT4-fs (mmcblk0p2): resizing filesystem from 179200 to 3783424 blocks
[ 11.712561] EXT4-fs (mmcblk0p2): resized filesystem to 3783424
[ 12.334240] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 12.487670] systemd-journald[177]: Received request to flush runtime journal from PID 1
[ 12.755373] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 12.783271] bcm2835-rng 3f104000.rng: hwrng registered
[ 13.050935] hidraw: raw HID events driver (C) Jiri Kosina
[ 13.154671] smsc95xx: unknown parameter 'macaddr' ignored
[ 13.178728] smsc95xx v1.0.6
[ 13.185158] usbcore: registered new interface driver usbhid
[ 13.185165] usbhid: USB HID core driver
[ 13.216891] input: MLK Trust Keyboard 14909 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:04FC:05D8.0001/input/input0
[ 13.249444] vc4_hdmi 3f902000.hdmi: vc4-hdmi-hifi <-> 3f902000.hdmi mapping ok
[ 13.249465] vc4_hdmi 3f902000.hdmi: ASoC: no DMI vendor name!
[ 13.250583] vc4-drm soc:gpu: bound 3f902000.hdmi (ops vc4_hdmi_ops [vc4])
[ 13.250854] vc4-drm soc:gpu: bound 3f806000.vec (ops vc4_vec_ops [vc4])
[ 13.250980] vc4-drm soc:gpu: bound 3f400000.hvs (ops vc4_hvs_ops [vc4])
[ 13.251344] vc4-drm soc:gpu: bound 3f206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 13.251597] vc4-drm soc:gpu: bound 3f207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 13.251852] vc4-drm soc:gpu: bound 3f807000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 13.251953] vc4-drm soc:gpu: Cannot do DMA to address 0x0000000000000000
[ 13.251961] swiotlb: coherent allocation failed for device soc:gpu size=16777216
[ 13.251975] CPU: 0 PID: 207 Comm: systemd-udevd Not tainted 4.13.0-1-arm64 #1 Debian 4.13.4-1
[ 13.251978] Hardware name: Raspberry Pi 3 Model B Rev 1.2 (DT)
[ 13.251985] Call trace:
[ 13.252013] [<ffff0a533a88a590>] dump_backtrace+0x0/0x2a0
[ 13.252025] [<ffff0a533a88a8a4>] show_stack+0x24/0x30
[ 13.252040] [<ffff0a533afdb134>] dump_stack+0x98/0xbc
[ 13.252052] [<ffff0a533ac21364>] swiotlb_alloc_coherent+0x17c/0x190
[ 13.252062] [<ffff0a533a89c5c0>] __dma_alloc+0x78/0x160
[ 13.252258] [<ffff03b38225910c>] drm_gem_cma_create+0xac/0x138 [drm]
[ 13.252345] [<ffff03b38246d714>] vc4_bo_create+0x104/0x160 [vc4]
[ 13.252432] [<ffff03b38247cbac>] vc4_allocate_bin_bo+0x9c/0x198 [vc4]
[ 13.252518] [<ffff03b38247ce60>] vc4_v3d_bind+0x100/0x288 [vc4]
[ 13.252532] [<ffff0a533adbbbe8>] component_bind_all+0x140/0x2c8
[ 13.252618] [<ffff03b38246fdac>] vc4_drm_bind+0x84/0x168 [vc4]
[ 13.252628] [<ffff0a533adbb770>] try_to_bring_up_master+0x290/0x2e0
[ 13.252637] [<ffff0a533adbba54>] component_master_add_with_match+0xb4/0x108
[ 13.252722] [<ffff03b38246ff60>] vc4_platform_drm_probe+0xd0/0x130 [vc4]
[ 13.252734] [<ffff0a533adc5b20>] platform_drv_probe+0x60/0xc8
[ 13.252742] [<ffff0a533adc31e4>] driver_probe_device+0x2e4/0x460
[ 13.252749] [<ffff0a533adc3484>] __driver_attach+0x124/0x128
[ 13.252756] [<ffff0a533adc08f0>] bus_for_each_dev+0x88/0xe8
[ 13.252763] [<ffff0a533adc28d0>] driver_attach+0x30/0x40
[ 13.252770] [<ffff0a533adc2268>] bus_add_driver+0x1f8/0x2b0
[ 13.252777] [<ffff0a533adc4238>] driver_register+0x68/0x100
[ 13.252785] [<ffff0a533adc5a44>] __platform_driver_register+0x54/0x60
[ 13.252872] [<ffff03b382496034>] vc4_drm_register+0x34/0x58 [vc4]
[ 13.252881] [<ffff0a533a88399c>] do_one_initcall+0x5c/0x168
[ 13.252890] [<ffff0a533a96ef58>] do_init_module+0x64/0x1cc
[ 13.252897] [<ffff0a533a96ddac>] load_module+0x2074/0x2718
[ 13.252903] [<ffff0a533a96e778>] SyS_finit_module+0x128/0x140
[ 13.252911] [<ffff0a533a88378c>] __sys_trace_return+0x0/0x4
[ 13.252943] vc4-drm soc:gpu: failed to allocate buffer with size 16777216
[ 13.252999] vc4-drm soc:gpu: Cannot do DMA to address 0x0000000000000000
[ 13.253005] swiotlb: coherent allocation failed for device soc:gpu size=16777216
[ 13.253013] CPU: 0 PID: 207 Comm: systemd-udevd Not tainted 4.13.0-1-arm64 #1 Debian 4.13.4-1
[ 13.253017] Hardware name: Raspberry Pi 3 Model B Rev 1.2 (DT)
[ 13.253020] Call trace:
[ 13.253031] [<ffff0a533a88a590>] dump_backtrace+0x0/0x2a0
[ 13.253040] [<ffff0a533a88a8a4>] show_stack+0x24/0x30
[ 13.253051] [<ffff0a533afdb134>] dump_stack+0x98/0xbc
[ 13.253061] [<ffff0a533ac21364>] swiotlb_alloc_coherent+0x17c/0x190
[ 13.253070] [<ffff0a533a89c5c0>] __dma_alloc+0x78/0x160
[ 13.253228] [<ffff03b38225910c>] drm_gem_cma_create+0xac/0x138 [drm]
[ 13.253313] [<ffff03b38246d738>] vc4_bo_create+0x128/0x160 [vc4]
[ 13.253398] [<ffff03b38247cbac>] vc4_allocate_bin_bo+0x9c/0x198 [vc4]
[ 13.253484] [<ffff03b38247ce60>] vc4_v3d_bind+0x100/0x288 [vc4]
[ 13.253494] [<ffff0a533adbbbe8>] component_bind_all+0x140/0x2c8
[ 13.253578] [<ffff03b38246fdac>] vc4_drm_bind+0x84/0x168 [vc4]
[ 13.253588] [<ffff0a533adbb770>] try_to_bring_up_master+0x290/0x2e0
[ 13.253596] [<ffff0a533adbba54>] component_master_add_with_match+0xb4/0x108
[ 13.253681] [<ffff03b38246ff60>] vc4_platform_drm_probe+0xd0/0x130 [vc4]
[ 13.253693] [<ffff0a533adc5b20>] platform_drv_probe+0x60/0xc8
[ 13.253701] [<ffff0a533adc31e4>] driver_probe_device+0x2e4/0x460
[ 13.253709] [<ffff0a533adc3484>] __driver_attach+0x124/0x128
[ 13.253716] [<ffff0a533adc08f0>] bus_for_each_dev+0x88/0xe8
[ 13.253723] [<ffff0a533adc28d0>] driver_attach+0x30/0x40
[ 13.253730] [<ffff0a533adc2268>] bus_add_driver+0x1f8/0x2b0
[ 13.253737] [<ffff0a533adc4238>] driver_register+0x68/0x100
[ 13.253745] [<ffff0a533adc5a44>] __platform_driver_register+0x54/0x60
[ 13.253831] [<ffff03b382496034>] vc4_drm_register+0x34/0x58 [vc4]
[ 13.253839] [<ffff0a533a88399c>] do_one_initcall+0x5c/0x168
[ 13.253847] [<ffff0a533a96ef58>] do_init_module+0x64/0x1cc
[ 13.253854] [<ffff0a533a96ddac>] load_module+0x2074/0x2718
[ 13.253860] [<ffff0a533a96e778>] SyS_finit_module+0x128/0x140
[ 13.253868] [<ffff0a533a88378c>] __sys_trace_return+0x0/0x4
[ 13.253926] vc4-drm soc:gpu: failed to allocate buffer with size 16777216
[ 13.254023] [drm:vc4_bo_create [vc4]] *ERROR* Failed to allocate from CMA:
[ 13.254034] [drm] num bos allocated: 0
[ 13.254037] [drm] size bos allocated: 0kb
[ 13.254039] [drm] num bos used: 0
[ 13.254042] [drm] size bos used: 0kb
[ 13.254044] [drm] num bos cached: 0
[ 13.254047] [drm] size bos cached: 0kb
[ 13.254058] vc4_v3d 3fc00000.v3d: Failed to allocate memory for tile binning: -12. You may need to enable CMA or give it more memory.
[ 13.254174] vc4-drm soc:gpu: failed to bind 3fc00000.v3d (ops vc4_v3d_ops [vc4]): -12
[ 13.257090] vc4-drm soc:gpu: master bind failed: -12
[ 13.257157] vc4-drm: probe of soc:gpu failed with error -12
[ 13.282707] sunplus 0003:04FC:05D8.0001: input,hidraw0: USB HID v1.00 Keyboard [MLK Trust Keyboard 14909] on usb-3f980000.usb-1.4/input0
[ 13.282807] sunplus 0003:04FC:05D8.0002: fixing up Sunplus Wireless Desktop report descriptor
[ 13.289106] input: MLK Trust Keyboard 14909 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:04FC:05D8.0002/input/input1
[ 13.358390] sunplus 0003:04FC:05D8.0002: input,hiddev0,hidraw1: USB HID v1.00 Mouse [MLK Trust Keyboard 14909] on usb-3f980000.usb-1.4/input1
[ 15.599610] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:2d:f5:ab
[ 15.646622] usbcore: registered new interface driver smsc95xx
[ 16.439420] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 16.861477] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 16.890036] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 18.319357] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 18.345975] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC1E1[/code]C'est un plus long.
Conclusion
Les deux OS reconnaissent le raspberry correctement.
Par contre, sous ArchLinux, la carte son n'est pas reconnu. Et sous Debian, le fichier /boot/config.txt est complètement différent. Il est déjà beaucoup plus long. Il faut un peu plus de 7000 lignes.
Il y a bien un partition de boot, mais je n'ai pas encore eu le temps de regarder.
Quelques infos :
[url=https://unix.stackexchange.com/questions/43539/what-do-the-flags-in-proc-cpuinfo-mean]Explication des flags de lscpu[/url]
[url=https://en.wikipedia.org/wiki/ARM_architecture#64/32-bit_architecture]ARMv8-A & AArch64 sur wikipedia[/url]
[url=https://en.wikipedia.org/wiki/Comparison_of_ARMv8-A_cores]Comparaison des ARMv8-A sur wikipedia[/url]
[url=https://en.wikipedia.org/wiki/ARM_Cortex-A53]Un petit détail de l'ARM Cortex-A53 sur wikipedia[/url]
[url=https://en.wikipedia.org/wiki/Raspberry_Pi#Specifications]Spécifications des différents rasp... encore sur wikipedia[/url]
Je reviens vers vous concernant le fichier de boot et la reconnaissance de la carte.
Bonne journée.
Le retour complet est :[ 0.000000] Booting Linux on physical CPU 0x0
[ 18.345975] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC1E1C’est un plus long.
Conclusion
Par contre, sous ArchLinux, la carte son n’est pas reconnu. Et sous Debian, le fichier /boot/config.txt est complètement différent. Il est déjà beaucoup plus long. Il faut un peu plus de 7000 lignes.
Il y a bien un partition de boot, mais je n’ai pas encore eu le temps de regarder.
Quelques infos :
Un petit détail de l’ARM Cortex-A53 sur wikipedia
Spécifications des différents rasp… encore sur wikipedia
Bonne journée.
