Je n’arrive pas a configurer cupsd.conf:
“$Id: cupsd.conf.in,v 1.3 2002/02/12 18:47:11 mike Exp $”
Sample configuration file for the Common UNIX Printing System (CUPS)
scheduler.
Copyright 1997-2002 by Easy Software Products, all rights reserved.
These coded instructions, statements, and computer programs are the
property of Easy Software Products and are protected by Federal
copyright law. Distribution and use rights are outlined in the file
“LICENSE.txt” which should have been included with this file. If this
file is missing or damaged please contact Easy Software Products
at:
Attn: CUPS Licensing Information
44141 Airport View Drive, Suite 204
Hollywood, Maryland 20636-3111 USA
Voice: (301) 373-9603
This is the CUPS configuration file. If you are familiar with
Apache or any of the other popular web servers, we’ve followed the
same format. Any configuration variable used here has the same
semantics as the corresponding variable in Apache. If we need
different functionality then a different name is used to avoid
confusion…
######## Server Identity
ServerName: the hostname of your server, as advertised to the world.
By default CUPS will use the hostname of the system.
To set the default server used by clients, see the client.conf file.
ServerName 192.168.2.2
ServerAdmin: the email address to send all complaints/problems to.
By default CUPS will use “root@hostname”.
#ServerAdmin root@domaine
######## Server Options
AccessLog: the access log file; if this does not start with a leading /
then it is assumed to be relative to ServerRoot. By default set to
“/var/log/cups/access_log”
You can also use the special name “syslog” to send the output to the
syslog file or daemon.
AccessLog /var/log/cups/access_log
Classification: the classification level of the server. If set, this
classification is displayed on all pages, and raw printing is disabled.
The default is the empty string.
#Classification classified
#Classification confidential
#Classification secret
#Classification topsecret
#Classification unclassified
ClassifyOverride: whether to allow users to override the classification
on printouts. If enabled, users can limit banner pages to before or
after the job, and can change the classification of a job, but cannot
completely eliminate the classification or banners.
The default is off.
#ClassifyOverride off
DataDir: the root directory for the CUPS data files.
By default “/usr/share/cups”.
DataDir /usr/share/cups
DefaultCharset: the default character set to use. If not specified,
defaults to “utf-8”. Note that this can also be overridden in
HTML documents…
#DefaultCharset utf-8
DefaultCharset ISO-8859-15
DefaultLanguage: the default language if not specified by the browser.
If not specified, the current locale is used.
DefaultLanguage fr
DocumentRoot: the root directory for HTTP documents that are served.
By default “/usr/share/cups/doc-root”.
DocumentRoot /usr/share/cups/doc-root
ErrorLog: the error log file; if this does not start with a leading /
“/var/log/cups/error_log”
ErrorLog /var/log/cups/error_log
FontPath: the path to locate all font files (currently only for pstoraster)
By default “/usr/share/cups/fonts”.
FontPath /usr/share/cups/fonts
LogLevel: controls the number of messages logged to the ErrorLog
file and can be one of the following:
debug2 Log everything.
debug Log almost everything.
info Log all requests and state changes.
warn Log errors and warnings.
error Log only errors.
none Log nothing.
LogLevel info
MaxLogSize: controls the maximum size of each log file before they are
rotated. Defaults to 1048576 (1MB). Set to 0 to disable log rotating.
#MaxLogSize 0
PageLog: the page log file; if this does not start with a leading /
“/var/log/cups/page_log”
PageLog /var/log/cups/page_log
PreserveJobHistory: whether or not to preserve the job history after a
job is completed, cancelled, or stopped. Default is Yes.
PreserveJobHistory No
PreserveJobFiles: whether or not to preserve the job files after a
job is completed, cancelled, or stopped. Default is No.
PreserveJobFiles No
AutoPurgeJobs: automatically purge jobs when not needed for quotas.
Default is No.
AutoPurgeJobs Yes
MaxJobs: maximum number of jobs to keep in memory (active and completed.)
Default is 500; the value 0 is used for no limit.
#MaxJobs 500
Printcap: the name of the printcap file. Default is /etc/printcap.
Leave blank to disable printcap file generation.
Printcap /etc/printcap
PrintcapFormat: the format of the printcap file, currently either
BSD or Solaris. The default is “BSD”.
#PrintcapFormat BSD
#PrintcapFormat Solaris
PrintcapGUI: the name of the GUI options panel program to associate
with print queues under IRIX. The default is “/usr/bin/glpoptions”
from ESP Print Pro.
This option is only used under IRIX; the options panel program
must accept the “-d printer” and “-o options” options and write
the selected printer options back to stdout on completion.
#PrintcapGUI /usr/bin/glpoptions
RequestRoot: the directory where request files are stored.
By default “/var/spool/cups”.
RequestRoot /var/spool/cups
RemoteRoot: the name of the user assigned to unauthenticated accesses
from remote systems. By default “remroot”.
#RemoteRoot remroot
ServerBin: the root directory for the scheduler executables.
By default “/usr/lib/cups”.
ServerBin /usr/lib/cups
ServerRoot: the root directory for the scheduler.
By default “/etc/cups”.
ServerRoot /etc/cups
######## Encryption Support
ServerCertificate: the file to read containing the server’s certificate.
Defaults to “/etc/cups/ssl/server.crt”.
#ServerCertificate /etc/cups/ssl/server.crt
ServerKey: the file to read containing the server’s key.
Defaults to “/etc/cups/ssl/server.key”.
#ServerKey /etc/cups/ssl/server.key
######## Filter Options
User/Group: the user and group the server runs under. Normally this
must be lp and sys, however you can configure things for another
user or group as needed.
Note: the server must be run initially as root to support the
default IPP port of 631. It changes users whenever an external
program is run, or if the RunAsUser directive is specified…
#User lp
#Group lp
RIPCache: the amount of memory that each RIP should use to cache
bitmaps. The value can be any real number followed by “k” for
kilobytes, “m” for megabytes, “g” for gigabytes, or “t” for tiles
(1 tile = 256x256 pixels.) Defaults to “8m” (8 megabytes).
#RIPCache 8m
TempDir: the directory to put temporary files in. This directory must be
writable by the user defined above! Defaults to “/var/spool/cups/tmp” or
the value of the TMPDIR environment variable.
TempDir /var/spool/cups/tmp
FilterLimit: sets the maximum cost of all job filters that can be run
at the same time. A limit of 0 means no limit. A typical job may need
a filter limit of at least 200; limits less than the minimum required
by a job force a single job to be printed at any time.
The default limit is 0 (unlimited).
#FilterLimit 0
######## Network Options
Ports/addresses that we listen to. The default port 631 is reserved
for the Internet Printing Protocol (IPP) and is what we use here.
You can have multiple Port/Listen lines to listen to more than one
port or address, or to restrict access:
Port 80
Port 631
Listen hostname
Listen hostname:80
Listen hostname:631
Listen 1.2.3.4
Listen 1.2.3.4:631
NOTE: Unfortunately, most web browsers don’t support TLS or HTTP Upgrades
for encryption. If you want to support web-based encryption you’ll
probably need to listen on port 443 (the “https” port…)
#Port 80
#Port 443
Port 631
HostNameLookups: whether or not to do lookups on IP addresses to get a
fully-qualified hostname. This defaults to Off for performance reasons…
#HostNameLookups On
KeepAlive: whether or not to support the Keep-Alive connection
option. Default is on.
KeepAlive On
KeepAliveTimeout: the timeout before Keep-Alive connections are
automatically closed. Default is 60 seconds.
KeepAliveTimeout 60
MaxClients: controls the maximum number of simultaneous clients that
will be handled. Defaults to 100.
MaxClients 100
MaxRequestSize: controls the maximum size of HTTP requests and print files.
Set to 0 to disable this feature (defaults to 0.)
#MaxRequestSize 0
Timeout: the timeout before requests time out. Default is 300 seconds.
#Timeout 300
######## Browsing Options
Browsing: whether or not to broadcast and/or listen for CUPS printer
information on the network. Enabled by default.
#Browsing Off
BrowseProtocols: which protocols to use for browsing. Can be
any of the following separated by whitespace and/or commas:
all - Use all supported protocols.
cups - Use the CUPS browse protocol.
slp - Use the SLPv2 protocol.
The default is “cups”.
NOTE: If you choose to use SLPv2, it is strongly recommended that
you have at least one SLP Directory Agent (DA) on your
network. Otherwise, browse updates can take several seconds,
during which the scheduler will not response to client
requests.
#BrowseProtocols cups
BrowseAddress: specifies a broadcast address to be used. By
default browsing information is not sent!
Note: HP-UX does not properly handle broadcast unless you have a
Class A, B, C, or D netmask (i.e. no CIDR support).
Note: Using the “global” broadcast address (255.255.255.255) will
activate a Linux demand-dial link with the default configuration.
If you have a LAN as well as the dial-up link, use the LAN’s
broadcast address.
#BrowseAddress x.y.z.255
#BrowseAddress x.y.255.255
#BrowseAddress x.255.255.255
#BrowseAddress 255.255.255.255
BrowseShortNames: whether or not to use “short” names for remote printers
when possible (e.g. “printer” instead of “printer@host”.) Enabled by
default.
#BrowseShortNames Yes
BrowseAllow: specifies an address mask to allow for incoming browser
packets. The default is to allow packets from all addresses.
BrowseDeny: specifies an address mask to deny for incoming browser
packets. The default is to deny packets from no addresses.
Both “BrowseAllow” and “BrowseDeny” accept the following notations for
addresses:
All
None
*.domain.com
.domain.com
nnn.*
nnn.nnn.*
nnn.nnn.nnn.*
nnn.nnn.nnn.nnn
nnn.nnn.nnn.nnn/mm
nnn.nnn.nnn.nnn/mmm.mmm.mmm.mmm
The hostname/domainname restrictions only work if you have turned hostname
lookups on!
#BrowseAllow address
#BrowseDeny address
BrowseInterval: the time between browsing updates in seconds. Default
is 30 seconds.
Note that browsing information is sent whenever a printer’s state changes
as well, so this represents the maximum time between updates.
Set this to 0 to disable outgoing broadcasts so your local printers are
not advertised but you can still see printers on other hosts.
#BrowseInterval 30
BrowseOrder: specifies the order of BrowseAllow/BrowseDeny comparisons.
#BrowseOrder allow,deny
#BrowseOrder deny,allow
BrowsePoll: poll the named server(s) for printers
#BrowsePoll address:port
BrowsePort: the port used for UDP broadcasts. By default this is
the IPP port; if you change this you need to do it on all servers.
Only one BrowsePort is recognized.
BrowsePort 631
BrowseRelay: relay browser packets from one address/network to another.
#BrowseRelay source-address destination-address
BrowseTimeout: the timeout for network printers - if we don’t
get an update within this time the printer will be removed
from the printer list. This number definitely should not be
less the BrowseInterval value for obvious reasons. Defaults
to 300 seconds.
#BrowseTimeout 300
ImplicitClasses: whether or not to use implicit classes.
Printer classes can be specified explicitly in the classes.conf
file, implicitly based upon the printers available on the LAN, or
both.
When ImplicitClasses is On, printers on the LAN with the same name
(e.g. Acme-LaserPrint-1000) will be put into a class with the same
name. This allows you to setup multiple redundant queues on a LAN
without a lot of administrative difficulties. If a user sends a
job to Acme-LaserPrint-1000, the job will go to the first available
queue.
Enabled by default.
#ImplicitClasses On
ImplicitAnyClasses: whether or not to create “AnyPrinter” implicit
classes.
When ImplicitAnyClasses is On and a local queue of the same name
exists, e.g. “printer”, “printer@server1”, “printer@server1”, then
an implicit class called “Anyprinter” is created instead.
When ImplicitAnyClasses is Off, implicit classes are not created
when there is a local queue of the same name.
Disabled by default.
#ImplicitAnyCLasses Off
HideImplicitMembers: whether or not to show the members of an
implicit class.
When HideImplicitMembers is On, any remote printers that are
part of an implicit class are hidden from the user, who will
then only see a single queue even though many queues will be
supporting the implicit class.
Enabled by default.
#HideImplicitMembers On
######## Security Options
SystemGroup: the group name for “System” (printer administration)
access. The default varies depending on the operating system, but
will be “sys”, “system”, or “root” (checked for in that order.)
SystemGroup lpadmin
Access permissions for each directory served by the scheduler.
Locations are relative to DocumentRoot…
AuthType: the authorization to use:
None - Perform no authentication
Basic - Perform authentication using the HTTP Basic method.
Digest - Perform authentication using the HTTP Digest method.
(Note: local certificate authentication can be substituted by
the client for Basic or Digest when connecting to the
localhost interface)
AuthClass: the authorization class; currently only “Anonymous”, “User”,
“System” (valid user belonging to group SystemGroup), and “Group”
(valid user belonging to the specified group) are supported.
AuthGroupName: the group name for “Group” authorization.
Order: the order of Allow/Deny processing.
Allow: allows access from the specified hostname, domain, IP address, or
network.
Deny: denies access from the specified hostname, domain, IP address, or
network.
Both “Allow” and “Deny” accept the following notations for addresses:
All
None
*.domain.com
.domain.com
nnn.*
nnn.nnn.*
nnn.nnn.nnn.*
nnn.nnn.nnn.nnn
nnn.nnn.nnn.nnn/mm
The host and domain address require that you enable hostname lookups
with “HostNameLookups On” above.
Encryption: whether or not to use encryption; this depends on having
the OpenSSL library linked into the CUPS library and scheduler.
Possible values:
Always - Always use encryption (SSL)
Never - Never use encryption
Required - Use TLS encryption upgrade
IfRequested - Use encryption if the server requests it
The default value is “IfRequested”.
Order Deny,Allow
#Deny From All
Allow From 127.0.0.1
Allow from 192.168.1.2
Allow from 192.168.2.2
#<Location /classes>
You may wish to limit access to printers and classes, either with Allow
and Deny lines, or by requiring a username and password.
#<Location /classes/name>
#<Location /printers>
#<Location /printers/name>
Anonymous access (default)
#AuthType None
Require a username and password (Basic authentication)
#AuthType Basic
#AuthClass User
Require a username and password (Digest/MD5 authentication)
#AuthType Digest
#AuthClass User
Restrict access to local domain
#Order Deny,Allow
#Deny From All
#Allow From .mydomain.com
<Location /admin>
You definitely will want to limit access to the administration functions.
The default configuration requires a local connection from a user who
is a member of the system group to do any admin tasks. You can change
the group name using the SystemGroup directive.
AuthType Basic
AuthClass System
Order Deny,Allow
#Deny From All
#Encryption Required
#Brwosing On
#BrowseOrder Deny,Allow
#BrowseAllow from @LOCAL
#Lsiten*:631
End of “$Id: cupsd.conf.in,v 1.3 2002/02/12 18:47:11 mike Exp $”.
Avec ceci je n’arrive pas a accéder à localhost:631
L’@ 192.168.2.2 coresspond a la machine ou est cups et 192.168.1.2 est l’@ du client qui voudrais utiliser l’imprimante.
Dans les deux cas imporssible d’accéder a la page.
Autrement j’ai bien décommenter la ligne des ficihers mime.
