Reconnaissance cle USB 32Go en FAT32
Ma Debian n’arrive pas à lire ma cle USB de 32 Go en FAT32, là mon windows XP sur le même PC y arrive.
Que ce soit en montage automatique ou à la mano: l’OS tente de mapper la clé pendant de longues minutes, en boucle, sans succès, sans message d’erreur particulier.
Selon vous, y-a t-il des restrictions côté linux?
Merci.
Des messages dans les logs du noyau ?
plugusb ? … fran.b
Source
dmesg:
[38439.997051] usb 1-3: new high speed USB device using ehci_hcd and address 4 [38440.233325] usb 1-3: New USB device found, idVendor=0011, idProduct=7788 [38440.233332] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [38440.233337] usb 1-3: Product: Mass Storage [38440.233340] usb 1-3: Manufacturer: Generic [38440.233344] usb 1-3: SerialNumber: BE4557B2 [38440.233534] usb 1-3: configuration #1 chosen from 1 choice [38440.233989] scsi5 : SCSI emulation for USB Mass Storage devices [38440.234298] usb-storage: device found at 4 [38440.234302] usb-storage: waiting for device to settle before scanning [38445.232233] usb-storage: device scan complete [38445.234070] scsi 5:0:0:0: Direct-Access Generic Flash Disk 8.00 PQ: 0 ANSI: 2 [38445.241076] sd 5:0:0:0: [sdc] 67174400 512-byte logical blocks: (34.3 GB/32.0 GiB) [38445.241544] sd 5:0:0:0: [sdc] Write Protect is off [38445.241551] sd 5:0:0:0: [sdc] Mode Sense: 03 00 00 00 [38445.241555] sd 5:0:0:0: [sdc] Assuming drive cache: write through [38445.248694] sd 5:0:0:0: [sdc] Assuming drive cache: write through [38445.248706] sdc: sdc1 [38445.471160] sd 5:0:0:0: [sdc] Assuming drive cache: write through [38445.471169] sd 5:0:0:0: [sdc] Attached SCSI removable disk
root@pif:/home/pif# mount -t vfat sdc1 toto/ mount: special device sdc1 does not exist
root@pif:/dev# ls sd* sda sda1 sda2 sda3 sdb sdb1 sdc sdc1
Qu’en pensez-vous?
J’en pense que ça pourrait mieux marcher avec des chemins absolus comme /dev/sdc1.
L’an dernier lors de l’acquisition d’une carte compaq flash de 16 G.o pour mon APN, je me suis heurté à un problème qui me semble similaire et par hasard en lisant la page de man de mkfs.vfat , je me suis aperçu que ma carte était mal formatée. Faut voir si tu es dans le même cas;
Vu que c’est une clé de grande capacité, il te faut du fat32 car le fat16 limite le formatage de ta carte à 4 G.o, donc à ta place je tenterais un formatage avec la commande :
C’est une piste, j’ai pas dit que j’avais la solution :confused: et si tu peux t’affranchir de ce système de fichier, c’est pas plus mal…
Avec le chemin absolu (désolé pour l’erreur), il ne se passe rien:
le prompt passe à la ligne en dessous, sans rendre la main, et rien ne se passe.
En résumé, il tente des choses mais sans succès.
dmesg à ce moment:
[ 153.365663] sd 5:0:0:0: [sdc] Write Protect is off [ 153.365668] sd 5:0:0:0: [sdc] Mode Sense: 03 00 00 00 [ 153.365673] sd 5:0:0:0: [sdc] Assuming drive cache: write through [ 153.375836] sd 5:0:0:0: [sdc] Assuming drive cache: write through [ 153.375848] sdc: sdc1 [ 153.678252] sd 5:0:0:0: [sdc] Assuming drive cache: write through [ 153.678262] sd 5:0:0:0: [sdc] Attached SCSI removable disk [ 183.916077] usb 1-3: reset high speed USB device using ehci_hcd and address 4 [ 214.928056] usb 1-3: reset high speed USB device using ehci_hcd and address 4 [ 245.932049] usb 1-3: reset high speed USB device using ehci_hcd and address 4 [ 276.928059] usb 1-3: reset high speed USB device using ehci_hcd and address 4 [ 307.928063] usb 1-3: reset high speed USB device using ehci_hcd and address 4
Et pour info:
lspci |grep -i ehci 00:12.2 USB Controller: ATI Technologies Inc SB700/SB800 USB EHCI Controller 00:13.2 USB Controller: ATI Technologies Inc SB700/SB800 USB EHCI Controller
lsusb: Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 004: ID 0011:7788 Bus 001 Device 003: ID 04f2:b175 Chicony Electronics Co., Ltd 4-Port Hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Pour info. également, j’ai trouvé ce lien:
cyberciti.biz/faq/rhel-redha … -ehci_hcd/
Extrait:
"How do I solve this problem?
The Enhanced Host Controller Interface (EHCI) is a register-level interface that enables a host controller for USB or FireWire hardware to communicate with a host controller driver in software. In this case USB revision 2.0. ehci-hcd.ko is USB 2.0 ‘Enhanced’ Host Controller (EHCI) driver. This error indicates that USB 2.0 may not function on your system, or may function only at USB 1.1 speeds. To fix this problem:
  1. Replace hardware: In most cases you need to replace the motherboard.
  2. Remove ehci_hcd driver
  3. Disable ehci_hcd drive USB 2.0 interface and use it as USB 1.1. In short disable the ehci_hcd."
Qu’en pensez-vous?
