Reconnaissance DD externe USB2
J’ai un DD externe (LaCie Hard Drive USB 2.0 320GB) branché sur une carte PCI USB2.
Impossible de le trouver, et donc de le monter.
Pas de /dev/hdb ni de /dev/sda
L’USB 2.0 est bien reconnu :
lspci -v | grep EHCI
00:0d.2 USB Controller: VIA Technologies, Inc. USB 2.0 (rev 65) (prog-if 20 [EHCI])
J’ai fait ensuite :
/bin/dmesg | grep usb
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
usb usb1: configuration #1 chosen from 1 choice
usb usb2: configuration #1 chosen from 1 choice
usb usb3: configuration #1 chosen from 1 choice
usb usb4: configuration #1 chosen from 1 choice
usb usb5: configuration #1 chosen from 1 choice
usbcore: registered new interface driver usblp
drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
usb 5-4: new high speed USB device using ehci_hcd and address 2
usb 5-4: configuration #1 chosen from 1 choice
usbcore: registered new interface driver usb-storage
usb-storage: device found at 2
usb-storage: waiting for device to settle before scanning
usb-storage: device scan complete
usb 5-4: reset high speed USB device using ehci_hcd and address 2
usb 5-4: device descriptor read/64, error -71
usb 5-4: device not accepting address 2, error -71
usb 5-4: USB disconnect, address 2
usb 5-4: new high speed USB device using ehci_hcd and address 3
usb 5-4: new high speed USB device using ehci_hcd and address 4
usb 5-4: new high speed USB device using ehci_hcd and address 5
usb 5-4: device not accepting address 5, error -71
usb 5-4: new high speed USB device using ehci_hcd and address 6
usb 5-4: device not accepting address 6, error -71
Quelqu’un peut-il m’aider à interpréter ?
Je n’ai rien dans mon fichier /proc/bus/usb/devices
Et dans /media , je n’ai que cdrom et floppy.
Je débute sous Linux, j’ai passé l’après-midi à naviguer pour résoudre ce truc mais là, je cale.
A l’aide svp
Debian Lenny 2.6.22
IOP,
t’a pas de /dev/sda mais t’es allé voir sur du /dev/sdb par exemple…
fait un
#lsusb
si t’arive a le detecter par la suite et n’arive pas a le monter, fait attention a ton format de fichier… ca se peu qu’un gros disque comme ca soit en ntfs… donc GO ntfs-3g…
Hello RedX42,
pas de /dev/sdb, sdc ou sdz non-plus :frowning:
J’ai déjà fait un #lsusb -v qui ne m’a rien donné de plus.
J’ajoute que mon imprimante USB connectée à un port 1.1 fonctionne sans problème.
Le DD USB possède sa propre alimentation secteur, est formaté en Fat32 et j’y accède sans problème de Windows98SE (je suis en double-boot).
Je n’ai pas essayé de le connecter à un port USB 1.1 mais puisque la carte PCI USB 2.0 est reconnue…
Bon, j’essaye ce soir (je suis au boulot, là)
Ton imprimante marche, mais sous Linux?
Au faite moi j’ai deja eut 2 cé USB qui n’on jamais voulut fonctionner sous linux… :’(
[quote=“RedX42”]Ton imprimante marche, mais sous Linux?
([/quote]
Oui oui, mon imprimante marche sous Linux.
Bon, y’a du nouveau :
J’ai essayé de brancher le DD sur un port USB 1.1 de la carte mère.
Une belle icône disque LACIE apparait sur le bureau. :smiley:
Le problème, c’est qu’elle est inactive. :frowning:
D’ailleurs toutes les autres icônes du bureau (poste de travail, dossier personnel, quelques fichiers) deviennent inactives. :open_mouth:
Je peux lancer des applications, xmms, iceweasel, et quand je ferme la fenêtre de ce dernier, toutes les icônes du bureau ont disparu.
Je débranche le DD, les icônes réapparaissent instantanément, ainsi que les fenêtres de ce que j’avais essayer d’ouvrir : poste de travail, dossier personnel, LACIE (vide)…
Je deviens dingue… :smt087
Bon, j’ai rebranché le DD sur un port USB2 de la carte PCI et j’ai retenté un lsusb :
# lsusb
Bus 005 Device 002: ID 059f:0951 LaCie, Ltd
Bus 005 Device 001: ID 0000:0000
Bus 004 Device 001: ID 0000:0000
Bus 003 Device 001: ID 0000:0000
Bus 002 Device 004: ID 03f0:4d11 Hewlett-Packard
Bus 002 Device 001: ID 0000:0000
Bus 001 Device 001: ID 0000:0000
Tiens, que vois-je ?
Mon DD LaCie est reconnu…
Je retourne dans le dossier /dev et je tombe, cette fois, sur sda1 :smiley:
Je fais
[i]# mkdir /mnt/DD_externe
mount -t vfat /dev/sda1 /mnt/DD_externe
ln -s /mnt/DD_externe /home/cyrcle/Desktop[/i]
Ayèèèè, j’accède enfin à mon DD USB !
# umount /dev/sda1 avant de l’éteindre.
Bon, maintenant il faut que je trouve le moyen d’obtenir automatiquement une icône disque sur mon bureau quand j’allume mon DD, avec un “monter/démonter le volume” dans le menu du click-droit, histoire de pas me taper toute la procédure en root à chaque fois que je veux accéder au DD…
Aarf… :unamused:
