Bonjour a tous,
Mon disque dur WD EADS 2To en EXT4 ne fonctionne plus. Il m’est impossible de demarrer le PC si il est branche dedans.
Je l’ai donc mis en USB afin de pouvoir essayer de recuperer les fichiers qui sont dessus ou de reparer/corriger les erreurs.
Mais je ne m’y connais pas tres bien.
Voici un peu ce qu’il a dans le ventre (disque dur non monte)
- fsck /dev/sdc
fsck.ext2: Attempt to read block from filesystem resulted in short read while trying to open /dev/sdc
Could this be a zero-length partition?
- fsck.ext4 -v /dev/sdc
fsck.ext4: Attempt to read block from filesystem resulted in short read while trying to open /dev/sdc
- fdisk -l
[code]WARNING: GPT (GUID Partition Table) detected on ‘/dev/sda’! The util fdisk doesn’t support GPT. Use GNU Parted.
Disk /dev/sda: 60.0 GB, 60022480896 bytes
255 heads, 63 sectors/track, 7297 cylinders
Disk identifier: 0x00000000
/dev/sda1 1 7298 58615703+ ee GPT
WARNING: GPT (GUID Partition Table) detected on ‘/dev/sdc’! The util fdisk doesn’t support GPT. Use GNU Parted.
- mkfs.ext4 -n /dev/sdc
mke2fs 1.41.12 (17-May-2010)
/dev/sdc is entire device, not just one partition!
Proceed anyway? (y,n) y
Filesystem label=
OS type: Linux
Block size=4096 (log=2)
Fragment size=4096 (log=2)
Stride=0 blocks, Stripe width=0 blocks
122101760 inodes, 488378646 blocks
24418932 blocks (5.00%) reserved for the super user
First data block=0
Maximum filesystem blocks=4294967296
14905 block groups
32768 blocks per group, 32768 fragments per group
8192 inodes per group
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
4096000, 7962624, 11239424, 20480000, 23887872, 71663616, 78675968,
102400000, 214990848
- fsck.ext4 -n -b 32768 /dev/sdc
[code]e2fsck 1.41.12 (17-May-2010)
fsck.ext4: Bad magic number in super-block while trying to open /dev/sdc
The superblock could not be read or does not describe a correct ext2
filesystem. If the device is valid and it really contains an ext2
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
e2fsck -b 8193 [/code]
Idem pour les autres blocks…
- DD bien reconnu par le BIOS ainsi que par testdisk (mais je ne maitrise pas bien testdisk, je ne veux pas faire de betise, donc j’attends vos retours)
- Si j’essaye de lister les fichiers des partitions avec Testdisk, celui ci m’informe que “No file found, filesystem seems damaged.”
Je suis en train de laisser testdisk tourner pour detecter les partitions.
J’ai essaye photorec mais celui ci n’a pas pu recuperer grand chose (Pas de partition liste non plus)
Merci de votre aide !
