bonjour à tous,
voila j’ai 2 problèmes:
- mon ordi redémarre (ou se met en veille 2 secondes et redémarre aussitôt) dès que je ne bouge plus la souris pendant 10 minutes.
- mes ventilos tournent à fond au démarrage mais lorsque l’ordi redémarre intempestivement ils tournent au minimum. J’ai réglé fancontrol mais sans succès… j’ai dépoussiéré tout l’intérieur et laissé le capot ouvert.
Voici ma config
[quote]00:00.0 Host bridge: Intel Corporation 82G33/G31/P35/P31 Express DRAM Controller (rev 10)
Subsystem: Hewlett-Packard Company Device 2a78
Flags: bus master, fast devsel, latency 0
Capabilities: [e0] Vendor Specific Information: Len=0b <?>
00:01.0 PCI bridge: Intel Corporation 82G33/G31/P35/P31 Express PCI Express Root Port (rev 10) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000c000-0000cfff
Memory behind bridge: f8000000-fbffffff
Prefetchable memory behind bridge: 00000000d0000000-00000000dfffffff
Capabilities: [88] Subsystem: Intel Corporation Device 0000
Capabilities: [80] Power Management version 3
Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [a0] Express Root Port (Slot+), MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [140] Root Complex Link
Kernel driver in use: pcieport
00:1b.0 Audio device: Intel Corporation NM10/ICH7 Family High Definition Audio Controller (rev 01)
Flags: bus master, fast devsel, latency 0, IRQ 43
Memory at fdffc000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [50] Power Management version 2
Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [130] Root Complex Link
Kernel driver in use: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 1 (rev 01) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 0000d000-0000dfff
Memory behind bridge: fdb00000-fdbfffff
Prefetchable memory behind bridge: 00000000fdc00000-00000000fdcfffff
Capabilities: [40] Express Root Port (Slot+), MSI 00
Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [90] Subsystem: Hewlett-Packard Company Device 2a78
Capabilities: [a0] Power Management version 2
Capabilities: [180] Root Complex Link
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev e1) (prog-if 01 [Subtractive decode])
Bus: primary=00, secondary=05, subordinate=05, sec-latency=32
I/O behind bridge: 0000e000-0000efff
Memory behind bridge: fdd00000-fddfffff
Prefetchable memory behind bridge: 00000000fde00000-00000000fdefffff
Capabilities: [50] Subsystem: Hewlett-Packard Company Device 2a78
00:1f.0 ISA bridge: Intel Corporation 82801GB/GR (ICH7 Family) LPC Interface Bridge (rev 01)
Flags: bus master, medium devsel, latency 0
Capabilities: [e0] Vendor Specific Information: Len=0c <?>
00:1f.2 IDE interface: Intel Corporation NM10/ICH7 Family SATA Controller [IDE mode] (rev 01) (prog-if 8a [Master SecP PriP])
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 19
I/O ports at 01f0 [size=8]
I/O ports at 03f4 [size=1]
I/O ports at 0170 [size=8]
I/O ports at 0374 [size=1]
I/O ports at f900 [size=16]
Capabilities: [70] Power Management version 2
Kernel driver in use: ata_piix
00:1f.3 SMBus: Intel Corporation NM10/ICH7 Family SMBus Controller (rev 01)
Flags: medium devsel, IRQ 19
I/O ports at 0500 [size=32]
Kernel driver in use: i801_smbus
01:00.0 VGA compatible controller: NVIDIA Corporation G98 [GeForce 9300 GE] (rev a1) (prog-if 00 [VGA controller])
Subsystem: Device 1b0a:9004
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at fa000000 (32-bit, non-prefetchable) [size=16M]
Memory at d0000000 (64-bit, prefetchable) [size=256M]
Memory at f8000000 (64-bit, non-prefetchable) [size=32M]
I/O ports at cf00 [size=128]
[virtual] Expansion ROM at fb000000 [disabled] [size=128K]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [128] Power Budgeting <?>
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Kernel driver in use: nouveau
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller (rev 01)
Flags: bus master, fast devsel, latency 0, IRQ 42
I/O ports at de00 [size=256]
Memory at fdbff000 (64-bit, non-prefetchable) [size=4K]
[virtual] Expansion ROM at fdc00000 [disabled] [size=128K]
Capabilities: [40] Power Management version 2
Capabilities: [48] Vital Product Data
Capabilities: [50] MSI: Enable+ Count=1/2 Maskable- 64bit+
Capabilities: [60] Express Endpoint, MSI 00
Capabilities: [84] Vendor Specific Information: Len=4c <?>
Capabilities: [100] Advanced Error Reporting
Capabilities: [12c] Virtual Channel
Capabilities: [148] Device Serial Number 05-00-00-00-36-4c-e0-00
Capabilities: [154] Power Budgeting <?>
Kernel driver in use: r8169[/quote]
et ma version
[ul]Linux Host-002 3.2.0-4-amd64 #1 SMP Debian 3.2.65-1+deb7u1 x86_64 GNU/Linux
[/ul]
en espérant que quelqu’un puisse m’aider, je précise que je suis super débutant avec debian… merci pour votre compréhension.
Comment veux-tu devenir le roi de la bricole si tu n’essaies jamais ?? Voici le lien que j’ai utilisé :
