Hum je suis bête, peut-être le “failed” ne concerne-t-il pas le ntfs mais la partition vfat…
Voici dmesg (je mets tout, par peur de passer à côté de l’important)
Bootdata ok (command line is root=/dev/sda5 ro )
Linux version 2.6.18-4-amd64 (Debian 2.6.18.dfsg.1-12etch2) (dannf@debian.org) (gcc version 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)) #1 SMP Fri May 4 00:37:33 UTC 2007
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009f000 (usable)
BIOS-e820: 000000000009f000 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000003fef0000 (usable)
BIOS-e820: 000000003fef0000 - 000000003fef3000 (ACPI NVS)
BIOS-e820: 000000003fef3000 - 000000003ff00000 (ACPI data)
BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
DMI 2.2 present.
ACPI: RSDP (v000 Nvidia ) @ 0x00000000000f7b70
ACPI: RSDT (v001 Nvidia AWRDACPI 0x42302e31 AWRD 0x00000000) @ 0x000000003fef3040
ACPI: FADT (v001 Nvidia AWRDACPI 0x42302e31 AWRD 0x00000000) @ 0x000000003fef30c0
ACPI: SSDT (v001 PTLTD POWERNOW 0x00000001 LTP 0x00000001) @ 0x000000003fef9680
ACPI: MCFG (v001 Nvidia AWRDACPI 0x42302e31 AWRD 0x00000000) @ 0x000000003fef9880
ACPI: MADT (v001 Nvidia AWRDACPI 0x42302e31 AWRD 0x00000000) @ 0x000000003fef95c0
ACPI: DSDT (v001 NVIDIA AWRDACPI 0x00001000 MSFT 0x0100000e) @ 0x0000000000000000
Scanning NUMA topology in Northbridge 24
Number of nodes 1
Node 0 MemBase 0000000000000000 Limit 000000003fef0000
NUMA: Using 63 for the hash shift.
Using node hash shift of 63
Bootmem setup node 0 0000000000000000-000000003fef0000
On node 0 totalpages: 257309
DMA zone: 3057 pages, LIFO batch:0
DMA32 zone: 254252 pages, LIFO batch:31
Nvidia board detected. Ignoring ACPI timer override.
ACPI: PM-Timer IO Port: 0x1008
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
Processor #0 15:11 APIC version 16
ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
Processor #1 15:11 APIC version 16
ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 2, version 17, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
ACPI: INT_SRC_OVR (bus 0 bus_irq 14 global_irq 14 high edge)
ACPI: INT_SRC_OVR (bus 0 bus_irq 15 global_irq 15 high edge)
ACPI: IRQ9 used by override.
ACPI: IRQ14 used by override.
ACPI: IRQ15 used by override.
Setting APIC routing to physical flat
Using ACPI (MADT) for SMP configuration information
Allocating PCI resources starting at 40000000 (gap: 3ff00000:a0100000)
SMP: Allowing 2 CPUs, 0 hotplug CPUs
Built 1 zonelists. Total pages: 257309
Kernel command line: root=/dev/sda5 ro
Initializing CPU#0
PID hash table entries: 4096 (order: 12, 32768 bytes)
Disabling vsyscall due to use of PM timer
time.c: Using 3.579545 MHz WALL PM GTOD PM timer.
time.c: Detected 2009.181 MHz processor.
Console: colour VGA+ 80x25
Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
Checking aperture...
CPU 0: aperture @ 4c18000000 size 32 MB
Aperture too small (32 MB)
No AGP bridge found
Memory: 1022632k/1047488k available (1930k kernel code, 24468k reserved, 868k data, 176k init)
Calibrating delay using timer specific routine.. 4022.87 BogoMIPS (lpj=8045754)
Security Framework v1.0.0 initialized
SELinux: Disabled at boot.
Capability LSM initialized
Mount-cache hash table entries: 256
CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
CPU: L2 Cache: 512K (64 bytes/line)
CPU 0/0 -> Node 0
CPU: Physical Processor ID: 0
CPU: Processor Core ID: 0
SMP alternatives: switching to UP code
ACPI: Core revision 20060707
Using local APIC timer interrupts.
result 12557400
Detected 12.557 MHz APIC timer.
SMP alternatives: switching to SMP code
Booting processor 1/2 APIC 0x1
Initializing CPU#1
Calibrating delay using timer specific routine.. 4018.55 BogoMIPS (lpj=8037107)
CPU 1/1 -> Node 0
CPU: Processor Core ID: 1
AMD Athlon(tm) 64 X2 Dual Core Processor 3800+ stepping 01
CPU 1: Syncing TSC to CPU 0.
CPU 1: synchronized TSC with CPU 0 (last diff 1 cycles, maxerr 515 cycles)
Brought up 2 CPUs
testing NMI watchdog ... OK.
migration_cost=276
checking if image is initramfs... it is
Freeing initrd memory: 4908k freed
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: Using MMCONFIG at e0000000
PCI: No mmconfig possible on device 0:18
ACPI: Interpreter enabled
ACPI: Using IOAPIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
Boot video device is 0000:02:00.0
PCI: Transparent bridge - 0000:00:10.0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.HUB0._PRT]
ACPI: PCI Interrupt Link [LNK1] (IRQs *5 7 9 10 11 14 15)
ACPI: PCI Interrupt Link [LNK2] (IRQs *5 7 9 10 11 14 15)
ACPI: PCI Interrupt Link [LNK3] (IRQs 5 7 9 10 11 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNK4] (IRQs 5 7 9 *10 11 14 15)
ACPI: PCI Interrupt Link [LNK5] (IRQs 5 7 9 10 *11 14 15)
ACPI: PCI Interrupt Link [LNK6] (IRQs 5 7 9 10 11 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNK7] (IRQs 5 7 9 10 11 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNK8] (IRQs 5 7 9 10 11 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LUBA] (IRQs 5 7 9 10 *11 14 15)
ACPI: PCI Interrupt Link [LUBB] (IRQs 5 7 9 10 11 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LMAC] (IRQs 5 7 9 *10 11 14 15)
ACPI: PCI Interrupt Link [LACI] (IRQs 5 7 9 *10 11 14 15)
ACPI: PCI Interrupt Link [LAZA] (IRQs 5 7 9 10 11 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LPMU] (IRQs 5 7 9 *10 11 14 15)
ACPI: PCI Interrupt Link [LMCI] (IRQs 5 7 9 10 11 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LSMB] (IRQs 5 7 9 *10 11 14 15)
ACPI: PCI Interrupt Link [LUB2] (IRQs *5 7 9 10 11 14 15)
ACPI: PCI Interrupt Link [LIDE] (IRQs 5 7 9 10 11 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LSID] (IRQs 5 7 9 10 *11 14 15)
ACPI: PCI Interrupt Link [LFID] (IRQs 5 7 9 *10 11 14 15)
ACPI: PCI Interrupt Link [APC1] (IRQs 16) *0, disabled.
ACPI: PCI Interrupt Link [APC2] (IRQs 17) *0, disabled.
ACPI: PCI Interrupt Link [APC3] (IRQs 18) *0, disabled.
ACPI: PCI Interrupt Link [APC4] (IRQs 19) *0, disabled.
ACPI: PCI Interrupt Link [APC5] (IRQs 16) *0, disabled.
ACPI: PCI Interrupt Link [APC6] (IRQs 16) *0, disabled.
ACPI: PCI Interrupt Link [APC7] (IRQs 16) *0, disabled.
ACPI: PCI Interrupt Link [APC8] (IRQs 16) *0, disabled.
ACPI: PCI Interrupt Link [APCF] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [APCG] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [APCH] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [APCJ] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [APMU] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [AAZA] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [APCK] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [APCS] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [APCL] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [APCM] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [APCZ] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [APSI] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [APSJ] (IRQs 20 21 22 23) *0, disabled.
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI init
pnp: ACPI device : hid PNP0A08
pnp: ACPI device : hid PNP0C02
pnp: ACPI device : hid PNP0200
pnp: ACPI device : hid PNP0B00
pnp: ACPI device : hid PNP0800
pnp: ACPI device : hid PNP0C04
pnp: ACPI device : hid PNP0700
pnp: ACPI device : hid PNP0501
pnp: ACPI device : hid PNP0400
pnp: ACPI device : hid PNP0F13
pnp: ACPI device : hid PNP0303
pnp: ACPI device : hid PNP0C01
pnp: PnP ACPI: found 15 devices
usbcore: registered new driver usbfs
usbcore: registered new driver hub
PCI: Using ACPI for IRQ routing
PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
PCI-DMA: Disabling IOMMU.
pnp: the driver 'system' has been registered
pnp: match found with the PnP device '00:01' and the driver 'system'
pnp: 00:01: ioport range 0x1000-0x107f could not be reserved
pnp: 00:01: ioport range 0x1080-0x10ff has been reserved
pnp: 00:01: ioport range 0x1400-0x147f has been reserved
pnp: 00:01: ioport range 0x1480-0x14ff could not be reserved
pnp: 00:01: ioport range 0x1800-0x187f has been reserved
pnp: 00:01: ioport range 0x1880-0x18ff has been reserved
pnp: 00:01: ioport range 0x2000-0x207f has been reserved
pnp: 00:01: ioport range 0x2080-0x20ff has been reserved
pnp: match found with the PnP device '00:02' and the driver 'system'
pnp: match found with the PnP device '00:0d' and the driver 'system'
pnp: match found with the PnP device '00:0e' and the driver 'system'
PCI: Bridge: 0000:00:02.0
IO window: a000-afff
MEM window: fda00000-fdafffff
PREFETCH window: fde00000-fdefffff
PCI: Bridge: 0000:00:04.0
IO window: b000-bfff
MEM window: fdb00000-fdbfffff
PREFETCH window: f8000000-fbffffff
PCI: Bridge: 0000:00:10.0
IO window: 9000-9fff
MEM window: fdd00000-fddfffff
PREFETCH window: fdc00000-fdcfffff
PCI: Setting latency timer of device 0000:00:02.0 to 64
PCI: Setting latency timer of device 0000:00:04.0 to 64
PCI: Setting latency timer of device 0000:00:10.0 to 64
NET: Registered protocol family 2
IP route cache hash table entries: 32768 (order: 6, 262144 bytes)
TCP established hash table entries: 131072 (order: 9, 2097152 bytes)
TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
audit: initializing netlink socket (disabled)
audit(1185231330.876:1): initialized
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
0000:00:0b.1 EHCI: BIOS handoff failed (BIOS bug ?) 01010001
pcie_portdrv_probe->Dev[02fc:10de] has invalid IRQ. Check vendor BIOS
assign_interrupt_mode Found MSI capability
Allocate Port Service[0000:00:02.0:pcie00]
Allocate Port Service[0000:00:02.0:pcie03]
pcie_portdrv_probe->Dev[02fb:10de] has invalid IRQ. Check vendor BIOS
Allocate Port Service[0000:00:04.0:pcie00]
Allocate Port Service[0000:00:04.0:pcie03]
Real Time Clock Driver v1.12ac
Linux agpgart interface v0.101 (c) Dave Jones
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
pnp: the driver 'serial' has been registered
pnp: match found with the PnP device '00:08' and the driver 'serial'
00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
pnp: match found with the PnP device '00:09' and the driver 'serial'
00:09: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 65536K size 1024 blocksize
pnp: the driver 'i8042 kbd' has been registered
pnp: match found with the PnP device '00:0c' and the driver 'i8042 kbd'
pnp: the driver 'i8042 aux' has been registered
pnp: match found with the PnP device '00:0b' and the driver 'i8042 aux'
PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
mice: PS/2 mouse device common for all mice
TCP bic registered
NET: Registered protocol family 17
NET: Registered protocol family 8
NET: Registered protocol family 20
ACPI: (supports S0 S3 S4 S5)
Freeing unused kernel memory: 176k freed
input: AT Translated Set 2 keyboard as /class/input/input0
ACPI: Fan [FAN] (on)
ACPI: Thermal Zone [THRM] (-11 C)
ohci_hcd: 2005 April 22 USB 1.1 'Open' Host Controller (OHCI) Driver (PCI)
ACPI: PCI Interrupt Link [APCF] enabled at IRQ 23
GSI 16 sharing vector 0xC9 and IRQ 16
ACPI: PCI Interrupt 0000:00:0b.0[A] -> Link [APCF] -> GSI 23 (level, low) -> IRQ 201
PCI: Setting latency timer of device 0000:00:0b.0 to 64
ohci_hcd 0000:00:0b.0: OHCI Host Controller
ohci_hcd 0000:00:0b.0: new USB bus registered, assigned bus number 1
ohci_hcd 0000:00:0b.0: irq 201, io mem 0xfe02f000
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
forcedeth.c: Reverse Engineered nForce ethernet driver. Version 0.56.
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 8 ports detected
ieee1394: Initialized config rom entry `ip1394'
ACPI: PCI Interrupt Link [APCL] enabled at IRQ 22
GSI 17 sharing vector 0xD1 and IRQ 17
ACPI: PCI Interrupt 0000:00:0b.1[B] -> Link [APCL] -> GSI 22 (level, low) -> IRQ 209
PCI: Setting latency timer of device 0000:00:0b.1 to 64
ehci_hcd 0000:00:0b.1: EHCI Host Controller
ehci_hcd 0000:00:0b.1: new USB bus registered, assigned bus number 2
ehci_hcd 0000:00:0b.1: debug port 1
PCI: cache line size of 64 is not supported by device 0000:00:0b.1
ehci_hcd 0000:00:0b.1: irq 209, io mem 0xfe02e000
ehci_hcd 0000:00:0b.1: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 8 ports detected
ACPI: PCI Interrupt Link [APCH] enabled at IRQ 21
GSI 18 sharing vector 0xD9 and IRQ 18
ACPI: PCI Interrupt 0000:00:14.0[A] -> Link [APCH] -> GSI 21 (level, low) -> IRQ 217
PCI: Setting latency timer of device 0000:00:14.0 to 64
forcedeth: using HIGHDMA
eth0: forcedeth.c: subsystem: 0105b:0caf bound to 0000:00:14.0
ACPI: PCI Interrupt Link [APC4] enabled at IRQ 19
GSI 19 sharing vector 0xE1 and IRQ 19
ACPI: PCI Interrupt 0000:03:06.0[A] -> Link [APC4] -> GSI 19 (level, low) -> IRQ 225
usb 2-1: new high speed USB device using ehci_hcd and address 2
ohci1394: fw-host0: OHCI-1394 1.1 (PCI): IRQ=[225] MMIO=[fddff000-fddff7ff] Max Packet=[2048] IR/IT contexts=[4/8]
NFORCE-MCP51: IDE controller at PCI slot 0000:00:0d.0
NFORCE-MCP51: chipset revision 161
NFORCE-MCP51: not 100% native mode: will probe irqs later
NFORCE-MCP51: 0000:00:0d.0 (rev a1) UDMA133 controller
ide0: BM-DMA at 0xf400-0xf407, BIOS settings: hda:DMA, hdb:DMA
ide1: BM-DMA at 0xf408-0xf40f, BIOS settings: hdc:DMA, hdd:DMA
Probing IDE interface ide0...
SCSI subsystem initialized
libata version 2.00 loaded.
usb 2-1: configuration #1 chosen from 1 choice
hub 2-1:1.0: USB hub found
hub 2-1:1.0: 4 ports detected
hda: Maxtor 6Y160P0, ATA DISK drive
usb 2-6: new high speed USB device using ehci_hcd and address 4
usb 2-6: configuration #1 chosen from 1 choice
ohci_hcd 0000:00:0b.0: wakeup
Initializing USB Mass Storage driver...
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1...
usb 2-1.2: new high speed USB device using ehci_hcd and address 5
usb 2-1.2: configuration #1 chosen from 1 choice
scsi0 : SCSI emulation for USB Mass Storage devices
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
usb-storage: device found at 4
usb-storage: waiting for device to settle before scanning
ieee1394: Host added: ID:BUS[0-00:1023] GUID[00016c20001e235c]
usb 1-5: new low speed USB device using ohci_hcd and address 2
hdc: HL-DT-ST DVD-RW_GSA-H11N, ATAPI CD/DVD-ROM drive
usb 1-5: configuration #1 chosen from 1 choice
usbcore: registered new driver hiddev
input: Acer IR Receiver as /class/input/input1
input,hiddev96: USB HID v1.10 Keyboard [Acer IR Receiver] on usb-0000:00:0b.0-5
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.6:USB HID core driver
ide1 at 0x170-0x177,0x376 on irq 15
sata_nv 0000:00:0e.0: version 2.0
ACPI: PCI Interrupt Link [APSI] enabled at IRQ 20
GSI 20 sharing vector 0xE9 and IRQ 20
ACPI: PCI Interrupt 0000:00:0e.0[A] -> Link [APSI] -> GSI 20 (level, low) -> IRQ 233
PCI: Setting latency timer of device 0000:00:0e.0 to 64
ata1: SATA max UDMA/133 cmd 0x9F0 ctl 0xBF2 bmdma 0xE000 irq 233
ata2: SATA max UDMA/133 cmd 0x970 ctl 0xB72 bmdma 0xE008 irq 233
scsi1 : sata_nv
ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
ata1.00: ATA-7, max UDMA/133, 488397168 sectors: LBA48 NCQ (depth 0/32)
ata1.00: ata1: dev 0 multi count 16
ata1.00: configured for UDMA/133
scsi2 : sata_nv
ata2: SATA link down (SStatus 0 SControl 300)
ATA: abnormal status 0x7F on port 0x977
Vendor: ATA Model: WDC WD2500JS-22N Rev: 10.0
Type: Direct-Access ANSI SCSI revision: 05
ACPI: PCI Interrupt Link [APSJ] enabled at IRQ 23
ACPI: PCI Interrupt 0000:00:0f.0[A] -> Link [APSJ] -> GSI 23 (level, low) -> IRQ 201
PCI: Setting latency timer of device 0000:00:0f.0 to 64
ata3: SATA max UDMA/133 cmd 0x9E0 ctl 0xBE2 bmdma 0xCC00 irq 201
ata4: SATA max UDMA/133 cmd 0x960 ctl 0xB62 bmdma 0xCC08 irq 201
scsi3 : sata_nv
ata3: SATA link down (SStatus 0 SControl 300)
ATA: abnormal status 0x7F on port 0x9E7
scsi4 : sata_nv
ata4: SATA link down (SStatus 0 SControl 300)
ATA: abnormal status 0x7F on port 0x967
hda: max request size: 512KiB
SCSI device sda: 488397168 512-byte hdwr sectors (250059 MB)
sda: Write Protect is off
sda: Mode Sense: 00 3a 00 00
SCSI device sda: drive cache: write back
sda:<6>hda: 320173056 sectors (163928 MB) w/7936KiB Cache, CHS=19929/255/63, UDMA(133)
hda: cache flushes supported
hda: sda1 sda2 sda3 sda4 < sda5 sda6 sda7 >
sd 1:0:0:0: Attached scsi disk sda
hda: dma_intr: status=0x51 { DriveReady SeekComplete Error }
hda: dma_intr: error=0x84 { DriveStatusError BadCRC }
ide: failed opcode was: unknown
ide0: reset: success
hda1 < hda5 hda6 >
hdc: ATAPI 40X DVD-ROM DVD-R CD-R/RW drive, 2048kB Cache, UDMA(66)
Uniform CD-ROM driver Revision: 3.20
Attempting manual resume
kjournald starting. Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
eth1394: eth0: IEEE-1394 IPv4 over 1394 Ethernet (fw-host0)
Vendor: Generic Model: 2.0 Reader-CF Rev: 1.00
Type: Direct-Access ANSI SCSI revision: 00
input: PC Speaker as /class/input/input2
drivers/usb/class/usblp.c: usblp0: USB Bidirectional printer dev 5 if 0 alt 0 proto 2 vid 0x03F0 pid 0x3A17
usbcore: registered new driver usblp
drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
ACPI: PCI Interrupt Link [APCJ] enabled at IRQ 22
ACPI: PCI Interrupt 0000:00:10.2[C] -> Link [APCJ] -> GSI 22 (level, low) -> IRQ 209
PCI: Setting latency timer of device 0000:00:10.2 to 64
Linux video capture interface: v2.00
logips2pp: Detected unknown logitech mouse model 62
FDC 0 is a post-1991 82077
intel8x0_measure_ac97_clock: measured 58679 usecs
intel8x0: clocking to 46943
i2c_adapter i2c-0: nForce2 SMBus adapter at 0x1c00
i2c_adapter i2c-1: nForce2 SMBus adapter at 0x1c40
pnp: the driver 'parport_pc' has been registered
pnp: match found with the PnP device '00:0a' and the driver 'parport_pc'
parport: PnPBIOS parport detected.
parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
saa7130/34: v4l2 driver version 0.2.14 loaded
ACPI: PCI Interrupt Link [APC1] enabled at IRQ 16
GSI 21 sharing vector 0x32 and IRQ 21
ACPI: PCI Interrupt 0000:03:07.0[A] -> Link [APC1] -> GSI 16 (level, low) -> IRQ 50
saa7133[0]: found at 0000:03:07.0, rev: 209, irq: 50, latency: 32, mmio: 0xfddfe000
saa7133[0]: subsystem: 5168:3306, board: LifeView FlyDVB-T Hybrid Cardbus [card=94,autodetected]
saa7133[0]: board init: gpio is 210000
saa7133[0]: i2c eeprom 00: 68 51 06 33 54 20 1c 00 43 43 a9 1c 55 d2 b2 92
saa7133[0]: i2c eeprom 10: 00 00 62 08 ff 20 ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom 20: 01 40 01 03 03 01 01 03 08 ff 01 16 ff ff ff ff
saa7133[0]: i2c eeprom 30: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom 40: ff 21 00 c2 96 10 05 01 01 16 32 15 ff ff ff ff
saa7133[0]: i2c eeprom 50: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom 60: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom 70: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
SCSI device sdb: 2001888 512-byte hdwr sectors (1025 MB)
sdb: Write Protect is off
sdb: Mode Sense: 03 00 00 00
sdb: assuming drive cache: write through
sdb: sdb1
sd 0:0:0:0: Attached scsi removable disk sdb
Vendor: Generic Model: 2.0 Reader-SM/xD Rev: 1.00
sd 0:0:0:1: Attached scsi removable disk sdc
tuner 2-004b: chip found @ 0x96 (saa7133[0])
Vendor: Generic Model: 2.0 Reader-SD Rev: 1.00
sd 0:0:0:2: Attached scsi removable disk sdd
tuner 2-004b: setting tuner address to 61
Vendor: Generic Model: 2.0 Reader-MS Rev: 1.00
sd 0:0:0:3: Attached scsi removable disk sde
tuner 2-004b: type set to tda8290+75a
usb-storage: device scan complete
input: ImExPS/2 Logitech Explorer Mouse as /class/input/input3
saa7133[0]: registered device video0 [v4l2]
saa7133[0]: registered device vbi0
saa7133[0]: registered device radio0
ACPI: PCI Interrupt Link [APC2] enabled at IRQ 17
GSI 22 sharing vector 0x3A and IRQ 22
ACPI: PCI Interrupt 0000:03:08.0[A] -> Link [APC2] -> GSI 17 (level, low) -> IRQ 58
rt2500 1.1.0 CVS 2005/07/10 http://rt2x00.serialmonkey.com
ts: Compaq touchscreen protocol output
Adding 1983988k swap on /dev/sda7. Priority:-1 extents:1 across:1983988k
EXT3 FS on sda5, internal journal
loop: loaded (max 8 devices)
ieee1394: sbp2: Driver forced to serialize I/O (serialize_io=1)
ieee1394: sbp2: Try serialize_io=0 for better performance
device-mapper: ioctl: 4.7.0-ioctl (2006-06-24) initialised: dm-devel@redhat.com
EXT3 FS on sda6, internal journal
NTFS driver 2.1.27 [Flags: R/W MODULE].
NTFS volume version 3.1.
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
Y’a de nombreuses lignes concernant le hda…
@cesar : je ne pense pas qu’il y ait conflit, le uid correspond à l’utilisateur courant.
