[Réglé] [POSTFIX] affiner la config
Bonsoir,
J’ai remarquer que dans la source de mais mails, j’ai cette ligne
Or dans la plus pas des autres mails de diverse expéditeur il n’y a pas sa, par quelle commande peut-on supprimer (localhost [127.0.0.1]) ??
Je vous remercie d’avance.
fais voir :
postconf -n
/etc/hosts
/etc/hostname
/etc/mailname
Bonsoir, merci de prendre le temps de me répondre, voici les infos.
postconf -n
alias_maps = hash:/etc/aliases append_dot_mydomain = no biff = no config_directory = /etc/postfix disable_vrfy_command = yes inet_interfaces = all mailbox_size_limit = 1024000000 mydestination = localhost, localhost.localdomain myhostname = mondomaine.com mynetworks = 127.0.0.0/8 192.168.1.0/24 relayhost = smtpd_client_restrictions = reject_unknown_client, permit_mynetworks smtpd_helo_required = yes smtpd_recipient_restrictions = permit_mynetworks, reject_unauth_destination, reject_unknown_recipient_domain, reject_non_fqdn_recipient, check_relay_domains smtpd_sender_restrictions = permit_mynetworks, reject_unknown_sender_domain, warn_if_reject reject_unverified_sender virtual_alias_maps = mysql:/etc/postfix/mysql-virtual_aliases.cf, mysql:/etc/postfix/mysql-virtual_aliases_mailbox.cf virtual_gid_maps = static:5000 virtual_mailbox_base = /var/spool/vmail/ virtual_mailbox_domains = mysql:/etc/postfix/mysql-virtual_domains.cf virtual_mailbox_limit = 1024000000 virtual_mailbox_maps = mysql:/etc/postfix/mysql-virtual_mailboxes.cf virtual_uid_maps = static:5000
/etc/hosts
[code]127.0.0.1 localhost
192.168.1.160 mondomaine.com
The following lines are desirable for IPv6 capable hosts
::1 ip6-localhost ip6-loopback
fe00::0 ip6-localnet
ff00::0 ip6-mcastprefix
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
ff02::3 ip6-allhosts
/etc/hostname
/etc/mailname
dans le main.cf, modifie/ajoute:
myhostname = le fqdn de la machine (c'est a dire par exemple: toto.domaine.com) myorigin = domaine.com
/etc/hosname:
/etc/hosts:
[code]127.0.0.1 mondomaine.com toto.domaine.com localhost localhost.localdomain
192.168.1.160 mondomaine.com toto.domaine.com
ff02::3 ip6-allhosts [/code]
puis
/etc/init.d/hostname.sh (pour prendre en compte le changement du hostname)
==> c’est un restart pas un reload, car il faut que le script de demarrage copie les nouvelles version des fichiers systeme dans le chroot.
Bonjour, merci pour la réponse, je viens de tester tout sa et je garde toujours dans la source du mail chez le destinataire 127.0.0.1, C’est normale ?
normalement non
mais cela depend a quel niveau tu vois ce message dans le header
il fautdrait voir le header complet
voici :slightly_smiling:
[code]Delivered-To: mymail@fia.com
Received: by 10.82.164.6 with SMTP id m6cs872163bue;
Tue, 28 Aug 2007 00:56:44 -0700 (PDT)
Received: by 10.86.71.1 with SMTP id t1mr5604475fga.1188287802810;
Tue, 28 Aug 2007 00:56:42 -0700 (PDT)
Return-Path: register@mondomaine.com
Received: from mondomaine.mondomaine.com (www.mondomaine.com [80.13.140.84])
by mx.google.com with ESMTP id p38si6379301fke.2007.08.28.00.56.42;
Received-SPF: pass (google.com: best guess record for domain of register@mondomaine.com designates 80.13.140.84 as permitted sender) client-ip=80.13.140.84;
Authentication-Results: mx.google.com; spf=pass (google.com: best guess record for domain of register@mondomaine.com designates 80.13.140.84 as permitted sender) smtp.mail=register@mondomaine.com
Received: from www.mondomaine.com (mondomaine.com [127.0.0.1])
by mondomaine.mondomaine.com (Postfix) with ESMTP id 645A54900BB
for mymail@fia.com; Tue, 28 Aug 2007 09:59:53 +0200 (CEST)
MIME-Version: 1.0
Date: Tue, 28 Aug 2007 09:59:53 +0200
To: mymail@fia.com
Subject: test
Message-ID: f190cdd4b239bfc63243631d9b6ac4c8@localhost
X-Sender: register@mondomaine.com
User-Agent: RoundCube Webmail/0.1-rc1
Content-Type: text/plain;
charset="UTF-8"
Content-Transfer-Encoding: 8bit
Status: R
X-Status: NC
X-KMail-EncryptionState:
X-KMail-SignatureState:
X-KMail-MDN-Sent:
test de mail[/code]
oui la c’est normal
ok résolu alors :stuck_out_tongue:
Merci beaucoup pour cette aide.
