hello
j’ai un petite problème agaçant le ventilo s’étin et ce rallume toute les 3-5 sec
je cherche donc un moyen d’y remédier, mai je commance par ou ?
lsmod |grep fan
fan 4964 0
thermal_sys 11624 4 video,thermal,processor,fan
dpkg -l |grep acpi
ii acpi 1.1-2 displays information on ACPI devices
ii acpi-support 0.109-11 scripts for handling many ACPI events
ii acpi-support-base 0.109-11 scripts for handling base ACPI events such a
ii acpid 1.0.8-1lenny1 Utilities for using ACPI power management
ii acpitool 0.5-2 command line ACPI client
dpkg -l |grep fan
ii libsensors4 1:3.0.2-1+b2 library to read temperature/voltage/fan sens
ii lm-sensors 1:3.0.2-1+b2 utilities to read temperature/voltage/fan se
ls -la /proc/acpi/fan
total 0
dr-xr-xr-x 2 root root 0 sep 18 23:30 .
dr-xr-xr-x 11 root root 0 sep 18 19:51 ..
pkg -l |grep power
ii libgnomecanvas2-0 2.20.1.1-1 A powerful object-oriented display - runtime
ii libgnomecanvas2-common 2.20.1.1-1 A powerful object-oriented display - common
ii libimlib2 1.4.0-1.2 powerful image loading and rendering library
ii libpowersave11 0.15.20-3 power management daemon - shared library
ii pm-utils 1.1.2.4-1 utilities and scripts for power management
ii powermgmt-base 1.30+nmu1 Common utils and configs for power managemen
ii powersaved 0.15.20-3 power management daemon
ii powertop 1.10-2 Linux tool to find out what is using power o
uname -a
Linux ultimate 2.6.26-2-686-bigmem #1 SMP Wed Aug 19 06:34:05 UTC 2009 i686 GNU/Linux
une idée ? google ma pas donnés une manière de faire qui me paraissait aproprié.
Merci d’avance
