Merci pour tes infos, seulement j ai un autre petit soucis:
il me demande le pilote de server X que je souhaite utiliser.
La liste:
apm
ark
ati
chips
cirrus
cyrixfbdev
glide
glint
i128
i740
i810
imstt
mga
neomagic
newport
nsc
nv
rendition
s3
s3virge
savage
siliconmotion
sis
tdfx
tga
tseng
vesa
vga
via
vmware
configuration de mon pc:
 	 Intel® Pentium® M - Intel Centrino Mobile Technology
Chipset: 	Intel 915GM / ICH6-M
Memory: 	SO-DIMM DDR2 533, max. 2.0 GB
Display: 	15.4" WXGA TFT-LCD, 1280x800 max. resolution
Graphic: 	UMA shared graphic, max. 224MB
Storage System: 	Harddisk, Optical Drive
Audio System: 	Intel® High Definition Audio
Communication: 	FAX Modem 56kbps V.90, GigaLAN, Wireless LAN 802.11a/b/g
Ports: 	3x USB 2.0, 1x Firewire, 1x PCMCIA Type II, 1x VGA-out, S-Video-out, 1x RJ-11 Modem, 1x RJ-45 LAN, 1x Audio-out, 1x Mic-in
Dimension/Weight: 	360x265x32.2 mm, 2.9 kg net, 5.7 kg gross
Special features: 	2 Easy Start Buttons, Card Reader SD/SM/MMC, PORT case
Software: 	Windows XP Home or Pro (optional), Panda Antivirus (optional), Ahead Nero 6.0, Cyberlink PowerDVD 6.0
tout n’est pas effectif, il est aussis ur mesur, mais tout est correct niveau hardware hormis les place dd, ram
