j’ai fais l’install comme sur le tuto et il me semble comme la 1ere fois, lorsque j’essaie de me connecté voila ce qu’il me donne :
daniel@localhost:~$ sftp -P 666 jessie@localhost
The authenticity of host ‘[localhost]:666 ([::1]:666)’ can’t be established.
ECDSA key fingerprint is d3:20:94:49:e0:aa:da:ad:c2:d4:04:9c:27:39:65:53.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added ‘[localhost]:666’ (ECDSA) to the list of known hosts.
jessie@localhost’s password:
Connection closed
ensuite j’ai vérifié avec ce que micp m’as expliqué, voici ce que donne :
daniel@localhost:~$ sftp -v -P 666 jessie@localhost
OpenSSH_6.0p1 Debian-4, OpenSSL 1.0.1e 11 Feb 2013
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug1: Connecting to localhost [::1] port 666.
debug1: Connection established.
debug1: identity file /home/daniel/.ssh/id_rsa type -1
debug1: identity file /home/daniel/.ssh/id_rsa-cert type -1
debug1: identity file /home/daniel/.ssh/id_dsa type -1
debug1: identity file /home/daniel/.ssh/id_dsa-cert type -1
debug1: identity file /home/daniel/.ssh/id_ecdsa type -1
debug1: identity file /home/daniel/.ssh/id_ecdsa-cert type -1
debug1: Remote protocol version 2.0, remote software version OpenSSH_6.0p1 Debian-4
debug1: match: OpenSSH_6.0p1 Debian-4 pat OpenSSH*
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_6.0p1 Debian-4
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: kex: server->client aes128-ctr hmac-md5 none
debug1: kex: client->server aes128-ctr hmac-md5 none
debug1: sending SSH2_MSG_KEX_ECDH_INIT
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: Server host key: ECDSA d3:20:94:49:e0:aa:da:ad:c2:d4:04:9c:27:39:65:53
debug1: Host ‘[localhost]:666’ is known and matches the ECDSA host key.
debug1: Found key in /home/daniel/.ssh/known_hosts:1
debug1: ssh_ecdsa_verify: signature correct
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug1: SSH2_MSG_NEWKEYS received
debug1: Roaming not allowed by server
debug1: SSH2_MSG_SERVICE_REQUEST sent
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug1: Authentications that can continue: publickey,password
debug1: Next authentication method: publickey
debug1: Trying private key: /home/daniel/.ssh/id_rsa
debug1: Trying private key: /home/daniel/.ssh/id_dsa
debug1: Trying private key: /home/daniel/.ssh/id_ecdsa
debug1: Next authentication method: password
debug1: Authentication succeeded (password).
Authenticated to localhost ([::1]:666).
debug1: channel 0: new [client-session]
debug1: Requesting no-more-sessions@openssh.com
debug1: Entering interactive session.
debug1: Sending environment.
debug1: Sending env LANG = fr_CA.UTF-8
debug1: Sending subsystem: sftp
debug1: client_input_channel_req: channel 0 rtype exit-status reply 0
debug1: client_input_channel_req: channel 0 rtype eow@openssh.com reply 0
debug1: channel 0: free: client-session, nchannels 1
debug1: fd 0 clearing O_NONBLOCK
Transferred: sent 1864, received 1600 bytes, in 0.0 seconds
Bytes per second: sent 62403.7, received 53565.4
debug1: Exit status 1
Connection closed
voila mon cat /etc/rssh.conf d’aujourd’hui :
daniel@localhost:~$ cat /etc/rssh.conf
cd /home/sftp
mkdir dev
mknod dev/null c 1 3
chmod 666 dev/null
chrootpath = “/home/sftp”
et voici le cat /etc/rssh.conf de 21 aout 2013 :
logfacility = LOG_USER
allowsftp
umask = 066
donc y a-t-il un moyen facile de réparé le dossier /etc/rssh.conf ou faut-il recommencé le tuto à partir de :
Le fichier de configuration est /etc/rssh.conf. Remplaçons celui créé lors de l’installation :
mv rssh.conf rssh.conf.old
echo “logfacility = LOG_USER” > /etc/rssh.conf
echo “allowsftp” >> /etc/rssh.conf
echo “umask = 022” >> /etc/rssh.conf
et continué jusqu’à la fin ?
